Convert the powermac PCI driver to use the generic config access functions.
This changes accesses from (in|out)_(8|le16|le32) to readX/writeX variants.
I believe these should be equivalent for PCI config space accesses, but
confirmation would be nice.
Signed-off-by: Rob Herring <robh@kernel.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: Paul Mackerras <paulus@samba.org>
CC: Michael Ellerman <mpe@ellerman.id.au>
CC: linuxppc-dev@lists.ozlabs.org
Although we are now selecting NO_BOOTMEM, we still have some traces of
bootmem lying around. That is because even with NO_BOOTMEM there is
still a shim that converts bootmem calls into memblock calls, but
ultimately we want to remove all traces of bootmem.
Most of the patch is conversions from alloc_bootmem() to
memblock_virt_alloc(). In general a call such as:
p = (struct foo *)alloc_bootmem(x);
Becomes:
p = memblock_virt_alloc(x, 0);
We don't need the cast because memblock_virt_alloc() returns a void *.
The alignment value of zero tells memblock to use the default alignment,
which is SMP_CACHE_BYTES, the same value alloc_bootmem() uses.
We remove a number of NULL checks on the result of
memblock_virt_alloc(). That is because memblock_virt_alloc() will panic
if it can't allocate, in exactly the same way as alloc_bootmem(), so the
NULL checks are and always have been redundant.
The memory returned by memblock_virt_alloc() is already zeroed, so we
remove several memsets of the result of memblock_virt_alloc().
Finally we convert a few uses of __alloc_bootmem(x, y, MAX_DMA_ADDRESS)
to just plain memblock_virt_alloc(). We don't use memblock_alloc_base()
because MAX_DMA_ADDRESS is ~0ul on powerpc, so limiting the allocation
to that is pointless, 16XB ought to be enough for anyone.
Lots of places included bootmem.h even when not using bootmem.
Tested-by: Emil Medve <Emilian.Medve@Freescale.com>
The generic Linux framework to power off the machine is a function pointer
called pm_power_off. The trick about this pointer is that device drivers can
potentially implement it rather than board files.
Today on powerpc we set pm_power_off to invoke our generic full machine power
off logic which then calls ppc_md.power_off to invoke machine specific power
off.
However, when we want to add a power off GPIO via the "gpio-poweroff" driver,
this card house falls apart. That driver only registers itself if pm_power_off
is NULL to ensure it doesn't override board specific logic. However, since we
always set pm_power_off to the generic power off logic (which will just not
power off the machine if no ppc_md.power_off call is implemented), we can't
implement power off via the generic GPIO power off driver.
To fix this up, let's get rid of the ppc_md.power_off logic and just always use
pm_power_off as was intended. Then individual drivers such as the GPIO power off
driver can implement power off logic via that function pointer.
With this patch set applied and a few patches on top of QEMU that implement a
power off GPIO on the virt e500 machine, I can successfully turn off my virtual
machine after halt.
[mpe: Squash into one patch and update changelog based on cover letter]
There is no need for yet another copy of the command line, just
use boot_command_line like everyone else.
Pull device tree updates from Grant Likely:
"The branch contains the following device tree changes the v3.17 merge
window:
Group changes to the device tree. In preparation for adding device
tree overlay support, OF_DYNAMIC is reworked so that a set of device
tree changes can be prepared and applied to the tree all at once.
OF_RECONFIG notifiers see the most significant change here so that
users always get a consistent view of the tree. Notifiers generation
is moved from before a change to after it, and notifiers for a group
of changes are emitted after the entire block of changes have been
applied
Automatic console selection from DT. Console drivers can now use
of_console_check() to see if the device node is specified as a console
device. If so then it gets added as a preferred console. UART
devices get this support automatically when uart_add_one_port() is
called.
DT unit tests no longer depend on pre-loaded data in the device tree.
Data is loaded dynamically at the start of unit tests, and then
unloaded again when the tests have completed.
