Fix wrong __IO_H definition in boot/io.h
Reported-by: Fernando Silveira <fsilveira@gmail.com>
Signed-off-by: Lucas Tanure <tanure@linux.com>
T2080PCIe-RDB is a Freescale Reference Design Board that hosts T2080 SoC.
The board feature overview:
Processor:
- T2080 SoC integrating four 64-bit dual-threads e6500 cores up to 1.8GHz
DDR Memory:
- Single memory controller capable of supporting DDR3 and DDR3-LP devices
- 72bit 4GB DDR3-LP SODIMM in slot
Ethernet interfaces:
- Two 1Gbps RGMII ports on-board
- Two 10Gbps SFP+ ports on-board
- Two 10Gbps Base-T ports on-board
Accelerator:
- DPAA components consist of FMan, BMan, QMan, PME, DCE and SEC
IFC/Local Bus
- NOR: 128MB 16-bit NOR flash
- NAND: 1GB 8-bit NAND flash
- CPLD: for system controlling with programable header on-board
eSPI:
- 64MB N25Q512 SPI flash
USB:
- Two USB2.0 ports with internal PHY (both Type-A)
PCIe:
- One PCIe x4 goldfinger(support SR-IOV)
- One PCIe x4 slot
- One PCIe x2 end-point device (C293 crypto co-processor)
SATA:
- Two SATA 2.0 ports on-board
SDHC:
- support a MicroSD/TF card on-board
I2C:
- Four I2C controllers.
UART:
- Dual 4-pins UART serial ports
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Add support for Freescale T2080/T2081 QDS Development System Board.
The T2080QDS Development System is a high-performance computing,
evaluation, and development platform that supports T2080 QorIQ
Power Architecture processor, with following major features:
T2080QDS feature overview:
Processor:
Memory:
- Dual DIMM slots up 2133MT/s with ECC
- Two 1Gbps RGMII on-board ports
- Four 10Gbps XFI on-board cages
- 1Gbps/2.5Gbps SGMII Riser card
- 10Gbps XAUI Riser card
Accelerator:
SerDes:
- 16 lanes up to 10.3125GHz
- Supports Aurora debug, PEX, SATA, SGMII, sRIO, HiGig, XFI and XAUI
IFC:
- 128MB NOR Flash, 512MB NAND Flash, PromJet debug port and FPGA
eSPI:
- Three SPI flash (16MB N25Q128A + 8MB EN25S64 + 512KB SST25WF040)
USB:
- Two USB2.0 ports with internal PHY (one Type-A + one micro Type-AB)
PCIE:
- Four PCI Express controllers (two PCIe 2.0 and two PCIe 3.0, SR-IOV)
SATA:
SRIO:
- Two Serial RapidIO 2.0 ports up to 5 GHz
eSDHC:
- Supports SD/MMC/eMMC Card
DMA:
- Three 8-channels DMA controllers
I2C:
UART:
System Logic:
- QIXIS-II FPGA system controll
T2081QDS board shares the same PCB with T1040QDS with some differences.
The T2080 QorIQ multicore processor combines four dual-threaded e6500 Power
Architecture processor cores with high-performance datapath acceleration
logic and network and peripheral bus interfaces required for networking,
telecom/datacom, wireless infrastructure, and mil/aerospace applications.
