path: root/arch/powerpc/kernel/traps.c
2012-09-19powerpc: Keep thread.dscr and thread.dscr_inherit in syncAnton Blanchard
commit 00ca0de02f80924dfff6b4f630e1dff3db005e35 upstream. When we update the DSCR either via emulation of mtspr(DSCR) or via a change to dscr_default in sysfs we don't update thread.dscr. We will eventually update it at context switch time but there is a period where thread.dscr is incorrect. If we fork at this point we will copy the old value of thread.dscr into the child. To avoid this, always keep thread.dscr in sync with reality. This issue was found with the following testcase: http://ozlabs.org/~anton/junkcode/dscr_inherit_test.c Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2011-11-17powerpc: Remove extraneous CONFIG_PPC_ADV_DEBUG_REGS defineKumar Gala
All of DebugException is already protected by CONFIG_PPC_ADV_DEBUG_REGS there is no need to have another such ifdef inside the function. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-10-06powerpc/fsl-booke: Handle L1 D-cache parity error correctly on e500mcKumar Gala
If the L1 D-Cache is in write shadow mode the HW will auto-recover the error. However we might still log the error and cause a machine check (if L1CSR0[CPE] - Cache error checking enable). We should only treat the non-write shadow case as non-recoverable. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-12powerpc/e500: Save SPEFCSR in flush_spe_to_thread()yu liu
giveup_spe() saves the SPE state which is protected by MSR[SPE]. However, modifying SPEFSCR does not trap when MSR[SPE]=0. And since SPEFSCR is already saved/restored in _switch(), not all the callers want to save SPEFSCR again. Thus, saving SPEFSCR should not belong to giveup_spe(). This patch moves SPEFSCR saving to flush_spe_to_thread(), and cleans up the caller that needs to save SPEFSCR accordingly. Signed-off-by: Liu Yu <yu.liu@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-06-29arch/powerpc: use printk_ratelimited instead of printk_ratelimitChristian Dietrich
Since printk_ratelimit() shouldn't be used anymore (see comment in include/linux/printk.h), replace it with printk_ratelimited. Signed-off-by: Christian Dietrich <christian.dietrich@informatik.uni-erlangen.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-06-22powerpc/e500: fix breakage with fsl_rio_mcheck_exceptionScott Wood
The wrong MCSR bit was being used on e500mc. MCSR_BUS_RBERR only exists on e500v1/v2. Use MCSR_LD on e500mc, and remove all MCSR checking in fsl_rio_mcheck_exception as we now no longer call that function if the appropriate bit in MCSR is not set. If RIO support was enabled at compile-time, but was never probed, just return from fsl_rio_mcheck_exception rather than dereference a NULL pointer. TODO: There is still a remaining, though comparitively minor, issue in that this recovery mechanism will falsely engage if there's an unrelated MCSR_LD event at the same time as a RIO error. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-05-20powerpc/fsl_rio: move machine_check handlerShaohui Xie
Add support for machine_check support into machine_check_e500 and machine_check_e500mc. Signed-off-by: Shaohui Xie <b21989@freescale.com> Cc: Li Yang <leoli@freescale.com> Cc: Roy Zang <tie-fei.zang@freescale.com> Cc: Alexandre Bounine <alexandre.bounine@idt.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-05-20Merge remote branch 'origin/master' into mergeBenjamin Herrenschmidt
Manual merge of arch/powerpc/kernel/smp.c and add missing scheduler_ipi() call to arch/powerpc/platforms/cell/interrupt.c Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-13sysfs: remove "last sysfs file:" line from the oops messagesGreg Kroah-Hartman
On some arches (x86, sh, arm, unicore, powerpc) the oops message would print out the last sysfs file accessed. This was very useful in finding a number of sysfs and driver core bugs in the 2.5 and early 2.6 development days, but it has been a number of years since this file has actually helped in debugging anything that couldn't also be trivially determined from the stack traceback. So it's time to delete the line. This is good as we need all the space we can get for oops messages at times on consoles. Acked-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-04powerpc: Convert old cpumask API into new oneKOSAKI Motohiro
Adapt new API. Almost change is trivial. Most important change is the below line because we plan to change task->cpus_allowed implementation. - ctx->cpus_allowed = current->cpus_allowed; Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-27powerpc: Use MSR_64BIT in placesMichael Ellerman
