path: root/arch/ppc/kernel
2005-09-13[PATCH] ppc32: remove use of asm/segment.hKumar Gala
Removed ppc32 architecture specific users of asm/segment.h and asm-ppc/segment.h itself Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] ppc32: discard *.exit.text and *.exit.data sectionsTom Rini
Discard *.exit.text sections on runtime. We cannot do this on link time because of the way BUG macros are implemented. If "__exit function" calls one of those macros, __bug_table section will reference this function. This is similar to ".altinstructions" situation on i386. *.exit.data seems to be OK in this respect and is discarded on link time. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Tom Rini <trini@kernel.crashing.org> Acked-by: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] ppc32: support hotplug cpu on powermacsPaul Mackerras
This allows cpus to be off-lined on 32-bit SMP powermacs. When a cpu is off-lined, it is put into sleep mode with interrupts disabled. It can be on-lined again by asserting its soft-reset pin, which is connected to a GPIO pin. With this I can off-line the second cpu in my dual G4 powermac, which means that I can then suspend the machine (the suspend/resume code refuses to suspend if more than one cpu is online, and making it cope with multiple cpus is surprisingly messy). Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] ppc32: Kill init on unhandled synchronous signalsPaul Mackerras
This is a patch that I have had in my tree for ages. If init causes an exception that raises a signal, such as a SIGSEGV, SIGILL or SIGFPE, and it hasn't registered a handler for it, we don't deliver the signal, since init doesn't get any signals that it doesn't have a handler for. But that means that we just return to userland and generate the same exception again immediately. With this patch we print a message and kill init in this situation. This is very useful when you have a bug in the kernel that means that init doesn't get as far as executing its first instruction. :) Without this patch the system hangs when it gets to starting the userland init; with it you at least get a message giving you a clue about what has gone wrong. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] merge some from Rusty's trivial patchesAdrian Bunk
This patch contains the most trivial from Rusty's trivial patches: - spelling fixes - remove duplicate includes Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09Merge master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuild Linus Torvalds
2005-09-09[PATCH] ppc32: make perfmon.o CONFIG_E500 specificMarcelo Tosatti
Subject says it all, there is no need to link perfmon.o on sub-architectures other than CONFIG_E500. Signed-off-by: Marcelo Tosatti <marcelo.tosatti@cyclades.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09kbuild: m68k,parisc,ppc,ppc64,s390,xtensa use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted parts form arch makefiles and rename to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-09[PATCH] powerpc: Make check_bugs() static inlinejdl@freescale.com
Make check_bugs() static inline and remove it from syscalls.c. Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-08[PATCH] PCI: fix up pretty-names removal patchAndrew Morton
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] ppc32: Fix head_4xx.S compile errorKumar Gala
head_4xx.S wasn't compiling due to a missing #endif Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] NTP: ntp-helper functionsjohn stultz
This patch cleans up a commonly repeated set of changes to the NTP state variables by adding two helper inline functions: ntp_clear(): Clears the ntp state variables ntp_synced(): Returns 1 if the system is synced with a time server. This was compile tested for alpha, arm, i386, x86-64, ppc64, s390, sparc, sparc64. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Added cputable entry for 7448Kumar Gala
Added cputable entry for 7448 as well adding it to checks for saving and restoring of cpu state. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: export cacheable_memcpy()Eugene Surovegin
Add declaration and cacheable_memcpy(). I'll be needing this function in new 4xx EMAC driver I'm going to submit to netdev soon. IMHO, the better place for the declaration would be asm-powerpc/string.h, unfortunately, ppc64 doesn't have this function, so asm-ppc/system.h is the next best place. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Add cputable entry for 750CXe DD2.4 ("Gekko")Arthur Othieno
Add a table entry for 750CXe DD2.4 ("Gekko") as found in the GameCube from Nintendo: http://www-306.ibm.com/chips/techlib/techlib.nsf/techdocs/291C8D0EF3EAEC1687256B72005C745C#C1 Signed-off-by: Arthur Othieno <a.othieno@bluewin.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Re-order cputable for 750CXe DD2.4 entryArthur Othieno
