ABIv2 kernels are failing to backtrace through the kernel. An example:
39.30% readseek2_proce [kernel.kallsyms] [k] find_get_entry
--- find_get_entry
__GI___libc_read
The problem is in valid_next_sp() where we check that the new stack
pointer is at least STACK_FRAME_OVERHEAD below the previous one.
ABIv1 has a minimum stack frame size of 112 bytes consisting of 48 bytes
and 64 bytes of parameter save area. ABIv2 changes that to 32 bytes
with no paramter save area.
STACK_FRAME_OVERHEAD is in theory the minimum stack frame size,
but we over 240 uses of it, some of which assume that it includes
space for the parameter area.
We need to work through all our stack defines and rationalise them
but let's fix perf now by creating STACK_FRAME_MIN_SIZE and using
in valid_next_sp(). This fixes the issue:
30.64% readseek2_proce [kernel.kallsyms] [k] find_get_entry
--- find_get_entry
pagecache_get_page
generic_file_read_iter
new_sync_read
vfs_read
sys_read
syscall_exit
__GI___libc_read
Cc: stable@vger.kernel.org # 3.16+
Reported-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
The new ELFv2 little-endian ABI increases the stack redzone -- the
area below the stack pointer that can be used for storing data --
from 288 bytes to 512 bytes. This means that we need to allow more
space on the user stack when delivering a signal to a 64-bit process.
To make the code a bit clearer, we define new USER_REDZONE_SIZE and
KERNEL_REDZONE_SIZE symbols in ptrace.h. For now, we leave the
kernel redzone size at 288 bytes, since increasing it to 512 bytes
would increase the size of interrupt stack frames correspondingly.
Gcc currently only makes use of 288 bytes of redzone even when
compiling for the new little-endian ABI, and the kernel cannot
currently be compiled with the new ABI anyway.
In the future, hopefully gcc will provide an option to control the
amount of redzone used, and then we could reduce it even more.
This also changes the code in arch_compat_alloc_user_space() to
preserve the expanded redzone. It is not clear why this function would
ever be used on a 64-bit process, though.
CC: <stable@vger.kernel.org> [v3.13]
Currently ptrace_get_reg returns error as a value
what make impossible to tell whether it is a correct value or error code.
The patch adds a parameter which points to the real return data and
returns an error code.
As get_user_msr() never fails and it is used in multiple places so it has not
been changed by this patch.
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Acked-by: Michael Neuling <mikey@neuling.org>
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc uapi disintegration from Benjamin Herrenschmidt.
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
UAPI: (Scripted) Disintegrate arch/powerpc/include/asm
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
the only non-obvious part is that current_pt_regs() is really needed
here - task_pt_regs() is NULL for kernel threads; it's OK for ptrace
uses (the thing task_pt_regs() is intended for), but not for us.
PowerPC has non standard getregs calls that only dump the GPRs or
FPRs and have their arguments reversed. commit e17666ba48f7 (ptrace
updates & new, better requests) in 2.6.3 deprecated them and introduced
more standard versions.
It's been about 5 years and I know of no users of the old calls so
lets remove them.
With this change, helpers such as instruction_pointer() et al, get defined
in the generic header in terms of GET_IP
Removed the unnecessary definition of profile_pc in !CONFIG_SMP case as
suggested by Mike Frysinger.
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
The audit system previously expected arches calling to audit_syscall_exit to
supply as arguments if the syscall was a success and what the return code was.
Audit also provides a helper AUDITSC_RESULT which was supposed to simplify things
by converting from negative retcodes to an audit internal magic value stating
success or failure. This helper was wrong and could indicate that a valid
pointer returned to userspace was a failed syscall. The fix is to fix the
layering foolishness. We now pass audit_syscall_exit a struct pt_reg and it
in turns calls back into arch code to collect the return value and to
determine if the syscall was a success or failure. We also define a generic
is_syscall_success() macro which determines success/failure based on if the
value is < -MAX_ERRNO. This works for arches like x86 which do not use a
separate mechanism to indicate syscall failure.
We make both the is_syscall_success() and regs_return_value() static inlines
instead of macros. The reason is because the audit function must take a void*
for the regs. (uml calls theirs struct uml_pt_regs instead of just struct
pt_regs so audit_syscall_exit can't take a struct pt_regs). Since the audit
function takes a void* we need to use static inlines to cast it back to the
arch correct structure to dereference it.
The other major change is that on some arches, like ia64, MIPS and ppc, we
change regs_return_value() to give us the negative value on syscall failure.
THE only other user of this macro, kretprobe_example.c, won't notice and it
makes the value signed consistently for the audit functions across all archs.
In arch/sh/kernel/ptrace_64.c I see that we were using regs[9] in the old
audit code as the return value. But the ptrace_64.h code defined the macro
regs_return_value() as regs[3]. I have no idea which one is correct, but this
patch now uses the regs_return_value() function, so it now uses regs[3].
