Replace __get_cpu_var safely with get_cpu_var to avoid
the following call trace:
[ 7253.637591] BUG: using smp_processor_id() in preemptible [00000000 00000000]
code: hugemmap01/9048
[ 7253.637601] caller is free_hugepd_range.constprop.25+0x88/0x1a8
[ 7253.637605] CPU: 1 PID: 9048 Comm: hugemmap01 Not tainted 3.10.20-rt14+ #114
[ 7253.637606] Call Trace:
[ 7253.637617] [cb049d80] [c0007ea4] show_stack+0x4c/0x168 (unreliable)
[ 7253.637624] [cb049dc0] [c031c674] debug_smp_processor_id+0x114/0x134
[ 7253.637628] [cb049de0] [c0016d28] free_hugepd_range.constprop.25+0x88/0x1a8
[ 7253.637632] [cb049e00] [c001711c] hugetlb_free_pgd_range+0x6c/0x168
[ 7253.637639] [cb049e40] [c0117408] free_pgtables+0x12c/0x150
[ 7253.637646] [cb049e70] [c011ce38] unmap_region+0xa0/0x11c
[ 7253.637671] [cb049ef0] [c011f03c] do_munmap+0x224/0x3bc
[ 7253.637676] [cb049f20] [c011f2e0] vm_munmap+0x38/0x5c
[ 7253.637682] [cb049f40] [c000ef88] ret_from_syscall+0x0/0x3c
[ 7253.637686] --- Exception: c01 at 0xff16004
Signed-off-by: Tiejun Chen<tiejun.chen@windriver.com>
allowed address space
According to Posix, if MAP_FIXED is specified mmap shall set ENOMEM if
the requested mapping exceeds the allowed range for address space of
the process. The generic code set it right, but the specific powerpc
slice_get_unmapped_area() function currently returns -EINVAL in that
case.
This patch corrects it.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
This should have been octal.
This contains a fix for a chroma_defconfig build break that was
introduced by e6500 tablewalk support, and a device tree binding patch
that missed the previous pull request due to some last-minute polishing.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Ben Herrenschmidt:
"So here's my next branch for powerpc. A bit late as I was on vacation
last week. It's mostly the same stuff that was in next already, I
just added two patches today which are the wiring up of lockref for
powerpc, which for some reason fell through the cracks last time and
is trivial.
The highlights are, in addition to a bunch of bug fixes:
- Reworked Machine Check handling on kernels running without a
hypervisor (or acting as a hypervisor). Provides hooks to handle
some errors in real mode such as TLB errors, handle SLB errors,
etc...
- Support for retrieving memory error information from the service
processor on IBM servers running without a hypervisor and routing
them to the memory poison infrastructure.
- _PAGE_NUMA support on server processors
- 32-bit BookE relocatable kernel support
- FSL e6500 hardware tablewalk support
- A bunch of new/revived board support
- FSL e6500 deeper idle states and altivec powerdown support
You'll notice a generic mm change here, it has been acked by the
relevant authorities and is a pre-req for our _PAGE_NUMA support"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (121 commits)
powerpc: Implement arch_spin_is_locked() using arch_spin_value_unlocked()
powerpc: Add support for the optimised lockref implementation
powerpc/powernv: Call OPAL sync before kexec'ing
powerpc/eeh: Escalate error on non-existing PE
powerpc/eeh: Handle multiple EEH errors
powerpc: Fix transactional FP/VMX/VSX unavailable handlers
powerpc: Don't corrupt transactional state when using FP/VMX in kernel
powerpc: Reclaim two unused thread_info flag bits
powerpc: Fix races with irq_work
Move precessing of MCE queued event out from syscall exit path.
pseries/cpuidle: Remove redundant call to ppc64_runlatch_off() in cpu idle routines
powerpc: Make add_system_ram_resources() __init
powerpc: add SATA_MV to ppc64_defconfig
powerpc/powernv: Increase candidate fw image size
powerpc: Add debug checks to catch invalid cpu-to-node mappings
powerpc: Fix the setup of CPU-to-Node mappings during CPU online
powerpc/iommu: Don't detach device without IOMMU group
powerpc/eeh: Hotplug improvement
powerpc/eeh: Call opal_pci_reinit() on powernv for restoring config space
powerpc/eeh: Add restore_config operation
[sfr@canb.auug.org.au: fix powerpc build]
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: "Rafael J . Wysocki" <rjw@sisk.pl>
Cc: Chen Tang <imtangchen@gmail.com>
Cc: Gong Chen <gong.chen@linux.intel.com>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Liu Jiang <jiang.liu@huawei.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Thomas Renninger <trenn@suse.de>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Vasilis Liaskovitis <vasilis.liaskovitis@profitbricks.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Yinghai Lu <yinghai@kernel.org>
...and make CONFIG_PPC_FSL_BOOK3E conflict with CONFIG_PPC_64K_PAGES.
