introduce new setsockopt() command:
setsockopt(sock, SOL_SOCKET, SO_ATTACH_BPF, &prog_fd, sizeof(prog_fd))
where prog_fd was received from syscall bpf(BPF_PROG_LOAD, attr, ...)
and attr->prog_type == BPF_PROG_TYPE_SOCKET_FILTER
setsockopt() calls bpf_prog_get() which increments refcnt of the program,
so it doesn't get unloaded while socket is using the program.
The same eBPF program can be attached to multiple sockets.
User task exit automatically closes socket which calls sk_filter_uncharge()
which decrements refcnt of eBPF program
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Alternative to RPS/RFS is to use hardware support for multiple
queues.
Then split a set of million of sockets into worker threads, each
one using epoll() to manage events on its own socket pool.
Ideally, we want one thread per RX/TX queue/cpu, but we have no way to
know after accept() or connect() on which queue/cpu a socket is managed.
We normally use one cpu per RX queue (IRQ smp_affinity being properly
set), so remembering on socket structure which cpu delivered last packet
is enough to solve the problem.
After accept(), connect(), or even file descriptor passing around
processes, applications can use :
int cpu;
socklen_t len = sizeof(cpu);
getsockopt(fd, SOL_SOCKET, SO_INCOMING_CPU, &cpu, &len);
And use this information to put the socket into the right silo
for optimal performance, as all networking stack should run
on the appropriate cpu, without need to send IPI (RPS/RFS).
This patch wires up the new syscall sys_bpf() on powerpc.
Passes the tests in samples/bpf:
#0 add+sub+mul OK
#1 unreachable OK
#2 unreachable2 OK
#3 out of range jump OK
#4 out of range jump2 OK
#5 test1 ld_imm64 OK
#6 test2 ld_imm64 OK
#7 test3 ld_imm64 OK
#8 test4 ld_imm64 OK
#9 test5 ld_imm64 OK
#10 no bpf_exit OK
#11 loop (back-edge) OK
#12 loop2 (back-edge) OK
#13 conditional loop OK
#14 read uninitialized register OK
#15 read invalid register OK
#16 program doesn't init R0 before exit OK
#17 stack out of bounds OK
#18 invalid call insn1 OK
#19 invalid call insn2 OK
#20 invalid function call OK
#21 uninitialized stack1 OK
#22 uninitialized stack2 OK
#23 check valid spill/fill OK
#24 check corrupted spill/fill OK
#25 invalid src register in STX OK
#26 invalid dst register in STX OK
#27 invalid dst register in ST OK
#28 invalid src register in LDX OK
#29 invalid dst register in LDX OK
#30 junk insn OK
#31 junk insn2 OK
#32 junk insn3 OK
#33 junk insn4 OK
#34 junk insn5 OK
#35 misaligned read from stack OK
#36 invalid map_fd for function call OK
#37 don't check return value before access OK
#38 access memory with incorrect alignment OK
#39 sometimes access memory with incorrect alignment OK
#40 jump test 1 OK
#41 jump test 2 OK
#42 jump test 3 OK
#43 jump test 4 OK
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
[mpe: test using samples/bpf]
Pull KVM updates from Paolo Bonzini:
"Fixes and features for 3.18.
Apart from the usual cleanups, here is the summary of new features:
- s390 moves closer towards host large page support
- PowerPC has improved support for debugging (both inside the guest
and via gdbstub) and support for e6500 processors
- ARM/ARM64 support read-only memory (which is necessary to put
firmware in emulated NOR flash)
- x86 has the usual emulator fixes and nested virtualization
improvements (including improved Windows support on Intel and
Jailhouse hypervisor support on AMD), adaptive PLE which helps
overcommitting of huge guests. Also included are some patches that
make KVM more friendly to memory hot-unplug, and fixes for rare
caching bugs.
Two patches have trivial mm/ parts that were acked by Rik and Andrew.
Note: I will soon switch to a subkey for signing purposes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (157 commits)
kvm: do not handle APIC access page if in-kernel irqchip is not in use
KVM: s390: count vcpu wakeups in stat.halt_wakeup
KVM: s390/facilities: allow TOD-CLOCK steering facility bit
KVM: PPC: BOOK3S: HV: CMA: Reserve cma region only in hypervisor mode
arm/arm64: KVM: Report correct FSC for unsupported fault types
arm/arm64: KVM: Fix VTTBR_BADDR_MASK and pgd alloc
kvm: Fix kvm_get_page_retry_io __gup retval check
arm/arm64: KVM: Fix set_clear_sgi_pend_reg offset
kvm: x86: Unpin and remove kvm_arch->apic_access_page
kvm: vmx: Implement set_apic_access_page_addr
kvm: x86: Add request bit to reload APIC access page address
kvm: Add arch specific mmu notifier for page invalidation
kvm: Rename make_all_cpus_request() to kvm_make_all_cpus_request() and make it non-static
kvm: Fix page ageing bugs
kvm/x86/mmu: Pass gfn and level to rmapp callback.
x86: kvm: use alternatives for VMCALL vs. VMMCALL if kernel text is read-only
kvm: x86: use macros to compute bank MSRs
KVM: x86: Remove debug assertion of non-PAE reserved bits
kvm: don't take vcpu mutex for obviously invalid vcpu ioctls
kvm: Faults which trigger IO release the mmap_sem
Move ONE_REG AltiVec support to powerpc generic layer.
Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com>
Signed-off-by: Bharat Bhushan <Bharat.Bhushan@freescale.com>
This patch wires up three new syscalls for powerpc. The three
new syscalls are seccomp, getrandom and memfd_create.
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Unfortunately, the LPCR got defined as a 32-bit register in the
one_reg interface. This is unfortunate because KVM allows userspace
to control the DPFD (default prefetch depth) field, which is in the
upper 32 bits. The result is that DPFD always get set to 0, which
reduces performance in the guest.
We can't just change KVM_REG_PPC_LPCR to be a 64-bit register ID,
since that would break existing userspace binaries. Instead we define
a new KVM_REG_PPC_LPCR_64 id which is 64-bit. Userspace can still use
the old KVM_REG_PPC_LPCR id, but it now only modifies those fields in
the bottom 32 bits that userspace can modify (ILE, TC and AIL).
If userspace uses the new KVM_REG_PPC_LPCR_64 id, it can modify DPFD
as well.
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Cc: stable@vger.kernel.org
We now support SPRG9 for guest, so also add a one reg interface for same
Note: Changes are in bookehv code only as we do not have SPRG9 on booke-pr.
The Vector Crypto category instructions are supported by current POWER8
chips, advertise them to userspace using a specific bit to properly
differentiate with chips of the same architecture level that might not
have them.
CC: <stable@vger.kernel.org> [v3.10+]
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Ben Herrenschmidt:
"Here is the bulk of the powerpc changes for this merge window. It got
a bit delayed in part because I wasn't paying attention, and in part
because I discovered I had a core PCI change without a PCI maintainer
ack in it. Bjorn eventually agreed it was ok to merge it though we'll
probably improve it later and I didn't want to rebase to add his ack.
There is going to be a bit more next week, essentially fixes that I
still want to sort through and test.
The biggest item this time is the support to build the ppc64 LE kernel
with our new v2 ABI. We previously supported v2 userspace but the
kernel itself was a tougher nut to crack. This is now sorted mostly
thanks to Anton and Rusty.
We also have a fairly big series from Cedric that add support for
64-bit LE zImage boot wrapper. This was made harder by the fact that
traditionally our zImage wrapper was always 32-bit, but our new LE
toolchains don't really support 32-bit anymore (it's somewhat there
but not really "supported") so we didn't want to rely on it. This
meant more churn that just endian fixes.
This brings some more LE bits as well, such as the ability to run in
LE mode without a hypervisor (ie. under OPAL firmware) by doing the
right OPAL call to reinitialize the CPU to take HV interrupts in the
right mode and the usual pile of endian fixes.
There's another series from Gavin adding EEH improvements (one day we
*will* have a release with less than 20 EEH patches, I promise!).
Another highlight is the support for the "Split core" functionality on
P8 by Michael. This allows a P8 core to be split into "sub cores" of
4 threads which allows the subcores to run different guests under KVM
(the HW still doesn't support a partition per thread).
And then the usual misc bits and fixes ..."
[ Further delayed by gmail deciding that BenH is a dirty spammer.
Google knows. ]
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (155 commits)
powerpc/powernv: Add missing include to LPC code
selftests/powerpc: Test the THP bug we fixed in the previous commit
powerpc/mm: Check paca psize is up to date for huge mappings
powerpc/powernv: Pass buffer size to OPAL validate flash call
powerpc/pseries: hcall functions are exported to modules, need _GLOBAL_TOC()
powerpc: Exported functions __clear_user and copy_page use r2 so need _GLOBAL_TOC()
powerpc/powernv: Set memory_block_size_bytes to 256MB
powerpc: Allow ppc_md platform hook to override memory_block_size_bytes
powerpc/powernv: Fix endian issues in memory error handling code
powerpc/eeh: Skip eeh sysfs when eeh is disabled
powerpc: 64bit sendfile is capped at 2GB
powerpc/powernv: Provide debugfs access to the LPC bus via OPAL
powerpc/serial: Use saner flags when creating legacy ports
powerpc: Add cpu family documentation
powerpc/xmon: Fix up xmon format strings
powerpc/powernv: Add calls to support little endian host
powerpc: Document sysfs DSCR interface
powerpc: Fix regression of per-CPU DSCR setting
powerpc: Split __SYSFS_SPRSETUP macro
arch: powerpc/fadump: Cleaning up inconsistent NULL checks
"At over 200 commits, covering almost all supported architectures, this
was a pretty active cycle for KVM. Changes include:
- a lot of s390 changes: optimizations, support for migration, GDB
support and more
- ARM changes are pretty small: support for the PSCI 0.2 hypercall
interface on both the guest and the host (the latter acked by
Catalin)
- initial POWER8 and little-endian host support
- support for running u-boot on embedded POWER targets
- pretty large changes to MIPS too, completing the userspace
interface and improving the handling of virtualized timer hardware
- for x86, a larger set of changes is scheduled for 3.17. Still, we
have a few emulator bugfixes and support for running nested
fully-virtualized Xen guests (para-virtualized Xen guests have
always worked). And some optimizations too.