Use the new MSR_64BIT in a few places. Some of these are already ifdef'ed for BOOKE vs BOOKS, but it's still clearer, MSR_SF does not immediately parse as "MSR bit for 64bit". Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-27powerpc: Per process DSCR + some fixes (try#4)Alexey Kardashevskiy
The DSCR (aka Data Stream Control Register) is supported on some server PowerPC chips and allow some control over the prefetch of data streams. This patch allows the value to be specified per thread by emulating the corresponding mfspr and mtspr instructions. Children of such threads inherit the value. Other threads use a default value that can be specified in sysfs - /sys/devices/system/cpu/dscr_default. If a thread starts with non default value in the sysfs entry, all children threads inherit this non default value even if the sysfs value is changed later. Signed-off-by: Alexey Kardashevskiy <aik@au1.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-01-21powerpc: Don't silently handle machine checks from userspaceAnton Blanchard
If a machine check comes from userspace we send a SIGBUS to the task and fail to printk anything. If we are taking machine checks due to bad hardware we want to know about it right away. Furthermore if we don't complain loudly then it will look a lot like a bug in the userspace application, potentially causing a lot of confusion. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-01-21powerpc: Remove duplicate debugger hook in machine_check_exceptionAnton Blanchard
We are calling debugger_fault_handler twice in machine_check_exception. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-01-21powerpc: Don't force MSR_RI in machine_check_exceptionAnton Blanchard
We should never force MSR_RI on. If we take a machine check with MSR_RI off then we have no chance of recovering safely. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-10-14powerpc/fsl-booke: Add support for FSL 64-bit e5500 coreKumar Gala
The new e5500 core is similar to the e500mc core but adds 64-bit support. We support running it in 32-bit mode as it is identical to the e500mc. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-09powerpc/book3e: Move doorbell_exception from traps.c to dbell.cBenjamin Herrenschmidt
... where it belongs Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-06-22powerpc, hw_breakpoint: Handle concurrent alignment interruptsK.Prasad
If an alignment interrupt occurs on an instruction that is being single-stepped, the alignment interrupt handler currently handles the single-step condition by unconditionally sending a SIGTRAP to the process. Other synchronous interrupts that result in the instruction being emulated do likewise. With hw_breakpoint support, the hw_breakpoint code needs to be able to intercept these single-step events as well as those where the instruction executes normally and a trace interrupt happens. Fix this by making emulate_single_step() use the existing single_step_exception() function instead of calling _exception() directly. We then make single_step_exception() use the abstracted clear_single_step() rather than clearing bits in the MSR image directly so that emulate_single_step() will continue to work correctly on Book 3E processors. Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2010-05-31Merge commit 'kumar/next' into nextBenjamin Herrenschmidt
Conflicts: arch/powerpc/sysdev/fsl_msi.c
2010-05-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (92 commits) powerpc: Remove unused 'protect4gb' boot parameter powerpc: Build-in e1000e for pseries & ppc64_defconfig powerpc/pseries: Make request_ras_irqs() available to other pseries code powerpc/numa: Use ibm,architecture-vec-5 to detect form 1 affinity powerpc/numa: Set a smaller value for RECLAIM_DISTANCE to enable zone reclaim powerpc: Use smt_snooze_delay=-1 to always busy loop powerpc: Remove check of ibm,smt-snooze-delay OF property powerpc/kdump: Fix race in kdump shutdown powerpc/kexec: Fix race in kexec shutdown powerpc/kexec: Speedup kexec hash PTE tear down powerpc/pseries: Add hcall to read 4 ptes at a time in real mode powerpc: Use more accurate limit for first segment memory allocations powerpc/kdump: Use chip->shutdown to disable IRQs powerpc/kdump: CPUs assume the context of the oopsing CPU powerpc/crashdump: Do not fail on NULL pointer dereferencing powerpc/eeh: Fix oops when probing in early boot powerpc/pci: Check devices status property when scanning OF tree powerpc/vio: Switch VIO Bus PM to use generic helpers powerpc: Avoid bad relocations in iSeries code powerpc: Use common cpu_die (fixes SMP+SUSPEND build) ...
