Merge hch's big DMA rework series. This is in a topic branch in case he
wants to merge it to minimise conflicts.
There is no need to provide anything but get_arch_dma_ops to
<linux/dma-mapping.h>. More the remaining declarations to <asm/iommu.h>
and drop all the includes.
Tested-by: Christian Zigotzky <chzigotzky@xenosoft.de>
There is no good reason for this helper, just opencode it.
Now that we've switched all the powerpc nommu and swiotlb methods to
use the generic dma_direct_* calls we can remove these ops vectors
entirely and rely on the common direct mapping bypass that avoids
indirect function calls entirely. This also allows to remove a whole
lot of boilerplate code related to setting up these operations.
Instead of letting the architecture supply all of dma_set_mask just
give it an additional hook selected by Kconfig.
The max_direct_dma_addr duplicates the bus_dma_mask field in struct
device. Use the generic field instead.
pci_dma_dev_setup_swiotlb is only used by the fsl_pci code, and closely
related to it, so fsl_pci.c seems like a better place for it.
Use the generic iommu bypass code instead of overriding set_dma_mask.
If dart_init failed we didn't have a chance to setup dma or controller
ops yet, so there is no point in resetting them.
There is not point in having a trailing semicolon after a closing curly
brace. Remove it.
Signed-off-by: Mathieu Malaterre <malat@debian.org>
WARN_ON() already contains an unlikely(), so it's not necessary to
wrap it into another.
Signed-off-by: Igor Stoppa <igor.stoppa@huawei.com>
Cc: Arseny Solokha <asolokha@kb.kras.ru>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
ipic_set_highest_priority(), ipic_enable_mcp() and ipic_disable_mcp()
are unused. This patch drops them.
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
We already need to zero out memory for dma_alloc_coherent(), as such
using dma_zalloc_coherent() is superflous. Phase it out.
This change was generated with the following Coccinelle SmPL patch:
@ replace_dma_zalloc_coherent @
expression dev, size, data, handle, flags;
-dma_zalloc_coherent(dev, size, handle, flags)
+dma_alloc_coherent(dev, size, handle, flags)
Suggested-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Luis Chamberlain <mcgrof@kernel.org>
[hch: re-ran the script on the latest tree]
This reverts commit c6e5485e0cb509292a14e880e1944143f99758c7
due to failures such as:
e1000e 2000:01:00.0: Tx DMA map failed
Signed-off-by: Scott Wood <oss@buserror.net>
Fix a spelling mistake in a register description.
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
swiotlb will only bounce buffer when the effective dma address for the
device is smaller than the actual DMA range. Instead of flipping between
the swiotlb and nommu ops for FSL SOCs that have the second outbound
window just don't set the bus dma_mask in this case.
Replaced dma_alloc_coherent + memset with dma_zalloc_coherent
Signed-off-by: Sabyasachi Gupta <sabyasachi.linux@gmail.com>
ipic_set_priority() has been unused since 2006 when the last usage was
removed in commit b9f0f1bb2bca ("[POWERPC] Adapt ipic driver to new
host_ops interface, add set_irq_type to set IRQ sense").
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Today we have:
config PPC_BOOK3S_32
bool "512x/52xx/6xx/7xx/74xx/82xx/83xx/86xx"
[depends on PPC32 within a choice]
config PPC_BOOK3S
def_bool y
depends on PPC_BOOK3S_32 || PPC_BOOK3S_64
config 6xx
def_bool y
depends on PPC32 && PPC_BOOK3S
6xx is therefore redundant with PPC_BOOK3S_32.
In order to make the code clearer, lets use preferably PPC_BOOK3S_32.
This will allow to remove CONFIG_6xx in a later patch.
Function scom_map_device() returns data type 'scom_map_t', which is a
typedef for 'void *'. This functions is currently returning NULL and zero,
which causes the following warning by 'sparse':
arch/powerpc/sysdev/scom.c:63:24: warning: Using plain integer as NULL pointer
arch/powerpc/sysdev/scom.c:86:24: warning: Using plain integer as NULL pointer
This patch simply replaces zero by NULL.
Signed-off-by: Breno Leitao <leitao@debian.org>
Sparse shows that xive_do_source_eoi() file is defined without any
declaration, thus, it should be a static function.
arch/powerpc/sysdev/xive/common.c:312:6: warning: symbol 'xive_do_source_eoi' was not declared. Should it be static?
