* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
powerpc/perf_events: Fix call-graph recording, add perf_arch_fetch_caller_regs
perf top: Add missing initialization to zero
perf probe: Use original address instead of CU-based address
perf probe: Fix offset to allow signed value
perf top: Improve the autosizing of column lenghts
perf probe: Fix need_dwarf flag if lazy matching is used
perf probe: Fix probe_point buffer overrun
The powerpc implementations of syscall_get_error and
syscall_set_return_value should use CCR0:S0 (0x10000000) for testing
and setting syscall error status. Fortunately these APIs don't seem
to be used at the moment.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
This implements a powerpc version of perf_arch_fetch_caller_regs
to get correct call-graphs.
It's implemented in assembly because that way we can be sure there isn't
a stack frame for perf_arch_fetch_caller_regs. If it was in C, gcc might
or might not create a stack frame for it, which would affect the number
of levels we have to skip.
With this, we see results from perf record -e lock:lock_acquire like
this:
# Samples: 24878
# Overhead Command Shared Object Symbol
14.99% perf [kernel.kallsyms] [k] ._raw_spin_lock
--- ._raw_spin_lock
|--25.00%-- .alloc_fd
| (nil)
| |--50.00%-- .anon_inode_getfd
| | .sys_perf_event_open
| | syscall_exit
| | syscall
| | create_counter
| | __cmd_record
| | run_builtin
| | main
| | 0xfd2e704
| | 0xfd2e8c0
| | (nil)
... etc.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: anton@samba.org
Cc: linuxppc-dev@ozlabs.org
LKML-Reference: <20100318050513.GA6575@drongo>
e500v1/v2 based chips will treat any reserved field being set in an
opcode as illegal. Thus always setting the hint in the opcode is
a bad idea.
Anton should be kept away from the powerpc opcode map.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/booke: Fix breakpoint/watchpoint one-shot behavior
powerpc: Reduce printk from pseries_mach_cpu_die()
powerpc: Move checks in pseries_mach_cpu_die()
powerpc: Reset kernel stack on cpu online from cede state
powerpc: Fix G5 thermal shutdown
powerpc/pseries: Pass CPPR value to H_XIRR hcall
powerpc/booke: Fix a couple typos in the advanced ptrace code
powerpc: Fix SMP build with disabled CPU hotplugging.
powerpc: Dynamically allocate pacas
powerpc/perf: e500 support
powerpc/perf: Build callchain code regardless of hardware event support.
powerpc/cpm2: Checkpatch cleanup
powerpc/86xx: Renaming following split of GE Fanuc joint venture
powerpc/86xx: Convert gef_pic_lock to raw_spinlock
powerpc/qe: Convert qe_ic_lock to raw_spinlock
powerpc/82xx: Convert pci_pic_lock to raw_spinlock
powerpc/85xx: Convert socrates_fpga_pic_lock to raw_spinlock
pci_set_consistent_dma_mask
This converts powerpc to use the generic pci_set_dma_mask and
pci_set_consistent_dma_mask (drivers/pci/pci.c).
The generic pci_set_dma_mask does what powerpc's pci_set_dma_mask does.
Unlike powerpc's pci_set_consistent_dma_mask, the gneric
pci_set_consistent_dma_mask sets only coherent_dma_mask. It doesn't work
for powerpc? pci_set_consistent_dma_mask API should set only
coherent_dma_mask?
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Greg KH <greg@kroah.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
All the architectures properly set NEED_DMA_MAP_STATE now so we can safely
add linux/pci-dma.h to linux/pci.h and remove the linux/pci-dma.h
inclusion in arch's asm/pci.h
While in theory user_enable_single_step/user_disable_single_step/
user_enable_blockstep could also be provided as an inline or macro there's
no good reason to do so, and having the prototype in one places keeps code
size and confusion down.
