The bestcomm dma hardware, and some of its users like the FEC ethernet
component, is used in different FreeScale parts, including non-powerpc
parts like the ColdFire MCF547x & MCF548x families. Don't keep the
driver hidden in arch/powerpc where it is inaccessible for other arches.
.c files are moved to drivers/dma/bestcomm, while .h files are moved to
include/linux/fsl/bestcomm. Makefiles, Kconfigs and #include directives
are updated for the new file locations.
Tested by recompiling for MPC5200 with all bestcomm users enabled.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
All these files were including module.h just for the basic
EXPORT_SYMBOL infrastructure. We can shift them off to the
export.h header which is a way smaller footprint and thus
realize some compile time gains.
This patch moves the declaration of of_get_address(), of_get_pci_address(),
and of_pci_address_to_resource() out of arch code and into the common
linux/of_address header file.
This patch also fixes some of the asm/prom.h ordering issues. It still
includes some header files that it ideally shouldn't be, but at least the
ordering is consistent now so that of_* overrides work.
Fix for the following compiler warnings:
CC arch/powerpc/sysdev/bestcomm/bestcomm.o
arch/powerpc/sysdev/bestcomm/bestcomm.c: In function 'mpc52xx_bcom_probe':
arch/powerpc/sysdev/bestcomm/bestcomm.c:446:
warning: format '%08lx' expects type 'long unsigned int',
but argument 2 has type 'phys_addr_t'
CC arch/powerpc/sysdev/bestcomm/sram.o
arch/powerpc/sysdev/bestcomm/sram.c: In function 'bcom_sram_init':
arch/powerpc/sysdev/bestcomm/sram.c:89:
but argument 3 has type 'phys_addr_t'
This patch adds support for the core of the BestComm API
for the Freescale MPC5200(b). The BestComm engine is a
microcode-controlled / tasks-based DMA used by several
of the onchip devices.
Setting up the tasks / memory allocation and all common
low level functions are handled by this patch.
The specifics details of each tasks and their microcode
are split-out in separate patches.
This is not the official API, but a much cleaner one.
(hopefully)
Signed-off-by: Sylvain Munaut <tnt@246tNt.com>