The only missing architecture here is ia64. It's not a coincidence
that support for KVM on ia64 is scheduled for removal in 3.17"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (203 commits)
KVM: add missing cleanup_srcu_struct
KVM: PPC: Book3S PR: Rework SLB switching code
KVM: PPC: Book3S PR: Use SLB entry 0
KVM: PPC: Book3S HV: Fix machine check delivery to guest
KVM: PPC: Book3S HV: Work around POWER8 performance monitor bugs
KVM: PPC: Book3S HV: Make sure we don't miss dirty pages
KVM: PPC: Book3S HV: Fix dirty map for hugepages
KVM: PPC: Book3S HV: Put huge-page HPTEs in rmap chain for base address
KVM: PPC: Book3S HV: Fix check for running inside guest in global_invalidates()
KVM: PPC: Book3S: Move KVM_REG_PPC_WORT to an unused register number
KVM: PPC: Book3S: Add ONE_REG register names that were missed
KVM: PPC: Add CAP to indicate hcall fixes
KVM: PPC: MPIC: Reset IRQ source private members
KVM: PPC: Graciously fail broken LE hypercalls
PPC: ePAPR: Fix hypercall on LE guest
KVM: PPC: BOOK3S: Remove open coded make_dsisr in alignment handler
KVM: PPC: BOOK3S: Always use the saved DAR value
PPC: KVM: Make NX bit available with magic page
KVM: PPC: Disable NX for old magic page using guests
KVM: PPC: BOOK3S: HV: Add mixed page-size support for guest
Commit b005255e12a3 ("KVM: PPC: Book3S HV: Context-switch new POWER8
SPRs") added a definition of KVM_REG_PPC_WORT with the same register
number as the existing KVM_REG_PPC_VRSAVE (though in fact the
definitions are not identical because of the different register sizes.)
For clarity, this moves KVM_REG_PPC_WORT to the next unused number,
and also adds it to api.txt.
Old guests try to use the magic page, but map their trampoline code inside
of an NX region.
Since we can't fix those old kernels, try to detect whether the guest is sane
or not. If not, just disable NX functionality in KVM so that old guests at
least work at all. For newer guests, add a bit that we can set to keep NX
functionality available.
The arch/powerpc/include/asm/linkage.h is being unintentionally exported
in the kernel headers since commit e1b5bb6d1236 (consolidate
cond_syscall and SYSCALL_ALIAS declarations) when
arch/powerpc/include/uapi/asm/linkage.h was deleted but the header-y not
removed from the Kbuild file. This happens because Makefile.headersinst
still checks the old asm/ directory if the specified header doesn't
exist in the uapi directory.
The asm/linkage.h shouldn't ever have been exported anyway. No other
arch does and it doesn't contain anything useful to userland, so remove
the header-y line from the Kbuild file which triggers the export.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: linuxppc-dev@lists.ozlabs.org
This series adds support for building the powerpc 64-bit
LE kernel using the new ABI v2. We already supported
running ABI v2 userspace programs but this adds support
for building the kernel itself using the new ABI.
I've had a report that the current limit is too small for
an automated network based installer. Bump it.
The new ELF ABI tends to use R_PPC64_REL16_LO and R_PPC64_REL16_HA
relocations (PC-relative), so implement them.
Pull more KVM updates from Paolo Bonzini:
"Second batch of KVM updates. Some minor x86 fixes, two s390 guest
features that need some handling in the host, and all the PPC changes.
The PPC changes include support for little-endian guests and
enablement for new POWER8 features"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (45 commits)
x86, kvm: correctly access the KVM_CPUID_FEATURES leaf at 0x40000101
x86, kvm: cache the base of the KVM cpuid leaves
kvm: x86: move KVM_CAP_HYPERV_TIME outside #ifdef
KVM: PPC: Book3S PR: Cope with doorbell interrupts
KVM: PPC: Book3S HV: Add software abort codes for transactional memory
KVM: PPC: Book3S HV: Add new state for transactional memory
powerpc/Kconfig: Make TM select VSX and VMX
KVM: PPC: Book3S HV: Basic little-endian guest support
KVM: PPC: Book3S HV: Add support for DABRX register on POWER7
KVM: PPC: Book3S HV: Prepare for host using hypervisor doorbells
KVM: PPC: Book3S HV: Handle new LPCR bits on POWER8
KVM: PPC: Book3S HV: Handle guest using doorbells for IPIs
KVM: PPC: Book3S HV: Consolidate code that checks reason for wake from nap
KVM: PPC: Book3S HV: Implement architecture compatibility modes for POWER8
KVM: PPC: Book3S HV: Add handler for HV facility unavailable
KVM: PPC: Book3S HV: Flush the correct number of TLB sets on POWER8
KVM: PPC: Book3S HV: Context-switch new POWER8 SPRs
KVM: PPC: Book3S HV: Align physical and virtual CPU thread numbers
KVM: PPC: Book3S HV: Don't set DABR on POWER8
kvm/ppc: IRQ disabling cleanup
This adds the software abort code defines for transactional memory (TM).