This fixes a build break with CONFIG_PPC_64K_PAGES on 64-bit book3e,
that was introduced by commit 28efc35fe68dacbddc4b12c2fa8f2df1593a4ad3
("powerpc/e6500: TLB miss handler with hardware tablewalk support").
Freescale updates from Scott:
Highlights include 32-bit booke relocatable support, e6500 hardware
tablewalk support, various e500 SPE fixes, some new/revived boards, and
e6500 deeper idle and altivec powerdown modes.
add_system_ram_resources() is a subsys_initcall.
There have been some weird bugs in the past where the kernel tried to associate
threads of the same core to different NUMA nodes, and things went haywire after
that point (as expected).
But unfortunately, root-causing such issues have been quite challenging, due to
the lack of appropriate debug checks in the kernel. These bugs usually lead to
some odd soft-lockups in the scheduler's build-sched-domain code in the CPU
hotplug path, which makes it very hard to trace it back to the incorrect
cpu-to-node mappings.
So add appropriate debug checks to catch such invalid cpu-to-node mappings
as early as possible.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
On POWER platforms, the hypervisor can notify the guest kernel about dynamic
changes in the cpu-numa associativity (VPHN topology update). Hence the
cpu-to-node mappings that we got from the firmware during boot, may no longer
be valid after such updates. This is handled using the arch_update_cpu_topology()
hook in the scheduler, and the sched-domains are rebuilt according to the new
mappings.
But unfortunately, at the moment, CPU hotplug ignores these updated mappings
and instead queries the firmware for the cpu-to-numa relationships and uses
them during CPU online. So the kernel can end up assigning wrong NUMA nodes
to CPUs during subsequent CPU hotplug online operations (after booting).
Further, a particularly problematic scenario can result from this bug:
On POWER platforms, the SMT mode can be switched between 1, 2, 4 (and even 8)
threads per core. The switch to Single-Threaded (ST) mode is performed by
offlining all except the first CPU thread in each core. Switching back to
SMT mode involves onlining those other threads back, in each core.
Now consider this scenario:
1. During boot, the kernel gets the cpu-to-node mappings from the firmware
and assigns the CPUs to NUMA nodes appropriately, during CPU online.
2. Later on, the hypervisor updates the cpu-to-node mappings dynamically and
communicates this update to the kernel. The kernel in turn updates its
cpu-to-node associations and rebuilds its sched domains. Everything is
fine so far.
3. Now, the user switches the machine from SMT to ST mode (say, by running
ppc64_cpu --smt=1). This involves offlining all except 1 thread in each
core.
4. The user then tries to switch back from ST to SMT mode (say, by running
ppc64_cpu --smt=4), and this involves onlining those threads back. Since
CPU hotplug ignores the new mappings, it queries the firmware and tries to
associate the newly onlined sibling threads to the old NUMA nodes. This
results in sibling threads within the same core getting associated with
different NUMA nodes, which is incorrect.
The scheduler's build-sched-domains code gets thoroughly confused with this
and enters an infinite loop and causes soft-lockups, as explained in detail
in commit 3be7db6ab (powerpc: VPHN topology change updates all siblings).
So to fix this, use the numa_cpu_lookup_table to remember the updated
cpu-to-node mappings, and use them during CPU hotplug online operations.
Further, we also need to ensure that all threads in a core are assigned to a
common NUMA node, irrespective of whether all those threads were online during
the topology update. To achieve this, we take care not to use cpu_sibling_mask()
since it is not hotplug invariant. Instead, we use cpu_first_sibling_thread()
and set up the mappings manually using the 'threads_per_core' value for that
particular platform. This helps us ensure that we don't hit this bug with any
combination of CPU hotplug and SMT mode switching.
Cc: stable@vger.kernel.org
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
The one instance where we add an include for init.h covers off
a case where that file was implicitly getting it from another
header which itself didn't need it.
