Merge common code between Microblaze and PowerPC
Acked-by: Michal Simek <monstr@monstr.eu>
Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com>
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
Merge common code between PowerPC and Microblaze
Merge common code for working with Flattened Device Tree data structure
Add a common header file for working with the flattened device tree
data structure and merge the shared data tags used by Microblaze and
PowerPC
Merge of common code duplicated between Sparc, PowerPC and Microblaze
In preparation to prune things out of the Sparc, PowerPC and Microblaze
asm/prom.h files, change the #include statements to ensure that
even if asm/prom.h is included first, linux/of.h gets to determine the
order in which files are processed.
This patch adds a #include <linux/of.h> to each of the prom.h files
*above* the multi-include protection macros to ensure that linux/of.h
can define things before prom.h gets processed.
At the end of the merge the cross dependencies between the files should
be gone and a sane #include scheme can be restored.
We have more than one piece of code that looks up cache nodes manually
using the "l2-cache" property. Add a common helper routine which does
this and handles ePAPR's "next-level-cache" property as well as
powermac.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
from include/asm-powerpc. This is the result of a
mkdir arch/powerpc/include/asm
git mv include/asm-powerpc/* arch/powerpc/include/asm
Followed by a few documentation/comment fixups and a couple of places
where <asm-powepc/...> was being used explicitly. Of the latter only
one was outside the arch code and it is a driver only built for powerpc.