These values are from PAPR.
Signed-off-by: Michael Neuling <mikey@neuling.org>
The DABRX (DABR extension) register on POWER7 processors provides finer
control over which accesses cause a data breakpoint interrupt. It
contains 3 bits which indicate whether to enable accesses in user,
kernel and hypervisor modes respectively to cause data breakpoint
interrupts, plus one bit that enables both real mode and virtual mode
accesses to cause interrupts. Currently, KVM sets DABRX to allow
both kernel and user accesses to cause interrupts while in the guest.
This adds support for the guest to specify other values for DABRX.
PAPR defines a H_SET_XDABR hcall to allow the guest to set both DABR
and DABRX with one call. This adds a real-mode implementation of
H_SET_XDABR, which shares most of its code with the existing H_SET_DABR
implementation. To support this, we add a per-vcpu field to store the
DABRX value plus code to get and set it via the ONE_REG interface.
For Linux guests to use this new hcall, userspace needs to add
"hcall-xdabr" to the set of strings in the /chosen/hypertas-functions
property in the device tree. If userspace does this and then migrates
the guest to a host where the kernel doesn't include this patch, then
userspace will need to implement H_SET_XDABR by writing the specified
DABR value to the DABR using the ONE_REG interface. In that case, the
old kernel will set DABRX to DABRX_USER | DABRX_KERNEL. That should
still work correctly, at least for Linux guests, since Linux guests
cope with getting data breakpoint interrupts in modes that weren't
requested by just ignoring the interrupt, and Linux guests never set
DABRX_BTI.
The other thing this does is to make H_SET_DABR and H_SET_XDABR work
on POWER8, which has the DAWR and DAWRX instead of DABR/X. Guests that
know about POWER8 should use H_SET_MODE rather than H_SET_[X]DABR, but
guests running in POWER7 compatibility mode will still use H_SET_[X]DABR.
For them, this adds the logic to convert DABR/X values into DAWR/X values
on POWER8.
This adds fields to the struct kvm_vcpu_arch to store the new
guest-accessible SPRs on POWER8, adds code to the get/set_one_reg
functions to allow userspace to access this state, and adds code to
the guest entry and exit to context-switch these SPRs between host
and guest.
Note that DPDES (Directed Privileged Doorbell Exception State) is
shared between threads on a core; hence we store it in struct
kvmppc_vcore and have the master thread save and restore it.
For user space packet capturing libraries such as libpcap, there's
currently only one way to check which BPF extensions are supported
by the kernel, that is, commit aa1113d9f85d ("net: filter: return
-EINVAL if BPF_S_ANC* operation is not supported"). For querying all
extensions at once this might be rather inconvenient.
Therefore, this patch introduces a new option which can be used as
an argument for getsockopt(), and allows one to obtain information
about which BPF extensions are supported by the current kernel.
As David Miller suggests, we do not need to define any bits right
now and status quo can just return 0 in order to state that this
versions supports SKF_AD_PROTOCOL up to SKF_AD_PAY_OFFSET. Later
additions to BPF extensions need to add their bits to the
bpf_tell_extensions() function, as documented in the comment.
Signed-off-by: Michal Sekletar <msekleta@redhat.com>
Reviewed-by: Daniel Borkmann <dborkman@redhat.com>
Pull KVM changes from Paolo Bonzini:
"Here are the 3.13 KVM changes. There was a lot of work on the PPC
side: the HV and emulation flavors can now coexist in a single kernel
is probably the most interesting change from a user point of view.
On the x86 side there are nested virtualization improvements and a few
bugfixes.
ARM got transparent huge page support, improved overcommit, and
support for big endian guests.
Finally, there is a new interface to connect KVM with VFIO. This
helps with devices that use NoSnoop PCI transactions, letting the
driver in the guest execute WBINVD instructions. This includes some
nVidia cards on Windows, that fail to start without these patches and
the corresponding userspace changes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (146 commits)
kvm, vmx: Fix lazy FPU on nested guest
arm/arm64: KVM: PSCI: propagate caller endianness to the incoming vcpu
arm/arm64: KVM: MMIO support for BE guest
kvm, cpuid: Fix sparse warning
kvm: Delete prototype for non-existent function kvm_check_iopl
kvm: Delete prototype for non-existent function complete_pio
hung_task: add method to reset detector
pvclock: detect watchdog reset at pvclock read
kvm: optimize out smp_mb after srcu_read_unlock
srcu: API for barrier after srcu read unlock
KVM: remove vm mmap method
KVM: IOMMU: hva align mapping page size
KVM: x86: trace cpuid emulation when called from emulator
KVM: emulator: cleanup decode_register_operand() a bit
KVM: emulator: check rex prefix inside decode_register()
KVM: x86: fix emulation of "movzbl %bpl, %eax"
kvm_host: typo fix
KVM: x86: emulate SAHF instruction
MAINTAINERS: add tree for kvm.git
Documentation/kvm: add a 00-INDEX file
Pull networking updates from David Miller:
1) The addition of nftables. No longer will we need protocol aware
firewall filtering modules, it can all live in userspace.