It was branching to the cleanup part of the non-bolted handler,
which would have been bad if there were any chips with tlbsrx.
that use the bolted handler.
This keeps usage coordinated for hugetlb and indirect entries, which
should make entry selection more predictable and probably improve overall
performance when mixing the two.
There are a few things that make the existing hw tablewalk handlers
unsuitable for e6500:
- Indirect entries go in TLB1 (though the resulting direct entries go in
TLB0).
- It has threads, but no "tlbsrx." -- so we need a spinlock and
a normal "tlbsx". Because we need this lock, hardware tablewalk
is mandatory on e6500 unless we want to add spinlock+tlbsx to
the normal bolted TLB miss handler.
- TLB1 has no HES (nor next-victim hint) so we need software round robin
(TODO: integrate this round robin data with hugetlb/KVM)
- The existing tablewalk handlers map half of a page table at a time,
because IBM hardware has a fixed 1MiB indirect page size. e6500
has variable size indirect entries, with a minimum of 2MiB.
So we can't do the half-page indirect mapping, and even if we
could it would be less efficient than mapping the full page.
- Like on e5500, the linear mapping is bolted, so we don't need the
overhead of supporting nested tlb misses.
Note that hardware tablewalk does not work in rev1 of e6500.
We do not expect to support e6500 rev1 in mainline Linux.
Cc: Mihai Caraman <mihai.caraman@freescale.com>
There is no barrier between something like ioremap() writing to
a PTE, and returning the value to a caller that may then store the
pointer in a place that is visible to other CPUs. Such callers
generally don't perform barriers of their own.
Even if callers of ioremap() and similar things did use barriers,
the most logical choise would be smp_wmb(), which is not
architecturally sufficient when BookE hardware tablewalk is used. A
full sync is specified by the architecture.
For userspace mappings, OTOH, we generally already have an lwsync due
to locking, and if we occasionally take a spurious fault due to not
having a full sync with hardware tablewalk, it will not be fatal
because we will retry rather than oops.
When booting above the 64M for a secondary cpu, we also face the
same issue as the boot cpu that the PAGE_OFFSET map two different
physical address for the init tlb and the final map. So we have to use
switch_to_as1/restore_to_as0 between the conversion of these two
maps. When restoring to as0 for a secondary cpu, we only need to
return to the caller. So add a new parameter for function
restore_to_as0 for this purpose.
Use LOAD_REG_ADDR_PIC to get the address of variables which may
be used before we set the final map in cams for the secondary cpu.
Move the setting of cams a bit earlier in order to avoid the
unnecessary using of LOAD_REG_ADDR_PIC.
Signed-off-by: Kevin Hao <haokexin@gmail.com>
relocatable kernel
This is always true for a non-relocatable kernel. Otherwise the kernel
would get stuck. But for a relocatable kernel, it seems a little
complicated. When booting a relocatable kernel, we just align the
kernel start addr to 64M and map the PAGE_OFFSET from there. The
relocation will base on this virtual address. But if this address
is not the same as the memstart_addr, we will have to change the
map of PAGE_OFFSET to the real memstart_addr and do another relocation
again.
[scottwood@freescale.com: make offset long and non-negative in simple case]
Introduce this function so we can set both the physical and virtual
address for the map in cams. This will be used by the relocation code.
We use the tlb1 entries to map low mem to the kernel space. In the
current code, it assumes that the first tlb entry would cover the
kernel image. But this is not true for some special cases, such as
when we run a relocatable kernel above the 64M or set
CONFIG_KERNEL_START above 64M. So we choose to switch to address
space 1 before setting these tlb entries.
This is based on the codes in the head_44x.S. The difference is that
the init tlb size we used is 64M. With this patch we can only load the
kernel at address between memstart_addr ~ memstart_addr + 64M. We will
fix this restriction in the following patches.
The e500v1 doesn't implement the MAS7, so we should avoid to access
this register on that implementations. In the current kernel, the
access to MAS7 are protected by either CONFIG_PHYS_64BIT or
MMU_FTR_BIG_PHYS. Since some code are executed before the code
patching, we have to use CONFIG_PHYS_64BIT in these cases.
We want to make sure we don't use these function when updating a pte
or pmd entry that have a valid hpte entry, because these functions
don't invalidate them. So limit the check to _PAGE_PRESENT bit.
