path: root/arch/ppc/boot/images
2006-12-04[POWERPC] Add files build to .gitignoreRutger Nijlunsing
Mostly taken from corresponding Makefile's make-clean rule. Tested by (cross)compiling for $ARCH PPC and POWERPC and checking output of git-status. Signed-off-by: Rutger Nijlunsing <git-commit@tux.tmfweb.nl> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Fix suboptimal uImage targetKumar Gala
Sam Ravnborg pointed out that calling if_changed was redundant in the rule since a prerequisite had to have changed for us to get there. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-07-13[PATCH] ppc32: make -j12 all fails in uImage targetOlaf Hering
make -j zImage may call if_changed twice at the same time, the result is a corrupted vmlinux.gz Write to a temporary file for the time being until someone with make skills fix the serialization properly. Signed-off-by: Olaf Hering <olh@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Tom Rini <trini@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-28[PATCH] ppc32: Fix uImage make target to report success correctlyKumar Gala
The existing make rule when building a uImage would check to see if the image file existed to report 'is ready' or 'not made'. However make appeared to compute the file list before the rule was executed. Signed-off-by: Chris Clark <cpclark@xmission.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-30[PATCH] kbuild/ppc: tell when uimage was not builtSam Ravnborg
Tom Rini said: Note that there is still a trivial'ish change to make. When mkimage doesn't exist on the host we should say "uImage not made" or something similar. So I did like Tom asked. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