At the core of nftables is a, for lack of a better term, virtual
machine that executes byte codes to inspect packet or metadata
(arriving interface index, etc.) and make verdict decisions.
Besides support for loading packet contents and comparing them, the
interpreter supports lookups in various datastructures as
fundamental operations. For example sets are supports, and
therefore one could create a set of whitelist IP address entries
which have ACCEPT verdicts attached to them, and use the appropriate
byte codes to do such lookups.
Since the interpreted code is composed in userspace, userspace can
do things like optimize things before giving it to the kernel.
Another major improvement is the capability of atomically updating
portions of the ruleset. In the existing netfilter implementation,
one has to update the entire rule set in order to make a change and
this is very expensive.
Userspace tools exist to create nftables rules using existing
netfilter rule sets, but both kernel implementations will need to
co-exist for quite some time as we transition from the old to the
new stuff.
Kudos to Patrick McHardy, Pablo Neira Ayuso, and others who have
worked so hard on this.
2) Daniel Borkmann and Hannes Frederic Sowa made several improvements
to our pseudo-random number generator, mostly used for things like
UDP port randomization and netfitler, amongst other things.
In particular the taus88 generater is updated to taus113, and test
cases are added.
3) Support 64-bit rates in HTB and TBF schedulers, from Eric Dumazet
and Yang Yingliang.
4) Add support for new 577xx tigon3 chips to tg3 driver, from Nithin
Sujir.
5) Fix two fatal flaws in TCP dynamic right sizing, from Eric Dumazet,
Neal Cardwell, and Yuchung Cheng.
6) Allow IP_TOS and IP_TTL to be specified in sendmsg() ancillary
control message data, much like other socket option attributes.
From Francesco Fusco.
7) Allow applications to specify a cap on the rate computed
automatically by the kernel for pacing flows, via a new
SO_MAX_PACING_RATE socket option. From Eric Dumazet.
8) Make the initial autotuned send buffer sizing in TCP more closely
reflect actual needs, from Eric Dumazet.
9) Currently early socket demux only happens for TCP sockets, but we
can do it for connected UDP sockets too. Implementation from Shawn
Bohrer.
10) Refactor inet socket demux with the goal of improving hash demux
performance for listening sockets. With the main goals being able
to use RCU lookups on even request sockets, and eliminating the
listening lock contention. From Eric Dumazet.
11) The bonding layer has many demuxes in it's fast path, and an RCU
conversion was started back in 3.11, several changes here extend the
RCU usage to even more locations. From Ding Tianhong and Wang
Yufen, based upon suggestions by Nikolay Aleksandrov and Veaceslav
Falico.
12) Allow stackability of segmentation offloads to, in particular, allow
segmentation offloading over tunnels. From Eric Dumazet.
13) Significantly improve the handling of secret keys we input into the
various hash functions in the inet hashtables, TCP fast open, as
well as syncookies. From Hannes Frederic Sowa. The key fundamental
operation is "net_get_random_once()" which uses static keys.
Hannes even extended this to ipv4/ipv6 fragmentation handling and
our generic flow dissector.
14) The generic driver layer takes care now to set the driver data to
NULL on device removal, so it's no longer necessary for drivers to
explicitly set it to NULL any more. Many drivers have been cleaned
up in this way, from Jingoo Han.
15) Add a BPF based packet scheduler classifier, from Daniel Borkmann.
16) Improve CRC32 interfaces and generic SKB checksum iterators so that
SCTP's checksumming can more cleanly be handled. Also from Daniel
Borkmann.
17) Add a new PMTU discovery mode, IP_PMTUDISC_INTERFACE, which forces
using the interface MTU value. This helps avoid PMTU attacks,
particularly on DNS servers. From Hannes Frederic Sowa.
