FSL PCIe controller v2.1:
- New MSI inbound window
- Same Inbound windows address as PCIe controller v1.x
Added new pit_t member(pmit) to struct ccsr_pci for MSI inbound window
FSL PCIe controller v2.2 and v2.3:
- Different addresses for PCIe inbound window 3,2,1
- Exposed PCIe inbound window 0
- New PCIe interrupt status register
Added new config and interrupt Status register to struct ccsr_pci & updated
pit_t array size to reflect the 4 inbound windows.
Device tree is used to maintain backward compatibility i.e. update inbound
window 1 index depending upon "compatible" field witin PCIE node.
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Acked-by: Roy Zang <tie-fei.zang@freescale.com>
The following commit broke 83xx because it assumed the 83xx platforms
exposed the "IMMR" address in BAR0 like the 85xx/86xx/QoriQ devices do:
commit 3da34aae03d498ee62f75aa7467de93cce3030fd
Author: Kumar Gala <galak@kernel.crashing.org>
Date: Tue May 12 15:51:56 2009 -0500
powerpc/fsl: Support unique MSI addresses per PCIe Root Complex
However that is not true, so we have to search through the inbound
window settings on 83xx to find which one matches the IMMR address to
determine its PCI address.
Reported-by: Ilya Yanok <yanok@emcraft.com>
Previouslly we just always set the inbound window to 2G. This was
broken for systems with >2G. If a system has >=4G we will need
SWIOTLB support to handle that case.
We now allocate PCICSRBAR/PEXCSRBAR right below the lowest PCI outbound
address for MMIO or the 4G boundary (if the lowest PCI address is above
4G).
This allows other platforms with the same pci block like MPC5121 to use it.
Signed-off-by: John Rigby <jrigby@freescale.com>
On the 85xx/86xx PCIe controllers if there is no device connected to the
PHB we will still allocate a pci_bus for downstream bus of the virtual
P2P bridge. However the resources allocated to the downstream bus are not
correct and so we just mimic the resources from the upstream pci_bus.
Rewrite the Freescale PCI code to support PCI on 83xx/85xx/86xx and
PCIe on 85xx/86xx.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Move
arch/powerpc/platforms/86xx/pci.c -> arch/powerpc/sysdev/fsl_pci.c
arch/powerpc/sysdev/fsl_pcie.h -> arch/powerpc/sysdev/fsl_pci.h
as the base to unify 83xx/85xx/86xx pci and pcie.
Add CONFIG_FSL_PCI to build fsl_pci.c for Freescale pci and pcie option.
The code still works for 86xx platforms.