The T2080 SoC includes the following function and features:
- Four dual-threaded 64-bit Power architecture e6500 cores, up to 1.8GHz
- 2MB L2 cache and 512KB CoreNet platform cache (CPC)
- Hierarchical interconnect fabric
- One 32-/64-bit DDR3/3L SDRAM memory controllers with ECC and interleaving
- Data Path Acceleration Architecture (DPAA) incorporating acceleration
- 16 SerDes lanes up to 10.3125 GHz
- 8 Ethernet interfaces (multiple 1G/2.5G/10G MACs)
- High-speed peripheral interfaces
- Four PCI Express controllers (two PCIe 2.0 and two PCIe 3.0)
- Two Serial RapidIO 2.0 controllers/ports running at up to 5 GHz
- Additional peripheral interfaces
- Two serial ATA (SATA 2.0) controllers
- Two high-speed USB 2.0 controllers with integrated PHY
- Enhanced secure digital host controller (SD/SDXC/eMMC)
- Enhanced serial peripheral interface (eSPI)
- Four 2-pin UARTs or two 4-pin UARTs
- Integrated Flash Controller supporting NAND and NOR flash
- Three eight-channel DMA engines
- Support for hardware virtualization and partitioning enforcement
- QorIQ Platform's Trust Architecture 2.0
T2081 is a reduced personality of T2080 with following difference:
Feature T2080 T2081
1G Ethernet numbers: 8 6
10G Ethernet numbers: 4 2
SerDes lanes: 16 8
Serial RapidIO,RMan: 2 no
SATA Controller: 2 no
Aurora: yes no
SoC Package: 896-pins 780-pins
[scottwood@freescale.com: added fsl,qoriq-pci-v3.0 for U-Boot compat]
T4240RDB board Specification
Memory subsystem:
6GB DDR3
128MB NOR flash
2GB NAND flash
Ethernet:
Eight 1G SGMII ports
Four 10Gbps SFP+ ports
PCIe:
Two PCIe slots
USB:
Two USB2.0 Type A ports
SDHC:
One SD-card port
SATA:
One SATA port
UART:
Dual RJ45 ports
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
The mux2 node is missing the clock-output-names field that is required
by the clk-ppc-corenet driver.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
T4240 has a third DMA engine controller, so add the corresponding DMA
node into the dts file.
[scottwood@freescale.com: reword commit message]
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
"Kbuild changes for v3.16-rc1:
- cross-compilation fix so that cc-option is testing the right
compiler
- Fix for make defconfig all
- Using relative paths to the object and source directory where
possible, plus fixes for the fallout of the change
- several cleanups in the Makefiles and scripts
The powerpc fix is from today, because it was only discovered
recently. The rest has been in linux-next for some time"
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
powerpc: Avoid circular dependency with zImage.%
kbuild: create include/config directory in scripts/kconfig/Makefile
kbuild: do not create include/linux directory
Makefile: Fix unrecognized cross-compiler command line options
kbuild: do not add "selinux" to subdir- twice
um: Fix for relative objtree when generating x86 headers
kbuild: Use relative path when building in a subdir of the source tree
kbuild: Use relative path when building in the source tree
kbuild: Use relative path for $(objtree)
firmware: Use $(quote) in the Makefile
firmware: Simplify directory creation
kbuild: trivial - fix comment block indent
kbuild: trivial - remove trailing spaces
kbuild: support simultaneous "make %config" and "make all"
kbuild: move extra gcc checks to scripts/Makefile.extrawarn
The rule to create the final images uses a zImage.% pattern.
Unfortunately, this also matches the names of the zImage.*.lds linker
scripts, which appear as a dependency of the final images. This somehow
worked when $(srctree) used to be an absolute path, but now the pattern
matches too much. List only the images from $(image-y) as the target of
the rule, to avoid the circular dependency.
Reported-and-tested-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Ben Herrenschmidt:
"Here is the bulk of the powerpc changes for this merge window. It got
a bit delayed in part because I wasn't paying attention, and in part
because I discovered I had a core PCI change without a PCI maintainer
ack in it. Bjorn eventually agreed it was ok to merge it though we'll
probably improve it later and I didn't want to rebase to add his ack.
There is going to be a bit more next week, essentially fixes that I
still want to sort through and test.
The biggest item this time is the support to build the ppc64 LE kernel
with our new v2 ABI. We previously supported v2 userspace but the
kernel itself was a tougher nut to crack. This is now sorted mostly
thanks to Anton and Rusty.
We also have a fairly big series from Cedric that add support for
64-bit LE zImage boot wrapper. This was made harder by the fact that
traditionally our zImage wrapper was always 32-bit, but our new LE
toolchains don't really support 32-bit anymore (it's somewhat there
but not really "supported") so we didn't want to rely on it. This
meant more churn that just endian fixes.