This patch simply turns this symbol into static.
When a memblock allocation APIs are called with align = 0, the alignment
is implicitly set to SMP_CACHE_BYTES.
Implicit alignment is done deep in the memblock allocator and it can
come as a surprise. Not that such an alignment would be wrong even
when used incorrectly but it is better to be explicit for the sake of
clarity and the prinicple of the least surprise.
Replace all such uses of memblock APIs with the 'align' parameter
explicitly set to SMP_CACHE_BYTES and stop implicit alignment assignment
in the memblock internal allocation functions.
For the case when memblock APIs are used via helper functions, e.g. like
iommu_arena_new_node() in Alpha, the helper functions were detected with
Coccinelle's help and then manually examined and updated where
appropriate.
The direct memblock APIs users were updated using the semantic patch below:
expression size, min_addr, max_addr, nid;
- memblock_alloc_try_nid_raw(size, 0, min_addr, max_addr, nid)
+ memblock_alloc_try_nid_raw(size, SMP_CACHE_BYTES, min_addr, max_addr,
nid)
- memblock_alloc_try_nid_nopanic(size, 0, min_addr, max_addr, nid)
+ memblock_alloc_try_nid_nopanic(size, SMP_CACHE_BYTES, min_addr, max_addr,
nid)
- memblock_alloc_try_nid(size, 0, min_addr, max_addr, nid)
+ memblock_alloc_try_nid(size, SMP_CACHE_BYTES, min_addr, max_addr, nid)
- memblock_alloc(size, 0)
+ memblock_alloc(size, SMP_CACHE_BYTES)
- memblock_alloc_raw(size, 0)
+ memblock_alloc_raw(size, SMP_CACHE_BYTES)
- memblock_alloc_from(size, 0, min_addr)
+ memblock_alloc_from(size, SMP_CACHE_BYTES, min_addr)
- memblock_alloc_nopanic(size, 0)
+ memblock_alloc_nopanic(size, SMP_CACHE_BYTES)
- memblock_alloc_low(size, 0)
+ memblock_alloc_low(size, SMP_CACHE_BYTES)
- memblock_alloc_low_nopanic(size, 0)
+ memblock_alloc_low_nopanic(size, SMP_CACHE_BYTES)
- memblock_alloc_from_nopanic(size, 0, min_addr)
+ memblock_alloc_from_nopanic(size, SMP_CACHE_BYTES, min_addr)
- memblock_alloc_node(size, 0, nid)
+ memblock_alloc_node(size, SMP_CACHE_BYTES, nid)
[mhocko@suse.com: changelog update]
[rppt@linux.ibm.com: fix missed uses of implicit alignment]
Link: http://lkml.kernel.org/r/20181016133656.GA10925@rapoport-lnx
Link: http://lkml.kernel.org/r/1538687224-17535-1-git-send-email-rppt@linux.vnet.ibm.com
Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
Suggested-by: Michal Hocko <mhocko@suse.com>
Acked-by: Paul Burton <paul.burton@mips.com> [MIPS]
Acked-by: Michael Ellerman <mpe@ellerman.id.au> [powerpc]
Cc: Chris Zankel <chris@zankel.net>
Cc: Guan Xuetao <gxt@pku.edu.cn>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Russell King <linux@armlinux.org.uk>
Move remaining definitions and declarations from include/linux/bootmem.h
into include/linux/memblock.h and remove the redundant header.