"745/755" (pvr_value:0x00083000) is a catch-all entry. Since arch/ppc/kernel/misc.S:identify_cpu() returns on first match, move this lower in the table so 750CXe DD2.4 (pvr_value:0x00083214) may be correctly enumerated. Signed-off-by: Arthur Othieno <a.othieno@bluewin.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: add cputable entry for 440SP Rev. AMatt Porter
Adds the appropriate cputable entry for PPC440SP so cache line sizes are configured correctly. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: removed find_name.cKumar Gala
No one uses find_name.c and no one seems to care about either. So I'm removing it. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: add 440GX rev.F cputable entryEugene Surovegin
Add PowerPC 440GX rev.F cputable entry. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Cleaned up global namespace of Book-E watchdog variablesKumar Gala
Renamed global variables used to convey if the watchdog is enabled and periodicity of the timer and moved the declarations into a header for these variables Signed-off-by: Matt McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Add ppc_sys descriptions for PowerQUICC II devicesKumar Gala
Added ppc_sys device and system definitions for PowerQUICC II devices. This will allow drivers for PQ2 to be proper platform device drivers. Which can be shared on PQ3 processors with the same peripherals. Signed-off-by: Matt McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: Added support for the Book-E style Watchdog TimerKumar Gala
PowerPC 40x and Book-E processors support a watchdog timer at the processor core level. The timer has implementation dependent timeout frequencies that can be configured by software. One the first Watchdog timeout we get a critical exception. It is left to board specific code to determine what should happen at this point. If nothing is done and another timeout period expires the processor may attempt to reset the machine. Command line parameters: wdt=0 : disable watchdog (default) wdt=1 : enable watchdog wdt_period=N : N sets the value of the Watchdog Timer Period. The Watchdog Timer Period meaning is implementation specific. Check User Manual for the processor for more details. This patch is based off of work done by Takeharu Kato. Signed-off-by: Matt McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] arch/ppc/kernel/ppc_ksyms.c: remove unused #define EXPORT_SYMTAB_STROPSAdrian Bunk
This #define is only used on sparc. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-01[PATCH] ppc: L2 cache prefetch fixes on 745xKumar Gala
We run into problems if we blindly enable L2 prefetching without checking that the L2 cache is actually enabled. Additionaly, if we disable the L2 cache we need to ensure that we disable L2 prefetching. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[PATCH] convert signal handling of NODEFER to act like other Unix boxes.Steven Rostedt
It has been reported that the way Linux handles NODEFER for signals is not consistent with the way other Unix boxes handle it. I've written a program to test the behavior of how this flag affects signals and had several reports from people who ran this on various Unix boxes, confirming that Linux seems to be unique on the way this is handled. The way NODEFER affects signals on other Unix boxes is as follows: 1) If NODEFER is set, other signals in sa_mask are still blocked. 2) If NODEFER is set and the signal is in sa_mask, then the signal is still blocked. (Note: this is the behavior of all tested but Linux _and_ NetBSD 2.0 *). The way NODEFER affects signals on Linux: 1) If NODEFER is set, other signals are _not_ blocked regardless of sa_mask (Even NetBSD doesn't do this). 2) If NODEFER is set and the signal is in sa_mask, then the signal being handled is not blocked. The patch converts signal handling in all current Linux architectures to the way most Unix boxes work. Unix boxes that were tested: DU4, AIX 5.2, Irix 6.5, NetBSD 2.0, SFU 3.5 on WinXP, AIX 5.3, Mac OSX, and of course Linux 2.6.13-rcX. * NetBSD was the only other Unix to behave like Linux on point #2. The main concern was brought up by point #1 which even NetBSD isn't like Linux. So with this patch, we leave NetBSD as the lonely one that behaves differently here with #2. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-06ppc: Export __handle_mm_fault for MOLLinus Torvalds
When we did the handle_mm_fault cleanup and get_user_page() race fixes, handle_mm_fault turned into an inline function that called the real __handle_mm_fault() code. The export needed for MOL on ppc wasn't updated to match the new world order, though. Turn it into a GPL export while at it, since this is all about internal interfaces and MOL is GPL'd anwyay.
