path: root/arch/powerpc
2019-07-19Merge tag 'v4.19.59' into v4.19-rtSteven Rostedt (VMware)
This is the 4.19.59 stable release
2019-06-25powerpc/mm/64s/hash: Reallocate context ids on forkMichael Ellerman
commit ca72d88378b2f2444d3ec145dd442d449d3fefbc upstream. When using the Hash Page Table (HPT) MMU, userspace memory mappings are managed at two levels. Firstly in the Linux page tables, much like other architectures, and secondly in the SLB (Segment Lookaside Buffer) and HPT. It's the SLB and HPT that are actually used by the hardware to do translations. As part of the series adding support for 4PB user virtual address space using the hash MMU, we added support for allocating multiple "context ids" per process, one for each 512TB chunk of address space. These are tracked in an array called extended_id in the mm_context_t of a process that has done a mapping above 512TB. If such a process forks (ie. clone(2) without CLONE_VM set) it's mm is copied, including the mm_context_t, and then init_new_context() is called to reinitialise parts of the mm_context_t as appropriate to separate the address spaces of the two processes. The key step in ensuring the two processes have separate address spaces is to allocate a new context id for the process, this is done at the beginning of hash__init_new_context(). If we didn't allocate a new context id then the two processes would share mappings as far as the SLB and HPT are concerned, even though their Linux page tables would be separate. For mappings above 512TB, which use the extended_id array, we neglected to allocate new context ids on fork, meaning the parent and child use the same ids and therefore share those mappings even though they're supposed to be separate. This can lead to the parent seeing writes done by the child, which is essentially memory corruption. There is an additional exposure which is that if the child process exits, all its context ids are freed, including the context ids that are still in use by the parent for mappings above 512TB. One or more of those ids can then be reallocated to a third process, that process can then read/write to the parent's mappings above 512TB. Additionally if the freed id is used for the third process's primary context id, then the parent is able to read/write to the third process's mappings *below* 512TB. All of these are fundamental failures to enforce separation between processes. The only mitigating factor is that the bug only occurs if a process creates mappings above 512TB, and most applications still do not create such mappings. Only machines using the hash page table MMU are affected, eg. PowerPC 970 (G5), PA6T, Power5/6/7/8/9. By default Power9 bare metal machines (powernv) use the Radix MMU and are not affected, unless the machine has been explicitly booted in HPT mode (using disable_radix on the kernel command line). KVM guests on Power9 may be affected if the host or guest is configured to use the HPT MMU. LPARs under PowerVM on Power9 are affected as they always use the HPT MMU. Kernels built with PAGE_SIZE=4K are not affected. The fix is relatively simple, we need to reallocate context ids for all extended mappings on fork. Fixes: f384796c40dc ("powerpc/mm: Add support for handling > 512TB address in SLB miss") Cc: stable@vger.kernel.org # v4.17+ Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-25powerpc/bpf: use unsigned division instruction for 64-bit operationsNaveen N. Rao
commit 758f2046ea040773ae8ea7f72dd3bbd8fa984501 upstream. BPF_ALU64 div/mod operations are currently using signed division, unlike BPF_ALU32 operations. Fix the same. DIV64 and MOD64 overflow tests pass with this fix. Fixes: 156d0e290e969c ("powerpc/ebpf/jit: Implement JIT compiler for extended BPF") Cc: stable@vger.kernel.org # v4.8+ Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-22KVM: PPC: Book3S HV: Don't take kvm->lock around kvm_for_each_vcpuPaul Mackerras
[ Upstream commit 5a3f49364c3ffa1107bd88f8292406e98c5d206c ] Currently the HV KVM code takes the kvm->lock around calls to kvm_for_each_vcpu() and kvm_get_vcpu_by_id() (which can call kvm_for_each_vcpu() internally). However, that leads to a lock order inversion problem, because these are called in contexts where the vcpu mutex is held, but the vcpu mutexes nest within kvm->lock according to Documentation/virtual/kvm/locking.txt. Hence there is a possibility of deadlock. To fix this, we simply don't take the kvm->lock mutex around these calls. This is safe because the implementations of kvm_for_each_vcpu() and kvm_get_vcpu_by_id() have been designed to be able to be called locklessly. Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Reviewed-by: Cédric Le Goater <clg@kaod.org> Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-22KVM: PPC: Book3S: Use new mutex to synchronize access to rtas token listPaul Mackerras
[ Upstream commit 1659e27d2bc1ef47b6d031abe01b467f18cb72d9 ] Currently the Book 3S KVM code uses kvm->lock to synchronize access to the kvm->arch.rtas_tokens list. Because this list is scanned inside kvmppc_rtas_hcall(), which is called with the vcpu mutex held, taking kvm->lock cause a lock inversion problem, which could lead to a deadlock. To fix this, we add a new mutex, kvm->arch.rtas_token_lock, which nests inside the vcpu mutexes, and use that instead of kvm->lock when accessing the rtas token list. This removes the lockdep_assert_held() in kvmppc_rtas_tokens_free(). At this point we don't hold the new mutex, but that is OK because kvmppc_rtas_tokens_free() is only called when the whole VM is being destroyed, and at that point nothing can be looking up a token in the list. Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-22powerpc/powernv: Return for invalid IMC domainAnju T Sudhakar
[ Upstream commit b59bd3527fe3c1939340df558d7f9d568fc9f882 ] Currently init_imc_pmu() can fail either because we try to register an IMC unit with an invalid domain (i.e an IMC node not supported by the kernel) or something went wrong while registering a valid IMC unit. In both the cases kernel provides a 'Register failed' error message. For example when trace-imc node is not supported by the kernel, but skiboot advertises a trace-imc node we print: IMC Unknown Device type IMC PMU (null) Register failed To avoid confusion just print the unknown device type message, before attempting PMU registration, so the second message isn't printed. Fixes: 8f95faaac56c ("powerpc/powernv: Detect and create IMC device") Reported-by: Pavaman Subramaniyam <pavsubra@in.ibm.com> Signed-off-by: Anju T Sudhakar <anju@linux.vnet.ibm.com> Reviewed-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> [mpe: Reword change log a bit] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-14Merge tag 'v4.19.50' into v4.19-rtSteven Rostedt (VMware)
This is the 4.19.50 stable release
2019-06-14Merge tag 'v4.19.47' into v4.19-rtSteven Rostedt (VMware)
This is the 4.19.47 stable release Conflicts: drivers/char/random.c kernel/irq_work.c Issues with kernel/irq/manage.c A use after free bug was fixed in stable. But it requires a backport of changes from rt-devel. The bug still exists in this tree for PREEMPT_RT, but will be fixed when backporting the rt-devel patches.
