path: root/arch/powerpc/mm/highmem.c
2010-10-27mm: fix race in kunmap_atomic()Peter Zijlstra
Christoph reported a nice splat which illustrated a race in the new stack based kmap_atomic implementation. The problem is that we pop our stack slot before we're completely done resetting its state -- in particular clearing the PTE (sometimes that's CONFIG_DEBUG_HIGHMEM). If an interrupt happens before we actually clear the PTE used for the last slot, that interrupt can reuse the slot in a dirty state, which triggers a BUG in kmap_atomic(). Fix this by introducing kmap_atomic_idx() which reports the current slot index without actually releasing it and use that to find the PTE and delay the _pop() until after we're completely done. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Christoph Hellwig <hch@infradead.org> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: stack based kmap_atomic()Peter Zijlstra
Keep the current interface but ignore the KM_type and use a stack based approach. The advantage is that we get rid of crappy code like: #define __KM_PTE \ (in_nmi() ? KM_NMI_PTE : \ in_irq() ? KM_IRQ_PTE : \ KM_PTE0) and in general can stop worrying about what context we're in and what kmap slots might be appropriate for that. The downside is that FRV kmap_atomic() gets more expensive. For now we use a CPP trick suggested by Andrew: #define kmap_atomic(page, args...) __kmap_atomic(page) to avoid having to touch all kmap_atomic() users in a single patch. [ not compiled on: - mn10300: the arch doesn't actually build with highmem to begin with ] [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix up drivers/gpu/drm/i915/intel_overlay.c] Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Airlie <airlied@linux.ie> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09kmap_atomic: make kunmap_atomic() harder to misuseCesar Eduardo Barros
kunmap_atomic() is currently at level -4 on Rusty's "Hard To Misuse" list[1] ("Follow common convention and you'll get it wrong"), except in some architectures when CONFIG_DEBUG_HIGHMEM is set[2][3]. kunmap() takes a pointer to a struct page; kunmap_atomic(), however, takes takes a pointer to within the page itself. This seems to once in a while trip people up (the convention they are following is the one from kunmap()). Make it much harder to misuse, by moving it to level 9 on Rusty's list[4] ("The compiler/linker won't let you get it wrong"). This is done by refusing to build if the type of its first argument is a pointer to a struct page. The real kunmap_atomic() is renamed to kunmap_atomic_notypecheck() (which is what you would call in case for some strange reason calling it with a pointer to a struct page is not incorrect in your code). The previous version of this patch was compile tested on x86-64. [1] http://ozlabs.org/~rusty/index.cgi/tech/2008-04-01.html [2] In these cases, it is at level 5, "Do it right or it will always break at runtime." [3] At least mips and powerpc look very similar, and sparc also seems to share a common ancestor with both; there seems to be quite some degree of copy-and-paste coding here. The include/asm/highmem.h file for these three archs mention x86 CPUs at its top. [4] http://ozlabs.org/~rusty/index.cgi/tech/2008-03-30.html [5] As an aside, could someone tell me why mn10300 uses unsigned long as the first parameter of kunmap_atomic() instead of void *? Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Russell King <linux@arm.linux.org.uk> (arch/arm) Cc: Ralf Baechle <ralf@linux-mips.org> (arch/mips) Cc: David Howells <dhowells@redhat.com> (arch/frv, arch/mn10300) Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> (arch/mn10300) Cc: Kyle McMartin <kyle@mcmartin.ca> (arch/parisc) Cc: Helge Deller <deller@gmx.de> (arch/parisc) Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> (arch/parisc) Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> (arch/powerpc) Cc: Paul Mackerras <paulus@samba.org> (arch/powerpc) Cc: "David S. Miller" <davem@davemloft.net> (arch/sparc) Cc: Thomas Gleixner <tglx@linutronix.de> (arch/x86) Cc: Ingo Molnar <mingo@redhat.com> (arch/x86) Cc: "H. Peter Anvin" <hpa@zytor.com> (arch/x86) Cc: Arnd Bergmann <arnd@arndb.de> (include/asm-generic) Cc: Rusty Russell <rusty@rustcorp.com.au> ("Hard To Misuse" list) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-26powerpc/mm: Make k(un)map_atomic out of lineBenjamin Herrenschmidt
Those functions are way too big to be inline, besides, kmap_atomic() wants to call debug_kmap_atomic() which isn't exported for modules and causes module link failures. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