The includes were replaced with the semantic patch below and then
semi-automated removal of duplicated '#include <linux/memblock.h>
- #include <linux/bootmem.h>
+ #include <linux/memblock.h>
[sfr@canb.auug.org.au: dma-direct: fix up for the removal of linux/bootmem.h]
Link: http://lkml.kernel.org/r/20181002185342.133d1680@canb.auug.org.au
[sfr@canb.auug.org.au: powerpc: fix up for removal of linux/bootmem.h]
Link: http://lkml.kernel.org/r/20181005161406.73ef8727@canb.auug.org.au
[sfr@canb.auug.org.au: x86/kaslr, ACPI/NUMA: fix for linux/bootmem.h removal]
Link: http://lkml.kernel.org/r/20181008190341.5e396491@canb.auug.org.au
Link: http://lkml.kernel.org/r/1536927045-23536-30-git-send-email-rppt@linux.vnet.ibm.com
Cc: Greentime Hu <green.hu@gmail.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Palmer Dabbelt <palmer@sifive.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Rich Felker <dalias@libc.org>
Cc: Serge Semin <fancer.lancer@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
The conversion is done using
sed -i 's@memblock_virt_alloc@memblock_alloc@g' \
$(git grep -l memblock_virt_alloc)
Link: http://lkml.kernel.org/r/1536927045-23536-8-git-send-email-rppt@linux.vnet.ibm.com
Cc: Michal Hocko <mhocko@suse.com>
Make it explicit that the caller gets a physical address rather than a
virtual one.
This will also allow using meblock_alloc prefix for memblock allocations
returning virtual address, which is done in the following patches.
The conversion is done using the following semantic patch:
expression e1, e2, e3;
- memblock_alloc(e1, e2)
+ memblock_phys_alloc(e1, e2)
- memblock_alloc_nid(e1, e2, e3)
+ memblock_phys_alloc_nid(e1, e2, e3)
- memblock_alloc_try_nid(e1, e2, e3)
+ memblock_phys_alloc_try_nid(e1, e2, e3)
Link: http://lkml.kernel.org/r/1536927045-23536-7-git-send-email-rppt@linux.vnet.ibm.com
ipic_get_mcp_status() is used by targets implementing NMI
watchdog in target specific machine check handler in order
to known whether a machine check results from a watchdog
NMI reset.
In case of very early machine check, primary_ipic pointer
might not have been set yet, so ipic_get_mcp_status() needs
to check it for nullity before using it.
Back when I added -Werror in commit ba55bd74360e ("powerpc: Add
configurable -Werror for arch/powerpc") I did it by adding it to most
of the arch Makefiles.
At the time we excluded math-emu, because apparently it didn't build
cleanly. But that seems to have been fixed somewhere in the interim.
So move the -Werror addition to the top-level of the arch, this saves
us from repeating it in every Makefile and means we won't forget to
add it to any new sub-dirs.
In many places, ioremap_prot() and __ioremap() can be replaced with
higher level functions like ioremap(), ioremap_coherent(),
ioremap_cache(), ioremap_wc() ...
'default n' is the default value for any bool or tristate Kconfig
setting so there is no need to write it explicitly.
Also since commit f467c5640c29 ("kconfig: only write '# CONFIG_FOO
is not set' for visible symbols") the Kconfig behavior is the same
regardless of 'default n' being present or not:
One side effect of (and the main motivation for) this change is making
the following two definitions behave exactly the same:
config FOO
bool
config FOO
bool
default n
With this change, neither of these will generate a
'# CONFIG_FOO is not set' line (assuming FOO isn't selected/implied).
That might make it clearer to people that a bare 'default n' is
redundant.
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Move the dereference of xc below the NULL test.
Signed-off-by: zhong jiang <zhongjiang@huawei.com>
Function xive_native_get_ipi() might use chip_id without it being
initialized, if the CPU node is not found, as reported by smatch:
error: uninitialized symbol 'chip_id'
As suggested by Cédric, we can use xc->chip_id instead of consulting
the device tree for chip id, which is safe since xive_prepare_cpu()
should have initialized ->chip_id by the time xive_native_get_ipi() is
called.
Reviewed-by: Cédric Le Goater <clg@kaod.org>
[mpe: Tweak change log]
Also add these typos to spelling.txt so checkpatch.pl will look for them.
Link: http://lkml.kernel.org/r/88af06b9de34d870cb0afc46cfd24e0458be2575.1529471371.git.fthain@telegraphics.com.au
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
Cc: Joe Perches <joe@perches.com>
commit e8cb7a55eb8dc ("powerpc: remove superflous inclusions of
asm/fixmap.h") removed inclusion of asm/fixmap.h from files not
including objects from that file.
However, asm/mmu-8xx.h includes call to __fix_to_virt(). The proper
way would be to include asm/fixmap.h in asm/mmu-8xx.h but it creates
an inclusion loop.