Also contains a few bugfixes for reserved regions and early memory
setup"
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux: (21 commits)
of: Fixing OF Selftest build error
drivers: of: add automated assignment of reserved regions to client devices
of: Use proper types for checking memory overflow
of: typo fix in __of_prop_dup()
Adding selftest testdata dynamically into live tree
of: Add todo tasklist for Devicetree
of: Transactional DT support.
of: Reorder device tree changes and notifiers
of: Move dynamic node fixups out of powerpc and into common code
of: Make sure attached nodes don't carry along extra children
of: Make devicetree sysfs update functions consistent.
of: Create unlocked versions of node and property add/remove functions
OF: Utility helper functions for dynamic nodes
of: Move CONFIG_OF_DYNAMIC code into a separate file
of: rename of_aliases_mutex to just of_mutex
of/platform: Fix of_platform_device_destroy iteration of devices
of: Migrate of_find_node_by_name() users to for_each_node_by_name()
tty: Update hypervisor tty drivers to use core stdout parsing code.
arm/versatile: Add the uart as the stdout device.
of: Enable console on serial ports specified by /chosen/stdout-path
Although the name CONFIG_POWER4 suggests that it controls support for
power4 cpus, this symbol is actually misnamed.
It is a historical wart from the powermac code, which used to support
building a 32-bit kernel for power4. CONFIG_POWER4 was used in that
context to guard code that was 64-bit only.
In the powermac code we can just use CONFIG_PPC64 instead, and in other
places it is a synonym for CONFIG_PPC_BOOK3S_64.
There are a bunch of users open coding the for_each_node_by_name() by
calling of_find_node_by_name() directly instead of using the macro. This
is getting in the way of some cleanups, and the possibility of removing
of_find_node_by_name() entirely. Clean it up so that all the users are
consistent.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Cc: Takashi Iwai <tiwai@suse.de>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
The one instance where we add an include for init.h covers off
a case where that file was implicitly getting it from another
header which itself didn't need it.
Use this new function to make code more comprehensible, since we are
reinitialzing the completion, not initializing.
[akpm@linux-foundation.org: linux-next resyncs]
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13)
struct of_irq and struct of_phandle_args are exactly the same structure.
This patch makes the kernel use of_phandle_args everywhere. This in
itself isn't a big deal, but it makes some follow-on patches simpler.
Acked-by: Michal Simek <monstr@monstr.eu>
The OF irq handling code has been overloading the term 'map' to refer to
both parsing the data in the device tree and mapping it to the internal
linux irq system. This is probably because the device tree does have the
concept of an 'interrupt-map' function for translating interrupt
references from one node to another, but 'map' is still confusing when
the primary purpose of some of the functions are to parse the DT data.
This patch renames all the of_irq_map_* functions to of_irq_parse_*
which makes it clear that there is a difference between the parsing
phase and the mapping phase. Kernel code can make use of just the
parsing or just the mapping support as needed by the subsystem.
The patch was generated mechanically with a handful of sed commands.
When removing prom.h include by of.h, several OF headers will no longer
be implicitly included. Add explicit includes of of_*.h as needed.
Acked-by: Grant Likely <grant.likely@linaro.org>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Olof Johansson <olof@lixom.net>
Cc: linuxppc-dev@lists.ozlabs.org
Pull irqdomain refactoring from Grant Likely:
"This is the long awaited simplification of irqdomain. It gets rid of
the different types of irq domains and instead both linear and tree
mappings can be supported in a single domain. Doing this removes a
lot of special case code and makes irq domains simpler to understand
overall"
* tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux:
irq: fix checkpatch error
irqdomain: Include hwirq number in /proc/interrupts
irqdomain: make irq_linear_revmap() a fast path again
irqdomain: remove irq_domain_generate_simple()
irqdomain: Refactor irq_domain_associate_many()
irqdomain: Beef up debugfs output
irqdomain: Clean up aftermath of irq_domain refactoring
irqdomain: Eliminate revmap type
irqdomain: merge linear and tree reverse mappings.
irqdomain: Add a name field
irqdomain: Replace LEGACY mapping with LINEAR
irqdomain: Relax failure path on setting up mappings
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Ben Herrenschmidt:
"This is the powerpc changes for the 3.11 merge window. In addition to
the usual bug fixes and small updates, the main highlights are:
- Support for transparent huge pages by Aneesh Kumar for 64-bit
server processors. This allows the use of 16M pages as transparent
huge pages on kernels compiled with a 64K base page size.
