per cpu data section contains two types of data. One set which is
exclusively accessed by the local cpu and the other set which is per cpu,
but also shared by remote cpus. In the current kernel, these two sets are
not clearely separated out. This can potentially cause the same data
cacheline shared between the two sets of data, which will result in
unnecessary bouncing of the cacheline between cpus.
One way to fix the problem is to cacheline align the remotely accessed per
cpu data, both at the beginning and at the end. Because of the padding at
both ends, this will likely cause some memory wastage and also the
interface to achieve this is not clean.
This patch:
Moves the remotely accessed per cpu data (which is currently marked
as ____cacheline_aligned_in_smp) into a different section, where all the data
elements are cacheline aligned. And as such, this differentiates the local
only data and remotely accessed data cleanly.
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: <linux-arch@vger.kernel.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@suse.de>
I realise jprobes are a razor-blades-included type of interface, but that
doesn't mean we can't try and make them safer to use. This guy I know once
wrote code like this:
struct jprobe jp = { .kp.symbol_name = "foo", .entry = "jprobe_foo" };
And then his kernel exploded. Oops.
This patch adds an arch hook, arch_deref_entry_point() (I don't like it
either) which takes the void * in a struct jprobe, and gives back the text
address that it represents.
We can then use that in register_jprobe() to check that the entry point we're
passed is actually in the kernel text, rather than just some random value.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com>
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
This patch completes Linus's wish that the fault return codes be made into
bit flags, which I agree makes everything nicer. This requires requires
all handle_mm_fault callers to be modified (possibly the modifications
should go further and do things like fault accounting in handle_mm_fault --
however that would be for another patch).
[akpm@linux-foundation.org: fix alpha build]
[akpm@linux-foundation.org: fix s390 build]
[akpm@linux-foundation.org: fix sparc build]
[akpm@linux-foundation.org: fix sparc64 build]
[akpm@linux-foundation.org: fix ia64 build]
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Ian Molton <spyro@f2s.com>
Cc: Bryan Wu <bryan.wu@analog.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Matthew Wilcox <willy@debian.org>
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Cc: Richard Curnow <rc@rc0.org.uk>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
Cc: Chris Zankel <chris@zankel.net>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Andi Kleen <ak@muc.de>
[ Still apparently needs some ARM and PPC loving - Linus ]
The TSEC/eTSEC can detect the interface to the PHY automatically,
but it isn't able to detect whether the RGMII connection needs internal
delay. So we need to detect that change in the device tree, propagate
it to the platform data, and then check it if we're in RGMII. This fixes
a bug on the 8641D HPCN board where the Vitesse PHY doesn't use the delay
for RGMII.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The TSEC/eTSEC automatically detect their PHY interface type, unless
the type is RGMII-ID (RGMII with internal delay). In that situation,
it just detects RGMII. In order to fix this, we need to pass in rgmii-id
if that is the connection type.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: extent macros cleanup
Fix compilation with EXT_DEBUG, also fix leXX_to_cpu conversions.
ext4: remove extra IS_RDONLY() check
ext4: Use is_power_of_2()
Use zero_user_page() in ext4 where possible
ext4: Remove 65000 subdirectory limit
ext4: Expand extra_inodes space per the s_{want,min}_extra_isize fields
ext4: Add nanosecond timestamps
jbd2: Move jbd2-debug file to debugfs
jbd2: Fix CONFIG_JBD_DEBUG ifdef to be CONFIG_JBD2_DEBUG
ext4: Set the journal JBD2_FEATURE_INCOMPAT_64BIT on large devices
ext4: Make extents code sanely handle on-disk corruption
ext4: copy i_flags to inode flags on write
ext4: Enable extents by default
Change on-disk format to support 2^15 uninitialized extents
write support for preallocated blocks
fallocate support in ext4
sys_fallocate() implementation on i386, x86_64 and powerpc
This reverts commit 5a26f6bbb767d7ad23311a1e81cfdd2bebefb855.
The original patch causes boot failures when built with ppc64_defconfig. The
quickest fix is to revert it while alterates are investigated.