Numafault core changes use these functions for updating _PAGE_NUMA bits.
That should be ok because when _PAGE_NUMA is set we can be sure that
hpte entries are not present.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Acked-by: Paul Mackerras <paulus@samba.org>
Set memory coherence always on hash64 config. If
a platform cannot have memory coherence always set they
can infer that from _PAGE_NO_CACHE and _PAGE_WRITETHRU
like in lpar. So we dont' really need a separate bit
for tracking _PAGE_COHERENCE.
So that it can be used by other codes. No function change.
And in flush_hugetlb_page(), don't check whether vma is NULL after
we've already dereferenced it.
This was found by Dan using static analysis as described here:
https://lists.ozlabs.org/pipermail/linuxppc-dev/2013-November/113161.html
We currently get away with this because the callers that currently pass
NULL for vma seem to be 32-bit-only (e.g. highmem, and
CONFIG_DEBUG_PGALLOC in pgtable_32.c) Hugetlb is currently 64-bit only,
so we never saw a NULL vma here.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Commit fba2369e6ceb (mm: use vm_unmapped_area() on powerpc architecture)
has a bug in slice_scan_available() where we compare an unsigned long
(high_slices) against a shifted int. As a result, comparisons against
the top 32 bits of high_slices (representing the top 32TB) always
returns 0 and the top of our mmap region is clamped at 32TB
This also breaks mmap randomisation since the randomised address is
always up near the top of the address space and it gets clamped down
to 32TB.
Cc: stable@vger.kernel.org # v3.10+
Acked-by: Michel Lespinasse <walken@google.com>
__get_user_pages_fast() may be called with interrupts disabled (see e.g.
get_futex_key() in kernel/futex.c) and therefore should use local_irq_save()
and local_irq_restore() instead of local_irq_disable()/enable().
CC: <stable@vger.kernel.org> [v3.12]
Use "pgdat_end_pfn()" instead of "pgdat->node_start_pfn +
pgdat->node_spanned_pages". Simplify the code, no functional change.
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
The callers of free_pgd_range() and hugetlb_free_pgd_range() don't hold
page table locks. The comments seems to be obsolete, so let's remove
them.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Use __free_reserved_page() to simplify the code in arch.
It used split_page() in consistent_alloc()/__dma_alloc_coherent()/dma_alloc_coherent(),
so page->_count == 1, and we can free it safely.
ClearPageReserved()
init_page_count() // it won't change the value
__free_page()
Simple fixes for sparse warnings in this file.
Resolves:
arch/powerpc/mm/numa.c:198:24:
warning: Using plain integer as NULL pointer
arch/powerpc/mm/numa.c:1157:5:
warning: symbol 'hot_add_node_scn_to_nid' was not declared.
Should it be static?
arch/powerpc/mm/numa.c:1238:28:
arch/powerpc/mm/numa.c:1538:6:
warning: symbol 'topology_schedule_update' was not declared.
Signed-off-by: Robert C Jennings <rcj@linux.vnet.ibm.com>
Activating CONFIG_PIN_TLB allows access to the 24 first Mbytes of
memory at bootup instead of 8. It is needed for "big" kernels for
instance when activating CONFIG_LOCKDEP_SUPPORT. This needs to be
taken into account in init_32 too, otherwise memory allocation soon
fails after startup.
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
Acked-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
The commit e0908085fc2391c85b85fb814ae1df377c8e0dcb ("powerpc/8xx: Fix
regression introduced by cache coherency rewrite") is not needed
anymore. The issue was because dcbst wrongly sets the store bit when
causing a DTLB error, but this is now fixed by commit
0a2ab51ffb8dfdf51402dcfb446629648c96bc78 ("powerpc/8xx: Fixup DAR from
buggy dcbX instructions.") which handles the buggy dcbx instructions on
data page faults on the 8xx.
[scottwood@freescale.com: fix commit message]
Topic branch for commits that the KVM tree might want to pull
in separately.
Hand merged a few files due to conflicts with the LE stuff
The current VFIO-on-POWER implementation supports only user mode
driven mapping, i.e. QEMU is sending requests to map/unmap pages.
However this approach is really slow, so we want to move that to KVM.
Since H_PUT_TCE can be extremely performance sensitive (especially with
network adapters where each packet needs to be mapped/unmapped) we chose
to implement that as a "fast" hypercall directly in "real
mode" (processor still in the guest context but MMU off).