2010-05-21powerpc/e500mc: Implement machine check handler.Scott Wood
Most of the MSCR bit assigments are different in e500mc versus e500, and they are now write-one-to-clear. Some e500mc machine check conditions are made recoverable (as long as they aren't stuck on), most notably L1 instruction cache parity errors. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-05-20powerpc,kgdb: Introduce low level trap catchingJason Wessel
The only way the debugger can handle a trap in inside rcu_lock, notify_die, or atomic_notifier_call_chain without a recursive fault is to allow the kernel debugger to handle the exception first in program_check_exception(). The other change here is to make sure that kgdb_handle_exception() is called with correct parameters when catching an oops, because kdb needs to know if the entry was an oops, single step, or breakpoint exception. [benh@kernel.crashing.org: move debugger_bpt instead of #ifdef] CC: Paul Mackerras <paulus@samba.org> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-05-05powerpc/476: add machine check handler for 47x coreDave Kleikamp
The 47x core's MCSR varies from 44x, so it needs it's own machine check handler. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-19powerpc: Convert die.lock to raw_spinlockThomas Gleixner
die.lock needs to be a real spinlock in RT. Convert it to raw_spinlock. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-02-17powerpc/booke: Add support for advanced debug registersDave Kleikamp
powerpc/booke: Add support for advanced debug registers From: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Based on patches originally written by Torez Smith. This patch defines context switch and trap related functionality for BookE specific Debug Registers. It adds support to ptrace() for setting and getting BookE related Debug Registers Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: Torez Smith <lnxtorez@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Gibson <dwg@au1.ibm.com> Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Sergio Durigan Junior <sergiodj@br.ibm.com> Cc: Thiago Jung Bauermann <bauerman@br.ibm.com> Cc: linuxppc-dev list <Linuxppc-dev@ozlabs.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-02-17powerpc/booke: Introduce new CONFIG options for advanced debug registersDave Kleikamp
powerpc/booke: Introduce new CONFIG options for advanced debug registers From: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Introduce new config options to simplify the ifdefs pertaining to the advanced debug registers for booke and 40x processors: CONFIG_PPC_ADV_DEBUG_REGS - boolean: true for dac-based processors CONFIG_PPC_ADV_DEBUG_IACS - number of IAC registers CONFIG_PPC_ADV_DEBUG_DACS - number of DAC registers CONFIG_PPC_ADV_DEBUG_DVCS - number of DVC registers CONFIG_PPC_ADV_DEBUG_DAC_RANGE - DAC ranges supported Beginning conservatively, since I only have the facilities to test 440 hardware. I believe all 40x and booke platforms support at least 2 IAC and 2 DAC registers. For 440, 4 IAC and 2 DVC registers are enabled, as well as the DAC ranges. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Acked-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-02-17powerpc: Add timer, performance monitor and machine check counts to ↵Anton Blanchard
/proc/interrupts With NO_HZ it is useful to know how often the decrementer is going off. The patch below adds an entry for it and also adds it into the /proc/stat summaries. While here, I added performance monitoring and machine check exceptions. I found it useful to keep an eye on the PMU exception rate when using the perf tool. Since it's possible to take a completely handled machine check on a System p box it also sounds like a good idea to keep a machine check summary. The event naming matches x86 to keep gratuitous differences to a minimum. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-02-09powerpc: Add last sysfs file and dump of ftrace buffer to oops printoutAnton Blanchard
Add printout of last accessed sysfs file, added to x86 in ae87221d3ce49d9de1e43756da834fd0bf05a2ad (sysfs: crash debugging) Also add the notify_die hook that allows us to print out the ftrace buffer on oops. This is useful in conjunction with ftrace function_graph: Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=128 NUMA pSeries last sysfs file: /sys/class/net/tunl0/type Dumping ftrace buffer: ... 0) | .sysrq_handle_crash() { 0) 0.476 us | .hash_page(); 0) 0.488 us | .xmon_fault_handler(); 0) | .bad_page_fault() { 0) | .search_exception_tables() { 0) 0.590 us | .search_module_extables(); 0) 2.546 us | } 0) | .printk() { 0) | .vprintk() { 0) 0.488 us | ._raw_spin_lock(); 0) 0.572 us | .emit_log_char(); Showing the function graph of a sysrq-c crash. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-02-03powerpc: Mark some variables in the page fault path __read_mostlyAnton Blanchard
