allowed address space
According to Posix, if MAP_FIXED is specified mmap shall set ENOMEM if
the requested mapping exceeds the allowed range for address space of
the process. The generic code set it right, but the specific powerpc
slice_get_unmapped_area() function currently returns -EINVAL in that
case.
This patch corrects it.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Commit fba2369e6ceb (mm: use vm_unmapped_area() on powerpc architecture)
has a bug in slice_scan_available() where we compare an unsigned long
(high_slices) against a shifted int. As a result, comparisons against
the top 32 bits of high_slices (representing the top 32TB) always
returns 0 and the top of our mmap region is clamped at 32TB
This also breaks mmap randomisation since the randomised address is
always up near the top of the address space and it gets clamped down
to 32TB.
Cc: stable@vger.kernel.org # v3.10+
Acked-by: Michel Lespinasse <walken@google.com>
Update the powerpc slice_get_unmapped_area function to make use of
vm_unmapped_area() instead of implementing a brute force search.
Signed-off-by: Michel Lespinasse <walken@google.com>
Tested-by: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Acked-by: David Gibson <david@gibson.dropbear.id.au>
As all other architectures have been converted to use vm_unmapped_area(),
we are about to retire the free_area_cache.
This change simply removes the use of that cache in
slice_get_unmapped_area(), which will most certainly have a
performance cost. Next one will convert that function to use the
vm_unmapped_area() infrastructure and regain the performance.
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
"Whether" is misspelled in various comments across the tree; this
fixes them. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
slice array size and slice mask size depend on PGTABLE_RANGE.
Reviewed-by: Paul Mackerras <paulus@samba.org>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
This patch makes the high psizes mask as an unsigned char array
so that we can have more than 16TB. Currently we support upto
64TB
All these files were including module.h just for the basic
EXPORT_SYMBOL infrastructure. We can shift them off to the
export.h header which is a way smaller footprint and thus
realize some compile time gains.
powerpc: is_hugepage_only_range() must account for both 4kB and 64kB slices
The subpage_prot syscall fails on second and subsequent calls for a given
region, because is_hugepage_only_range() is mis-identifying the 4 kB
slices when the process has a 64 kB page size.
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Manual merge of:
arch/powerpc/Kconfig
arch/powerpc/kernel/stacktrace.c
arch/powerpc/mm/slice.c
arch/ppc/kernel/smp.c
At present, if we have a kernel with a 64kB page size, and some
process maps something that has to be mapped with 4kB pages (such as a
cache-inhibited mapping on POWER5+, or the eHCA infiniband queue-pair
pages), we change the process to use 4kB pages everywhere. This hurts
the performance of HPC programs that access eHCA from userspace.
With this patch, the kernel will only demote the slice(s) containing
the eHCA or cache-inhibited mappings, leaving the remaining slices
able to use 64kB hardware pages.
This also changes the slice_get_unmapped_area code so that it is
willing to place a 64k-page mapping into (or across) a 4k-page slice
if there is no better alternative, i.e. if the program specified
MAP_FIXED or if there is not sufficient space available in slices that
are either empty or already have 64k-page mappings in them.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
It's not even passed on to smp_call_function() anymore, since that
was removed. So kill it.
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Replace some SPIN_LOCK_UNLOCKED with DEFINE_SPINLOCK
Signed-off-by: Roel Kluin <12o3l@tiscali.nl>
arch/powerpc/mm/mmu_context_64.c: In function 'init_new_context':
arch/powerpc/mm/mmu_context_64.c:31: warning: unused variable 'new_context'
My "slices" address space management code that was added in the 2.6.22
implementation of get_unmapped_area() doesn't properly check that the
size is a multiple of the requested page size. This allows userland to
create VMAs that aren't a multiple of the huge page size with hugetlbfs
(since hugetlbfs entirely relies on get_unmapped_area() to do that
checking) which leads to a kernel BUG() when such areas are torn down.
The basic issue is to be able to do what hugetlbfs does but with
different page sizes for some other special filesystems; more
specifically, my need is:
- Huge pages
- SPE local store mappings using 64K pages on a 4K base page size
kernel on Cell
- Some special 4K segments in 64K-page kernels for mapping a dodgy
type of powerpc-specific infiniband hardware that requires 4K MMU
mappings for various reasons I won't explain here.
The main issues are:
- To maintain/keep track of the page size per "segment" (as we can
only have one page size per segment on powerpc, which are 256MB
divisions of the address space).
- To make sure special mappings stay within their allotted
"segments" (including MAP_FIXED crap)
- To make sure everybody else doesn't mmap/brk/grow_stack into a
"segment" that is used for a special mapping
Some of the necessary mechanisms to handle that were present in the
hugetlbfs code, but mostly in ways not suitable for anything else.
The patch relies on some changes to the generic get_unmapped_area()
that just got merged. It still hijacks hugetlb callbacks here or
there as the generic code hasn't been entirely cleaned up yet but
that shouldn't be a problem.
So what is a slice ? Well, I re-used the mechanism used formerly by our
hugetlbfs implementation which divides the address space in
"meta-segments" which I called "slices". The division is done using
256MB slices below 4G, and 1T slices above. Thus the address space is
divided currently into 16 "low" slices and 16 "high" slices. (Special
case: high slice 0 is the area between 4G and 1T).
Doing so simplifies significantly the tracking of segments and avoids
having to keep track of all the 256MB segments in the address space.
While I used the "concepts" of hugetlbfs, I mostly re-implemented
everything in a more generic way and "ported" hugetlbfs to it.
Slices can have an associated page size, which is encoded in the mmu
context and used by the SLB miss handler to set the segment sizes. The
hash code currently doesn't care, it has a specific check for hugepages,
though I might add a mechanism to provide per-slice hash mapping
functions in the future.
The slice code provide a pair of "generic" get_unmapped_area() (bottomup
and topdown) functions that should work with any slice size. There is
some trickiness here so I would appreciate people to have a look at the
implementation of these and let me know if I got something wrong.