To be able to do that, we need to provide some facilities to
access the struct page count within that real mode environment as things
like the sparsemem vmemmap mappings aren't accessible.
This adds an API function realmode_pfn_to_page() to get page struct when
MMU is off.
This adds to MM a new function put_page_unless_one() which drops a page
if counter is bigger than 1. It is going to be used when MMU is off
(for example, real mode on PPC64) and we want to make sure that page
release will not happen in real mode as it may crash the kernel in
a horrible way.
CONFIG_SPARSEMEM_VMEMMAP and CONFIG_FLATMEM are supported.
Cc: linux-mm@kvack.org
Reviewed-by: Paul Mackerras <paulus@samba.org>
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Previous commit 46723bfa540... introduced a new config option
HAVE_BOOTMEM_INFO_NODE that ended up breaking memory hot-remove for ppc
when sparse vmemmap is not defined.
This patch defines HAVE_BOOTMEM_INFO_NODE for ppc and adds the call to
register_page_bootmem_info_node. Without this we get a BUG_ON for memory
hot remove in put_page_bootmem().
This also adds a stub for register_page_bootmem_memmap to allow ppc to build
with sparse vmemmap defined. Leaving this as a stub is fine since the same
vmemmap addresses are also handled in vmemmap_populate and as such are
properly mapped.
Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com>
CC: <stable@vger.kernel.org> [v3.9+]
Unlike global OOM handling, memory cgroup code will invoke the OOM killer
in any OOM situation because it has no way of telling faults occuring in
kernel context - which could be handled more gracefully - from
user-triggered faults.
Pass a flag that identifies faults originating in user space from the
architecture-specific fault handlers to generic code so that memcg OOM
handling can be improved.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: azurIt <azurit@pobox.sk>
Currently hugepage migration works well only for pmd-based hugepages
(mainly due to lack of testing,) so we had better not enable migration of
other levels of hugepages until we are ready for it.
Some users of hugepage migration (mbind, move_pages, and migrate_pages) do
page table walk and check pud/pmd_huge() there, so they are safe. But the
other users (softoffline and memory hotremove) don't do this, so without
this patch they can try to migrate unexpected types of hugepages.
To prevent this, we introduce hugepage_migration_support() as an
architecture dependent check of whether hugepage are implemented on a pmd
basis or not. And on some architecture multiple sizes of hugepages are
available, so hugepage_migration_support() also checks hugepage size.
Cc: Hillf Danton <dhillf@gmail.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
stack_grow_into/14082 is trying to acquire lock:
(&mm->mmap_sem){++++++}, at: [<c000000000206d28>] .might_fault+0x78/0xe0
but task is already holding lock:
(&mm->mmap_sem){++++++}, at: [<c0000000007ffd8c>] .do_page_fault+0x24c/0x910
Possible unsafe locking scenario:
CPU0
lock(&mm->mmap_sem);
*** DEADLOCK ***
May be due to missing lock nesting notation
1 lock held by stack_grow_into/14082:
#0: (&mm->mmap_sem){++++++}, at: [<c0000000007ffd8c>] .do_page_fault+0x24c/0x910
stack backtrace:
CPU: 21 PID: 14082 Comm: stack_grow_into Not tainted 3.10.0-10.el7.ppc64.debug #1
Call Trace:
[c0000003d396b850] [c000000000016e7c] .show_stack+0x7c/0x1f0 (unreliable)
[c0000003d396b920] [c000000000813fc8] .dump_stack+0x28/0x3c
[c0000003d396b990] [c000000000124b90] .__lock_acquire+0x1640/0x1800
[c0000003d396bab0] [c00000000012570c] .lock_acquire+0xac/0x250
[c0000003d396bb80] [c000000000206d54] .might_fault+0xa4/0xe0
[c0000003d396bbf0] [c0000000007ffe2c] .do_page_fault+0x2ec/0x910
[c0000003d396be30] [c0000000000092e8] handle_page_fault+0x10/0x30
"Here's the powerpc batch for this merge window. Some of the
highlights are:
- A bunch of endian fixes ! We don't have full LE support yet in that
release but this contains a lot of fixes all over arch/powerpc to
use the proper accessors, call the firmware with the right endian
mode, etc...
- A few updates to our "powernv" platform (non-virtualized, the one
to run KVM on), among other, support for bridging the P8 LPC bus
for UARTs, support and some EEH fixes.