- Base VFIO support for KVM on power by Alexey Kardashevskiy
- Wiring up of our nvram to the pstore infrastructure, including
putting compressed oopses in there by Aruna Balakrishnaiah
- Move, rework and improve our "EEH" (basically PCI error handling
and recovery) infrastructure. It is no longer specific to pseries
but is now usable by the new "powernv" platform as well (no
hypervisor) by Gavin Shan.
- I fixed some bugs in our math-emu instruction decoding and made it
usable to emulate some optional FP instructions on processors with
hard FP that lack them (such as fsqrt on Freescale embedded
processors).
- Support for Power8 "Event Based Branch" facility by Michael
Ellerman. This facility allows what is basically "userspace
interrupts" for performance monitor events.
- A bunch of Transactional Memory vs. Signals bug fixes and HW
breakpoint/watchpoint fixes by Michael Neuling.
And more ... I appologize in advance if I've failed to highlight
something that somebody deemed worth it."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits)
pstore: Add hsize argument in write_buf call of pstore_ftrace_call
powerpc/fsl: add MPIC timer wakeup support
powerpc/mpic: create mpic subsystem object
powerpc/mpic: add global timer support
powerpc/mpic: add irq_set_wake support
powerpc/85xx: enable coreint for all the 64bit boards
powerpc/8xx: Erroneous double irq_eoi() on CPM IRQ in MPC8xx
powerpc/fsl: Enable CONFIG_E1000E in mpc85xx_smp_defconfig
powerpc/mpic: Add get_version API both for internal and external use
powerpc: Handle both new style and old style reserve maps
powerpc/hw_brk: Fix off by one error when validating DAWR region end
powerpc/pseries: Support compression of oops text via pstore
powerpc/pseries: Re-organise the oops compression code
pstore: Pass header size in the pstore write callback
powerpc/powernv: Fix iommu initialization again
powerpc/pseries: Inform the hypervisor we are using EBB regs
powerpc/perf: Add power8 EBB support
powerpc/perf: Core EBB support for 64-bit book3s
powerpc/perf: Drop MMCRA from thread_struct
powerpc/perf: Don't enable if we have zero events
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
This removes all the powerpc uses of the __cpuinit macros. There
are no __CPUINIT users in assembly files in powerpc.
[1] https://lkml.org/lkml/2013/5/20/589
Cc: Josh Boyer <jwboyer@gmail.com>
Cc: Matt Porter <mporter@kernel.crashing.org>
After refactoring the irqdomain code, there are a number of API
functions that are merely empty wrappers around core code. Drop those
wrappers out of the C file and replace them with static inlines in the
header.
Move cpufreq driver of powerpc platform to drivers/cpufreq.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
The PCI core supports an offset per aperture nowadays but our arch
code still has a single offset per host bridge representing the
difference betwen CPU memory addresses and PCI MMIO addresses.
This is a problem as new machines and hypervisor versions are
coming out where the 64-bit windows will have a different offset
(basically mapped 1:1) from the 32-bit windows.
This fixes it by using separate offsets. In the long run, we probably
want to get rid of that intermediary struct pci_controller and have
those directly stored into the pci_host_bridge as they are parsed
but this will be a more invasive change.
policy->cpus contains all online cpus that have single shared clock line. And
their frequencies are always updated together.
Many SMP system's cpufreq drivers take care of this in individual drivers but
the best place for this code is in cpufreq core.
This patch modifies cpufreq_notify_transition() to notify frequency change for
all cpus in policy->cpus and hence updates all users of this API.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Pull powerpc update from Benjamin Herrenschmidt:
"The main highlight is probably some base POWER8 support. There's more
to come such as transactional memory support but that will wait for
the next one.
