Fallback gracefully when reading /proc/ppc64/lparcfg when the /rtas
device node can't be found.
A few symbols are exported twice, remove them from ppc_ksyms.c
Remove users of sys_ctrler in arch/ppc/
WARNING: vmlinux: duplicate symbol '__delay' previous definition was in vmlinux
WARNING: vmlinux: duplicate symbol '__up' previous definition was in vmlinux
WARNING: vmlinux: duplicate symbol '__down' previous definition was in vmlinux
WARNING: vmlinux: duplicate symbol '__down_interruptible' previous definition was in vmlinux
WARNING: vmlinux: duplicate symbol 'sys_ctrler' previous definition was in vmlinux
WARNING: vmlinux: duplicate symbol 'strncat' previous definition was in vmlinux
WARNING: vmlinux: duplicate symbol 'strncmp' previous definition was in vmlinux
WARNING: vmlinux: duplicate symbol 'strchr' previous definition was in vmlinux
WARNING: vmlinux: duplicate symbol 'strrchr' previous definition was in vmlinux
WARNING: vmlinux: duplicate symbol 'strnlen' previous definition was in vmlinux
WARNING: vmlinux: duplicate symbol 'strpbrk' previous definition was in vmlinux
WARNING: vmlinux: duplicate symbol 'memscan' previous definition was in vmlinux
WARNING: vmlinux: duplicate symbol 'strstr' previous definition was in vmlinux
Signed-off-by: Olaf Hering <olh@suse.de>
This fixes a regression which was introduced by moving ppc32 to use
the same sort of lockless gettimeofday as ppc64 has been using for
some time. This involves getting the timebase and performing some
simple arithmetic to convert it to seconds and microseconds. However,
the factor and offset used there weren't being updated when NTP
varied the tick length using adjtimex. 64-bit didn't notice the
problem because it had a hook in the 32-bit adjtimex compat routine
that attempted to work out what the generic timekeeping code would
do and alter the factor and offset to match. However, that code
was very complex and it wasn't clear that it still matched what the
generic code would do.
Now we use the generic current_tick_length() routine that was recently
added to check that the current tick will be as long as we expect; if
not we recompute the factor and offset. This keeps gettimeofday and
xtime in sync. In addition we check that gettimeofday hasn't got ahead
of xtime on each timer interrupt; if it has, we resync.
We are setting up sources for building external modules like this:
/usr/src/linux-obj> # create a .config file
/usr/src/linux-obj> make -C /usr/src/linux O=$PWD oldconfig
/usr/src/linux-obj> make -C /usr/src/linux O=$PWD prepare
/usr/src/linux-obj> make -C /usr/src/linux O=$PWD scripts
/usr/src/linux-obj> make -C /usr/src/linux O=$PWD clean
After that, external modules can be built with:
/usr/src/module> make -C /usr/src/linux-obj M=$PWD
This fails for ppc32 because the `make clean' removes the
arch/powerpc/include directory. This should be done in archmrproper
instead of in archclean.
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
Embedded boards that u-boot require a kernel image in the uImage format.
This allows a given board to specify it wants a uImage built by default.
This also fixes a warning at config time, as this symbol is referred
to in arch/powerpc/platforms/83xx/Kconfig.
Registers system call for the powerpc architecture.
Signed-off-by: Janak Desai <janak@us.ibm.com>
Cc: Al Viro <viro@ftp.linux.org.uk>
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
Cc: Andi Kleen <ak@muc.de>
With this, new system calls only have to be wired up in one place
for ARCH=ppc and ARCH=powerpc, rather than 2.
it's int __iomem *, not int * __iomem...
extern in function definition is an odd thing..
drive_info is used only by hd.c and that happens under #ifdef __i386__.
When a cpu is hotplug-onlined, if we don't set per_cpu(last_jiffy) to
something sane, timer_interrupt will execute its while loop for every
tick missed since the cpu was last online (or since the system was
booted, if we're adding a new cpu). This can cause weird hangs, ssh
sessions dropping, and we can even go xmon if we take a global IPI at
the wrong time.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
We call unregister_vpa but we don't check to see if the hypervisor
supports this.
Signed-off-by: Michael Neuling <mikey@neuling.org>
Acked-by: Anton Blanchard <anton@samba.org>
arch/powerpc/platforms/pseries/setup.c | 2 +-
1 files changed, 1 insertion(+), 1 deletion(-)
Since 404849bbd2bfd62e05b36f4753f6e1af6050a824 we've been using
LOAD_REG_ADDRBASE, which uses the toc pointer, in decrementer_iSeries_masked.
This can explode if we take the decrementer interrupt while we're in a module,
because the toc pointer in r2 will be the module's toc pointer.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
The code to mark a page as icache dirty (so that it will later be
icache-dcache flushed when we try to execute from it) is duplicated in
three places: flush_dcache_page() does this marking and nothing else,
but clear_user_page() and copy_user_page() duplicate it, since those
functions make the page icache dirty themselves.