Using perf to trace L1 dcache misses and dumping data addresses I found a few variables taking a lot of misses. Since they are almost never written, they should go into the __read_mostly section. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-16ptrace: powerpc: implement user_single_step_siginfo()Oleg Nesterov
Suggested by Roland. Implement user_single_step_siginfo() for powerpc. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: <linux-arch@vger.kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-09Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Conflicts: include/linux/kvm.h
2009-11-24powerpc: kill the obsolete code under is_global_init()Benjamin Herrenschmidt
The code under "if (is_global_init())" is bogus, and is_global_init() itself is not right in mt case. Contrary to what the comment says, nowadays force_sig_info() does kill init even if the handler is SIG_DFL. Note that force_sig_info() clears SIGNAL_UNKILLABLE exactly for this case. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-28powerpc: Create PPC_WARN_ALIGNMENT to match PPC_WARN_EMULATEDAnton Blanchard
perf_event wants a separate event for alignment and emulation faults, so create another emulation event. This will make it easy to hook in perf_event at one spot. We pass in regs which will be required for these events. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-06-09powerpc: Add PTRACE_SINGLEBLOCK supportRoland McGrath
Reworked by: Benjamin Herrenschmidt <benh@kernel.crashing.org> This adds block-step support on powerpc, including a PTRACE_SINGLEBLOCK request for ptrace. The BookE implementation is tweaked to fire a single step after a block step in order to mimmic the server behaviour. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-21powerpc: Keep track of emulated instructionsGeert Uytterhoeven
If CONFIG_PPC_EMULATED_STATS is enabled, make available counters for the various classes of emulated instructions under /sys/kernel/debug/powerpc/emulated_instructions/ (assumed debugfs is mounted on /sys/kernel/debug). Optionally (controlled by /sys/kernel/debug/powerpc/emulated_instructions/do_warn), rate-limited warnings can be printed to the console when instructions are emulated. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-23powerpc: Add support for using doorbells for SMP IPIKumar Gala
The e500mc supports the new msgsnd/doorbell mechanisms that were added in the Power ISA 2.05 architecture. We use the normal level doorbell for doing SMP IPIs at this point. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-23powerpc: Unify opcode definitions and supportKumar Gala
Create a new header that becomes a single location for defining PowerPC opcodes used by code that is either generationg instructions at runtime (fixups, debug, etc.), emulating instructions, or just compiling instructions old assemblers don't know about. We currently don't handle the floating point emulation or alignment decode as both are better handled by the specific decode support they already have. Added support for the new dcbzl, dcbal, msgsnd, tlbilx, & wait instructions since older assemblers don't know about them. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-12-03powerpc: Add SPE/EFP math emulation for E500v1/v2 processors.Liu Yu
This patch add the handlers of SPE/EFP exceptions. The code is used to emulate float point arithmetic, when MSR(SPE) is enabled and receive EFP data interrupt or EFP round interrupt. This patch has no conflict with or dependence on FP math-emu. The code has been tested by TestFloat. Now the code doesn't support SPE/EFP instructions emulation (it won't be called when receive program interrupt), but it could be easily added. Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-06Remove asm/a.out.h files for all architectures without a.out support.Adrian Bunk
This patch also includes the required removal of (unused) inclusion of <asm/a.out.h> <linux/a.out.h>'s in the arch/ code for these architectures. [dwmw2: updated for 2.6.27-rc] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-25powerpc: BookE hardware watchpoint supportLuis Machado
This patch implements support for HW based watchpoint via the DBSR_DAC (Data Address Compare) facility of the BookE processors. It does so by interfacing with the existing DABR breakpoint code and adding the necessary bits and pieces for the new bits to be properly set or cleared Signed-off-by: Luis Machado <luisgpm@br.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-01powerpc: Add VSX context save/restore, ptrace and signal supportMichael Neuling