Roland said:
The original thought there was that user_enable_single_step() et al
might well be only an instruction or three on a sane machine (as if we
have any of those!), and since there is only one call site inlining
would be beneficial. But I agree that there is no strong reason to care
about inlining it.
As to the arch changes, there is only one thought I'd add to the
record. It was always my thinking that for an arch where
PTRACE_SINGLESTEP does text-modifying breakpoint insertion,
user_enable_single_step() should not be provided. That is,
arch_has_single_step()=>true means that there is an arch facility with
"pure" semantics that does not have any unexpected side effects.
Inserting a breakpoint might do very unexpected strange things in
multi-threaded situations. Aside from that, it is a peculiar side
effect that user_{enable,disable}_single_step() should cause COW
de-sharing of text pages and so forth. For PTRACE_SINGLESTEP, all these
peculiarities are the status quo ante for that arch, so having
arch_ptrace() itself do those is one thing. But for building other
things in the future, it is nicer to have a uniform "pure" semantics
that arch-independent code can expect.
OTOH, all such arch issues are really up to the arch maintainer. As
of today, there is nothing but ptrace using user_enable_single_step() et
al so it's a distinction without a practical difference. If/when there
are other facilities that use user_enable_single_step() and might care,
the affected arch's can revisit the question when someone cares about
the quality of the arch support for said new facility.
Cc: Roland McGrath <roland@redhat.com>
Add generic implementations of the old and really old uname system calls.
Note that sh only implements sys_olduname but not sys_oldolduname, but I'm
not going to bother with another ifdef for that special case.
m32r implemented an old uname but never wired it up, so kill it, too.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andreas Schwab <schwab@linux-m68k.org>
On an architecture that supports 32-bit compat we need to override the
reported machine in uname with the 32-bit value. Instead of doing this
separately in every architecture introduce a COMPAT_UTS_MACHINE define in
<asm/compat.h> and apply it directly in sys_newuname().
Add a generic implementation of the ipc demultiplexer syscall. Except for
s390 and sparc64 all implementations of the sys_ipc are nearly identical.
There are slight differences in the types of the parameters, where mips
and powerpc as the only 64-bit architectures with sys_ipc use unsigned
long for the "third" argument as it gets casted to a pointer later, while
it traditionally is an "int" like most other paramters. frv goes even
further and uses unsigned long for all parameters execept for "ptr" which
is a pointer type everywhere. The change from int to unsigned long for
"third" and back to "int" for the others on frv should be fine due to the
in-register calling conventions for syscalls (we already had a similar
issue with the generic sys_ptrace), but I'd prefer to have the arch
maintainers looks over this in details.
Except for that h8300, m68k and m68knommu lack an impplementation of the
semtimedop sub call which this patch adds, and various architectures have
gets used - at least on i386 it seems superflous as the compat code on
x86-64 and ia64 doesn't even bother to implement it.
[akpm@linux-foundation.org: add sys_ipc to sys_ni.c]
Reviewed-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Found and fixed a couple typos in the advanced ptrace patches.
(These patches are currently in benh's next tree.)
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: linuxppc-dev list <Linuxppc-dev@ozlabs.org>
On 64-bit kernels we currently have a 512 byte struct paca_struct for
each cpu (usually just called "the paca"). Currently they are statically
allocated, which means a kernel built for a large number of cpus will
waste a lot of space if it's booted on a machine with few cpus.
We can avoid that by only allocating the number of pacas we need at
boot. However this is complicated by the fact that we need to access
the paca before we know how many cpus there are in the system.