Overall it's pretty quiet, or rather I've been pretty poor at picking
things up from patchwork and reviewing them this time around and Kumar
no better on the FSL side it seems..."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (73 commits)
powerpc+of: Rename and fix OF reconfig notifier error inject module
powerpc: mpc5200: Add a3m071 board support
powerpc/512x: don't compile any platform DIU code if the DIU is not enabled
powerpc/mpc52xx: use module_platform_driver macro
powerpc+of: Export of_reconfig_notifier_[register,unregister]
powerpc/dma/raidengine: add raidengine device
powerpc/iommu/fsl: Add PAMU bypass enable register to ccsr_guts struct
powerpc/mpc85xx: Change spin table to cached memory
powerpc/fsl-pci: Add PCI controller ATMU PM support
powerpc/86xx: fsl_pcibios_fixup_bus requires CONFIG_PCI
drivers/virt: the Freescale hypervisor driver doesn't need to check MSR[GS]
powerpc/85xx: p1022ds: Use NULL instead of 0 for pointers
powerpc: Disable relocation on exceptions when kexecing
powerpc: Enable relocation on during exceptions at boot
powerpc: Move get_longbusy_msecs into hvcall.h and remove duplicate function
powerpc: Add wrappers to enable/disable relocation on exceptions
powerpc: Add set_mode hcall
powerpc: Setup relocation on exceptions for bare metal systems
powerpc: Move initial mfspr LPCR out of __init_LPCR
powerpc: Add relocation on exception vector handlers
Pull trivial branch from Jiri Kosina:
"Usual stuff -- comment/printk typo fixes, documentation updates, dead
code elimination."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
HOWTO: fix double words typo
x86 mtrr: fix comment typo in mtrr_bp_init
propagate name change to comments in kernel source
doc: Update the name of profiling based on sysfs
treewide: Fix typos in various drivers
treewide: Fix typos in various Kconfig
wireless: mwifiex: Fix typo in wireless/mwifiex driver
messages: i2o: Fix typo in messages/i2o
scripts/kernel-doc: check that non-void fcts describe their return value
Kernel-doc: Convention: Use a "Return" section to describe return values
radeon: Fix typo and copy/paste error in comments
doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c
various: Fix spelling of "asynchronous" in comments.
Fix misspellings of "whether" in comments.
eisa: Fix spelling of "asynchronous".
various: Fix spelling of "registered" in comments.
doc: fix quite a few typos within Documentation
target: iscsi: fix comment typos in target/iscsi drivers
treewide: fix typo of "suport" in various comments and Kconfig
treewide: fix typo of "suppport" in various comments
"Whether" is misspelled in various comments across the tree; this
fixes them. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Neither of these should ever be changed once set. Make them const and
fix up the users that try to modify it in-place. In one case
kmalloc+memcpy is replaced with kstrdup() to avoid modifying the string.
Build tested with defconfigs on ARM, PowerPC, Sparc, MIPS, x86 among
others.
Cc: Julian Calaby <julian.calaby@gmail.com>
The transition time for the 7447A is around 8ms which makes it possible
to use the ondemand governor. This has been tested on the iBook G4
(PowerBook6,7).
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
Tested-by: Michel Dänzer <michel@daenzer.net>
This causes i2c-powermac to register i2c devices exposed in the
device-tree, enabling new-style probing of devices.
Note that we prefix the IDs with "MAC," in order to prevent the
generic drivers from matching. This is done on purpose as we only
want drivers specifically tested/designed to operate on powermacs
to match.
This removes the special case we had for the AMS driver, and updates
the driver's match table instead.
The switch from using irq_map to irq_alloc_desc*() for managing irq
number allocations introduced new bugs in some of the powerpc
interrupt code. Several functions rely on the value of NR_IRQS to
determine the maximum irq number that could get allocated. However,
with sparse_irq and using irq_alloc_desc*() the maximum possible irq
number is now specified with 'nr_irqs' which may be a number larger
than NR_IRQS. This has caused breakage on powermac when
CONFIG_NR_IRQS is set to 32.
This patch removes most of the direct references to NR_IRQS in the
powerpc code and replaces them with either a nr_irqs reference or by
using the common for_each_irq_desc() macro. The powerpc-specific
for_each_irq() macro is removed at the same time.
Also, the Cell axon_msi driver is refactored to remove the global
build assumption on the size of NR_IRQS and instead add a limit to the
maximum irq number when calling irq_domain_add_nomap().
If the interrupt and the timeout happen roughly at the same
time, we can get into a situation where the timer function
is run while the interrupt has already been processed. In
this case, the timer function might end up doing an add_timer
on an already pending timer, causing a BUG_ON() to trigger.