2019-06-11pstore: Convert buf_lock to semaphoreKees Cook
commit ea84b580b95521644429cc6748b6c2bf27c8b0f3 upstream. Instead of running with interrupts disabled, use a semaphore. This should make it easier for backends that may need to sleep (e.g. EFI) when performing a write: |BUG: sleeping function called from invalid context at kernel/sched/completion.c:99 |in_atomic(): 1, irqs_disabled(): 1, pid: 2236, name: sig-xstate-bum |Preemption disabled at: |[<ffffffff99d60512>] pstore_dump+0x72/0x330 |CPU: 26 PID: 2236 Comm: sig-xstate-bum Tainted: G D 4.20.0-rc3 #45 |Call Trace: | dump_stack+0x4f/0x6a | ___might_sleep.cold.91+0xd3/0xe4 | __might_sleep+0x50/0x90 | wait_for_completion+0x32/0x130 | virt_efi_query_variable_info+0x14e/0x160 | efi_query_variable_store+0x51/0x1a0 | efivar_entry_set_safe+0xa3/0x1b0 | efi_pstore_write+0x109/0x140 | pstore_dump+0x11c/0x330 | kmsg_dump+0xa4/0xd0 | oops_exit+0x22/0x30 ... Reported-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Fixes: 21b3ddd39fee ("efi: Don't use spinlocks for efi vars") Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-09KVM: s390: Do not report unusabled IDs via KVM_CAP_MAX_VCPU_IDThomas Huth
commit a86cb413f4bf273a9d341a3ab2c2ca44e12eb317 upstream. KVM_CAP_MAX_VCPU_ID is currently always reporting KVM_MAX_VCPU_ID on all architectures. However, on s390x, the amount of usable CPUs is determined during runtime - it is depending on the features of the machine the code is running on. Since we are using the vcpu_id as an index into the SCA structures that are defined by the hardware (see e.g. the sca_add_vcpu() function), it is not only the amount of CPUs that is limited by the hard- ware, but also the range of IDs that we can use. Thus KVM_CAP_MAX_VCPU_ID must be determined during runtime on s390x, too. So the handling of KVM_CAP_MAX_VCPU_ID has to be moved from the common code into the architecture specific code, and on s390x we have to return the same value here as for KVM_CAP_MAX_VCPUS. This problem has been discovered with the kvm_create_max_vcpus selftest. With this change applied, the selftest now passes on s390x, too. Reviewed-by: Andrew Jones <drjones@redhat.com> Reviewed-by: Cornelia Huck <cohuck@redhat.com> Reviewed-by: David Hildenbrand <david@redhat.com> Signed-off-by: Thomas Huth <thuth@redhat.com> Message-Id: <20190523164309.13345-9-thuth@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-09powerpc/perf: Fix MMCRA corruption by bhrb_filterRavi Bangoria
commit 3202e35ec1c8fc19cea24253ff83edf702a60a02 upstream. Consider a scenario where user creates two events: 1st event: attr.sample_type |= PERF_SAMPLE_BRANCH_STACK; attr.branch_sample_type = PERF_SAMPLE_BRANCH_ANY; fd = perf_event_open(attr, 0, 1, -1, 0); This sets cpuhw->bhrb_filter to 0 and returns valid fd. 2nd event: attr.sample_type |= PERF_SAMPLE_BRANCH_STACK; attr.branch_sample_type = PERF_SAMPLE_BRANCH_CALL; fd = perf_event_open(attr, 0, 1, -1, 0); It overrides cpuhw->bhrb_filter to -1 and returns with error. Now if power_pmu_enable() gets called by any path other than power_pmu_add(), ppmu->config_bhrb(-1) will set MMCRA to -1. Fixes: 3925f46bb590 ("powerpc/perf: Enable branch stack sampling framework") Cc: stable@vger.kernel.org # v3.10+ Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.ibm.com> Reviewed-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-09KVM: PPC: Book3S HV: XIVE: Do not clear IRQ data of passthrough interruptsCédric Le Goater
commit ef9740204051d0e00f5402fe96cf3a43ddd2bbbf upstream. The passthrough interrupts are defined at the host level and their IRQ data should not be cleared unless specifically deconfigured (shutdown) by the host. They differ from the IPI interrupts which are allocated by the XIVE KVM device and reserved to the guest usage only. This fixes a host crash when destroying a VM in which a PCI adapter was passed-through. In this case, the interrupt is cleared and freed by the KVM device and then shutdown by vfio at the host level. [ 1007.360265] BUG: Kernel NULL pointer dereference at 0x00000d00 [ 1007.360285] Faulting instruction address: 0xc00000000009da34 [ 1007.360296] Oops: Kernel access of bad area, sig: 7 [#1] [ 1007.360303] LE PAGE_SIZE=64K MMU=Radix MMU=Hash SMP NR_CPUS=2048 NUMA PowerNV [ 1007.360314] Modules linked in: vhost_net vhost iptable_mangle ipt_MASQUERADE iptable_nat nf_nat xt_conntrack nf_conntrack nf_defrag_ipv4 ipt_REJECT nf_reject_ipv4 tun bridge stp llc kvm_hv kvm xt_tcpudp iptable_filter squashfs fuse binfmt_misc vmx_crypto ib_iser rdma_cm iw_cm ib_cm libiscsi scsi_transport_iscsi nfsd ip_tables x_tables autofs4 btrfs zstd_decompress zstd_compress lzo_compress raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq multipath mlx5_ib ib_uverbs ib_core crc32c_vpmsum mlx5_core [ 1007.360425] CPU: 9 PID: 15576 Comm: CPU 18/KVM Kdump: loaded Not tainted 5.1.0-gad7e7d0ef #4 [ 1007.360454] NIP: c00000000009da34 LR: c00000000009e50c CTR: c00000000009e5d0 [ 1007.360482] REGS: c000007f24ccf330 TRAP: 0300 Not tainted (5.1.0-gad7e7d0ef) [ 1007.360500] MSR: 900000000280b033 <SF,HV,VEC,VSX,EE,FP,ME,IR,DR,RI,LE> CR: 24002484 XER: 00000000 [ 1007.360532] CFAR: c00000000009da10 DAR: 0000000000000d00 DSISR: 00080000 IRQMASK: 1 [ 1007.360532] GPR00: c00000000009e62c c000007f24ccf5c0 c000000001510600 c000007fe7f947c0 [ 1007.360532] GPR04: 0000000000000d00 0000000000000000 0000000000000000 c000005eff02d200 [ 1007.360532] GPR08: 0000000000400000 0000000000000000 0000000000000000 fffffffffffffffd [ 1007.360532] GPR12: c00000000009e5d0 c000007fffff7b00 0000000000000031 000000012c345718 [ 1007.360532] GPR16: 0000000000000000 0000000000000008 0000000000418004 0000000000040100 [ 1007.360532] GPR20: 0000000000000000 0000000008430000 00000000003c0000 0000000000000027 [ 1007.360532] GPR24: 00000000000000ff 0000000000000000 00000000000000ff c000007faa90d98c [ 1007.360532] GPR28: c000007faa90da40 00000000000fe040 ffffffffffffffff c000007fe7f947c0 [ 1007.360689] NIP [c00000000009da34] xive_esb_read+0x34/0x120 [ 1007.360706] LR [c00000000009e50c] xive_do_source_set_mask.part.0+0x2c/0x50 [ 1007.360732] Call Trace: [ 1007.360738] [c000007f24ccf5c0] [c000000000a6383c] snooze_loop+0x15c/0x270 (unreliable) [ 1007.360775] [c000007f24ccf5f0] [c00000000009e62c] xive_irq_shutdown+0x5c/0xe0 [ 1007.360795] [c000007f24ccf630] [c00000000019e4a0] irq_shutdown+0x60/0xe0 [ 1007.360813] [c000007f24ccf660] [c000000000198c44] __free_irq+0x3a4/0x420 [ 1007.360831] [c000007f24ccf700] [c000000000198dc8] free_irq+0x78/0xe0 [ 1007.360849] [c000007f24ccf730] [c00000000096c5a8] vfio_msi_set_vector_signal+0xa8/0x350 [ 1007.360878] [c000007f24ccf7f0] [c00000000096c938] vfio_msi_set_block+0xe8/0x1e0 [ 1007.360899] [c000007f24ccf850] [c00000000096cae0] vfio_msi_disable+0xb0/0x110 [ 1007.360912] [c000007f24ccf8a0] [c00000000096cd04] vfio_pci_set_msi_trigger+0x1c4/0x3d0 [ 1007.360922] [c000007f24ccf910] [c00000000096d910] vfio_pci_set_irqs_ioctl+0xa0/0x170 [ 1007.360941] [c000007f24ccf930] [c00000000096b400] vfio_pci_disable+0x80/0x5e0 [ 1007.360963] [c000007f24ccfa10] [c00000000096b9bc] vfio_pci_release+0x5c/0x90 [ 1007.360991] [c000007f24ccfa40] [c000000000963a9c] vfio_device_fops_release+0x3c/0x70 [ 1007.361012] [c000007f24ccfa70] [c0000000003b5668] __fput+0xc8/0x2b0 [ 1007.361040] [c000007f24ccfac0] [c0000000001409b0] task_work_run+0x140/0x1b0 [ 1007.361059] [c000007f24ccfb20] [c000000000118f8c] do_exit+0x3ac/0xd00 [ 1007.361076] [c000007f24ccfc00] [c0000000001199b0] do_group_exit+0x60/0x100 [ 1007.361094] [c000007f24ccfc40] [c00000000012b514] get_signal+0x1a4/0x8f0 [ 1007.361112] [c000007f24ccfd30] [c000000000021cc8] do_notify_resume+0x1a8/0x430 [ 1007.361141] [c000007f24ccfe20] [c00000000000e444] ret_from_except_lite+0x70/0x74 [ 1007.361159] Instruction dump: [ 1007.361175] 38422c00 e9230000 712a0004 41820010 548a2036 7d442378 78840020 71290020 [ 1007.361194] 4082004c e9230010 7c892214 7c0004ac <e9240000> 0c090000 4c00012c 792a0022 Cc: stable@vger.kernel.org # v4.12+ Fixes: 5af50993850a ("KVM: PPC: Book3S HV: Native usage of the XIVE interrupt controller") Signed-off-by: Cédric Le Goater <clg@kaod.org> Signed-off-by: Greg Kurz <groug@kaod.org> Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-04jump_label: move 'asm goto' support test to KconfigMasahiro Yamada