The solution is to dynamically allocate enough space for NR_CPUS pacas,
but then later in boot when we know how many cpus we have, we free any
unused pacas.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
* 'kvm-updates/2.6.34' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (145 commits)
KVM: x86: Add KVM_CAP_X86_ROBUST_SINGLESTEP
KVM: VMX: Update instruction length on intercepted BP
KVM: Fix emulate_sys[call, enter, exit]()'s fault handling
KVM: Fix segment descriptor loading
KVM: Fix load_guest_segment_descriptor() to inject page fault
KVM: x86 emulator: Forbid modifying CS segment register by mov instruction
KVM: Convert kvm->requests_lock to raw_spinlock_t
KVM: Convert i8254/i8259 locks to raw_spinlocks
KVM: x86 emulator: disallow opcode 82 in 64-bit mode
KVM: x86 emulator: code style cleanup
KVM: Plan obsolescence of kernel allocated slots, paravirt mmu
KVM: x86 emulator: Add LOCK prefix validity checking
KVM: x86 emulator: Check CPL level during privilege instruction emulation
KVM: x86 emulator: Fix popf emulation
KVM: x86 emulator: Check IOPL level during io instruction emulation
KVM: x86 emulator: fix memory access during x86 emulation
KVM: x86 emulator: Add Virtual-8086 mode of emulation
KVM: x86 emulator: Add group9 instruction decoding
KVM: x86 emulator: Add group8 instruction decoding
KVM: do not store wqh in irqfd
Trivial conflicts in Documentation/feature-removal-schedule.txt
This implements perf_event support for the Freescale embedded performance
monitor, based on the existing perf_event.c that supports server/classic
chips.
Some limitations:
- Performance monitor interrupts are regular EE interrupts, and thus you
can't profile places with interrupts disabled. We may want to implement
soft IRQ-disabling, with perfmon interrupts exempted and treated as NMIs.
- When trying to schedule multiple event groups at once, and using
restricted events, situations could arise where scheduling fails even
though it would be possible. Consider three groups, each with two events.
One group has restricted events, the others don't. The two non-restricted
groups are scheduled, then one is removed, which happens to occupy the two
counters that can't do restricted events. The remaining non-restricted
group will not be moved to the non-restricted-capable counters to make
room if the restricted group tries to be scheduled.
Acked-by: Paul Mackerras <paulus@samba.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: add __percpu sparse annotations to what's left
percpu: add __percpu sparse annotations to fs
percpu: add __percpu sparse annotations to core kernel subsystems
local_t: Remove leftover local.h
this_cpu: Remove pageset_notifier
this_cpu: Page allocator conversion
percpu, x86: Generic inc / dec percpu instructions
local_t: Move local.h include to ringbuffer.c and ring_buffer_benchmark.c
module: Use this_cpu_xx to dynamically allocate counters
local_t: Remove cpu_local_xx macros
percpu: refactor the code in pcpu_[de]populate_chunk()
percpu: remove compile warnings caused by __verify_pcpu_ptr()
percpu: make accessors check for percpu pointer in sparse
percpu: add __percpu for sparse.
percpu: make access macros universal
percpu: remove per_cpu__ prefix.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits)
ARM: Eliminate decompressor -Dstatic= PIC hack
ARM: 5958/1: ARM: U300: fix inverted clk round rate
ARM: 5956/1: misplaced parentheses
ARM: 5955/1: ep93xx: move timer defines into core.c and document
ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c
ARM: 5953/1: ep93xx: fix broken build of clock.c
ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig
ARM: 5949/1: NUC900 add gpio virtual memory map
ARM: 5948/1: Enable timer0 to time4 clock support for nuc910
ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk
ARM: make_coherent(): fix problems with highpte, part 2
MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself
ARM: 5945/1: ep93xx: include correct irq.h in core.c
ARM: 5933/1: amba-pl011: support hardware flow control
ARM: 5930/1: Add PKMAP area description to memory.txt.
ARM: 5929/1: Add checks to detect overlap of memory regions.
ARM: 5928/1: Change type of VMALLOC_END to unsigned long.
ARM: 5927/1: Make delimiters of DMA area globally visibly.
ARM: 5926/1: Add "Virtual kernel memory..." printout.
ARM: 5920/1: OMAP4: Enable L2 Cache
Fix up trivial conflict in arch/arm/mach-mx25/clock.c
Old method prematurely sets ESR and DEAR.