Instead, just skip the whole timeout operation if we see that
the timer is pending. The spinlock ensures that the only way
that happens is if we already started a new operation and thus
the timeout can be ignored.
This patch replaces the old global setting of irq_virq_count that is only
used by the NOMAP mapping and instead uses a revmap_data property so that
the maximum NOMAP allocation can be set per NOMAP irq_domain.
There is exactly one user of irq_virq_count in-tree right now: PS3.
Also, irq_virq_count is only useful for the NOMAP mapping. So,
instead of having a single global irq_virq_count values, this change
drops it entirely and added a max_irq argument to irq_domain_add_nomap().
That makes it a property of an individual nomap irq domain instead of
a global system settting.
Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Milton Miller <miltonm@bga.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Disintegrate asm/system.h for PowerPC.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
cc: linuxppc-dev@lists.ozlabs.org
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci
Pull PCI changes (including maintainer change) from Jesse Barnes:
"This pull has some good cleanups from Bjorn and Yinghai, as well as
some more code from Yinghai to better handle resource re-allocation
when enabled.
There's also a new initcall_debug feature from Arjan which will print
out quirk timing information to help identify slow quirks for fixing
or refinement (Yinghai sent in a few patches to do just that once the
new debug code landed).
Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas.
He's been a core PCI and Linux contributor for some time now, and has
kindly volunteered to take over. I just don't feel I have the time
for PCI review and work that it deserves lately (I've taken on some
other projects), and haven't been as responsive lately as I'd like, so
I approached Bjorn asking if he'd like to manage things. He's going
to give it a try, and I'm confident he'll do at least as well as I
have in keeping the tree managed, patches flowing, and keeping things
stable."
Fix up some fairly trivial conflicts due to other cleanups (mips device
resource fixup cleanups clashing with list handling cleanup, ppc iseries
removal clashing with pci_probe_only cleanup etc)
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits)
PCI: Bjorn gets PCI hotplug too
PCI: hand PCI maintenance over to Bjorn Helgaas
unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h
sparc/PCI: convert devtree and arch-probed bus addresses to resource
powerpc/PCI: allow reallocation on PA Semi
powerpc/PCI: convert devtree bus addresses to resource
powerpc/PCI: compute I/O space bus-to-resource offset consistently
arm/PCI: don't export pci_flags
PCI: fix bridge I/O window bus-to-resource conversion
x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()'
PCI / PCIe: Introduce command line option to disable ARI
PCI: make acpihp use __pci_remove_bus_device instead
PCI: export __pci_remove_bus_device
PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge
PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device
PCI: print out PCI device info along with duration
PCI: Move "pci reassigndev resource alignment" out of quirks.c
PCI: Use class for quirk for usb host controller fixup
PCI: Use class for quirk for ti816x class fixup
PCI: Use class for quirk for intel e100 interrupt fixup
Pull powerpc merge from Benjamin Herrenschmidt:
"Here's the powerpc batch for this merge window. It is going to be a
bit more nasty than usual as in touching things outside of
arch/powerpc mostly due to the big iSeriesectomy :-) We finally got
rid of the bugger (legacy iSeries support) which was a PITA to
maintain and that nobody really used anymore.
Here are some of the highlights:
- Legacy iSeries is gone. Thanks Stephen ! There's still some bits
and pieces remaining if you do a grep -ir series arch/powerpc but
they are harmless and will be removed in the next few weeks
hopefully.
- The 'fadump' functionality (Firmware Assisted Dump) replaces the
previous (equivalent) "pHyp assisted dump"... it's a rewrite of a
mechanism to get the hypervisor to do crash dumps on pSeries, the
new implementation hopefully being much more reliable. Thanks
Mahesh Salgaonkar.
- The "EEH" code (pSeries PCI error handling & recovery) got a big
spring cleaning, motivated by the need to be able to implement a
new backend for it on top of some new different type of firwmare.
The work isn't complete yet, but a good chunk of the cleanups is
there. Note that this adds a field to struct device_node which is
not very nice and which Grant objects to. I will have a patch soon
that moves that to a powerpc private data structure (hopefully
before rc1) and we'll improve things further later on (hopefully
getting rid of the need for that pointer completely). Thanks Gavin
Shan.