So we have to leave asm/fixmap.h in sysdep/cpm_common.c for
CONFIG_PPC_EARLY_DEBUG_CPM
CC arch/powerpc/sysdev/cpm_common.o
In file included from ./arch/powerpc/include/asm/mmu.h:340:0,
from ./arch/powerpc/include/asm/reg_8xx.h:8,
from ./arch/powerpc/include/asm/reg.h:29,
from ./arch/powerpc/include/asm/processor.h:13,
from ./arch/powerpc/include/asm/thread_info.h:28,
from ./include/linux/thread_info.h:38,
from ./arch/powerpc/include/asm/ptrace.h:159,
from ./arch/powerpc/include/asm/hw_irq.h:12,
from ./arch/powerpc/include/asm/irqflags.h:12,
from ./include/linux/irqflags.h:16,
from ./include/asm-generic/cmpxchg-local.h:6,
from ./arch/powerpc/include/asm/cmpxchg.h:537,
from ./arch/powerpc/include/asm/atomic.h:11,
from ./include/linux/atomic.h:5,
from ./include/linux/mutex.h:18,
from ./include/linux/kernfs.h:13,
from ./include/linux/sysfs.h:16,
from ./include/linux/kobject.h:20,
from ./include/linux/device.h:16,
from ./include/linux/node.h:18,
from ./include/linux/cpu.h:17,
from ./include/linux/of_device.h:5,
from arch/powerpc/sysdev/cpm_common.c:21:
arch/powerpc/sysdev/cpm_common.c: In function ‘udbg_init_cpm’:
./arch/powerpc/include/asm/mmu-8xx.h:218:25: error: implicit declaration of function ‘__fix_to_virt’ [-Werror=implicit-function-declaration]
#define VIRT_IMMR_BASE (__fix_to_virt(FIX_IMMR_BASE))
arch/powerpc/sysdev/cpm_common.c:75:7: note: in expansion of macro ‘VIRT_IMMR_BASE’
VIRT_IMMR_BASE);
./arch/powerpc/include/asm/mmu-8xx.h:218:39: error: ‘FIX_IMMR_BASE’ undeclared (first use in this function)
VIRT_IMMR_BASE);
./arch/powerpc/include/asm/mmu-8xx.h:218:39: note: each undeclared identifier is reported only once for each function it appears in
VIRT_IMMR_BASE);
cc1: all warnings being treated as errors
make[1]: *** [arch/powerpc/sysdev/cpm_common.o] Error 1
Fixes: e8cb7a55eb8dc ("powerpc: remove superflous inclusions of asm/fixmap.h")
The problem is the the calculation should be "end - start + 1" but the
plus one is missing in this calculation.
Fixes: 8626816e905e ("powerpc: add support for MPIC message register API")
Reviewed-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
In Makefiles if we're testing a CONFIG_FOO symbol for equality with 'y'
we can instead just use ifdef. The latter reads easily, so convert to
it where possible.
Signed-off-by: Rodrigo R. Galvao <rosattig@linux.vnet.ibm.com>
Reviewed-by: Mauro S. M. Rodrigues <maurosr@linux.vnet.ibm.com>
It's identical to xive_teardown_cpu() so just use the latter
Those overly verbose statement in the setup of the pool VP
aren't particularly useful (esp. considering we don't actually
use the pool, we configure it bcs HW requires it only). So
remove them which improves the code readability.
asm/tlbflush.h is only needed for:
- using functions xxx_flush_tlb_xxx()
- using MMU_NO_CONTEXT
- including asm-generic/pgtable.h
Files not using fixmap consts or functions don't need asm/fixmap.h
Update the comment to account for the spurious interrupt number. The
code was already accounting for it, but that was unclear because it
was achieved by mpic_setup_error_int() knowing that the number it was
passed was the last used vector, rather than the first free vector.
So change the meaning of the argument to the first free vector and
update the caller to pass 13, instead of 12, to achieve the same
result.
Signed-off-by: Bharat Bhushan <Bharat.Bhushan@nxp.com>
[mpe: Rewrite change log]
Merge in some commits we're sharing with the KVM tree.
I manually propagated the change from commit d3d4ffaae439
("powerpc/powernv/ioda2: Reduce upper limit for DMA window size") into
pci-ioda-tce.c.
arch/powerpc/include/asm/cputable.h
arch/powerpc/platforms/powernv/pci-ioda.c
arch/powerpc/platforms/powernv/pci.h
POWER9 DD1 was never a product. It is no longer supported by upstream
firmware, and it is not effectively supported in Linux due to lack of
testing.