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
This fixes the fallout from the recent powerpc merge (commit
489de30259e667d7bc47da9da44a0270b050cd97):
CC arch/powerpc/kernel/pci-common.o
arch/powerpc/kernel/pci-common.c:160: error: conflicting types for 'pcibios_add_platform_entries'
include/linux/pci.h:889: error: previous declaration of 'pcibios_add_platform_entries' was here
Tested-by: Bret Towe <magnade@gmail.com>
fallocate() is a new system call being proposed here which will allow
applications to preallocate space to any file(s) in a file system.
Each file system implementation that wants to use this feature will need
to support an inode operation called ->fallocate().
Applications can use this feature to avoid fragmentation to certain
level and thus get faster access speed. With preallocation, applications
also get a guarantee of space for particular file(s) - even if later the
the system becomes full.
Currently, glibc provides an interface called posix_fallocate() which
can be used for similar cause. Though this has the advantage of working
on all file systems, but it is quite slow (since it writes zeroes to
each block that has to be preallocated). Without a doubt, file systems
can do this more efficiently within the kernel, by implementing
the proposed fallocate() system call. It is expected that
posix_fallocate() will be modified to call this new system call first
and incase the kernel/filesystem does not implement it, it should fall
back to the current implementation of writing zeroes to the new blocks.
ToDos:
1. Implementation on other architectures (other than i386, x86_64,
and ppc). Patches for s390(x) and ia64 are already available from
previous posts, but it was decided that they should be added later
once fallocate is in the mainline. Hence not including those patches
in this take.
2. Changes to glibc,
a) to support fallocate() system call
b) to make posix_fallocate() and posix_fallocate64() call fallocate()
Signed-off-by: Amit Arora <aarora@in.ibm.com>
Let spu_management_ops.enumerate_spus() return the number of found SPEs
and use that information to draw some little helper penguin logos.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Acked-By: James Simmons <jsimmons@infradead.org>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Based on usage and testing over the past couple of years, kprobes on
i386, ia64, powerpc and x86_64 is no longer EXPERIMENTAL.
This is a follow-up to Robert P.J. Day's patch making "Instrumentation
support" non-EXPERIMENTAL:
http://marc.info/?l=linux-kernel&m=118396955423812&w=2
Arch maintainers for sparc64, avr32 and s390 need to take a similar call.
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Identical implementations of PTRACE_POKEDATA go into generic_ptrace_pokedata()
function.
AFAICS, fix bug on xtensa where successful PTRACE_POKEDATA will nevertheless
return EPERM.
Identical implementations of PTRACE_PEEKDATA go into generic_ptrace_peekdata()
function.
If the kernel OOPSed or BUGed then it probably should be considered as
tainted. Thus, all subsequent OOPSes and SysRq dumps will report the
tainted kernel. This saves a lot of time explaining oddities in the
calltraces.
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
[ Added parisc patch from Matthew Wilson -Linus ]
Rolling forward PCMCIA driver, it was discovered that the indentation in
existing one, as well as in BSP side are very odd. This patch is just result
of Lindent run ontop of culprit files.
Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org>
Cc: Olof Johansson <olof@lixom.net>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Kumar Gala <galak@gate.crashing.org>
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (209 commits)
[POWERPC] Create add_rtc() function to enable the RTC CMOS driver
[POWERPC] Add H_ILLAN_ATTRIBUTES hcall number
[POWERPC] xilinxfb: Parameterize xilinxfb platform device registration
[POWERPC] Oprofile support for Power 5++
[POWERPC] Enable arbitary speed tty ioctls and split input/output speed
[POWERPC] Make drivers/char/hvc_console.c:khvcd() static
[POWERPC] Remove dead code for preventing pread() and pwrite() calls
[POWERPC] Remove unnecessary #undef printk from prom.c
[POWERPC] Fix typo in Ebony default DTS
[POWERPC] Check for NULL ppc_md.init_IRQ() before calling
[POWERPC] Remove extra return statement
[POWERPC] pasemi: Don't auto-select CONFIG_EMBEDDED
[POWERPC] pasemi: Rename platform
[POWERPC] arch/powerpc/kernel/sysfs.c: Move NUMA exports
[POWERPC] Add __read_mostly support for powerpc
[POWERPC] Modify sched_clock() to make CONFIG_PRINTK_TIME more sane
[POWERPC] Create a dummy zImage if no valid platform has been selected
[POWERPC] PS3: Bootwrapper support.