commit e9666d10a5677a494260d60d1fa0b73cc7646eb3 upstream. Currently, CONFIG_JUMP_LABEL just means "I _want_ to use jump label". The jump label is controlled by HAVE_JUMP_LABEL, which is defined like this: #if defined(CC_HAVE_ASM_GOTO) && defined(CONFIG_JUMP_LABEL) # define HAVE_JUMP_LABEL #endif We can improve this by testing 'asm goto' support in Kconfig, then make JUMP_LABEL depend on CC_HAS_ASM_GOTO. Ugly #ifdef HAVE_JUMP_LABEL will go away, and CONFIG_JUMP_LABEL will match to the real kernel capability. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Tested-by: Sedat Dilek <sedat.dilek@gmail.com> [nc: Fix trivial conflicts in 4.19 arch/xtensa/kernel/jump_label.c doesn't exist yet Ensured CC_HAVE_ASM_GOTO and HAVE_JUMP_LABEL were sufficiently eliminated] Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-31powerpc/64: Fix booting large kernels with STRICT_KERNEL_RWXRussell Currey
[ Upstream commit 56c46bba9bbfe229b4472a5be313c44c5b714a39 ] With STRICT_KERNEL_RWX enabled anything marked __init is placed at a 16M boundary. This is necessary so that it can be repurposed later with different permissions. However, in kernels with text larger than 16M, this pushes early_setup past 32M, incapable of being reached by the branch instruction. Fix this by setting the CTR and branching there instead. Fixes: 1e0fc9d1eb2b ("powerpc/Kconfig: Enable STRICT_KERNEL_RWX for some configs") Signed-off-by: Russell Currey <ruscur@russell.cc> [mpe: Fix it to work on BE by using DOTSYM()] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-31powerpc/numa: improve control of topology updatesNathan Lynch
[ Upstream commit 2d4d9b308f8f8dec68f6dbbff18c68ec7c6bd26f ] When booted with "topology_updates=no", or when "off" is written to /proc/powerpc/topology_updates, NUMA reassignments are inhibited for PRRN and VPHN events. However, migration and suspend unconditionally re-enable reassignments via start_topology_update(). This is incoherent. Check the topology_updates_enabled flag in start/stop_topology_update() so that callers of those APIs need not be aware of whether reassignments are enabled. This allows the administrative decision on reassignments to remain in force across migrations and suspensions. Signed-off-by: Nathan Lynch <nathanl@linux.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-31powerpc/watchdog: Use hrtimers for per-CPU heartbeatNicholas Piggin
[ Upstream commit 7ae3f6e130e8dc6188b59e3b4ebc2f16e9c8d053 ] Using a jiffies timer creates a dependency on the tick_do_timer_cpu incrementing jiffies. If that CPU has locked up and jiffies is not incrementing, the watchdog heartbeat timer for all CPUs stops and creates false positives and confusing warnings on local CPUs, and also causes the SMP detector to stop, so the root cause is never detected. Fix this by using hrtimer based timers for the watchdog heartbeat, like the generic kernel hardlockup detector. Cc: Gautham R. Shenoy <ego@linux.vnet.ibm.com> Reported-by: Ravikumar Bangoria <ravi.bangoria@in.ibm.com> Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Tested-by: Ravi Bangoria <ravi.bangoria@linux.ibm.com> Reported-by: Ravi Bangoria <ravi.bangoria@linux.ibm.com> Reviewed-by: Gautham R. Shenoy <ego@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-31powerpc/perf: Fix loop exit condition in nest_imc_event_initAnju T Sudhakar
[ Upstream commit 860b7d2286236170a36f94946d03ca9888d32571 ] The data structure (i.e struct imc_mem_info) to hold the memory address information for nest imc units is allocated based on the number of nodes in the system. nest_imc_event_init() traverse this struct array to calculate the memory base address for the event-cpu. If we fail to find a match for the event cpu's chip-id in imc_mem_info struct array, then the do-while loop will iterate until we crash. Fix this by changing the loop exit condition based on the number of non zero vbase elements in the array, since the allocation is done for nr_chips + 1. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Fixes: 885dcd709ba91 ("powerpc/perf: Add nest IMC PMU support") Signed-off-by: Anju T Sudhakar <anju@linux.vnet.ibm.com> Reviewed-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-31powerpc/boot: Fix missing check of lseek() return valueBo YU
[ Upstream commit 5d085ec04a000fefb5182d3b03ee46ca96d8389b ] This is detected by Coverity scan: CID: 1440481 Signed-off-by: Bo YU <tsu.yubo@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-31powerpc/perf: Return accordingly on invalid chip-id inAnju T Sudhakar
[ Upstream commit a913e5e8b43be1d3897a141ce61c1ec071cad89c ] Nest hardware counter memory resides in a per-chip reserve-memory. During nest_imc_event_init(), chip-id of the event-cpu is considered to calculate the base memory addresss for that cpu. Return, proper error condition if the chip_id calculated is invalid. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Fixes: 885dcd709ba91 ("powerpc/perf: Add nest IMC PMU support") Reviewed-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> Signed-off-by: Anju T Sudhakar <anju@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-24powerpc: reshuffle TIF bitsSebastian Andrzej Siewior
Powerpc32/64 does not compile because TIF_SYSCALL_TRACE's bit is higher than 15 and the assembly instructions don't expect that. Move TIF_RESTOREALL, TIF_NOERROR to the higher bits and keep TIF_NEED_RESCHED_LAZY in the lower range. As a result one split load is needed and otherwise we can use immediates. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
2019-05-24powerpc/pseries/iommu: Use a locallock instead local_irq_save()Sebastian Andrzej Siewior
The locallock protects the per-CPU variable tce_page. The function attempts to allocate memory while tce_page is protected (by disabling interrupts). Use local_irq_save() instead of local_irq_disable(). Cc: stable-rt@vger.kernel.org Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
2019-05-16powerpc/booke64: set RI in default MSRLaurentiu Tudor
commit 5266e58d6cd90ac85c187d673093ad9cb649e16d upstream. Set RI in the default kernel's MSR so that the architected way of detecting unrecoverable machine check interrupts has a chance to work. This is inline with the MSR setup of the rest of booke powerpc architectures configured here. Signed-off-by: Laurentiu Tudor <laurentiu.tudor@nxp.com> Cc: stable@vger.kernel.org Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16powerpc/powernv/idle: Restore IAMR after idleRussell Currey