- I dug into our exception & interrupt handling code to improve the
way we do lazy interrupt handling (and make it work properly with
"edge" triggered interrupt sources), and while at it found & fixed
a wagon of issues in those areas, including adding support for page
fault retry & fatal signals on page faults.
- Your usual random batch of small fixes & updates, including a bunch
of new embedded boards, both Freescale and APM based ones, etc..."
I fixed up some conflicts with the generalized irq-domain changes from
Grant Likely, hopefully correctly.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (141 commits)
powerpc/ps3: Do not adjust the wrapper load address
powerpc: Remove the rest of the legacy iSeries include files
powerpc: Remove the remaining CONFIG_PPC_ISERIES pieces
init: Remove CONFIG_PPC_ISERIES
powerpc: Remove FW_FEATURE ISERIES from arch code
tty/hvc_vio: FW_FEATURE_ISERIES is no longer selectable
powerpc/spufs: Fix double unlocks
powerpc/5200: convert mpc5200 to use of_platform_populate()
powerpc/mpc5200: add options to mpc5200_defconfig
powerpc/mpc52xx: add a4m072 board support
powerpc/mpc5200: update mpc5200_defconfig to fit for charon board
Documentation/powerpc/mpc52xx.txt: Checkpatch cleanup
powerpc/44x: Add additional device support for APM821xx SoC and Bluestone board
powerpc/44x: Add support PCI-E for APM821xx SoC and Bluestone board
MAINTAINERS: Update PowerPC 4xx tree
powerpc/44x: The bug fixed support for APM821xx SoC and Bluestone board
powerpc: document the FSL MPIC message register binding
powerpc: add support for MPIC message register API
powerpc/fsl: Added aliased MSIIR register address to MSI node in dts
powerpc/85xx: mpc8548cds - add 36-bit dts
- Use memchr_inv to check if the data contains all 0xFF bytes.
It is faster than looping for each byte.
- Use memcmp to compare memory areas
pci_probe_only is set on ppc64 to prevent resource re-allocation
by the core. It's meant to be used in very specific circumstances
such as when operating under a hypervisor that may prevent such
re-allocation.
Instead of default to 1, we make it default to 0 and explicitly
set it in the few cases where we need it.
This fixes FSL PCI which wants it clear among others.
There are two separate flags controlling whether or not the MPIC is
reset during initialization, which is completely unnecessary, and only
one of them can be specified in the device tree.
Also, most platforms in-tree right now do actually want to reset the
MPIC during initialization anyways, which means lots of duplicate code
passing the MPIC_WANTS_RESET flag.
Fix all of the callers which currently do not pass the MPIC_WANTS_RESET
flag to pass the MPIC_NO_RESET flag, then remove the MPIC_WANTS_RESET
flag and make the code reset the MPIC by default.
Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
This patch converts a number of the powerpc drivers to use the common library
of irq_domain xlate functions, dropping a bunch of lines in the process.
v5: - Remove tsi108 changes from patch
Cc: Rob Herring <rob.herring@calxeda.com>
Tested-by: Olof Johansson <olof@lixom.net>
Make all the irq_domain_ops structures in powerpc 'static const'
Each revmap type has different arguments for setting up the revmap.
This patch splits up the generator functions so that each revmap type
can do its own setup and the user doesn't need to keep track of how
each revmap type handles the arguments.
This patch also adds a host_data argument to the generators. There are
cases where the host_data pointer will be needed before the function returns.
ie. the legacy map calls the .map callback for each irq before returning.
v2: - Add void *host_data argument to irq_domain_add_*() functions
- fixed failure to compile
- Moved IRQ_DOMAIN_MAP_* defines into irqdomain.c
This patch drops the powerpc-specific irq_host structures and uses the common
irq_domain strucutres defined in linux/irqdomain.h. It also fixes all
the users to use the new structure names.
Renaming irq_host to irq_domain has been discussed for a long time, and this
patch is a step in the process of generalizing the powerpc virq code to be
usable by all architecture.
