Although we are now selecting NO_BOOTMEM, we still have some traces of
bootmem lying around. That is because even with NO_BOOTMEM there is
still a shim that converts bootmem calls into memblock calls, but
ultimately we want to remove all traces of bootmem.
Most of the patch is conversions from alloc_bootmem() to
memblock_virt_alloc(). In general a call such as:
p = (struct foo *)alloc_bootmem(x);
Becomes:
p = memblock_virt_alloc(x, 0);
We don't need the cast because memblock_virt_alloc() returns a void *.
The alignment value of zero tells memblock to use the default alignment,
which is SMP_CACHE_BYTES, the same value alloc_bootmem() uses.
We remove a number of NULL checks on the result of
memblock_virt_alloc(). That is because memblock_virt_alloc() will panic
if it can't allocate, in exactly the same way as alloc_bootmem(), so the
NULL checks are and always have been redundant.
The memory returned by memblock_virt_alloc() is already zeroed, so we
remove several memsets of the result of memblock_virt_alloc().
Finally we convert a few uses of __alloc_bootmem(x, y, MAX_DMA_ADDRESS)
to just plain memblock_virt_alloc(). We don't use memblock_alloc_base()
because MAX_DMA_ADDRESS is ~0ul on powerpc, so limiting the allocation
to that is pointless, 16XB ought to be enough for anyone.
The PCI core supports an offset per aperture nowadays but our arch
code still has a single offset per host bridge representing the
difference betwen CPU memory addresses and PCI MMIO addresses.
This is a problem as new machines and hypervisor versions are
coming out where the 64-bit windows will have a different offset
(basically mapped 1:1) from the 32-bit windows.
This fixes it by using separate offsets. In the long run, we probably
want to get rid of that intermediary struct pci_controller and have
those directly stored into the pci_host_bridge as they are parsed
but this will be a more invasive change.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Rename the prom_*_property routines of the generic OF code to of_*_property.
This brings them in line with the naming used by the rest of the OF code.
Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Acked-by: Geoff Levand <geoff@infradead.org>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Make sure we compute CPU addresses (resource start/end) the same way both
when we set up the I/O aperture (hose->io_resource) and when we use
pcibios_bus_to_resource() to convert BAR values into resources.
This fixes a build failure ("cast from pointer to integer of different
size" in configs where resource_size_t is 64 bits but pointers are 32 bits)
I introduced in 6c5705fec63d.
Acked-By: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Fix failures in powerpc associated with the previously allowed
implicit module.h presence that now lead to things like this:
arch/powerpc/mm/mmu_context_hash32.c:76:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL'
arch/powerpc/mm/tlb_hash32.c:48:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL'
arch/powerpc/kernel/pci_32.c:51:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL'
arch/powerpc/kernel/iomap.c:36:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL'
arch/powerpc/platforms/44x/canyonlands.c:126:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL'
arch/powerpc/kvm/44x.c:168:59: error: 'THIS_MODULE' undeclared (first use in this function)
[with several contibutions from Stephen Rothwell <sfr@canb.auug.org.au>]
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: Consolidate the clkdev header files
ARM: set vga memory base at run-time
ARM: convert PCI defines to variables
ARM: pci: make pcibios_assign_all_busses use pci_has_flag
ARM: remove unnecessary mach/hardware.h includes
pci: move microblaze and powerpc pci flag functions into asm-generic
powerpc: rename ppc_pci_*_flags to pci_*_flags
Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits)
drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c
powerpc/85xx: fix mpic configuration in CAMP mode
powerpc: Copy back TIF flags on return from softirq stack
powerpc/64: Make server perfmon only built on ppc64 server devices
powerpc/pseries: Fix hvc_vio.c build due to recent changes
powerpc: Exporting boot_cpuid_phys
powerpc: Add CFAR to oops output
hvc_console: Add kdb support
powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon
powerpc/irq: Quieten irq mapping printks
powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs
powerpc: Add mpt2sas driver to pseries and ppc64 defconfig
powerpc: Disable IRQs off tracer in ppc64 defconfig
powerpc: Sync pseries and ppc64 defconfigs
powerpc/pseries/hvconsole: Fix dropped console output
hvc_console: Improve tty/console put_chars handling
powerpc/kdump: Fix timeout in crash_kexec_wait_realmode
powerpc/mm: Fix output of total_ram.
powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards
powerpc: Correct annotations of pmu registration functions
Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and
drivers/cpufreq
This renames pci flags functions and enums in preparation for creating
generic version in asm-generic/pci-bridge.h. The following search and
replace is done:
s/ppc_pci_/pci_/
s/PPC_PCI_/PCI_/
Direct accesses to ppc_pci_flag variable are replaced with helper
functions.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
We need the FSL specific header fixup code on both 32-bit and 64-bit
platforms so just move the code into pci-common.c.
powerpc has two different ways of matching PCI devices to their
corresponding OF node (if any) for historical reasons. The ppc64 one
does a scan looking for matching bus/dev/fn, while the ppc32 one does a
scan looking only for matching dev/fn on each level in order to be
agnostic to busses being renumbered (which Linux does on some
platforms).
This removes both and instead moves the matching code to the PCI core
itself. It's the most logical place to do it: when a pci_dev is created,
we know the parent and thus can do a single level scan for the matching
device_node (if any).
The benefit is that all archs now get the matching for free. There's one
hook the arch might want to provide to match a PHB bus to its device
node. A default weak implementation is provided that looks for the
parent device device node, but it's not entirely reliable on powerpc for
various reasons so powerpc provides its own.
Acked-by: Michal Simek <monstr@monstr.eu>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Currently, ppc32 uses sysdata for the pci_controller pointer, and
ppc64 uses it to hold the device_node pointer. This patch moves the
of_node pointer into (struct pci_bus*)->dev.of_node and
(struct pci_dev*)->dev.of_node so that sysdata can be converted to always
use the pci_controller pointer instead. It also fixes up the
allocating of pci devices so that the of_node pointer gets assigned
consistently and increments the ref count.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The two versions are doing almost exactly the same thing. No need to
maintain them as separate files. This patch also has the side effect
of making the PCI device tree scanning code available to 32 bit powerpc
machines, but no board ports actually make use of this feature at this
point.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Some of the PCI features we have in ppc32 we will need on ppc64
platforms in the future. These include support for:
* ppc_md.pci_exclude_device
* indirect config cycles
* early config cycles
We also simplified the logic in fake_pci_bus() to assume it will always
get a valid pci_controller. Since all current callers seem to pass it
one.
PPC_OF is always selected for arch/powerpc. This patch removes the stale
#defines
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
The pcnet32 driver has had in its device id table for some time a match
against the "broken" vendor ID. No need to fake out the vendor ID
with an explicit fixup.
* Removed building setup-irq on ppc32, we don't use it anymore
* Remove duplicate prototype for setup_grackle() code that needs it
gets it from <asm/grackle.h>
* Removed gratuitous pci_io_size type differences between ppc32/ppc64
Old OF variants used to create a 'dummy' parent node "multifunc-device"
for devices with more than one PCI function. Our code that matches OF
nodes to PCI devices dealt with that in one place but not in another,
this fixes it.
This has the practical effect of fixing interrupt routing of multifunction
PCI cards on some older PowerMac machines.
Signed-off-by: Tom Arbuckle <tom.d.arbuckle@gmail.com>
move the definition of hose_list next to its hotplug spinlock.
create pcibios_io_size to encapsulate ifdef in existing pci-common
function pcibios_vaddr_is_ioport
move pci_address_to_pio to pci-common, using new pcibios_io_size, and
protect this GPL exported function against concurrent hotplug removal
Signed-off-by: Milton Miller <miltonm@bga.com>
The `have_of' variable is a relic from the arch/ppc time, it isn't
useful nowadays.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
The function pcibios_do_bus_setup() was used by pcibios_fixup_bus()
to perform setup that is different between the 32-bit and 64-bit
code. This difference no longer exists, thus the function is removed
and the setup now done directly from pci-common.c.
