path: root/arch/ppc/mm
2005-06-21[PATCH] ppc32: Kill embedded system.map, use kallsymsBenjamin Herrenschmidt
This patch kills the whole embedded System.map mecanism and the bootloader-passed System.map that was used to provide symbol resolution in xmon. Instead, xmon now uses kallsyms like ppc64 does. No hurry getting that in Linus tree, let it be tested in -mm for a while first and make sure it doesn't break various embedded configs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ppc32: Clean up NUM_TLBCAMS usage for Freescale Book-E PPC'sKumar Gala
Made the number of TLB CAM entries private and converted the board consumers to use num_tlbcam_entries which is setup at boot time from configuration registers. This way the only consumers of the #define NUM_TLBCAMS are the arrays used to manage the TLB. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] mm: remove PG_highmemBadari Pulavarty
Remove PG_highmem, to save a page flag. Use is_highmem() instead. It'll generate a little more code, but we don't use PageHigheMem() in many places. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-20[PATCH] ppc32: don't call progress functions after bootPaul Mackerras
On ppc32, the platform code can supply a "progress" function that is used to show progress through the boot. These functions are usually in an init section and so can't be called after the init pages are freed. Now that the cpu bringup code can be called after the system is booted (for hotplug cpu) we can get the situation where the progress function can be called after boot. The simple fix is to set the progress function pointer to NULL when the init pages are freed, and that is what this patch does (note that all callers already check whether the function pointer is NULL before trying to call it). Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] ppc32: make usage of CONFIG_PTE_64BIT & CONFIG_PHYS_64BIT consistentKumar Gala
CONFIG_PTE_64BIT & CONFIG_PHYS_64BIT are not currently consistently used in the code base. Fixed up the usage such that CONFIG_PTE_64BIT is used when we have a 64-bit PTE regardless of physical address width. CONFIG_PHYS_64BIT is used if the physical address width is larger than 32-bits, regardless of PTE size. These changes required a few sub-arch specific ifdef's to be fixed and the introduction of a physical address format string. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
