path: root/arch/powerpc/kernel/module_32.c
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-11-20powerpc/ppc32: ftrace, dynamic ftrace to handle modulesSteven Rostedt
Impact: add ability to trace modules on 32 bit PowerPC This patch performs the necessary trampoline calls to handle modules with dynamic ftrace on 32 bit PowerPC. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2008-07-01powerpc: Move common module code into its own fileKumar Gala
Refactor common code between ppc32 and ppc64 module handling into a shared filed. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-21[POWERPC] Optimize counting distinct entries in the relocation sectionsEmil Medve
When a module has relocation sections with tens of thousands of entries, counting the distinct/unique entries only (i.e. no duplicates) at load time can take tens of seconds and up to minutes. The sore point is the count_relocs() function which is called as part of the architecture specific module loading processing path: -> load_module() generic -> module_frob_arch_sections() arch specific -> get_plt_size() 32-bit -> get_stubs_size() 64-bit -> count_relocs() Here count_relocs is being called to find out how many distinct targets of R_PPC_REL24 relocations there are, since each distinct target needs a PLT entry or a stub created for it. The previous counting algorithm has O(n^2) complexity. Basically two solutions were proposed on the e-mail list: a hash based approach and a sort based approach. The hash based approach is the fastest (O(n)) but the has it needs additional memory and for certain corner cases it could take lots of memory due to the degeneration of the hash. One such proposal was submitted here: http://ozlabs.org/pipermail/linuxppc-dev/2007-June/037641.html The sort based approach is slower (O(n * log n + n)) but if the sorting is done "in place" it doesn't need additional memory. This has O(n + n * log n) complexity with no additional memory requirements. This commit implements the in-place sort option. Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-01-24[POWERPC] Add support for R_PPC_ADDR16_HI relocationsSimon Vallet
apply_relocate_add() does not support R_PPC_ADDR16_HI relocations, which prevents some non gcc-built modules to be loaded. Signed-off-by: Simon Vallet <svallet@gmail.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-11[POWERPC] Generic BUG for powerpcJeremy Fitzhardinge
This makes powerpc use the generic BUG machinery. The biggest reports the function name, since it is redundant with kallsyms, and not needed in general. There is an overall reduction of code, since module_32/64 duplicated several functions. Unfortunately there's no way to tell gcc that BUG won't return, so the BUG macro includes a goto loop. This will generate a real jmp instruction, which is never used. [akpm@osdl.org: build fix] [paulus@samba.org: remove infinite loop in BUG_ON] Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Andi Kleen <ak@muc.de> Cc: Hugh Dickens <hugh@veritas.com> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-25[POWERPC] Support feature fixups in modulesBenjamin Herrenschmidt
This patch adds support for feature fixups in modules. This involves adding support for R_PPC64_REL64 relocs to the 64 bits module loader. It also modifies modpost.c to ignore the powerpc fixup sections (or it would warn when used in .init.text). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27powerpc: Move module.c over to arch/powerpcPaul Mackerras
... and rename it to module_32.c since it is the 32-bit version. The 32-bit and 64-bit ABIs are sufficiently different that having a merged version isn't really practical. Signed-off-by: Paul Mackerras <paulus@samba.org>