The 32-bit and 64-bit powerpc PCI code used to set up the resource
pointers of the root bus of a given PHB in completely different
places.
This unifies this in large part, by making 32-bit use a routine very
similar to what 64-bit does when initially scanning the PCI busses.
The actual setup of the PHB resources itself is then moved to a
common function in pci-common.c.
This should cause no functional change on 64-bit. On 32-bit, the
effect is that the PHB resources are going to be setup a bit earlier,
instead of being setup from pcibios_fixup_bus().
This removes the various DBG() macro from the powerpc PCI code and
makes it use the standard pr_debug instead.
The new merged DMA code will try to access isa_bridge_pcidev when
trying to DMA to/from legacy devices. This is however only defined
on 64-bit. Fixes this for now by adding the variable, even if it
stays NULL. In the long run, we'll make isa-bridge.c common to
32 and 64-bit.
The class of the MPC5121 pci host bridge is PCI_CLASS_BRIDGE_OTHER
while other freescale host bridges have class set to
PCI_CLASS_PROCESSOR_POWERPC.
This patch makes fixup_hide_host_resource_fsl match
PCI_CLASS_BRIDGE_OTHER in addition to PCI_CLASS_PROCESSOR_POWERPC.
Signed-off-by: John Rigby <jrigby@freescale.com>
We essentially adopt the 64-bit dma code, with some changes to support
32-bit systems, including HIGHMEM. dma functions on 32-bit are now
invoked via accessor functions which call the correct op for a device based
on archdata dma_ops. If there is no archdata dma_ops, this defaults
to dma_direct_ops.
In addition, the dma_map/unmap_page functions are added to dma_ops
because we can't just fall back on map/unmap_single when HIGHMEM is
enabled. In the case of dma_direct_*, we stop using map/unmap_single
and just use the page version - this saves a lot of ugly
ifdeffing. We leave map/unmap_single in the dma_ops definition,
though, because they are needed by the iommu code, which does not
implement map/unmap_page. Ideally, going forward, we will completely
eliminate map/unmap_single and just have map/unmap_page, if it's
workable for 64-bit.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
The 85xx/86xx pci code no longer uses update_bridge_resource and it was the
only caller.
The 32-bit PCI code tests if "bus" is non-NULL after calling
pci_scan_bus_parented() in one place but not another before
dereferencing it.
This merge the two implementations, based on the previously
fixed up 32 bits one. The pcibios_enable_device_hook in ppc_md
is now available for ppc64 use. Also remove the new unused
"initial" parameter from it and fixup users.
Our implementation of pcibios_enable_device() incorrectly ignores
the mask argument and always checks that all resources have been
allocated, which isn't the right thing to do anymore.
The 32 bits PCI code now uses the generic code for assigning unassigned
resources and an algorithm similar to x86 for claiming existing ones.
This works far better than the 64 bits code which basically can only
claim existing ones (pci_probe_only=1) or would fall apart completely.
This merges them so that the new 32 bits implementation is used for both.
64 bits now gets the new PCI flags for controlling the behaviour, though
the old pci_probe_only global is still there for now to be cleared if you
want to.
I kept a pcibios_claim_one_bus() function mostly based on the old 64
bits code for use by the DLPAR hotplug. This will have to be cleaned
up, thought I hope it will work in the meantime.
The PCI code in 32 and 64 bits fixes up resources differently.
32 bits uses a header quirk plus handles bridges in pcibios_fixup_bus()
while 64 bits does things in various places depending on whether you
are using OF probing, using PCI hotplug, etc...
This merges those by basically using the 32 bits approach for both,
with various tweaks to make 64 bits work with the new approach.
This merges the PowerPC 32 and 64 bits version of pcibios_resource_to_bus
and pcibios_bus_to_resource().
The 32 bits PCI code carries an old hack that was only useful for G5
machines. Nowdays, the 32 bits kernel doesn't support any of those
machines anymore so the hack is basically never used, so remove it.
This adds to the 32 bits PCI code some flags, replacing the old
pci_assign_all_busses global, that allow us to control various
aspects of the PCI probing, such as whether to re-assign all
resources or not, or to not try to assign anything at all.