2005-08-04[PATCH] pci and yenta: pcibios_bus_to_resourceDominik Brodowski
In yenta_socket, we default to using the resource setting of the CardBus bridge. However, this is a PCI-bus-centric view of resources and thus needs to be converted to generic resources first. Therefore, add a call to pcibios_bus_to_resource() call in between. This function is a mere wrapper on x86 and friends, however on some others it already exists, is added in this patch (alpha, arm, ppc, ppc64) or still needs to be provided (parisc -- where is its pcibios_resource_to_bus() ?). Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-01[PATCH] ppc32: add 440ep supportMatt Porter
Add PPC440EP core support. PPC440EP is a PPC440-based SoC with a classic PPC FPU and another set of peripherals. Signed-off-by: Wade Farnsworth <wfarnsworth@mvista.com> Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-30[PATCH] ppc32: fix 44x early serial debug for configurations with more than ↵Eugene Surovegin
512M of RAM Fix 44x early serial debugging for big RAM configurations (more than 512M). We cannot use default OpenBIOS virtual mapping, because it interferes with pinned TLB entry. While we are at it, move early UART mapping to TLB slot 0, so it can survive longer during boot process (slot 1 is used by the first ioremap call, effectively killing UART mapping if it occupies this slot). Also, change UART TLB entry size to 4K (256M is too much for a bunch of registers :). Squash some warnings on the way. Tested on Ebony and Ocotea with 1G of RAM. Thanks to Scott Coulter <scott.coulter@cyclone.com> for diagnosing this problem. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-30[PATCH] ppc32: inotify syscallsRobert Love
Add inotify system call stubs to PPC32. Signed-off-by: Robert Love <rml@novell.com> Acked-by: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] ppc32: 8xx: update DataTLBMiss exception commentMarcelo Tosatti
On PPC 8xx, the DataTLBMiss handler does not jump directly to the page fault handler, as was the case in v2.4. It instead loads an invalid TLB which causes a subsequent DataTLBError exception. The comment on top of it haven't been update to reflect the change, though. Signed-off-by: Marcelo Tosatti <marcelo.tosatti@cyclades.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Don't export machine_restart, machine_halt, or machine_power_off.Eric W. Biederman
machine_restart, machine_halt and machine_power_off are machine specific hooks deep into the reboot logic, that modules have no business messing with. Usually code should be calling kernel_restart, kernel_halt, kernel_power_off, or emergency_restart. So don't export machine_restart, machine_halt, and machine_power_off so we can catch buggy users. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] kexec-ppc: fix for ksysfs crash_notesAlbert Herranz
The following patch prevents the crash dump helper code found within kexec from breaking ppc which still lacks crash dump functionality. ksysfs crash_notes attribute handling was left under CONFIG_KEXEC for simplicity although it is not strictly kexec related. We provide here a dummy definition for crash_notes on ppc. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-05[PATCH] ppc32: stop misusing NTP's time_offset valuejohn stultz
As part of my timeofday rework, I've been looking at the NTP code and I noticed that the PPC architecture is apparently misusing the NTP's time_offset (it is a terrible name!) value as some form of timezone offset. This could cause problems when time_offset changed by the NTP code. This patch changes the PPC code so it uses a more clear local variable: timezone_offset. Signed-off-by: John Stultz <johnstul@us.ibm.com> Acked-by: Tom Rini <trini@kernel.crashing.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] ppc32: use correct register names in arch/ppc/kernel/relocate_kernel.SOlaf Hering
CONFIG_KEXEC=y doesnt work: arch/ppc/kernel/relocate_kernel.S:37: Error: unsupported relocation against SRR1 arch/ppc/kernel/relocate_kernel.S:39: Error: unsupported relocation against SRR0 Signed-off-by: Olaf Hering <olh@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Greg KH
2005-06-27[PATCH] PCI: fix-pci-mmap-on-ppc-and-ppc64.patchMichael Ellerman