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Reviewed-by: Michael Ellerman <mpe@ellerman.id.au>
[mpe: Remove arch_make_huge_pte() entirely]
Replace msleep(x) with with msleep(OPAL_BUSY_DELAY_MS) to document
these sleeps are to wait for opal (firmware).
Signed-off-by: Daniel Klamt <eleon@ele0n.de>
Signed-off-by: Bjoern Noetel <bjoern@br3ak3r.de>
In the quest to remove all stack VLA usage from the kernel[1], this
switches from an unchanging variable to a constant expression to
eliminate the VLA generation.
[1] https://lkml.kernel.org/r/CA+55aFzCG-zNmZwX4A2FQpadafLfEzK6CC=qPXydAacU1RqZWA@mail.gmail.com
The kzalloc() function has a 2-factor argument form, kcalloc(). This
patch replaces cases of:
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
as well as handling cases of:
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kzalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(u8) * COUNT
+ COUNT
kzalloc(
- sizeof(__u8) * COUNT
+ COUNT
kzalloc(
- sizeof(char) * COUNT
+ COUNT
kzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_CONST
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kzalloc(
- sizeof(TYPE) * COUNT * STRIDE
kzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kzalloc(
- sizeof(THING) * (COUNT) * STRIDE
kzalloc(
- sizeof(THING) * COUNT * (STRIDE)
kzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kzalloc(
- COUNT * (STRIDE) * SIZE
kzalloc(
- COUNT * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * SIZE
kzalloc(
- COUNT * (STRIDE) * (SIZE)
kzalloc(
- (COUNT) * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * (SIZE)
kzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
The kmalloc() function has a 2-factor argument form, kmalloc_array(). This
kmalloc(a * b, gfp)
with:
kmalloc_array(a * b, gfp)
kmalloc(a * b * c, gfp)
with:
kmalloc(array3_size(a, b, c), gfp)
kmalloc_array(array_size(a, b), c, gfp)
kmalloc(4 * 1024, gfp)
The tools/ directory was manually excluded, since it has its own
implementation of kmalloc().
type TYPE;
kmalloc(
+ sizeof(TYPE) * E
kmalloc(
+ sizeof(THING) * E
expression COUNT;
typedef u8;
typedef __u8;
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
type TYPE;
expression THING;
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- SIZE * COUNT
+ COUNT, SIZE
expression THING;
type TYPE;
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
identifier COUNT;
type TYPE1, TYPE2;
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(C1 * C2 * C3, ...)
kmalloc(
- (E1) * E2 * E3
kmalloc(
- (E1) * (E2) * E3
kmalloc(
kmalloc(
- E1 * E2 * E3
type TYPE;
kmalloc(sizeof(THING) * C2, ...)
kmalloc(sizeof(TYPE) * C2, ...)
kmalloc(C1 * C2, ...)
- kmalloc
+ kmalloc_array
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- (E1) * E2
+ E1, E2
- kmalloc
+ kmalloc_array
- (E1) * (E2)
+ E1, E2
- kmalloc
+ kmalloc_array
- E1 * E2
+ E1, E2
There are no longer any platforms that use Marvell's mv64x60
hostbridges so remove the supporting kernel code.
CC: Dale Farnsworth <dale@farnsworth.org>
Signed-off-by: Mark Greer <mgreer@animalcreek.com>
The device node obtained with of_find_compatible_node() should be
released by calling of_node_put(). But it was not released when
of_get_property() failed.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
[mpe: Invert the sense of the if so we only need one return path]
Structure platform_driver does not need to set the owner field, as this
will be populated by the driver core.
Generated by scripts/coccinelle/api/platform_no_drv_owner.cocci.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
The GETFIELD and SETFIELD macros in xive-regs.h aren't used except for
a single instance of GETFIELD, so replace that and remove them.
These macros are also defined in vas.h, so either those should be
eventually replaced or the macros moved into bitops.h.
Signed-off-by: Russell Currey <ruscur@russell.cc>
[mpe: Rewrite the assignment to 'he' to avoid ffs() etc.]
