path: root/arch/powerpc/kernel/misc_64.S
2006-01-13[PATCH] powerpc: Cleanup LOADADDR etc. asm macrosDavid Gibson
This patch consolidates the variety of macros used for loading 32 or 64-bit constants in assembler (LOADADDR, LOADBASE, SET_REG_TO_*). The idea is to make the set of macros consistent across 32 and 64 bit and to make it more obvious which is the appropriate one to use in a given situation. The new macros and their semantics are described in the comments in ppc_asm.h. In the process, we change several places that were unnecessarily using immediate loads on ppc64 to use the GOT/TOC. Likewise we cleanup a couple of places where we were clumsily subtracting PAGE_OFFSET with asm instructions to use assemble-time arithmetic or the toreal() macro instead. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-09ppc64: remove ppc_irq_dispatch_handlerStephen Rothwell
Use __do_IRQ instead. The only difference is that every controller is now assumed to have an end() routine (only xics_8259 did not). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2005-11-09ppc64: move stack switching up in interrupt processingStephen Rothwell
This will make the ppc64 multiplatform irq handling more like the generic handling. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2005-11-08[PATCH] ppc64: SMU based macs cpufreq supportBenjamin Herrenschmidt
CPU freq support using 970FX powertune facility for iMac G5 and SMU based single CPU desktop. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-27[PATCH] powerpc: Fix handling of fpscr on 64-bitDavid Gibson
The recent merge of fpu.S broken the handling of fpscr for ARCH=powerpc and CONFIG_PPC64=y. FP registers could be corrupted, leading to strange random application crashes. The confusion arises, because the thread_struct has (and requires) a 64-bit area to save the fpscr, because we use load/store double instructions to get it in to/out of the FPU. However, only the low 32-bits are actually used, so we want to treat it as a 32-bit quantity when manipulating its bits to avoid extra load/stores on 32-bit. This patch replaces the current definition with a structure of two 32-bit quantities (pad and val), to clarify things as much as is possible. The 'val' field is used when manipulating bits, the structure itself is used when obtaining the address for loading/unloading the value from the FPU. While we're at it, consolidate the 4 (!) almost identical versions of cvt_fd() and cvt_df() (arch/ppc/kernel/misc.S, arch/ppc64/kernel/misc.S, arch/powerpc/kernel/misc_32.S, arch/powerpc/kernel/misc_64.S) into a single version in fpu.S. The new version takes a pointer to thread_struct and applies the correct offset itself, rather than a pointer to the fpscr field itself, again to avoid confusion as to which is the correct field to use. Finally, this patch makes ARCH=ppc64 also use the consolidated fpu.S code, which it previously did not. Built for G5 (ARCH=ppc64 and ARCH=powerpc), 32-bit powermac (ARCH=ppc and ARCH=powerpc) and Walnut (ARCH=ppc, CONFIG_MATH_EMULATION=y). Booted on G5 (ARCH=powerpc) and things which previously fell over no longer do. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-21[PATCH] powerpc: Merge thread_info.hDavid Gibson
Merge ppc32 and ppc64 versions of thread_info.h. They were pretty similar already, the chief changes are: - Instead of inline asm to implement current_thread_info(), which needs to be different for ppc32 and ppc64, we use C with an asm("r1") register variable. gcc turns it into the same asm as we used to have for both platforms. - We replace ppc32's 'local_flags' with the ppc64 'syscall_noerror' field. The noerror flag was in fact the only thing in the local_flags field anyway, so the ppc64 approach is simpler, and means we only need a load-immediate/store instead of load/mask/store when clearing the flag. - In readiness for 64k pages, when THREAD_SIZE will be less than a page, ppc64 used kmalloc() rather than get_free_pages() to allocate the kernel stack. With this patch we do the same for ppc32, since there's no strong reason not to. - For ppc64, we no longer export THREAD_SHIFT and THREAD_SIZE via asm-offsets, thread_info.h can now be safely included in asm, as on ppc32. Built and booted on G4 Powerbook (ARCH=ppc and ARCH=powerpc) and Power5 (ARCH=ppc64 and ARCH=powerpc). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-10powerpc: Introduce entry_{32,64}.S, misc_{32,64}.S, systbl.SPaul Mackerras
The system call table has been consolidated into systbl.S. We have separate 32-bit and 64-bit versions of entry.S and misc.S since the code is mostly sufficiently different to be not worth merging. There are some common bits that will be extracted in future. Signed-off-by: Paul Mackerras <paulus@samba.org>