This patch makes those other functions call flush_dcache_page()
instead, so the logic's all in one place. This will make life less
confusing if we ever need to tweak the details of the the lazy icache
flush mechanism.
arch/powerpc/mm/mem.c | 14 ++------------
1 file changed, 2 insertions(+), 12 deletions(-)
Signed-off-by: David Gibson <dwg@au1.ibm.com>
[arch/powerpc/kernel/rtas_flash.c]
Checking a pointer for NULL before passing it to kfree is pointless, kfree
does its own NULL checking of input.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
arch/powerpc/kernel/udbg_16550.c: In function `udbg_init_maple_realmode':
arch/powerpc/kernel/udbg_16550.c:162: warning: assignment from incompatible pointer type
setup_peg2 must do some refcounting.
of_get_pci_address may need to drop the node
Pegasos l2cr : L2 cache was not active, activating
PCI bus 0 controlled by pci at 80000000
Badness in kref_get at /home/olaf/kernel/olh/ppc64/linux-2.6.16-rc2-olh/lib/kref.c:32
Call Trace:
[C037BD00] [C0007934] show_stack+0x5c/0x184 (unreliable)
[C037BD30] [C000E068] program_check_exception+0x184/0x584
[C037BD90] [C000F5F0] ret_from_except_full+0x0/0x4c
--- Exception: 700 at kref_get+0xc/0x24
LR = of_node_get+0x24/0x3c
[C037BE50] [C004FD94] __pte_alloc_kernel+0x64/0x80 (unreliable)
[C037BE70] [C000CA18] of_get_parent+0x34/0x58
[C037BE90] [C0009B18] of_get_address+0x24/0x174
[C037BED0] [C000A108] of_address_to_resource+0x24/0x68
[C037BF00] [C038B128] chrp_find_bridges+0x114/0x470
[C037BF90] [C038AE48] chrp_setup_arch+0x1fc/0x32c
[C037BFB0] [C03849B0] setup_arch+0x144/0x188
[C037BFD0] [C037C45C] start_kernel+0x34/0x1a8
[C037BFF0] [000037A0] 0x37a0
Call Trace:
[C037BC90] [C0007934] show_stack+0x5c/0x184 (unreliable)
[C037BCC0] [C000E068] program_check_exception+0x184/0x584
[C037BD20] [C000F5F0] ret_from_except_full+0x0/0x4c
[C037BDE0] [00000000] 0x0 (unreliable)
[C037BE00] [C000CA18] of_get_parent+0x34/0x58
[C037BE20] [C0009CE8] of_translate_address+0x2c/0x2fc
[C037BEA0] [C0009FE8] __of_address_to_resource+0x30/0xc4
[C037BED0] [C000A130] of_address_to_resource+0x4c/0x68
PCI bus 0 controlled by pci at c0000000
Top of RAM: 0x10000000, Total RAM: 0x10000000
remove pointer/integer confusion
Use generic_calibrate_decr to restore missing clock: speed in /proc/cpuinfo
It's possible for prom_init to allocate the flat device tree inside the
kdump crash kernel region. If this happens, when we load the kdump kernel we
overwrite the flattened device tree, which is bad.
We could make prom_init try and avoid allocating inside the crash kernel
region, but then we run into issues if the crash kernel region uses all the
space inside the RMO. The easiest solution is to move the flat device tree
once we're running in the kernel.
It turns out that we can't stop the watchdog from
triggering here. If we touch the timer (which just uses the current jiffie
value) before we enable interrupts, it does nothing because jiffies
are not mass-updated until after we enable interrupts. If we touch the
timer after we enable interrupts, its too late because the softlockup
watchdog will already have triggered. The touch_softlockup_watchdog
call removed below does nothing.
Signed-off-by: Dave Boutcher <sleddog@us.ibm.com>
We need to prod everyone here since this is the only CPU that is
guaranteed to be running after the ibm,suspend-me RTAS call returns.
Correctly return the status from the RTAS call. rtas_call expects
to return the status as a return value.
arch/powerpc/kernel/rtas.c is getting hvcall.h via spinlock.h, but when we're
building for UP we don't include spinlock.h.
This addresses two items, which are unlikely to be hit if we
trust drivers.
The first is moving a memory barrier below where the vmerged SG count
is passed back, but before the list is set to end. If those
instructions were reordered, there could be an issue in iommu_unmap_sg().
The second is making sure we terminate the list on the failure case of
iommu_map_sg(). If a driver does not look at the failure return code,
it could pass a ill-formed SG list to iommu_unmap_sg().