18) Use generic XPS for transmit queue steering rather than internal
(re-)implementation in virtio-net. From Jason Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits)
random32: add test cases for taus113 implementation
random32: upgrade taus88 generator to taus113 from errata paper
random32: move rnd_state to linux/random.h
random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized
random32: add periodic reseeding
random32: fix off-by-one in seeding requirement
PHY: Add RTL8201CP phy_driver to realtek
xtsonic: add missing platform_set_drvdata() in xtsonic_probe()
macmace: add missing platform_set_drvdata() in mace_probe()
ethernet/arc/arc_emac: add missing platform_set_drvdata() in arc_emac_probe()
ipv6: protect for_each_sk_fl_rcu in mem_check with rcu_read_lock_bh
vlan: Implement vlan_dev_get_egress_qos_mask as an inline.
ixgbe: add warning when max_vfs is out of range.
igb: Update link modes display in ethtool
netfilter: push reasm skb through instead of original frag skbs
ip6_output: fragment outgoing reassembled skb properly
MAINTAINERS: mv643xx_eth: take over maintainership from Lennart
net_sched: tbf: support of 64bit rates
ixgbe: deleting dfwd stations out of order can cause null ptr deref
ixgbe: fix build err, num_rx_queues is only available with CONFIG_RPS
This patch adds the debug stub support on booke/bookehv.
Now QEMU debug stub can use hw breakpoint, watchpoint and
software breakpoint to debug guest.
This is how we save/restore debug register context when switching
between guest, userspace and kernel user-process:
When QEMU is running
-> thread->debug_reg == QEMU debug register context.
-> Kernel will handle switching the debug register on context switch.
-> no vcpu_load() called
QEMU makes ioctls (except RUN)
-> This will call vcpu_load()
-> should not change context.
-> Some ioctls can change vcpu debug register, context saved in vcpu->debug_regs
QEMU Makes RUN ioctl
-> Save thread->debug_reg on STACK
-> Store thread->debug_reg == vcpu->debug_reg
-> load thread->debug_reg
-> RUN VCPU ( So thread points to vcpu context )
Context switch happens When VCPU running
-> makes vcpu_load() should not load any context
-> kernel loads the vcpu context as thread->debug_regs points to vcpu context.
On heavyweight_exit
-> Load the context saved on stack in thread->debug_reg
Currently we do not support debug resource emulation to guest,
On debug exception, always exit to user space irrespective of
user space is expecting the debug exception or not. If this is
unexpected exception (breakpoint/watchpoint event not set by
userspace) then let us leave the action on user space. This
is similar to what it was before, only thing is that now we
have proper exit state available to user space.
Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com>
"ehpriv 1" instruction is used for setting software breakpoints
by user space. This patch adds support to exit to user space
with "run->debug" have relevant information.
As this is the first point we are using run->debug, also defined
the run->debug structure.
This enables us to use the Processor Compatibility Register (PCR) on
POWER7 to put the processor into architecture 2.05 compatibility mode
when running a guest. In this mode the new instructions and registers
that were introduced on POWER7 are disabled in user mode. This
includes all the VSX facilities plus several other instructions such
as ldbrx, stdbrx, popcntw, popcntd, etc.
To select this mode, we have a new register accessible through the
set/get_one_reg interface, called KVM_REG_PPC_ARCH_COMPAT. Setting
this to zero gives the full set of capabilities of the processor.
Setting it to one of the "logical" PVR values defined in PAPR puts
the vcpu into the compatibility mode for the corresponding
architecture level. The supported values are:
0x0f000002 Architecture 2.05 (POWER6)
0x0f000003 Architecture 2.06 (POWER7)
0x0f100003 Architecture 2.06+ (POWER7+)
Since the PCR is per-core, the architecture compatibility level and
the corresponding PCR value are stored in the struct kvmppc_vcore, and
are therefore shared between all vcpus in a virtual core.
[agraf: squash in fix to add missing break statements and documentation]
POWER7 and later IBM server processors have a register called the
Program Priority Register (PPR), which controls the priority of
each hardware CPU SMT thread, and affects how fast it runs compared
to other SMT threads. This priority can be controlled by writing to
the PPR or by use of a set of instructions of the form or rN,rN,rN
which are otherwise no-ops but have been defined to set the priority
to particular levels.
This adds code to context switch the PPR when entering and exiting
guests and to make the PPR value accessible through the SET/GET_ONE_REG
interface. When entering the guest, we set the PPR as late as
possible, because if we are setting a low thread priority it will
make the code run slowly from that point on. Similarly, the
first-level interrupt handlers save the PPR value in the PACA very
early on, and set the thread priority to the medium level, so that
the interrupt handling code runs at a reasonable speed.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
This adds the ability to have a separate LPCR (Logical Partitioning
Control Register) value relating to a guest for each virtual core,
rather than only having a single value for the whole VM. This
corresponds to what real POWER hardware does, where there is a LPCR
per CPU thread but most of the fields are required to have the same
value on all active threads in a core.
The per-virtual-core LPCR can be read and written using the
GET/SET_ONE_REG interface. Userspace can can only modify the
following fields of the LPCR value:
DPFD Default prefetch depth
ILE Interrupt little-endian
TC Translation control (secondary HPT hash group search disable)
We still maintain a per-VM default LPCR value in kvm->arch.lpcr, which
contains bits relating to memory management, i.e. the Virtualized
Partition Memory (VPM) bits and the bits relating to guest real mode.
When this default value is updated, the update needs to be propagated
to the per-vcore values, so we add a kvmppc_update_lpcr() helper to do
that.