This is an updated version of Ben's fix-pci-mmap-on-ppc-and-ppc64.patch which is in 2.6.12-rc4-mm1. It fixes the patch to work on PPC iSeries, removes some debug printks at Ben's request, and incorporates your fix-pci-mmap-on-ppc-and-ppc64-fix.patch also. Originally from Benjamin Herrenschmidt <benh@kernel.crashing.org> This patch was discussed at length on linux-pci and so far, the last iteration of it didn't raise any comment. It's effect is a nop on architecture that don't define the new pci_resource_to_user() callback anyway. It allows architecture like ppc who put weird things inside of PCI resource structures to convert to some different value for user visible ones. It also fixes mmap'ing of IO space on those archs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] Update cfq io scheduler to time sliced designJens Axboe
This updates the CFQ io scheduler to the new time sliced design (cfq v3). It provides full process fairness, while giving excellent aggregate system throughput even for many competing processes. It supports io priorities, either inherited from the cpu nice value or set directly with the ioprio_get/set syscalls. The latter closely mimic set/getpriority. This import is based on my latest from -mm. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25Merge Christoph's freeze cleanup patchLinus Torvalds
2005-06-25[PATCH] Cleanup patch for process freezingChristoph Lameter
1. Establish a simple API for process freezing defined in linux/include/sched.h: frozen(process) Check for frozen process freezing(process) Check if a process is being frozen freeze(process) Tell a process to freeze (go to refrigerator) thaw_process(process) Restart process frozen_process(process) Process is frozen now 2. Remove all references to PF_FREEZE and PF_FROZEN from all kernel sources except sched.h 3. Fix numerous locations where try_to_freeze is manually done by a driver 4. Remove the argument that is no longer necessary from two function calls. 5. Some whitespace cleanup 6. Clear potential race in refrigerator (provides an open window of PF_FREEZE cleared before setting PF_FROZEN, recalc_sigpending does not check PF_FROZEN). This patch does not address the problem of freeze_processes() violating the rule that a task may only modify its own flags by setting PF_FREEZE. This is not clean in an SMP environment. freeze(process) is therefore not SMP safe! Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec code cleanupManeesh Soni
o Following patch provides purely cosmetic changes and corrects CodingStyle guide lines related certain issues like below in kexec related files o braces for one line "if" statements, "for" loops, o more than 80 column wide lines, o No space after "while", "for" and "switch" key words o Changes: o take-2: Removed the extra tab before "case" key words. o take-3: Put operator at the end of line and space before "*/" Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Use real pt_regs from exceptionAlexander Nyberg
Makes kexec_crashdump() take a pt_regs * as an argument. This allows to get exact register state at the point of the crash. If we come from direct panic assertion NULL will be passed and the current registers saved before crashdump. This hooks into two places: die(): check the conditions under which we will panic when calling do_exit and go there directly with the pt_regs that caused the fatal fault. die_nmi(): If we receive an NMI lockup while in the kernel use the pt_regs and go directly to crash_kexec(). We're probably nested up badly at this point so this might be the only chance to escape with proper information. Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: kexec ppc supportEric W. Biederman
I have tweaked this patch slightly to handle an empty list of pages to relocate passed to relocate_new_kernel. And I have added ppc_md.machine_crash_shutdown. To keep up with the changes in the generic kexec infrastructure. From: Albert Herranz <albert_herranz@yahoo.es> The following patch adds support for kexec on the ppc32 platform. Non-OpenFirmware based platforms are likely to work directly without additional changes on the kernel side. The kexec-tools userland package may need to be slightly updated, though. For OpenFirmware based machines, additional work is still needed on the kernel side before kexec support is ready. Benjamin Herrenschmidt is kindly working on that part. In order for a ppc platform to use the kexec kernel services it must implement some ppc_md hooks. Otherwise, kexec will be explicitly disabled, as suggested by benh. There are 3+1 new ppc_md hooks that a platform supporting kexec may implement. Two of them are mandatory for kexec to work. See include/asm-ppc/machdep.h for details. - machine_kexec_prepare(image) This function is called to make any arrangements to