We are going to decouple splitting THP PMD from splitting underlying
compound page.
This patch renames split_huge_page_pmd*() functions to split_huge_pmd*()
to reflect the fact that it doesn't imply page splitting, only PMD.
Tested-by: Sasha Levin <sasha.levin@oracle.com>
Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Acked-by: Jerome Marchand <jmarchan@redhat.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Steve Capper <steve.capper@linaro.org>
Cc: Christoph Lameter <cl@linux.com>
We don't have to use mm_walk->private to pass vma to the callback function
because of mm_walk->vma. And walk_page_vma() is useful if we walk over a
single vma.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
pte_update() is a powerpc-ism used to change the bits of a PTE
when the access permission is being restricted (a flush is
potentially needed).
It uses atomic operations on when needed and handles the hash
synchronization on hash based processors.
It is currently only used to clear PTE bits and so the current
implementation doesn't provide a way to also set PTE bits.
The new _PAGE_NUMA bit, when set, is actually restricting access
so it must use that function too, so this change adds the ability
for pte_update() to also set bits.
We will use this later to set the _PAGE_NUMA bit.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Address some of the trivial sparse warnings in arch/powerpc.
We find all the overlapping vma and mark them such that we don't allocate
hugepage in that range. Also we split existing huge page so that the
normal page hash can be invalidated and new page faulted in with new
protection bits.
sys_subpage_prot() takes an unsigned long for 'addr' then does some stuff
with it and the result is stored in a signed int, i, which is eventually
used as the size parameter in a copy_from_user call. Update 'i' to be an
unsigned long as well and since 'nw' is used in a size_t context which,
depending on whether this is 32- or 64-bit may be unsigned int or unsigned
long, switch that to a size_t and always be right.
Finally, since we're in the neighbourhood, make the same changes to
subpage_prot_clear().
Signed-off-by: Joe MacDonald <joe.macdonald@windriver.com>
Acked-by: Paul Mackerras <paulus@samba.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Commit a0668cdc154e54bf0c85182e0535eea237d53146 cleans up the handling
of kmem_caches for allocating various levels of pagetables.
Unfortunately, it conflicts badly with CONFIG_PPC_SUBPAGE_PROT, due to
the latter's cleverly hidden technique of adding some extra allocation
space to the top level page directory to store the extra information
it needs.
Since that extra allocation really doesn't fit into the cleaned up
page directory allocating scheme, this patch alters
CONFIG_PPC_SUBPAGE_PROT to instead allocate its struct
subpage_prot_table as part of the mm_context_t.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
CONFIG_PPC_SUBPAGE_PROT"
This reverts commit c045256d146800ea1d741a8e9e377dada6b7e195.
It breaks build when CONFIG_PPC_SUBPAGE_PROT is not set. I will
commit a fixed version separately
it needs.
Using 64k pages on 64-bit PowerPC systems makes life difficult for
emulators that are trying to emulate an ISA, such as x86, which use a
smaller page size, since the emulator can no longer use the MMU and
the normal system calls for controlling page protections. Of course,
the emulator can emulate the MMU by checking and possibly remapping
the address for each memory access in software, but that is pretty
slow.
This provides a facility for such programs to control the access
permissions on individual 4k sub-pages of 64k pages. The idea is
that the emulator supplies an array of protection masks to apply to a
specified range of virtual addresses. These masks are applied at the
level where hardware PTEs are inserted into the hardware page table
based on the Linux PTEs, so the Linux PTEs are not affected. Note
that this new mechanism does not allow any access that would otherwise
be prohibited; it can only prohibit accesses that would otherwise be
allowed. This new facility is only available on 64-bit PowerPC and
only when the kernel is configured for 64k pages.
The masks are supplied using a new subpage_prot system call, which
takes a starting virtual address and length, and a pointer to an array
of protection masks in memory. The array has a 32-bit word per 64k
page to be protected; each 32-bit word consists of 16 2-bit fields,
for which 0 allows any access (that is otherwise allowed), 1 prevents
write accesses, and 2 or 3 prevent any access.
Implicit in this is that the regions of the address space that are
protected are switched to use 4k hardware pages rather than 64k
hardware pages (on machines with hardware 64k page support). In fact
the whole process is switched to use 4k hardware pages when the
subpage_prot system call is used, but this could be improved in future
to switch only the affected segments.
The subpage protection bits are stored in a 3 level tree akin to the
page table tree. The top level of this tree is stored in a structure
that is appended to the top level of the page table tree, i.e., the
pgd array. Since it will often only be 32-bit addresses (below 4GB)
that are protected, the pointers to the first four bottom level pages
are also stored in this structure (each bottom level page contains the
protection bits for 1GB of address space), so the protection bits for
addresses below 4GB can be accessed with one fewer loads than those
for higher addresses.