This patch extends the floating point save and restore code to use the VSX load/stores when VSX is available. This will make FP context save/restore marginally slower on FP only code, when VSX is available, as it has to load/store 128bits rather than just 64bits. Mixing FP, VMX and VSX code will get constant architected state. The signals interface is extended to enable access to VSR 0-31 doubleword 1 after discussions with tool chain maintainers. Backward compatibility is maintained. The ptrace interface is also extended to allow access to VSR 0-31 full registers. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-26powerpc/booke: Add kprobes support for booke style processorsKumar Gala
This patch is based on work done by Madhvesh. R. Sulibhavi back in March 2007. We refactor some of the single step handling since it differs between "classic" and "booke" powerpc cores. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-07[POWERPC] Fix compilation for CONFIG_DEBUGGER=n and CONFIG_KEXEC=yOlof Johansson
Looks like "[POWERPC] kdump shutdown hook support" broke builds when CONFIG_DEBUGGER=n and CONFIG_KEXEC=y, such as in g5_defconfig: arch/powerpc/kernel/crash.c: In function 'default_machine_crash_shutdown': arch/powerpc/kernel/crash.c:388: error: '__debugger_fault_handler' undeclared (first use in this function) arch/powerpc/kernel/crash.c:388: error: (Each undeclared identifier is reported only once arch/powerpc/kernel/crash.c:388: error: for each function it appears in.) Move the debugger hooks to under CONFIG_DEBUGGER || CONFIG_KEXEC, since that's when the crash code is enabled. (I should have caught this with my build-script pre-merge, my bad. :( ) Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-23[POWERPC] Reworking machine check handling and Fix 440/440ABenjamin Herrenschmidt
This adds a cputable function pointer for the CPU-side machine check handling. The semantic is still the same as the old one, the one in ppc_md. overrides the one in cputable, though ultimately we'll want to change that so the CPU gets first. This removes CONFIG_440A which was a problem for multiplatform kernels and instead fixes up the IVOR at runtime from a setup_cpu function. The "A" version of the machine check also tweaks the regs->trap value to differenciate the 2 versions at the C level. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-11[POWERPC] Emulate isel (Integer Select) instructionKumar Gala
isel (Integer Select) is a new user space instruction in the PowerISA 2.04 spec. Not all processors implement it so lets emulate to ensure code built with isel will run everywhere. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-19Use helpers to obtain task pid in printks (arch code)Alexey Dobriyan
One of the easiest things to isolate is the pid printed in kernel log. There was a patch, that made this for arch-independent code, this one makes so for arch/xxx files. It took some time to cross-compile it, but hopefully these are all the printks in arch code. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: define is_global_init() and is_container_init()Serge E. Hallyn
is_init() is an ambiguous name for the pid==1 check. Split it into is_global_init() and is_container_init(). A cgroup init has it's tsk->pid == 1. A global init also has it's tsk->pid == 1 and it's active pid namespace is the init_pid_ns. But rather than check the active pid namespace, compare the task structure with 'init_pid_ns.child_reaper', which is initialized during boot to the /sbin/init process and never changes. Changelog: 2.6.22-rc4-mm2-pidns1: - Use 'init_pid_ns.child_reaper' to determine if a given task is the global init (/sbin/init) process. This would improve performance and remove dependence on the task_pid(). 2.6.21-mm2-pidns2: - [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc, ppc,avr32}/traps.c for the _exception() call to is_global_init(). This way, we kill only the cgroup if the cgroup's init has a bug rather than force a kernel panic. [akpm@linux-foundation.org: fix comment] [sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c] [bunk@stusta.de: kernel/pid.c: remove unused exports] [sukadev@us.ibm.com: Fix capability.c to work with threaded init] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[POWERPC] Implement logging of unhandled signalsOlof Johansson
Implement show_unhandled_signals sysctl + support to print when a process is killed due to unhandled signals just as i386 and x86_64 does. Default to having it off, unlike x86 that defaults on. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