[POWERPC] powermac i2c: Use mutex
[POWERPC] Schedule removal of arch/ppc
Fixed up conflicts manually in:
Documentation/feature-removal-schedule.txt
arch/powerpc/kernel/pci_32.c
arch/powerpc/kernel/pci_64.c
include/asm-powerpc/pci.h
and asked the powerpc people to double-check the result..
The current generic bug implementation has a call to dump_stack() in case a
WARN_ON(whatever) gets hit. Since report_bug(), which calls dump_stack(),
gets called from an exception handler we can do better: just pass the
pt_regs structure to report_bug() and pass it to show_regs() in case of a
warning. This will give more debug informations like register contents,
etc... In addition this avoids some pointless lines that dump_stack()
emits, since it includes a stack backtrace of the exception handler which
is of no interest in case of a warning. E.g. on s390 the following lines
are currently always present in a stack backtrace if dump_stack() gets
called from report_bug():
[<000000000001517a>] show_trace+0x92/0xe8)
[<0000000000015270>] show_stack+0xa0/0xd0
[<00000000000152ce>] dump_stack+0x2e/0x3c
[<0000000000195450>] report_bug+0x98/0xf8
[<0000000000016cc8>] illegal_op+0x1fc/0x21c
[<00000000000227d6>] sysc_return+0x0/0x10
Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
Cc: Kyle McMartin <kyle@parisc-linux.org>
Make some offending drivers depend on it and set CONFIG_ARCH_NO_VIRT_TO_BUS
for ppc64 so that we don't build those drivers.
This gets PowerPC allmodconfig and allyesconfig much closer to building.
Cc: Al Viro <viro@ftp.linux.org.uk>
Acked-by: David Miller <davem@davemloft.net>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
The PCI syscalls are built on every architecture except X86, but only
a few have ever hooked them up. Use a new Kconfig symbol to save a
couple of kB on the architectures that have never used the syscalls.
Tested on x86 and ia64 only.
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Currently there are 97 occurrences where drivers need the pci
revision ID. We can do this once for all devices. Even the pci
subsystem needs the revision several times for quirks. The extra
u8 member pads out nicely in the pci_dev struct.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Currently pcibios_add_platform_entries() returns void, but could fail,
so instead have it return an int and propagate errors up to
pci_create_sysfs_dev_files().
Fixes:
arch/powerpc/kernel/pci_64.c: In function 'pcibios_add_platform_entries':
arch/powerpc/kernel/pci_64.c:878: warning: ignoring return value of
'device_create_file', declared with attribute warn_unused_result
arch/powerpc/kernel/pci_32.c: In function 'pcibios_add_platform_entries':
arch/powerpc/kernel/pci_32.c:1043: warning: ignoring return value of
In order to use the RTC CMOS driver, each architecture must register a
platform device for the RTC.
This creates a function to register the platform device based on the RTC
device node and verifies that the RTC port against the hard-coded value
in asm/mc146818rtc.h.
Signed-off-by: Wade Farnsworth <wfarnsworth@mvista.com>
This adds a new oprofile cpu type for Power 5 revision 3 chips.
The new name is ppc64/power5++ and is used so that the performance
counters can be set up correctly.
Signed-off-by: Mike Wolf <mjw@us.ibm.com>
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Signed-off-by: Li Yang <leoli@freescale.com>
Check to make sure ppc_md.init_IRQ has been set before calling it.
Signed-off-by: Sonny Rao <sonny@burdell.org>
Found 2 instances of return one right after each other in
arch_add_memory(). This removes the superfluous one.
Signed-off-by: Manish Ahuja <mahuja@us.ibm.com>
Disable auto-select of CONFIG_EMBEDDED. ELECTRA_IDE selects
PATA_PLATFORM which should be sufficient.
Rename the pasemi platform to "pasemi" to be in line with the
platform's directory name.
With !CONFIG_NUMA, these are static inlines in the header file so
don't generate exports for them in that case.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
When booting a current kernel with CONFIG_PRINTK_TIME enabled you'll
see messages like:
[ 0.000000] time_init: decrementer frequency = 188.044000 MHz
[ 0.000000] time_init: processor frequency = 1504.352000 MHz
[3712914.436297] Console: colour dummy device 80x25
This cause by the initialisation of tb_to_ns_scale in time_init(), suddenly the
multiplication in sched_clock() now does something :). This patch modifies
sched_clock() to report the offset since the machine booted so the same
printk's now look like:
[ 0.000135] Console: colour dummy device 80x25
Effectivly including the uptime in printk()s.