commit a3f3072db6cad40895c585dce65e36aab997f042 upstream. Without restoring the IAMR after idle, execution prevention on POWER9 with Radix MMU is overwritten and the kernel can freely execute userspace without faulting. This is necessary when returning from any stop state that modifies user state, as well as hypervisor state. To test how this fails without this patch, load the lkdtm driver and do the following: $ echo EXEC_USERSPACE > /sys/kernel/debug/provoke-crash/DIRECT which won't fault, then boot the kernel with powersave=off, where it will fault. Applying this patch will fix this. Fixes: 3b10d0095a1e ("powerpc/mm/radix: Prevent kernel execution of user space") Cc: stable@vger.kernel.org # v4.10+ Signed-off-by: Russell Currey <ruscur@russell.cc> Reviewed-by: Akshay Adiga <akshay.adiga@linux.vnet.ibm.com> Reviewed-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16powerpc/book3s/64: check for NULL pointer in pgd_alloc()Rick Lindsley
commit f39356261c265a0689d7ee568132d516e8b6cecc upstream. When the memset code was added to pgd_alloc(), it failed to consider that kmem_cache_alloc() can return NULL. It's uncommon, but not impossible under heavy memory contention. Example oops: Unable to handle kernel paging request for data at address 0x00000000 Faulting instruction address: 0xc0000000000a4000 Oops: Kernel access of bad area, sig: 11 [#1] LE SMP NR_CPUS=2048 NUMA pSeries CPU: 70 PID: 48471 Comm: entrypoint.sh Kdump: loaded Not tainted 4.14.0-115.6.1.el7a.ppc64le #1 task: c000000334a00000 task.stack: c000000331c00000 NIP: c0000000000a4000 LR: c00000000012f43c CTR: 0000000000000020 REGS: c000000331c039c0 TRAP: 0300 Not tainted (4.14.0-115.6.1.el7a.ppc64le) MSR: 800000010280b033 <SF,VEC,VSX,EE,FP,ME,IR,DR,RI,LE,TM[E]> CR: 44022840 XER: 20040000 CFAR: c000000000008874 DAR: 0000000000000000 DSISR: 42000000 SOFTE: 1 ... NIP [c0000000000a4000] memset+0x68/0x104 LR [c00000000012f43c] mm_init+0x27c/0x2f0 Call Trace: mm_init+0x260/0x2f0 (unreliable) copy_mm+0x11c/0x638 copy_process.isra.28.part.29+0x6fc/0x1080 _do_fork+0xdc/0x4c0 ppc_clone+0x8/0xc Instruction dump: 409e000c b0860000 38c60002 409d000c 90860000 38c60004 78a0d183 78a506a0 7c0903a6 41820034 60000000 60420000 <f8860000> f8860008 f8860010 f8860018 Fixes: fc5c2f4a55a2 ("powerpc/mm/hash64: Zero PGD pages on allocation") Cc: stable@vger.kernel.org # v4.16+ Signed-off-by: Rick Lindsley <ricklind@vnet.linux.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16powerpc/64s: Include cpu headerBreno Leitao
commit 42e2acde1237878462b028f5a27d9cc5bea7502c upstream. Current powerpc security.c file is defining functions, as cpu_show_meltdown(), cpu_show_spectre_v{1,2} and others, that are being declared at linux/cpu.h header without including the header file that contains these declarations. This is being reported by sparse, which thinks that these functions are static, due to the lack of declaration: arch/powerpc/kernel/security.c:105:9: warning: symbol 'cpu_show_meltdown' was not declared. Should it be static? arch/powerpc/kernel/security.c:139:9: warning: symbol 'cpu_show_spectre_v1' was not declared. Should it be static? arch/powerpc/kernel/security.c:161:9: warning: symbol 'cpu_show_spectre_v2' was not declared. Should it be static? arch/powerpc/kernel/security.c:209:6: warning: symbol 'stf_barrier' was not declared. Should it be static? arch/powerpc/kernel/security.c:289:9: warning: symbol 'cpu_show_spec_store_bypass' was not declared. Should it be static? This patch simply includes the proper header (linux/cpu.h) to match function definition and declaration. Signed-off-by: Breno Leitao <leitao@debian.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Cc: Joel Stanley <joel@jms.id.au> Cc: Nathan Chancellor <natechancellor@gmail.com> Cc: Major Hayden <major@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16powerpc/smp: Fix NMI IPI xmon timeoutNicholas Piggin
[ Upstream commit 88b9a3d1425a436e95c41f09986fdae2daee437a ] The xmon debugger IPI handler waits in the callback function while xmon is still active. This means they don't complete the IPI, and the initiator always times out waiting for them. Things manage to work after the timeout because there is some fallback logic to keep NMI IPI state sane in case of the timeout, but this is a bit ugly. This patch changes NMI IPI back to half-asynchronous (i.e., wait for everyone to call in, do not wait for IPI function to complete), but the complexity is avoided by going one step further and allowing new IPIs to be issued before the IPI functions to all complete. If synchronization against that is required, it is left up to the caller, but current callers don't require that. In fact with the timeout handling, callers must be able to cope with this already. Fixes: 5b73151fff63 ("powerpc: NMI IPI make NMI IPIs fully sychronous") Cc: stable@vger.kernel.org # v4.19+ Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com>
2019-05-16powerpc/smp: Fix NMI IPI timeoutNicholas Piggin
[ Upstream commit 1b5fc84aba170bdfe3533396ca9662ceea1609b7 ] The NMI IPI timeout logic is broken, if __smp_send_nmi_ipi() times out on the first condition, delay_us will be zero which will send it into the second spin loop with no timeout so it will spin forever. Fixes: 5b73151fff63 ("powerpc: NMI IPI make NMI IPIs fully sychronous") Cc: stable@vger.kernel.org # v4.19+ Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com>
2019-05-14powerpc/speculation: Support 'mitigations=' cmdline optionJosh Poimboeuf
commit 782e69efb3dfed6e8360bc612e8c7827a901a8f9 upstream Configure powerpc CPU runtime speculation bug mitigations in accordance with the 'mitigations=' cmdline option. This affects Meltdown, Spectre v1, Spectre v2, and Speculative Store Bypass. The default behavior is unchanged. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Jiri Kosina <jkosina@suse.cz> (on x86) Reviewed-by: Jiri Kosina <jkosina@suse.cz> Cc: Borislav Petkov <bp@alien8.de> Cc: "H . Peter Anvin" <hpa@zytor.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Waiman Long <longman@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Jon Masters <jcm@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: linuxppc-dev@lists.ozlabs.org Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux-s390@vger.kernel.org Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-arch@vger.kernel.org Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Tyler Hicks <tyhicks@canonical.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Steven Price <steven.price@arm.com> Cc: Phil Auld <pauld@redhat.com> Link: https://lkml.kernel.org/r/245a606e1a42a558a310220312d9b6adb9159df6.1555085500.git.jpoimboe@redhat.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-08powerpc/mm/hash: Handle mmap_min_addr correctly in get_unmapped_area topdown ↵Aneesh Kumar K.V
search commit 3b4d07d2674f6b4a9281031f99d1f7efd325b16d upstream. When doing top-down search the low_limit is not PAGE_SIZE but rather max(PAGE_SIZE, mmap_min_addr). This handle cases in which mmap_min_addr > PAGE_SIZE. Fixes: fba2369e6ceb ("mm: use vm_unmapped_area() on powerpc architecture") Reviewed-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-08kmemleak: powerpc: skip scanning holes in the .bss sectionCatalin Marinas