Move this part after we decide to inject interrupt,
which is more like hardware behave.
Signed-off-by: Liu Yu <yu.liu@freescale.com>
Acked-by: Hollis Blanchard <hollis@penguinppc.org>
Acked-by: Alexander Graf <agraf@suse.de>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit 55fb1027c1cf9797dbdeab48180da530e81b1c39 doesn't update tlbcfg correctly.
Fix it.
And since guest OS likes 'fixed' hardware,
initialize tlbcfg everytime when guest access is useless.
So move this part to init code.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Latest kernel start to access l1csr0 to contron L1.
We just tell guest no operation is on going.
SRR1 stores more information that just the MSR value. It also stores
valuable information about the type of interrupt we received, for
example whether the storage interrupt we just got was because of a
missing htab entry or not.
We use that information to speed up the exit path.
Now if we get preempted before we can interpret the shadow_msr values,
we get into vcpu_put which then calls the MSR handler, which then sets
all the SRR1 information bits in shadow_msr to 0. Great.
So let's preserve the SRR1 specific bits in shadow_msr whenever we set
the MSR. They don't hurt.
Commit 7d01b4c3ed2bb33ceaf2d270cb4831a67a76b51b introduced PACA backed vcpu
values. With this patch, when a userspace app was setting GPRs before it was
actually first loaded, the set values get discarded.
This is because vcpu_load loads them from the vcpu backing store that we use
whenever we're not owning the PACA.
That behavior is not really a major problem, because we don't need it for
qemu. Other users (like kvmctl) do have problems with it though, so let's
better do it right.
When our guest starts using either the FPU, Altivec or VSX we need to make
sure Linux knows about it and sneak into its process switching code
accordingly.
This patch makes accesses to the above parts of the system work inside the
VM.
Linux contains quite some bits of code to load FPU, Altivec and VSX lazily for
a task. It calls those bits in real mode, coming from an interrupt handler.
For KVM we better reuse those, so let's wrap a bit of trampoline magic around
them and then we can call them from normal module code.
An SLB entry contains two pieces of information related to size:
1) PTE size
2) SLB size
The L bit defines the PTE be "large" (usually means 16MB),
SLB_VSID_B_1T defines that the SLB should span 1 GB instead of the
default 256MB.
Apparently I messed things up and just put those two in one box,
shaked it heavily and came up with the current code which handles
large pages incorrectly, because it also treats large page SLB entries
as "1TB" segment entries.
This patch splits those two features apart, making Linux guests boot
even when they have > 256MB.
Book3S needs some flags in SRR1 to get to know details about an interrupt.
One such example is the trap instruction. It tells the guest kernel that
a program interrupt is due to a trap using a bit in SRR1.
This patch implements above behavior, making WARN_ON behave like WARN_ON.
Currently we're racy when doing the transition from IR=1 to IR=0, from
the module memory entry code to the real mode SLB switching code.
To work around that I took a look at the RTAS entry code which is faced
with a similar problem and did the same thing:
A small helper in linear mapped memory that does mtmsr with IR=0 and
then RFIs info the actual handler.
Thanks to that trick we can safely take page faults in the entry code
and only need to be really wary of what to do as of the SLB switching
part.
To fetch the last instruction we were interrupted on, we enable DR in early
exit code, where we are still in a very transitional phase between guest
and host state.
Most of the time this seemed to work, but another CPU can easily flush our
TLB and HTAB which makes us go in the Linux page fault handler which totally
breaks because we still use the guest's SLB entries.
To work around that, let's introduce a second KVM guest mode that defines
that whenever we get a trap, we don't call the Linux handler or go into
the KVM exit code, but just jump over the faulting instruction.
That way a potentially bad lwz doesn't trigger any faults and we can later
on interpret the invalid instruction we fetched as "fetch didn't work".
We're being horribly racy right now. All the entry and exit code hijacks
random fields from the PACA that could easily be used by different code in
case we get interrupted, for example by a #MC or even page fault.