This also adds the flag x86 already has to avoid ISA alignment
on bridges that don't have ISA forwarding enabled (no legacy
devices on the top level bus) and sets it for PowerMacs.
The 32 bits PowerPC PCI code has a hack for use by some PowerMacs
to try to re-open PCI<->PCI bridge IO resources that were closed
by the firmware. This is no longer necessary as the generic code
will now do that for us.
This makes the 32 bits PowerPC PCI code use the generic code to assign
resources to devices that had unassigned or conflicting resources.
This allow us to remove the local implementation that was incomplete and
could not assign for example a PCI<->PCI bridge from scratch, which is
needed on various embedded platforms.
There's a stale & bogus piece of code in 32 bits PCI code that
complains about ISA related alignment issues. Just remove it.
The 32 bits PCI code will display a rather scary error message
PCI: Cannot allocate resource region N of device XXX
at boot when the existing setup of a device as left by the
firmware doesn't match the kernel needs and the device needs
to be moved. This is often not an error at all, as the kernel
will generally easily reallocate the device elsewhere.
This changes the message to something less scary and lowers
its level from error to warning.
The 32-bit powerpc resource fixup code uses unsigned longs to do the
offsetting of resources which overflows on platforms such as 4xx where
resources can be 64 bits.
This fixes it by using resource_size_t instead.
However, the IO stuff does rely on some 32 bits arithmetic, so we hack
by cropping the result of the fixups for IO resources with a 32 bits
mask.
This isn't the prettiest but should work for now until we change the
32 bits PCI code to do IO mappings like 64 bits does, within a reserved
are of the kernel address space.
This merges the 32-bit and 64-bit implementations of
pci_process_bridge_OF_ranges(). The new function is cleaner than both
the old ones, and supports 64 bits ranges on ppc32 which is necessary
for the 4xx port.
It also adds some better (hopefully) output to the kernel log which
should help diagnose problems and makes better use of existing OF
parsing helpers (avoiding a few bugs of both implementations along
the way).
There are still a few unfortunate ifdef's but there is no way around
these for now at least not until some other bits of the PCI code are
made common.
This defines isa_mem_base on both 32 and 64 bits (it used to be 32 bits
only). This avoids a few ifdef's in later patches and potentially can
allow support for VGA text mode on 64 bits powerpc.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
__must_check, so do so.
Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org>
Fixed the following warnings:
WARNING: vmlinux.o(.text+0x2934): Section mismatch: reference to .init.text:__alloc_bootmem (between 'irq_alloc_host' and 'irq_set_default_host')
WARNING: vmlinux.o(.text+0xb2aa): Section mismatch: reference to .init.data:boot_command_line (between 'register_early_udbg_console' and 'udbg_printf')
WARNING: vmlinux.o(.text+0xb2b2): Section mismatch: reference to .init.data:boot_command_line (between 'register_early_udbg_console' and 'udbg_printf')
WARNING: vmlinux.o(.text+0xe354): Section mismatch: reference to .init.text:__alloc_bootmem (between 'pcibios_alloc_controller' and 'pci_domain_nr')
WARNING: vmlinux.o(.text+0x12768): Section mismatch: reference to .init.text:update_bridge_resource (between 'quirk_fsl_pcie_transparent' and 'indirect_read_config')
WARNING: vmlinux.o(.text+0x127a8): Section mismatch: reference to .init.text:update_bridge_resource (between 'quirk_fsl_pcie_transparent' and 'indirect_read_config')
WARNING: vmlinux.o(.text+0x17566c): Section mismatch: reference to .init.text:pcibios_fixup_bus (between 'pci_scan_child_bus' and 'pci_scan_bus_parented')
The Freescale PCI PHBs actual report back values in the BAR registers
this causes issues in that we try to allocate resources for them
and will get error messages like the following on MPC8544 DS:
PCI: Failed to allocate mem resource #1:80000000@0 for 0000:00:00.0
To address this if we are class PCI_CLASS_PROCESSOR_POWERPC, a normal
header type, and the PHB we clear out all the resources.