[ Upstream commit 298a32b132087550d3fa80641ca58323c5dfd4d9 ] Commit 2d4f567103ff ("KVM: PPC: Introduce kvm_tmp framework") adds kvm_tmp[] into the .bss section and then free the rest of unused spaces back to the page allocator. kernel_init kvm_guest_init kvm_free_tmp free_reserved_area free_unref_page free_unref_page_prepare With DEBUG_PAGEALLOC=y, it will unmap those pages from kernel. As the result, kmemleak scan will trigger a panic when it scans the .bss section with unmapped pages. This patch creates dedicated kmemleak objects for the .data, .bss and potentially .data..ro_after_init sections to allow partial freeing via the kmemleak_free_part() in the powerpc kvm_free_tmp() function. Link: http://lkml.kernel.org/r/20190321171917.62049-1-catalin.marinas@arm.com Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Qian Cai <cai@lca.pw> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Tested-by: Qian Cai <cai@lca.pw> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Avi Kivity <avi@redhat.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krcmar <rkrcmar@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-02powerpc/mm/radix: Make Radix require HUGETLB_PAGEMichael Ellerman
commit 8adddf349fda0d3de2f6bb41ddf838cbf36a8ad2 upstream. Joel reported weird crashes using skiroot_defconfig, in his case we jumped into an NX page: kernel tried to execute exec-protected page (c000000002bff4f0) - exploit attempt? (uid: 0) BUG: Unable to handle kernel instruction fetch Faulting instruction address: 0xc000000002bff4f0 Looking at the disassembly, we had simply branched to that address: c000000000c001bc 49fff335 bl c000000002bff4f0 But that didn't match the original kernel image: c000000000c001bc 4bfff335 bl c000000000bff4f0 <kobject_get+0x8> When STRICT_KERNEL_RWX is enabled, and we're using the radix MMU, we call radix__change_memory_range() late in boot to change page protections. We do that both to mark rodata read only and also to mark init text no-execute. That involves walking the kernel page tables, and clearing _PAGE_WRITE or _PAGE_EXEC respectively. With radix we may use hugepages for the linear mapping, so the code in radix__change_memory_range() uses eg. pmd_huge() to test if it has found a huge mapping, and if so it stops the page table walk and changes the PMD permissions. However if the kernel is built without HUGETLBFS support, pmd_huge() is just a #define that always returns 0. That causes the code in radix__change_memory_range() to incorrectly interpret the PMD value as a pointer to a PTE page rather than as a PTE at the PMD level. We can see this using `dv` in xmon which also uses pmd_huge(): 0:mon> dv c000000000000000 pgd @ 0xc000000001740000 pgdp @ 0xc000000001740000 = 0x80000000ffffb009 pudp @ 0xc0000000ffffb000 = 0x80000000ffffa009 pmdp @ 0xc0000000ffffa000 = 0xc00000000000018f <- this is a PTE ptep @ 0xc000000000000100 = 0xa64bb17da64ab07d <- kernel text The end result is we treat the value at 0xc000000000000100 as a PTE and clear _PAGE_WRITE or _PAGE_EXEC, potentially corrupting the code at that address. In Joel's specific case we cleared the sign bit in the offset of the branch, causing a backward branch to turn into a forward branch which caused us to branch into a non-executable page. However the exact nature of the crash depends on kernel version, compiler version, and other factors. We need to fix radix__change_memory_range() to not use accessors that depend on HUGETLBFS, but we also have radix memory hotplug code that uses pmd_huge() etc that will also need fixing. So for now just disallow the broken combination of Radix with HUGETLBFS disabled. The only defconfig we have that is affected is skiroot_defconfig, so turn on HUGETLBFS there so that it still gets Radix. Fixes: 566ca99af026 ("powerpc/mm/radix: Add dummy radix_enabled()") Cc: stable@vger.kernel.org # v4.7+ Reported-by: Joel Stanley <joel@jms.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-02powerpc/vdso32: fix CLOCK_MONOTONIC on PPC64Christophe Leroy
[ Upstream commit dd9a994fc68d196a052b73747e3366c57d14a09e ] Commit b5b4453e7912 ("powerpc/vdso64: Fix CLOCK_MONOTONIC inconsistencies across Y2038") changed the type of wtom_clock_sec to s64 on PPC64. Therefore, VDSO32 needs to read it with a 4 bytes shift in order to retrieve the lower part of it. Fixes: b5b4453e7912 ("powerpc/vdso64: Fix CLOCK_MONOTONIC inconsistencies across Y2038") Reported-by: Christian Zigotzky <chzigotzky@xenosoft.de> Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-28Merge tag 'v4.19.37' into v4.19-rtSteven Rostedt (VMware)
This is the 4.19.37 stable release Conflicts: include/linux/sched/mm.h kernel/sched/fair.c
2019-04-20powerpc/pseries: Remove prrn_work workqueueNathan Fontenot
[ Upstream commit cd24e457fd8b2d087d9236700c8d2957054598bf ] When a PRRN event is received we are already running in a worker thread. Instead of spawning off another worker thread on the prrn_work workqueue to handle the PRRN event we can just call the PRRN handler routine directly. With this update we can also pass the scope variable for the PRRN event directly to the handler instead of it being a global variable. This patch fixes the following oops mnessage we are seeing in PRRN testing: Oops: Bad kernel stack pointer, sig: 6 [#1] SMP NR_CPUS=2048 NUMA pSeries Modules linked in: nfsv3 nfs_acl rpcsec_gss_krb5 auth_rpcgss nfsv4 dns_resolver nfs lockd grace sunrpc fscache binfmt_misc reiserfs vfat fat rpadlpar_io(X) rpaphp(X) tcp_diag udp_diag inet_diag unix_diag af_packet_diag netlink_diag af_packet xfs libcrc32c dm_service_time ibmveth(X) ses enclosure scsi_transport_sas rtc_generic btrfs xor raid6_pq sd_mod ibmvscsi(X) scsi_transport_srp ipr(X) libata sg dm_multipath dm_mod scsi_dh_rdac scsi_dh_emc scsi_dh_alua scsi_mod autofs4 Supported: Yes, External 54 CPU: 7 PID: 18967 Comm: kworker/u96:0 Tainted: G X 4.4.126-94.22-default #1 Workqueue: pseries hotplug workque pseries_hp_work_fn task: c000000775367790 ti: c00000001ebd4000 task.ti: c00000070d140000 NIP: 0000000000000000 LR: 000000001fb3d050 CTR: 0000000000000000 REGS: c00000001ebd7d40 TRAP: 0700 Tainted: G X (4.4.126-94.22-default) MSR: 8000000102081000 <41,VEC,ME5 CR: 28000002 XER: 20040018 4 CFAR: 000000001fb3d084 40 419 1 3 GPR00: 000000000000000040000000000010007 000000001ffff400 000000041fffe200 GPR04: 000000000000008050000000000000000 000000001fb15fa8 0000000500000500 GPR08: 000000000001f40040000000000000001 0000000000000000 000005:5200040002 GPR12: 00000000000000005c000000007a05400 c0000000000e89f8 000000001ed9f668 GPR16: 000000001fbeff944000000001fbeff94 000000001fb545e4 0000006000000060 GPR20: ffffffffffffffff4ffffffffffffffff 0000000000000000 0000000000000000 GPR24: 00000000000000005400000001fb3c000 0000000000000000 000000001fb1b040 GPR28: 000000001fb240004000000001fb440d8 0000000000000008 0000000000000000 NIP [0000000000000000] 5 (null) LR [000000001fb3d050] 031fb3d050 Call Trace: 4 Instruction dump: 4 5:47 12 2 XXXXXXXX XXXXXXXX XXXXX4XX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXX5XX XXXXXXXX 60000000 60000000 60000000 60000000 ---[ end trace aa5627b04a7d9d6b ]--- 3NMI watchdog: BUG: soft lockup - CPU#27 stuck for 23s! [kworker/27:0:13903] Modules linked in: nfsv3 nfs_acl rpcsec_gss_krb5 auth_rpcgss nfsv4 dns_resolver nfs lockd grace sunrpc fscache binfmt_misc reiserfs vfat fat rpadlpar_io(X) rpaphp(X) tcp_diag udp_diag inet_diag unix_diag