After discussing this with Ben, we figured it's best to reserve some more
space in the PACA and just shove off some vcpu state to there.
That way we can drastically improve the readability of the code, make it
less racy and less complex.
We now have helpers for the GPRs, so let's also add some for CR and XER.
Having them in the PACA simplifies code a lot, as we don't need to care
about where to store CC or not to overflow any integers.
All code in PPC KVM currently accesses gprs in the vcpu struct directly.
While there's nothing wrong with that wrt the current way gprs are stored
and loaded, it doesn't suffice for the PACA acceleration that will follow
in this patchset.
So let's just create little wrapper inline functions that we call whenever
a GPR needs to be read from or written to. The compiled code shouldn't really
change at all for now.
We treated the DEC interrupt like an edge based one. This is not true for
Book3s. The DEC keeps firing until mtdec is issued again and thus clears
the interrupt line.
So let's implement this logic in KVM too. This patch moves the line clearing
from the firing of the interrupt to the mtdec emulation.
This makes PPC64 guests work without AGGRESSIVE_DEC defined.
Acked-by: Acked-by: Hollis Blanchard <hollis@penguinppc.org>
Anton's commit enabling the use of the lwsync fixup mechanism on 64-bit
breaks modules. The lwsync fixup section uses .long instead of the
FTR_ENTRY_OFFSET macro used by other fixups sections, and thus will
generate 32-bit relocations that our module loader cannot resolve.
This changes it to use the same type as other feature sections.
Note however that we might want to consider using 32-bit for all the
feature fixup offsets and add support for R_PPC_REL32 to module_64.c
instead as that would reduce the size of the kernel image. I'll leave
that as an exercise for the reader for now...
Manual merge of:
drivers/char/hvc_console.c
drivers/char/hvc_console.h
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (41 commits)
of: remove undefined request_OF_resource & release_OF_resource
of/sparc: Remove sparc-local declaration of allnodes and devtree_lock
of: move definition of of_chosen into common code.
of: remove unused extern reference to devtree_lock
of: put default string compare and #a/s-cell values into common header
of/flattree: Don't assume HAVE_LMB
of: protect linux/of.h with CONFIG_OF
proc_devtree: fix THIS_MODULE without module.h
of: Remove old and misplaced function declarations
of/flattree: Make the kernel accept ePAPR style phandle information
of/flattree: endian-convert members of boot_param_header
of: assume big-endian properties, adding conversions where necessary
of: use __be32 for cell value accessors
of/flattree: use OF_ROOT_NODE_{SIZE,ADDR}_CELLS DEFAULT for fdt parsing
of/flattree: use callback to setup initrd from /chosen
proc_devtree: include linux/of.h
of: make set_node_proc_entry private to proc_devtree.c
of: include linux/proc_fs.h
of/flattree: merge early_init_dt_scan_memory() common code
of: add 'of_' prefix to machine_is_compatible()
On VIVT ARM, when we have multiple shared mappings of the same file
in the same MM, we need to ensure that we have coherency across all
copies. We do this via make_coherent() by making the pages
uncacheable.
This used to work fine, until we allowed highmem with highpte - we
now have a page table which is mapped as required, and is not available
for modification via update_mmu_cache().
Ralf Beache suggested getting rid of the PTE value passed to
update_mmu_cache():
On MIPS update_mmu_cache() calls __update_tlb() which walks pagetables
to construct a pointer to the pte again. Passing a pte_t * is much
more elegant. Maybe we might even replace the pte argument with the
pte_t?
Ben Herrenschmidt would also like the pte pointer for PowerPC:
Passing the ptep in there is exactly what I want. I want that
-instead- of the PTE value, because I have issue on some ppc cases,
for I$/D$ coherency, where set_pte_at() may decide to mask out the
_PAGE_EXEC.