the image before it is loaded. This hook _MUST_ be provided by a platform in order to activate kexec support for that platform. Otherwise, the platform is considered to not support kexec and the kexec_load system call will fail (that makes all existing platforms by default non-kexec'able). - machine_kexec_cleanup(image) This function is called to make any cleanups on image after the loaded image data it is freed. This hook is optional. A platform may or may not provide this hook. - machine_kexec(image) This function is called to perform the _actual_ kexec. This hook _MUST_ be provided by a platform in order to activate kexec support for that platform. If a platform provides machine_kexec_prepare but forgets to provide machine_kexec, a kexec will fall back to a reboot. A ready-to-use machine_kexec_simple() generic function is provided to, hopefully, simplify kexec adoption for embedded platforms. A platform may call this function from its specific machine_kexec hook, like this: void myplatform_kexec(struct kimage *image) { machine_kexec_simple(image); } - machine_shutdown() This function is called to perform any machine specific shutdowns, not already done by drivers. This hook is optional. A platform may or may not provide this hook. An example (trimmed) platform specific module for a platform supporting kexec through the existing machine_kexec_simple follows: /* ... */ #ifdef CONFIG_KEXEC int myplatform_kexec_prepare(struct kimage *image) { /* here, we can place additional preparations */ return 0; /* yes, we support kexec */ } void myplatform_kexec(struct kimage *image) { machine_kexec_simple(image); } #endif /* CONFIG_KEXEC */ /* ... */ void __init platform_init(unsigned long r3, unsigned long r4, unsigned long r5, unsigned long r6, unsigned long r7) { /* ... */ #ifdef CONFIG_KEXEC ppc_md.machine_kexec_prepare = myplatform_kexec_prepare; ppc_md.machine_kexec = myplatform_kexec; #endif /* CONFIG_KEXEC */ /* ... */ } The kexec ppc kernel support has been heavily tested on the GameCube Linux port, and, as reported in the fastboot mailing list, it has been tested too on a Moto 82xx ppc by Rick Richardson. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] ppc32: Add support for Freescale e200 (Book-E) coreKumar Gala
The e200 core is a Book-E core (similar to e500) that has a unified L1 cache and is not cache coherent on the bus. The e200 core also adds a separate exception level for debug exceptions. Part of this patch helps to cleanup a few cases that are true for all Freescale Book-E parts, not just e500. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ppc32: Kill embedded system.map, use kallsymsBenjamin Herrenschmidt
This patch kills the whole embedded System.map mecanism and the bootloader-passed System.map that was used to provide symbol resolution in xmon. Instead, xmon now uses kallsyms like ppc64 does. No hurry getting that in Linus tree, let it be tested in -mm for a while first and make sure it doesn't break various embedded configs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ppc32: don't recursively crash in die() on CHRP/PReP machinesJakub Bogusz
This patch avoids recursive crash (leading to kernel stack overflow) in die() on CHRP/PReP machines when CONFIG_PMAC_BACKLIGHT=y. set_backlight_* functions are placed in pmac section, which is discarded when _machine != _MACH_Pmac. Signed-off-by: Jakub Bogusz <qboosh@pld-linux.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ppc32: Factor out common exception code into macro's for 4xx/Book-EKumar Gala
4xx and Book-E PPC's have several exception levels. The code to handle each level is fairly regular. Turning the code into macro's will ease the handling of future exception levels (debug) in forth coming chips. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ppc32: fix CONFIG_TASK_SIZE handling on 40xMatt Porter
This patch is virtually identical to my previous 44x one. It removes 0x8000'0000 TASK_SIZE hardcoded assumption from head_4xx.S. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ppc32: Converted MPC10X bridge to use platform devices instead of OCPKumar Gala
Converted the MPC10x bridge support (used by MPC10x and 8240/1/5) to used the standard platform device model. Signed-off-by: Matt McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ppc32: Added support for new MPC8548 family of PowerQUICC III processorsKumar Gala
Added descriptions of the new MPC8548 family processors, e500 core and peripherals. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