An astute reader will notice that this patch actually removes the irq_host
structure instead of renaming it. This is because the irq_domain structure
already exists in include/linux/irqdomain.h and has the needed data members.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits)
arm: fix up some samsung merge sysdev conversion problems
firmware: Fix an oops on reading fw_priv->fw in sysfs loading file
Drivers:hv: Fix a bug in vmbus_driver_unregister()
driver core: remove __must_check from device_create_file
debugfs: add missing #ifdef HAS_IOMEM
arm: time.h: remove device.h #include
driver-core: remove sysdev.h usage.
clockevents: remove sysdev.h
arm: convert sysdev_class to a regular subsystem
arm: leds: convert sysdev_class to a regular subsystem
kobject: remove kset_find_obj_hinted()
m86k: gpio - convert sysdev_class to a regular subsystem
mips: txx9_sram - convert sysdev_class to a regular subsystem
mips: 7segled - convert sysdev_class to a regular subsystem
sh: dma - convert sysdev_class to a regular subsystem
sh: intc - convert sysdev_class to a regular subsystem
power: suspend - convert sysdev_class to a regular subsystem
power: qe_ic - convert sysdev_class to a regular subsystem
power: cmm - convert sysdev_class to a regular subsystem
s390: time - convert sysdev_class to a regular subsystem
Fix up conflicts with 'struct sysdev' removal from various platform
drivers that got changed:
- arch/arm/mach-exynos/cpu.c
- arch/arm/mach-exynos/irq-eint.c
- arch/arm/mach-s3c64xx/common.c
- arch/arm/mach-s3c64xx/cpu.c
- arch/arm/mach-s5p64x0/cpu.c
- arch/arm/mach-s5pv210/common.c
- arch/arm/plat-samsung/include/plat/cpu.h
- arch/powerpc/kernel/sysfs.c
and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
This resolves the conflict in the arch/arm/mach-s3c64xx/s3c6400.c file,
and it fixes the build error in the arch/x86/kernel/microcode_core.c
file, that the merge did not catch.
The microcode_core.c patch was provided by Stephen Rothwell
<sfr@canb.auug.org.au> who was invaluable in the merge issues involved
with the large sysdev removal process in the driver-core tree.
The sysdev.h file should not be needed by any in-kernel code, so remove
the .h file from these random files that seem to still want to include
it.
The sysdev code will be going away soon, so this include needs to be
removed no matter what.
Cc: Jiandong Zheng <jdzheng@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: David Brown <davidb@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: "Venkatesh Pallipadi
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
The code for "powersurge" SMP would kick in and cause a crash
at boot due to the lack of a NULL test.
In the old days, we treated all interrupts from the legacy Apple home made
interrupt controllers as level, with a trick reading the "level" register
along with the "event" register to work arounds bugs where it would
occasionally fail to latch some events.
Doing so appeared to work fine for both level and edge interrupts.
Later on, we discovered in Darwin source the magic masks that define which
interrupts are actually level and which are edge, and implemented a
different algorithm, more similar to what Apple does, that treats those
differently.
I recently discovered however that this caused problems (including loss
of interrupts) with an old Wallstreet PowerBook when trying to use the
internal modem (connected to a cascaded controller).
It looks like some interrupts are treated as edge while they are really
level and I'm starting to seriously doubt the correctness of the Darwin
code (which has other obvious bugs when you read it, so ...)
This patch reverts to our original behaviour of treating everything as
a level interrupt. It appears to solve the problems with the modem on
the Wallstreet and everything else seems to be working properly as well.
The Cell and PowerMac platforms use virtually identical cascaded-IRQ
setup code, so just merge it into the core. Ideally this code would
trigger automatically when an MPIC device-node specifies an "interrupts"
property, perhaps even enabling MPIC_SECONDARY along the way.
Unfortunately, Benjamin Herrenschmidt has had bad experiences in the
past with the quality of Apple PowerMac device-trees, so to be safe we
will only try to parse out an IRQ if the MPIC_SECONDARY flag is set by
the caller.
It turns out that there are only 2 in-tree platforms which use MPICs
which are not "primary": IBM Cell and PowerMac. To reduce the
complexity of the typical board setup code, invert the MPIC_PRIMARY bit
into MPIC_SECONDARY.