Signed-off-by: Jake Moilanen <moilanen@austin.ibm.com>
Acked-by: Olof Johansson <olof@lixom.net>
You can't boot a kdump kernel via OF, not reliably anyway, the kernel being at
32 MB conflicts with the zImage wrapper etc. and it blows up.
It's trivial to check in prom_init though, and this is early enough that we can
actually drop back to OF where a reset-all will get you going again, which is
kinda nice. I think this should go in for 2.6.16.
To prevent problems later in boot, make sure we don't create zero-size lmb
regions.
I've checked all the callers, and at the moment no one should ever hit this.
All callers use a constant size, or they check the computed size before they
call us.
In prom.c we run finish_node() on allnodes twice. The first time we just
calculate how much memory we'll need, the second time we do the actual work.
If the calculation stage determines that we need 0 bytes, then we should skip
the lmb allocation. Although an alloc of zero will work, it has been seen to
lead to a BUG_ON() in reserve_bootmem() on at least one machine.
This is a small fix to get the spufs init sequence right.
init_spu_base() in spu_base.c should be called (via
module_init(init_spu_base)) before spufs_init() (via
module_init(spufs_init)) in spufs/inode.c gets called.
Signed-off-by: Masato Noguchi <Masato.Noguchi@jp.sony.com>
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
When loading up the FPU, we were using a 'ld' (load doubleword)
instruction to get the FP exception mode from the thread_struct,
but it's only an int field. This changes the ld to lwz (load
word and zero-extend).
Build break: Building PCI hotplug on PowerPC results in
a build break, due to failure to export symbols.
Reported today by Dave Jones <davej@redhat.com>:
drivers/pci/hotplug/rpaphp.ko needs unknown symbol pcibios_add_pci_devices
This patch fixes the break in the arch/powerpc tree.
Next patch fixes same problem in drivers/pci tree
Signed-off-by: Linas Vepstas <linas@austin.ibm.com>
Better save the sigmask instead of throwing it away so it can be restored.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Make the platform function interrupt functions actually work. Calls
irq_enable() for the first in the list, and irq_disable() for the last.
Added *func to struct irq_client so the the user can pass just that to
pmf_unregister_irq_client().
Signed-off-by: Ben Collins <bcollins@ubuntu.com>
Older pSeries systems with serial ports dont get any console output after
recent changes. CONFIG_ISA does not make sense for CONFIG_PPC_PSERIES
because it enables lots of old drivers. Instead, remove the dependency on
CONFIG_ISA from the serial port discovery code.
Revert: 40727198bfb2ce5842a6e8c7f89cf8a40ff7bf14
These PHY changes hang the sungem driver on startup with Sun chips on
sparc64. Hopefully we can redo these changes in a way that doesn't
break non-Apple systems.
On my latest laptop, I've had occasional PHY dead on wakeup from
sleep... the PHY would be totally unresponsive even to toggling the hard
reset line until the machine is powered down... Looking closely at the
code, I found some possible issues in the way we setup the MDIO lines
during suspend along with slight divergences from what Darwin does when
resetting it that may explain the problem. That patch change these and
the problem appear to be gone for me at least... I also fixed an mdelay
-> msleep while I was at it to the pmac feature code that is called
when toggling the PHY reset line since sungem doesn't call it in an
atomic context anymore.
Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>b
Implement the TIF_RESTORE_SIGMASK flag in the new arch/powerpc kernel, for
both 32-bit and 64-bit system call paths.
The TIF_RESTORE_SIGMASK flag allows us to have a generic implementation of
sys_rt_sigsuspend() instead of duplicating it for each architecture. This
provides such an implementation and makes arch/powerpc use it.
It also tidies up the ppc32 sys_sigsuspend() to use TIF_RESTORE_SIGMASK.
Adds the ability to disability packet split at compile time and use the legacy receive path on PCI express hardware. Made this a CONFIG option and modified the Kconfig, to reflect the new option.
Signed-off-by: John Ronciak <john.ronciak@intel.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
When I removed the powermac support from arch/ppc/kernel/pci.c,
I overlooked the fact that that file is used in 32-bit ARCH=powerpc
builds. To prevent problems in future, restore the original version
of that file as arch/powerpc/kernel/pci_32.c, and use that.
Noticed in 2.6.15-git9 that CRASH_DUMP option is moved to top level.
Moved CRASH_DUMP into "kernel options" next to KEXEC and this config
option supports only for PPC64 at this time.
Signed-off-by: Haren Myneni <haren@us.ibm.com>
The changes to the device node structure broke Maple build. This fixes it.
Unfortunately I coudn't test as my Maple board appears to be dead.
- This contains the arch specific changes for the following the
kdump generic fixes which were already accepted in the upstream.
. Capturing CPU registers (for the case of 'panic' and invoking
the dump using 'sysrq-trigger') from a function (stack frame) which will
be not be available during the kdump boot. Hence, might result in
invalid stack trace.
. Dynamically allocating per cpu ELF notes section instead of
statically for NR_CPUS.
- Fix the compiler warning in prom_init.c.