So, pass in the mapped page table pointer into update_mmu_cache(), and
remove the PTE value, updating all implementations and call sites to
suit.
Includes a fix from Stephen Rothwell:
sparc: fix fallout from update_mmu_cache API change
mpic_lock, irq_rover_lock and fixup_lock need to be real spinlocks in
RT. Convert them to raw_spinlock.
feature_lock needs to be a real spinlock in RT. Convert it to
raw_spinlock.
MPC5121 has 12 PSC devices. Enable UART support for all of
them by defining the number of max. PSCs depending on
selection of PPC_MPC512x platform support.
powerpc/booke: Add support for advanced debug registers
Based on patches originally written by Torez Smith.
This patch defines context switch and trap related functionality
for BookE specific Debug Registers. It adds support to ptrace()
for setting and getting BookE related Debug Registers
Cc: Torez Smith <lnxtorez@linux.vnet.ibm.com>
Cc: David Gibson <dwg@au1.ibm.com>
Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Sergio Durigan Junior <sergiodj@br.ibm.com>
Cc: Thiago Jung Bauermann <bauerman@br.ibm.com>
powerpc/booke: Add definitions for advanced debug registers
This patch adds additional definitions for BookE Debug Registers
to the reg_booke.h header file.
Acked-by: David Gibson <dwg@au1.ibm.com>
powerpc: Extended ptrace interface
Add a new extended ptrace interface so that user-space has a single
interface for powerpc, without having to know the specific layout
of the debug registers.
Implement:
PPC_PTRACE_GETHWDEBUGINFO
PPC_PTRACE_SETHWDEBUG
PPC_PTRACE_DELHWDEBUG
Nick Piggin discovered that lwsync barriers around locks were faster than isync
on 970. That was a long time ago and I completely dropped the ball in testing
his patches across other ppc64 processors.
Turns out the idea helps on other chips. Using a microbenchmark that
uses a lot of threads to contend on a global pthread mutex (and therefore a
global futex), POWER6 improves 8% and POWER7 improves 2%. I checked POWER5
and while I couldn't measure an improvement, there was no regression.
This patch uses the lwsync patching code to replace the isyncs with lwsyncs
on CPUs that support the instruction. We were marking POWER3 and RS64 as lwsync
capable but in reality they treat it as a full sync (ie slow). Remove the
CPU_FTR_LWSYNC bit from these CPUs so they continue to use the faster isync
method.
PPC_ACQUIRE_BARRIER
For performance reasons we are about to change ISYNC_ON_SMP to sometimes be
lwsync. Now that the macro name doesn't make sense, change it and LWSYNC_ON_SMP
to better explain what the barriers are doing.
This patch implements the lwarx/ldarx hint bit for bit locks.
Recent versions of the PowerPC architecture added a hint bit to the larx
instructions to differentiate between an atomic operation and a lock operation:
> 0 Other programs might attempt to modify the word in storage addressed by EA
> even if the subsequent Store Conditional succeeds.
> 1 Other programs will not attempt to modify the word in storage addressed by
> EA until the program that has acquired the lock performs a subsequent store
> releasing the lock.
To avoid a binutils dependency this patch create macros for the extended lwarx
format and uses it in the spinlock code. To test this change I used a simple
test case that acquires and releases a global pthread mutex:
pthread_mutex_lock(&mutex);
pthread_mutex_unlock(&mutex);
On a 32 core POWER6, running 32 test threads we spend almost all our time in
the futex spinlock code:
94.37% perf [kernel] [k] ._raw_spin_lock
|--99.95%-- ._raw_spin_lock
| |--63.29%-- .futex_wake
| |--36.64%-- .futex_wait_setup
Which is a good test for this patch. The results (in lock/unlock operations per
second) are:
before: 1538203 ops/sec
after: 2189219 ops/sec
An improvement of 42%
A 32 core POWER7 improves even more:
before: 1279529 ops/sec
after: 2282076 ops/sec
An improvement of 78%