af_packet_diag netlink_diag af_packet xfs libcrc32c dm_service_time ibmveth(X) ses enclosure scsi_transport_sas rtc_generic btrfs xor raid6_pq sd_mod ibmvscsi(X) scsi_transport_srp ipr(X) libata sg dm_multipath dm_mod scsi_dh_rdac scsi_dh_emc scsi_dh_alua scsi_mod autofs4 Supported: Yes, External CPU: 27 PID: 13903 Comm: kworker/27:0 Tainted: G D X 4.4.126-94.22-default #1 Workqueue: events prrn_work_fn task: c000000747cfa390 ti: c00000074712c000 task.ti: c00000074712c000 NIP: c0000000008002a8 LR: c000000000090770 CTR: 000000000032e088 REGS: c00000074712f7b0 TRAP: 0901 Tainted: G D X (4.4.126-94.22-default) MSR: 8000000100009033 <SF,EE,ME,IR,DR,RI,LE> CR: 22482044 XER: 20040000 CFAR: c0000000008002c4 SOFTE: 1 GPR00: c000000000090770 c00000074712fa30 c000000000f09800 c000000000fa1928 6:02 GPR04: c000000775f5e000 fffffffffffffffe 0000000000000001 c000000000f42db8 GPR08: 0000000000000001 0000000080000007 0000000000000000 0000000000000000 GPR12: 8006210083180000 c000000007a14400 NIP [c0000000008002a8] _raw_spin_lock+0x68/0xd0 LR [c000000000090770] mobility_rtas_call+0x50/0x100 Call Trace: 59 5 [c00000074712fa60] [c000000000090770] mobility_rtas_call+0x50/0x100 [c00000074712faf0] [c000000000090b08] pseries_devicetree_update+0xf8/0x530 [c00000074712fc20] [c000000000031ba4] prrn_work_fn+0x34/0x50 [c00000074712fc40] [c0000000000e0390] process_one_work+0x1a0/0x4e0 [c00000074712fcd0] [c0000000000e0870] worker_thread+0x1a0/0x6105:57 2 [c00000074712fd80] [c0000000000e8b18] kthread+0x128/0x150 [c00000074712fe30] [c0000000000096f8] ret_from_kernel_thread+0x5c/0x64 Instruction dump: 2c090000 40c20010 7d40192d 40c2fff0 7c2004ac 2fa90000 40de0018 5:540030 3 e8010010 ebe1fff8 7c0803a6 4e800020 <7c210b78> e92d0000 89290009 792affe3 Signed-off-by: John Allen <jallen@linux.ibm.com> Signed-off-by: Haren Myneni <haren@us.ibm.com> Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-17powerpc/tm: Limit TM code inside PPC_TRANSACTIONAL_MEMBreno Leitao
commit 897bc3df8c5aebb54c32d831f917592e873d0559 upstream. Commit e1c3743e1a20 ("powerpc/tm: Set MSR[TS] just prior to recheckpoint") moved a code block around and this block uses a 'msr' variable outside of the CONFIG_PPC_TRANSACTIONAL_MEM, however the 'msr' variable is declared inside a CONFIG_PPC_TRANSACTIONAL_MEM block, causing a possible error when CONFIG_PPC_TRANSACTION_MEM is not defined. error: 'msr' undeclared (first use in this function) This is not causing a compilation error in the mainline kernel, because 'msr' is being used as an argument of MSR_TM_ACTIVE(), which is defined as the following when CONFIG_PPC_TRANSACTIONAL_MEM is *not* set: #define MSR_TM_ACTIVE(x) 0 This patch just fixes this issue avoiding the 'msr' variable usage outside the CONFIG_PPC_TRANSACTIONAL_MEM block, avoiding trusting in the MSR_TM_ACTIVE() definition. Cc: stable@vger.kernel.org Reported-by: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de> Fixes: e1c3743e1a20 ("powerpc/tm: Set MSR[TS] just prior to recheckpoint") Signed-off-by: Breno Leitao <leitao@debian.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05powerpc/pseries: Perform full re-add of CPU for topology update post-migrationNathan Fontenot
[ Upstream commit 81b61324922c67f73813d8a9c175f3c153f6a1c6 ] On pseries systems, performing a partition migration can result in altering the nodes a CPU is assigned to on the destination system. For exampl, pre-migration on the source system CPUs are in node 1 and 3, post-migration on the destination system CPUs are in nodes 2 and 3. Handling the node change for a CPU can cause corruption in the slab cache if we hit a timing where a CPUs node is changed while cache_reap() is invoked. The corruption occurs because the slab cache code appears to rely on the CPU and slab cache pages being on the same node. The current dynamic updating of a CPUs node done in arch/powerpc/mm/numa.c does not prevent us from hitting this scenario. Changing the device tree property update notification handler that recognizes an affinity change for a CPU to do a full DLPAR remove and add of the CPU instead of dynamically changing its node resolves this issue. Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Signed-off-by: Michael W. Bringmann <mwb@linux.vnet.ibm.com> Tested-by: Michael W. Bringmann <mwb@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05powerpc/64s: Clear on-stack exception marker upon exception returnNicolai Stange
[ Upstream commit eddd0b332304d554ad6243942f87c2fcea98c56b ] The ppc64 specific implementation of the reliable stacktracer, save_stack_trace_tsk_reliable(), bails out and reports an "unreliable trace" whenever it finds an exception frame on the stack. Stack frames are classified as exception frames if the STACK_FRAME_REGS_MARKER magic, as written by exception prologues, is found at a particular location. However, as observed by Joe Lawrence, it is possible in practice that non-exception stack frames can alias with prior exception frames and thus, that the reliable stacktracer can find a stale STACK_FRAME_REGS_MARKER on the stack. It in turn falsely reports an unreliable stacktrace and blocks any live patching transition to finish. Said condition lasts until the stack frame is overwritten/initialized by function call or other means. In principle, we could mitigate this by making the exception frame classification condition in save_stack_trace_tsk_reliable() stronger: in addition to testing for STACK_FRAME_REGS_MARKER, we could also take into account that for all exceptions executing on the kernel stack - their stack frames's backlink pointers always match what is saved in their pt_regs instance's ->gpr[1] slot and that - their exception frame size equals STACK_INT_FRAME_SIZE, a value uncommonly large for non-exception frames. However, while these are currently true, relying on them would make the reliable stacktrace implementation more sensitive towards future changes in the exception entry code. Note that false negatives, i.e. not detecting exception frames, would silently break the live patching consistency model. Furthermore, certain other places (diagnostic stacktraces, perf, xmon) rely on STACK_FRAME_REGS_MARKER as well. Make the exception exit code clear the on-stack STACK_FRAME_REGS_MARKER for those exceptions running on the "normal" kernel stack and returning to kernelspace: because the topmost frame is ignored by the reliable stack tracer anyway, returns to userspace don't need to take care of clearing the marker. Furthermore, as I don't have the ability to test this on Book 3E or 32 bits, limit the change to Book 3S and 64 bits. Fixes: df78d3f61480 ("powerpc/livepatch: Implement reliable stack tracing for the consistency model") Reported-by: Joe Lawrence <joe.lawrence@redhat.com> Signed-off-by: Nicolai Stange <nstange@suse.de> Signed-off-by: Joe Lawrence <joe.lawrence@redhat.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05powerpc/hugetlb: Handle mmap_min_addr correctly in get_unmapped_area callbackAneesh Kumar K.V