This patch makes tb_to_ns_scale and tb_to_ns_shift static and
read_mostly for good measure.
This simply prevents a build error if no platform is selected.
Add support to build the PS3 flash rom image and remove some unneeded
lmb calls.
The PS3's lv1 loader supports loading gzipped binary images from flash
rom to addr zero. The loader enters the image at addr 0x100.
In this implementation a bootwrapper overlay is use to arrange for the
kernel to be loaded to addr zero and to have a suitable bootwrapper
entry at 0x100. To construct the rom image, 0x100 bytes from offset
0x100 in the kernel is copied to the bootwrapper symbol
__system_reset_kernel. The 0x100 bytes at the bootwrapper symbol
__system_reset_overlay is then copied to offset 0x100. At runtime the
bootwrapper program copies the 0x100 bytes at __system_reset_kernel to
addr 0x100.
zImage.ps3 is a wrapped image that contains a flat device tree, an lv1
compatible entry point, and an optional initrd. otheros.bld is the gzip
compresed rom image built from zImage.ps3. otheros.bld is suitable for
programming into the PS3 boot flash memory.
Convert the semaphores in low_i2c that are used as mutexes to real
mutexes.
Oprofile enhanced instruction sampling support.
When performing instruction sampling, the mmcra[SLOT] field can be used to
more accurately identify the address of the sampled instruction.
Tested on power4, js20, power5 and power5+.
Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com>
cc: Maynard Johnson <maynardj@us.ibm.com>
xmon_early and xmon_off are only used in this file.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
The prom.c debugging code creates a "powerpc" directory in debugfs,
which is nice, but doesn't allow any other debugging code to stick things
under "powerpc" in debugfs. So make it global.
While we're there we should make the prom.c debugging code depend on
CONFIG_DEBUG_FS, because it doesn't work otherwise.
The device tree for the MPC8641 HPCN does not implement the device type
property for I8042 nodes.
In addition to checking the I8042 node's device type, also match the
keyboard and/or mouse nodes' compatible property.
When the refcount for a device node goes to 0, we call the
destructor - of_node_release(). This should only happen if we've
already detached the node from the device tree.
So add a flag OF_DETACHED which tracks detached-ness, and if we
find ourselves in of_node_release() without it set, issue a
warning and don't free the device_node. To avoid warning
continuously reinitialise the kref to a sane value.
The struct device_node currently has a _flags variable, although
it's only used for one flag - OF_DYNAMIC. Generalise the flag
accessors so we can use them with other flags in future.
It's not sensible to call of_detach_node() on the root node,
but we should check for it just to be safe.
When adding the cputable entry for 440SPe Rev. B, we also need to
adjust the existing entries for 440SP Rev. A and 440SPe Rev. B so that
they look more bits of the PVR. The 440SPe Rev. B has PVR 53421891,
which would match the current 440SP Rev. A pattern of 53xxx891. To
distinguish between 440SP and 440SPe, we need to use the first three
digits of the PVR, which are respectively 532 and 534.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
do_signal is never used in modular code (obviously), and no other
architecture exports it either.
Removed explicit linux,phandle usage. Using references and labels now in PQ
and PQ2 boards currently supported in arch/powerpc.
Adds support for PowerQuicc on-chip PCMCIA. The driver is implemented as
of_device, so only arch/powerpc stuff is capable to use it, which now implies
only mpc885ads reference board.
To cope with the code that should be hooked inside driver, but is really board
specific (like set_voltage), global structure mpc8xx_pcmcia_ops holds
necessary function pointers that are filled in the BSP code.
[akpm@linux-foundation.org: whitespace diddles]
Acked-by: Olof Johansson <olof@lixom.net>
Use the eieio function so we can redefine what eieio does rather
than direct inline asm. This is part code clean up and partially
because not all PPCs have eieio (book-e has mbar that maps to eieio).
sparse caught these static functions / __iomem annotations
under arch/powerpc/platform/52xx/
Signed-off-by: Domen Puncer <domen.puncer@telargo.com>