- Some mpc51xx clock API cleanups in preparation for a clock API
overhaul
- A pile of cleanups of our old math emulation code, including better
support for using it to emulate optional FP instructions on
embedded chips that otherwise have a HW FPU.
- Some infrastructure in selftest, for powerpc now, but could be
generalized, initially used by some tests for our perf instruction
counting code.
- A pile of fixes for hotplug on pseries (that was seriously
bitrotting)
- The usual slew of freescale embedded updates, new boards, 64-bit
hiberation support, e6500 core PMU support, etc..."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (146 commits)
powerpc: Correct FSCR bit definitions
powerpc/xmon: Fix printing of set of CPUs in xmon
powerpc/pseries: Move lparcfg.c to platforms/pseries
powerpc/powernv: Return secondary CPUs to firmware on kexec
powerpc/btext: Fix CONFIG_PPC_EARLY_DEBUG_BOOTX on ppc32
powerpc: Cleanup handling of the DSCR bit in the FSCR register
powerpc/pseries: Child nodes are not detached by dlpar_detach_node
powerpc/pseries: Add mising of_node_put in delete_dt_node
powerpc/pseries: Make dlpar_configure_connector parent node aware
powerpc/pseries: Do all node initialization in dlpar_parse_cc_node
powerpc/pseries: Fix parsing of initial node path in update_dt_node
powerpc/pseries: Pack update_props_workarea to map correctly to rtas buffer header
powerpc/pseries: Fix over writing of rtas return code in update_dt_node
powerpc/pseries: Fix creation of loop in device node property list
powerpc: Skip emulating & leave interrupts off for kernel program checks
powerpc: Add more exception trampolines for hypervisor exceptions
powerpc: Fix location and rename exception trampolines
powerpc: Add more trap names to xmon
powerpc/pseries: Add a warning in the case of cross-cpu VPA registration
powerpc: Update the 00-Index in Documentation/powerpc
Pull trivial tree from Jiri Kosina:
"The usual trivial updates all over the tree -- mostly typo fixes and
documentation updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits)
doc: Documentation/cputopology.txt fix typo
treewide: Convert retrun typos to return
Fix comment typo for init_cma_reserved_pageblock
Documentation/trace: Correcting and extending tracepoint documentation
mm/hotplug: fix a typo in Documentation/memory-hotplug.txt
power: Documentation: Update s2ram link
doc: fix a typo in Documentation/00-INDEX
Documentation/printk-formats.txt: No casts needed for u64/s64
doc: Fix typo "is is" in Documentations
treewide: Fix printks with 0x%#
zram: doc fixes
Documentation/kmemcheck: update kmemcheck documentation
doc: documentation/hwspinlock.txt fix typo
PM / Hibernate: add section for resume options
doc: filesystems : Fix typo in Documentations/filesystems
scsi/megaraid fixed several typos in comments
ppc: init_32: Fix error typo "CONFIG_START_KERNEL"
treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks
page_isolation: Fix a comment typo in test_pages_isolated()
doc: fix a typo about irq affinity
Memory I/O resources need to be marked as busy or else we cannot remove
them when doing memory hot remove.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
The lppaca, slb_shadow and dtl_entry hypervisor structures are
big endian, so we have to byte swap them in little endian builds.
LE KVM hosts will also need to be fixed but for now add an #error
to remind us.
The device tree is big endian so make sure we byteswap on little
endian. We assume any pHyp calls also return big endian results in
memory.
Signed-off-by: Alistair Popple <alistair@popple.id.au>
Other architectures have a __get_user_pages_fast(), in addition to the
regular get_user_pages_fast(), which doesn't call get_user_pages() on
failure, and thus doesn't attempt to fault pages in or COW them. The
generic KVM code uses __get_user_pages_fast() to detect whether a page
for which we have only requested read access is actually writable.
This provides an implementation of __get_user_pages_fast() by
splitting the existing get_user_pages_fast() in two. With this, the
generic KVM code will get the right answer instead of always
considering such pages non-writable.
Although the shared_proc field in the lppaca works today, it is
not architected. A shared processor partition will always have a non
zero yield_count so use that instead. Create a wrapper so users
don't have to know about the details.
In order for older kernels to continue to work on KVM we need
to set the shared_proc bit. While here, remove the ugly bitfield.