[ Upstream commit 5330367fa300742a97e20e953b1f77f48392faae ] After we ALIGN up the address we need to make sure we didn't overflow and resulted in zero address. In that case, we need to make sure that the returned address is greater than mmap_min_addr. This fixes selftest va_128TBswitch --run-hugetlb reporting failures when run as non root user for mmap(-1, MAP_HUGETLB) The bug is that a non-root user requesting address -1 will be given address 0 which will then fail, whereas they should have been given something else that would have succeeded. We also avoid the first mmap(-1, MAP_HUGETLB) returning NULL address as mmap address with this change. So we think this is not a security issue, because it only affects whether we choose an address below mmap_min_addr, not whether we actually allow that address to be mapped. ie. there are existing capability checks to prevent a user mapping below mmap_min_addr and those will still be honoured even without this fix. Fixes: 484837601d4d ("powerpc/mm: Add radix support for hugetlb") Reviewed-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05powerpc/xmon: Fix opcode being uninitialized in print_insn_powerpcNathan Chancellor
[ Upstream commit e7140639b1de65bba435a6bd772d134901141f86 ] When building with -Wsometimes-uninitialized, Clang warns: arch/powerpc/xmon/ppc-dis.c:157:7: warning: variable 'opcode' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized] if (cpu_has_feature(CPU_FTRS_POWER9)) ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ arch/powerpc/xmon/ppc-dis.c:167:7: note: uninitialized use occurs here if (opcode == NULL) ^~~~~~ arch/powerpc/xmon/ppc-dis.c:157:3: note: remove the 'if' if its condition is always true if (cpu_has_feature(CPU_FTRS_POWER9)) ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ arch/powerpc/xmon/ppc-dis.c:132:38: note: initialize the variable 'opcode' to silence this warning const struct powerpc_opcode *opcode; ^ = NULL 1 warning generated. This warning seems to make no sense on the surface because opcode is set to NULL right below this statement. However, there is a comma instead of semicolon to end the dialect assignment, meaning that the opcode assignment only happens in the if statement. Properly terminate that line so that Clang no longer warns. Fixes: 5b102782c7f4 ("powerpc/xmon: Enable disassembly files (compilation changes)") Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Reviewed-by: Nick Desaulniers <ndesaulniers@google.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05powerpc/powernv/ioda: Fix locked_vm counting for memory used by IOMMU tablesAlexey Kardashevskiy
[ Upstream commit 11f5acce2fa43b015a8120fa7620fa4efd0a2952 ] We store 2 multilevel tables in iommu_table - one for the hardware and one with the corresponding userspace addresses. Before allocating the tables, the iommu_table_group_ops::get_table_size() hook returns the combined size of the two and VFIO SPAPR TCE IOMMU driver adjusts the locked_vm counter correctly. When the table is actually allocated, the amount of allocated memory is stored in iommu_table::it_allocated_size and used to decrement the locked_vm counter when we release the memory used by the table; .get_table_size() and .create_table() calculate it independently but the result is expected to be the same. However the allocator does not add the userspace table size to .it_allocated_size so when we destroy the table because of VFIO PCI unplug (i.e. VFIO container is gone but the userspace keeps running), we decrement locked_vm by just a half of size of memory we are releasing. To make things worse, since we enabled on-demand allocation of indirect levels, it_allocated_size contains only the amount of memory actually allocated at the table creation time which can just be a fraction. It is not a problem with incrementing locked_vm (as get_table_size() value is used) but it is with decrementing. As the result, we leak locked_vm and may not be able to allocate more IOMMU tables after few iterations of hotplug/unplug. This sets it_allocated_size in the pnv_pci_ioda2_ops::create_table() hook to what pnv_pci_ioda2_get_table_size() returns so from now on we have a single place which calculates the maximum memory a table can occupy. The original meaning of it_allocated_size is somewhat lost now though. We do not ditch it_allocated_size whatsoever here and we do not call get_table_size() from vfio_iommu_spapr_tce.c when decrementing locked_vm as we may have multiple IOMMU groups per container and even though they all are supposed to have the same get_table_size() implementation, there is a small chance for failure or confusion. Fixes: 090bad39b237 ("powerpc/powernv: Add indirect levels to it_userspace") Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-03powerpc/64: Fix memcmp reading past the end of src/destMichael Ellerman
commit d9470757398a700d9450a43508000bcfd010c7a4 upstream. Chandan reported that fstests' generic/026 test hit a crash: BUG: Unable to handle kernel data access at 0xc00000062ac40000 Faulting instruction address: 0xc000000000092240 Oops: Kernel access of bad area, sig: 11 [#1] LE SMP NR_CPUS=2048 DEBUG_PAGEALLOC NUMA pSeries CPU: 0 PID: 27828 Comm: chacl Not tainted 5.0.0-rc2-next-20190115-00001-g6de6dba64dda #1 NIP: c000000000092240 LR: c00000000066a55c CTR: 0000000000000000 REGS: c00000062c0c3430 TRAP: 0300 Not tainted (5.0.0-rc2-next-20190115-00001-g6de6dba64dda) MSR: 8000000002009033 <SF,VEC,EE,ME,IR,DR,RI,LE> CR: 44000842 XER: 20000000 CFAR: 00007fff7f3108ac DAR: c00000062ac40000 DSISR: 40000000 IRQMASK: 0 GPR00: 0000000000000000 c00000062c0c36c0 c0000000017f4c00 c00000000121a660 GPR04: c00000062ac3fff9 0000000000000004 0000000000000020 00000000275b19c4 GPR08: 000000000000000c 46494c4500000000 5347495f41434c5f c0000000026073a0 GPR12: 0000000000000000 c0000000027a0000 0000000000000000 0000000000000000 GPR16: 0000000000000000 0000000000000000 0000000000000000 0000000000000000 GPR20: c00000062ea70020 c00000062c0c38d0 0000000000000002 0000000000000002 GPR24: c00000062ac3ffe8 00000000275b19c4 0000000000000001 c00000062ac30000 GPR28: c00000062c0c38d0 c00000062ac30050 c00000062ac30058 0000000000000000 NIP memcmp+0x120/0x690 LR xfs_attr3_leaf_lookup_int+0x53c/0x5b0 Call Trace: xfs_attr3_leaf_lookup_int+0x78/0x5b0 (unreliable) xfs_da3_node_lookup_int+0x32c/0x5a0 xfs_attr_node_addname+0x170/0x6b0 xfs_attr_set+0x2ac/0x340 __xfs_set_acl+0xf0/0x230 xfs_set_acl+0xd0/0x160 set_posix_acl+0xc0/0x130 posix_acl_xattr_set+0x68/0x110 __vfs_setxattr+0xa4/0x110 __vfs_setxattr_noperm+0xac/0x240 vfs_setxattr+0x128/0x130 setxattr+0x248/0x600 path_setxattr+0x108/0x120 sys_setxattr+0x28/0x40 system_call+0x5c/0x70 Instruction dump: 7d201c28 7d402428 7c295040 38630008 38840008 408201f0 4200ffe8 2c050000 4182ff6c 20c50008 54c61838 7d201c28 <7d402428> 7d293436 7d4a3436 7c295040 The instruction dump decodes as: subfic r6,r5,8 rlwinm r6,r6,3,0,28 ldbrx r9,0,r3 ldbrx r10,0,r4 <- Which shows us doing an 8 byte load from c00000062ac3fff9, which crosses the page boundary at c00000062ac40000 and faults. It's not OK for memcmp to read past the end of the source or destination buffers if that would cross a page boundary, because we don't know that the next page is mapped. As pointed out by Segher, we can read past the end of the source or destination as long as we don't cross a 4K boundary, because that's our minimum page size on all platforms. The bug is in the code at the .Lcmp_rest_lt8bytes label. When we get there we know that s1 is 8-byte aligned and we have at least 1 byte to read, so a single 8-byte load won't read past the end of s1 and cross a page boundary. But we have to be more careful with s2. So check if it's within 8 bytes of a 4K boundary and if so go to the byte-by-byte loop. Fixes: 2d9ee327adce ("powerpc/64: Align bytes before fall back to .Lshort in powerpc64 memcmp()") Cc: stable@vger.kernel.org # v4.19+ Reported-by: Chandan Rajendra <chandan@linux.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Reviewed-by: Segher Boessenkool <segher@kernel.crashing.org> Tested-by: Chandan Rajendra <chandan@linux.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03powerpc/pseries/energy: Use OF accessor functions to read ibm,drc-indexesGautham R. Shenoy