[agraf: fix whitespace]
The VRSAVE register value for a vcpu is accessible through the
GET/SET_SREGS interface for Book E processors, but not for Book 3S
processors. In order to make this accessible for Book 3S processors,
this adds a new register identifier for GET/SET_ONE_REG, and adds
the code to implement it.
This allows guests to have a different timebase origin from the host.
This is needed for migration, where a guest can migrate from one host
to another and the two hosts might have a different timebase origin.
However, the timebase seen by the guest must not go backwards, and
should go forwards only by a small amount corresponding to the time
taken for the migration.
Therefore this provides a new per-vcpu value accessed via the one_reg
interface using the new KVM_REG_PPC_TB_OFFSET identifier. This value
defaults to 0 and is not modified by KVM. On entering the guest, this
value is added onto the timebase, and on exiting the guest, it is
subtracted from the timebase.
This is only supported for recent POWER hardware which has the TBU40
(timebase upper 40 bits) register. Writing to the TBU40 register only
alters the upper 40 bits of the timebase, leaving the lower 24 bits
unchanged. This provides a way to modify the timebase for guest
migration without disturbing the synchronization of the timebase
registers across CPU cores. The kernel rounds up the value given
to a multiple of 2^24.
Timebase values stored in KVM structures (struct kvm_vcpu, struct
kvmppc_vcore, etc.) are stored as host timebase values. The timebase
values in the dispatch trace log need to be guest timebase values,
however, since that is read directly by the guest. This moves the
setting of vcpu->arch.dec_expires on guest exit to a point after we
have restored the host timebase so that vcpu->arch.dec_expires is a
host timebase value.
This reserves space in get/set_one_reg ioctl for the extra guest state
needed for POWER8. It doesn't implement these at all, it just reserves
them so that the ABI is defined now.
A few things to note here:
- This add *a lot* state for transactional memory. TM suspend mode,
this is unavoidable, you can't simply roll back all transactions and
store only the checkpointed state. I've added this all to
get/set_one_reg (including GPRs) rather than creating a new ioctl
which returns a struct kvm_regs like KVM_GET_REGS does. This means we
if we need to extract the TM state, we are going to need a bucket load
of IOCTLs. Hopefully most of the time this will not be needed as we
can look at the MSR to see if TM is active and only grab them when
needed. If this becomes a bottle neck in future we can add another
ioctl to grab all this state in one go.
- The TM state is offset by 0x80000000.
- For TM, I've done away with VMX and FP and created a single 64x128 bit
VSX register space.
- I've left a space of 1 (at 0x9c) since Paulus needs to add a value
which applies to POWER7 as well.
This patch will have powerpc include the appropriate generic endianness
header depending on what the compiler reports.
Signed-off-by: Ian Munsie <imunsie@au1.ibm.com>
As mentioned in commit afe4fd062416b ("pkt_sched: fq: Fair Queue packet
scheduler"), this patch adds a new socket option.
SO_MAX_PACING_RATE offers the application the ability to cap the
rate computed by transport layer. Value is in bytes per second.
u32 val = 1000000;
setsockopt(sockfd, SOL_SOCKET, SO_MAX_PACING_RATE, &val, sizeof(val));
To be effectively paced, a flow must use FQ packet scheduler.
Note that a packet scheduler takes into account the headers for its
computations. The effective payload rate depends on MSS and retransmits
if any.
I chose to make this pacing rate a SOL_SOCKET option instead of a
TCP one because this can be used by other protocols.
Cc: Steinar H. Gunderson <sesse@google.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
We need to set ELF_DATA correctly on LE coredumps.
Simplify things by putting all the 32bit and 64bit defines
together instead of in two spots.
We use bit 63 of the event code for userspace to request that the event
be counted using EBB (Event Based Branches). Export this value, making
it part of the API - though only on processors that support EBB.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Rename LL_SO to BUSY_POLL_SO
Rename sysctl_net_ll_{read,poll} to sysctl_busy_{read,poll}
Fix up users of these variables.
Fix documentation for sysctl.
a patch for the socket.7 man page will follow separately,
because of limitations of my mail setup.
Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com>
adds a socket option for low latency polling.
This allows overriding the global sysctl value with a per-socket one.
Unexport sysctl_net_ll_poll since for now it's not needed in modules.
These cause codes are usable by userspace, so let's export to uapi.