For powerpc we previously used regs->result but now use the
regs_return_value() function which uses regs->gprs[3]. regs->gprs[3] is
always positive so the regs_return_value(), much like ia64 makes it negative
before calling the audit code when appropriate.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: H. Peter Anvin <hpa@zytor.com> [for x86 portion]
Acked-by: Tony Luck <tony.luck@intel.com> [for ia64]
Acked-by: Richard Weinberger <richard@nod.at> [for uml]
Acked-by: David S. Miller <davem@davemloft.net> [for sparc]
Acked-by: Ralf Baechle <ralf@linux-mips.org> [for mips]
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [for ppc]
In some cases during a threaded core dump not all the threads will have
a full register set. This happens when the signal causing the core dump
races with a thread exiting. The race happens when the exiting thread
has entered the kernel for the last time before the signal arrives, but
doesn't get far enough through the exit code to avoid being included
in the core dump.
So we get a thread included in the core dump which is never going to go
out to userspace again and only has a partial register set recorded
Normally we would catch each thread as it is about to go into userspace
and capture the full register set then.
However, this exiting thread is never going to go out to userspace
again, so we have no way to capture its full register set. It doesn't
really matter, though, as this is a thread which is effectively
already dead.
So instead of hitting a BUG() in this case (a really bad choice of
action in the first place), we use a poison value for the register
values.
[BenH]: Some cosmetic/stylistic changes and fix build on ppc32
Signed-off-by: Mike Wolf <mjw@linux.vnet.ibm.com>
Build of ptrace.h failed for assembly because it
pulls in stdint.h.
Use exportable types (__u32, __u64) to avoid the dependency
on stdint.h.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Andrey Volkov <avolkov@varma-el.com>
Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
This patch ports the kprobe-based event tracer to powerpc. This patch
is based on x86 port. This brings powerpc on par with x86.
Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
While in theory user_enable_single_step/user_disable_single_step/
user_enable_blockstep could also be provided as an inline or macro there's
no good reason to do so, and having the prototype in one places keeps code
size and confusion down.
Roland said:
The original thought there was that user_enable_single_step() et al
might well be only an instruction or three on a sane machine (as if we
have any of those!), and since there is only one call site inlining
would be beneficial. But I agree that there is no strong reason to care
about inlining it.
As to the arch changes, there is only one thought I'd add to the
record. It was always my thinking that for an arch where
PTRACE_SINGLESTEP does text-modifying breakpoint insertion,
user_enable_single_step() should not be provided. That is,
arch_has_single_step()=>true means that there is an arch facility with
"pure" semantics that does not have any unexpected side effects.
Inserting a breakpoint might do very unexpected strange things in
multi-threaded situations. Aside from that, it is a peculiar side
effect that user_{enable,disable}_single_step() should cause COW
de-sharing of text pages and so forth. For PTRACE_SINGLESTEP, all these
peculiarities are the status quo ante for that arch, so having
arch_ptrace() itself do those is one thing. But for building other
things in the future, it is nicer to have a uniform "pure" semantics
that arch-independent code can expect.
OTOH, all such arch issues are really up to the arch maintainer. As
of today, there is nothing but ptrace using user_enable_single_step() et
al so it's a distinction without a practical difference. If/when there
are other facilities that use user_enable_single_step() and might care,
the affected arch's can revisit the question when someone cares about
the quality of the arch support for said new facility.
Cc: Roland McGrath <roland@redhat.com>
powerpc: Extended ptrace interface
Based on patches originally written by Torez Smith.
Add a new extended ptrace interface so that user-space has a single
interface for powerpc, without having to know the specific layout
of the debug registers.
Implement:
PPC_PTRACE_GETHWDEBUGINFO
PPC_PTRACE_SETHWDEBUG
PPC_PTRACE_DELHWDEBUG
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Acked-by: David Gibson <dwg@au1.ibm.com>
Cc: Torez Smith <lnxtorez@linux.vnet.ibm.com>
Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Sergio Durigan Junior <sergiodj@br.ibm.com>
Cc: Thiago Jung Bauermann <bauerman@br.ibm.com>
Cc: linuxppc-dev list <Linuxppc-dev@ozlabs.org>
Suggested by Roland.
Implement user_single_step_siginfo() for powerpc.
Acked-by: Roland McGrath <roland@redhat.com>
Cc: <linux-arch@vger.kernel.org>
Reworked by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
This adds block-step support on powerpc, including a PTRACE_SINGLEBLOCK
request for ptrace.
The BookE implementation is tweaked to fire a single step after a
block step in order to mimmic the server behaviour.
Signed-off-by: Roland McGrath <roland@redhat.com>
All architectures now use the generic compat_sys_ptrace, as should every
new architecture that needs 32bit compat (if we'll ever get another).
Remove the now superflous __ARCH_WANT_COMPAT_SYS_PTRACE define, and also
kill a comment about __ARCH_SYS_PTRACE that was added after
__ARCH_SYS_PTRACE was already gone.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
from include/asm-powerpc. This is the result of a
mkdir arch/powerpc/include/asm
git mv include/asm-powerpc/* arch/powerpc/include/asm
Followed by a few documentation/comment fixups and a couple of places
where <asm-powepc/...> was being used explicitly. Of the latter only
one was outside the arch code and it is a driver only built for powerpc.