commit ce9afe08e71e3f7d64f337a6e932e50849230fc2 upstream. In cpu_to_drc_index() in the case when FW_FEATURE_DRC_INFO is absent, we currently use of_read_property() to obtain the pointer to the array corresponding to the property "ibm,drc-indexes". The elements of this array are of type __be32, but are accessed without any conversion to the OS-endianness, which is buggy on a Little Endian OS. Fix this by using of_property_read_u32_index() accessor function to safely read the elements of the array. Fixes: e83636ac3334 ("pseries/drc-info: Search DRC properties for CPU indexes") Cc: stable@vger.kernel.org # v4.16+ Reported-by: Pavithra R. Prakash <pavrampu@in.ibm.com> Signed-off-by: Gautham R. Shenoy <ego@linux.vnet.ibm.com> Reviewed-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> [mpe: Make the WARN_ON a WARN_ON_ONCE so it's not retriggerable] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03powerpc: bpf: Fix generation of load/store DW instructionsNaveen N. Rao
commit 86be36f6502c52ddb4b85938145324fd07332da1 upstream. Yauheni Kaliuta pointed out that PTR_TO_STACK store/load verifier test was failing on powerpc64 BE, and rightfully indicated that the PPC_LD() macro is not masking away the last two bits of the offset per the ISA, resulting in the generation of 'lwa' instruction instead of the intended 'ld' instruction. Segher also pointed out that we can't simply mask away the last two bits as that will result in loading/storing from/to a memory location that was not intended. This patch addresses this by using ldx/stdx if the offset is not word-aligned. We load the offset into a temporary register (TMP_REG_2) and use that as the index register in a subsequent ldx/stdx. We fix PPC_LD() macro to mask off the last two bits, but enhance PPC_BPF_LL() and PPC_BPF_STL() to factor in the offset value and generate the proper instruction sequence. We also convert all existing users of PPC_LD() and PPC_STD() to use these macros. All existing uses of these macros have been audited to ensure that TMP_REG_2 can be clobbered. Fixes: 156d0e290e96 ("powerpc/ebpf/jit: Implement JIT compiler for extended BPF") Cc: stable@vger.kernel.org # v4.9+ Reported-by: Yauheni Kaliuta <yauheni.kaliuta@redhat.com> Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03powerpc/security: Fix spectre_v2 reportingMichael Ellerman
commit 92edf8df0ff2ae86cc632eeca0e651fd8431d40d upstream. When I updated the spectre_v2 reporting to handle software count cache flush I got the logic wrong when there's no software count cache enabled at all. The result is that on systems with the software count cache flush disabled we print: Mitigation: Indirect branch cache disabled, Software count cache flush Which correctly indicates that the count cache is disabled, but incorrectly says the software count cache flush is enabled. The root of the problem is that we are trying to handle all combinations of options. But we know now that we only expect to see the software count cache flush enabled if the other options are false. So split the two cases, which simplifies the logic and fixes the bug. We were also missing a space before "(hardware accelerated)". The result is we see one of: Mitigation: Indirect branch serialisation (kernel only) Mitigation: Indirect branch cache disabled Mitigation: Software count cache flush Mitigation: Software count cache flush (hardware accelerated) Fixes: ee13cb249fab ("powerpc/64s: Add support for software count cache flush") Cc: stable@vger.kernel.org # v4.19+ Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Reviewed-by: Michael Neuling <mikey@neuling.org> Reviewed-by: Diana Craciun <diana.craciun@nxp.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03powerpc/fsl: Fix the flush of branch predictor.Christophe Leroy
commit 27da80719ef132cf8c80eb406d5aeb37dddf78cc upstream. The commit identified below adds MC_BTB_FLUSH macro only when CONFIG_PPC_FSL_BOOK3E is defined. This results in the following error on some configs (seen several times with kisskb randconfig_defconfig) arch/powerpc/kernel/exceptions-64e.S:576: Error: Unrecognized opcode: `mc_btb_flush' make[3]: *** [scripts/Makefile.build:367: arch/powerpc/kernel/exceptions-64e.o] Error 1 make[2]: *** [scripts/Makefile.build:492: arch/powerpc/kernel] Error 2 make[1]: *** [Makefile:1043: arch/powerpc] Error 2 make: *** [Makefile:152: sub-make] Error 2 This patch adds a blank definition of MC_BTB_FLUSH for other cases. Fixes: 10c5e83afd4a ("powerpc/fsl: Flush the branch predictor at each kernel entry (64bit)") Cc: Diana Craciun <diana.craciun@nxp.com> Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Reviewed-by: Daniel Axtens <dja@axtens.net> Reviewed-by: Diana Craciun <diana.craciun@nxp.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03powerpc/fsl: Fixed warning: orphan section `__btb_flush_fixup'Diana Craciun
commit 039daac5526932ec731e4499613018d263af8b3e upstream. Fixed the following build warning: powerpc-linux-gnu-ld: warning: orphan section `__btb_flush_fixup' from `arch/powerpc/kernel/head_44x.o' being placed in section `__btb_flush_fixup'. Signed-off-by: Diana Craciun <diana.craciun@nxp.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03powerpc/fsl: Update Spectre v2 reportingDiana Craciun
commit dfa88658fb0583abb92e062c7a9cd5a5b94f2a46 upstream. Report branch predictor state flush as a mitigation for Spectre variant 2. Signed-off-by: Diana Craciun <diana.craciun@nxp.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03powerpc/fsl: Enable runtime patching if nospectre_v2 boot arg is usedDiana Craciun
commit 3bc8ea8603ae4c1e09aca8de229ad38b8091fcb3 upstream. If the user choses not to use the mitigations, replace the code sequence with nops. Signed-off-by: Diana Craciun <diana.craciun@nxp.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03powerpc/fsl: Flush branch predictor when entering KVMDiana Craciun
commit e7aa61f47b23afbec41031bc47ca8d6cb6516abc upstream. Switching from the guest to host is another place where the speculative accesses can be exploited. Flush the branch predictor when entering KVM. Signed-off-by: Diana Craciun <diana.craciun@nxp.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03powerpc/fsl: Flush the branch predictor at each kernel entry (32 bit)Diana Craciun
commit 7fef436295bf6c05effe682c8797dfcb0deb112a upstream. In order to protect against speculation attacks on indirect branches, the branch predictor is flushed at kernel entry to protect for the following situations: - userspace process attacking another userspace process - userspace process attacking the kernel Basically when the privillege level change (i.e.the kernel is entered), the branch predictor state is flushed. Signed-off-by: Diana Craciun <diana.craciun@nxp.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