Cc: <stable@vger.kernel.org> # v3.9
Also, make HTM's presence dependent on the .config option.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Pull kvm updates from Gleb Natapov:
"Highlights of the updates are:
general:
- new emulated device API
- legacy device assignment is now optional
- irqfd interface is more generic and can be shared between arches
x86:
- VMCS shadow support and other nested VMX improvements
- APIC virtualization and Posted Interrupt hardware support
- Optimize mmio spte zapping
ppc:
- BookE: in-kernel MPIC emulation with irqfd support
- Book3S: in-kernel XICS emulation (incomplete)
- Book3S: HV: migration fixes
- BookE: more debug support preparation
- BookE: e6500 support
ARM:
- reworking of Hyp idmaps
s390:
- ioeventfd for virtio-ccw
And many other bug fixes, cleanups and improvements"
* tag 'kvm-3.10-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (204 commits)
kvm: Add compat_ioctl for device control API
KVM: x86: Account for failing enable_irq_window for NMI window request
KVM: PPC: Book3S: Add API for in-kernel XICS emulation
kvm/ppc/mpic: fix missing unlock in set_base_addr()
kvm/ppc: Hold srcu lock when calling kvm_io_bus_read/write
kvm/ppc/mpic: remove users
kvm/ppc/mpic: fix mmio region lists when multiple guests used
kvm/ppc/mpic: remove default routes from documentation
kvm: KVM_CAP_IOMMU only available with device assignment
ARM: KVM: iterate over all CPUs for CPU compatibility check
KVM: ARM: Fix spelling in error message
ARM: KVM: define KVM_ARM_MAX_VCPUS unconditionally
KVM: ARM: Fix API documentation for ONE_REG encoding
ARM: KVM: promote vfp_host pointer to generic host cpu context
ARM: KVM: add architecture specific hook for capabilities
ARM: KVM: perform HYP initilization for hotplugged CPUs
ARM: KVM: switch to a dual-step HYP init code
ARM: KVM: rework HYP page table freeing
ARM: KVM: enforce maximum size for identity mapped code
ARM: KVM: move to a KVM provided HYP idmap
Pull powerpc update from Benjamin Herrenschmidt:
"The main highlights this time around are:
- A pile of addition POWER8 bits and nits, such as updated
performance counter support (Michael Ellerman), new branch history
buffer support (Anshuman Khandual), base support for the new PCI
host bridge when not using the hypervisor (Gavin Shan) and other
random related bits and fixes from various contributors.
- Some rework of our page table format by Aneesh Kumar which fixes a
thing or two and paves the way for THP support. THP itself will
not make it this time around however.
- More Freescale updates, including Altivec support on the new e6500
cores, new PCI controller support, and a pile of new boards support
and updates.
- The usual batch of trivial cleanups & fixes"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits)
powerpc: Fix build error for book3e
powerpc: Context switch the new EBB SPRs
powerpc: Turn on the EBB H/FSCR bits
powerpc: Replace CPU_FTR_BCTAR with CPU_FTR_ARCH_207S
powerpc: Setup BHRB instructions facility in HFSCR for POWER8
powerpc: Fix interrupt range check on debug exception
powerpc: Update tlbie/tlbiel as per ISA doc
powerpc: Print page size info during boot
powerpc: print both base and actual page size on hash failure
powerpc: Fix hpte_decode to use the correct decoding for page sizes
powerpc: Decode the pte-lp-encoding bits correctly.
powerpc: Use encode avpn where we need only avpn values
powerpc: Reduce PTE table memory wastage
powerpc: Move the pte free routines from common header
powerpc: Reduce the PTE_INDEX_SIZE
powerpc: Switch 16GB and 16MB explicit hugepages to a different page table format
powerpc: New hugepage directory format
powerpc: Don't truncate pgd_index wrongly
powerpc: Don't hard code the size of pte page
powerpc: Save DAR and DSISR in pt_regs on MCE
This adds the API for userspace to instantiate an XICS device in a VM
and connect VCPUs to it. The API consists of a new device type for
the KVM_CREATE_DEVICE ioctl, a new capability KVM_CAP_IRQ_XICS, which
functions similarly to KVM_CAP_IRQ_MPIC, and the KVM_IRQ_LINE ioctl,
which is used to assert and deassert interrupt inputs of the XICS.
The XICS device has one attribute group, KVM_DEV_XICS_GRP_SOURCES.
Each attribute within this group corresponds to the state of one
interrupt source. The attribute number is the same as the interrupt
source number.
This does not support irq routing or irqfd yet.
Acked-by: David Gibson <david@gibson.dropbear.id.au>
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull compat cleanup from Al Viro:
"Mostly about syscall wrappers this time; there will be another pile
with patches in the same general area from various people, but I'd
rather push those after both that and vfs.git pile are in."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
syscalls.h: slightly reduce the jungles of macros
get rid of union semop in sys_semctl(2) arguments
make do_mremap() static
sparc: no need to sign-extend in sync_file_range() wrapper
ppc compat wrappers for add_key(2) and request_key(2) are pointless
x86: trim sys_ia32.h
x86: sys32_kill and sys32_mprotect are pointless
get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC
merge compat sys_ipc instances
consolidate compat lookup_dcookie()
convert vmsplice to COMPAT_SYSCALL_DEFINE
switch getrusage() to COMPAT_SYSCALL_DEFINE
switch epoll_pwait to COMPAT_SYSCALL_DEFINE
convert sendfile{,64} to COMPAT_SYSCALL_DEFINE
switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE
make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect
make HAVE_SYSCALL_WRAPPERS unconditional
consolidate cond_syscall and SYSCALL_ALIAS declarations
teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long
get rid of duplicate logics in __SC_....[1-6] definitions