This brings some more LE bits as well, such as the ability to run in
LE mode without a hypervisor (ie. under OPAL firmware) by doing the
right OPAL call to reinitialize the CPU to take HV interrupts in the
right mode and the usual pile of endian fixes.
There's another series from Gavin adding EEH improvements (one day we
*will* have a release with less than 20 EEH patches, I promise!).
Another highlight is the support for the "Split core" functionality on
P8 by Michael. This allows a P8 core to be split into "sub cores" of
4 threads which allows the subcores to run different guests under KVM
(the HW still doesn't support a partition per thread).
And then the usual misc bits and fixes ..."
[ Further delayed by gmail deciding that BenH is a dirty spammer.
Google knows. ]
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (155 commits)
powerpc/powernv: Add missing include to LPC code
selftests/powerpc: Test the THP bug we fixed in the previous commit
powerpc/mm: Check paca psize is up to date for huge mappings
powerpc/powernv: Pass buffer size to OPAL validate flash call
powerpc/pseries: hcall functions are exported to modules, need _GLOBAL_TOC()
powerpc: Exported functions __clear_user and copy_page use r2 so need _GLOBAL_TOC()
powerpc/powernv: Set memory_block_size_bytes to 256MB
powerpc: Allow ppc_md platform hook to override memory_block_size_bytes
powerpc/powernv: Fix endian issues in memory error handling code
powerpc/eeh: Skip eeh sysfs when eeh is disabled
powerpc: 64bit sendfile is capped at 2GB
powerpc/powernv: Provide debugfs access to the LPC bus via OPAL
powerpc/serial: Use saner flags when creating legacy ports
powerpc: Add cpu family documentation
powerpc/xmon: Fix up xmon format strings
powerpc/powernv: Add calls to support little endian host
powerpc: Document sysfs DSCR interface
powerpc: Fix regression of per-CPU DSCR setting
powerpc: Split __SYSFS_SPRSETUP macro
arch: powerpc/fadump: Cleaning up inconsistent NULL checks
Pull slave-dmaengine updates from Vinod Koul:
- new Xilixn VDMA driver from Srikanth
- bunch of updates for edma driver by Thomas, Joel and Peter
- fixes and updates on dw, ste_dma, freescale, mpc512x, sudmac etc
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (45 commits)
dmaengine: sh: don't use dynamic static allocation
dmaengine: sh: fix print specifier warnings
dmaengine: sh: make shdma_prep_dma_cyclic static
dmaengine: Kconfig: Update MXS_DMA help text to include MX6Q/MX6DL
of: dma: Grammar s/requests/request/, s/used required/required/
dmaengine: shdma: Enable driver compilation with COMPILE_TEST
dmaengine: rcar-hpbdma: Include linux/err.h
dmaengine: sudmac: Include linux/err.h
dmaengine: sudmac: Keep #include sorted alphabetically
dmaengine: shdmac: Include linux/err.h
dmaengine: shdmac: Keep #include sorted alphabetically
dmaengine: s3c24xx-dma: Add cyclic transfer support
dmaengine: s3c24xx-dma: Process whole SG chain
dmaengine: imx: correct sdmac->status for cyclic dma tx
dmaengine: pch: fix compilation for alpha target
dmaengine: dw: check return code of dma_async_device_register()
dmaengine: dw: fix regression in dw_probe() function
dmaengine: dw: enable clock before access
dma: pch_dma: Fix Kconfig dependencies
dmaengine: mpc512x: add support for peripheral transfers
Cc: Diana Craciun <diana.craciun@freescale.com>
- BSC9132 is an integrated device that targets Femto base station market.
It combines Power Architecture e500v2 and DSP StarCore SC3850 technologies
with MAPLE-B2F baseband acceleration processing elements
- BSC9132QDS Overview
2Gbyte DDR3 (on board DDR)
32Mbyte 16bit NOR flash
128Mbyte 2K page size NAND Flash
256 Kbit M24256 I2C EEPROM
128 Mbit SPI Flash memory
SD slot
eTSEC1: Connected to SGMII PHY
eTSEC2: Connected to SGMII PHY
DUART interface: supports one UARTs up to 115200 bps for console display
Signed-off-by: Harninder Rai <harninder.rai@freescale.com>
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
P1023RDS is no longer supported/manufactured by Freescale while P1023RDB is.
Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com>
Add support for T104x board in board file t104x_qds.c, It is common for
both T1040 and T1042 as they share same QDS board.
T1040QDS board Overview
- SERDES Connections, 8 lanes supporting:
— PCI Express: supporting Gen 1 and Gen 2;
— SGMII
— QSGMII
— SATA 2.0
— Aurora debug with dedicated connectors (T1040 only)
- DDR Controller
- Supports rates of up to 1600 MHz data-rate
- Supports one DDR3LP UDIMM/RDIMMs, of single-, dual- or quad-rank types.
-IFC/Local Bus
- NAND flash: 8-bit, async, up to 2GB.
- NOR: 8-bit or 16-bit, non-multiplexed, up to 512MB
- GASIC: Simple (minimal) target within Qixis FPGA
- PromJET rapid memory download support
- Ethernet
- Two on-board RGMII 10/100/1G ethernet ports.
- PHY #0 remains powered up during deep-sleep (T1040 only)
- QIXIS System Logic FPGA
- Clocks
- System and DDR clock (SYSCLK, “DDRCLK”)
- SERDES clocks
- Power Supplies
- Video
- DIU supports video at up to 1280x1024x32bpp
- USB
- Supports two USB 2.0 ports with integrated PHYs
— Two type A ports with 5V@1.5A per port.
— Second port can be converted to OTG mini-AB
- SDHC
- SDHC port connects directly to an adapter card slot, featuring:
- Supporting SD slots for: SD, SDHC (1x, 4x, 8x) and/or MMC
— Supporting eMMC memory devices
- SPI
- On-board support of 3 different devices and sizes
- Other IO
- Two Serial ports
- ProfiBus port
- Four I2C ports
Add T104xQDS support in Kconfig and Makefile. Also create device tree.
Following features are currently not implmented.
- SerDes: Aurora
- IFC: GASIC, Promjet
- QIXIS
- Ethernet
- DIU
- power supplies management
- ProfiBus
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
The QorIQ T1040/T1042 processor support four integrated 64-bit e5500 PA
processor cores with high-performance data path acceleration architecture
and network peripheral interfaces required for networking & telecommunications.
T1042 personality is a reduced personality of T1040 without Integrated 8-port
Gigabit Ethernet switch.
The T1040/T1042 SoC includes the following function and features:
- Four e5500 cores, each with a private 256 KB L2 cache
- 256 KB shared L3 CoreNet platform cache (CPC)
- Interconnect CoreNet platform
- 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving
support
for the following functions:
- Packet parsing, classification, and distribution
- Queue management for scheduling, packet sequencing, and congestion
management
- Cryptography Acceleration (SEC 5.0)
- RegEx Pattern Matching Acceleration (PME 2.2)
- IEEE Std 1588 support
- Hardware buffer management for buffer allocation and deallocation
- Ethernet interfaces
- Integrated 8-port Gigabit Ethernet switch (T1040 only)
- Four 1 Gbps Ethernet controllers
- Two RGMII interfaces or one RGMII and one MII interfaces
- High speed peripheral interfaces
- Four PCI Express 2.0 controllers running at up to 5 GHz
- Two SATA controllers supporting 1.5 and 3.0 Gb/s operation
- Upto two QSGMII interface
- Upto six SGMII interface supporting 1000 Mbps
- One SGMII interface supporting upto 2500 Mbps
- Two USB 2.0 controllers with integrated PHY
- SD/eSDHC/eMMC
- eSPI controller
- Four UARTs
- Four GPIO controllers
- Integrated flash controller (IFC)
- Change this to LCD/ HDMI interface (DIU) with 12 bit dual data rate
- TDM interface
- Multicore programmable interrupt controller (PIC)
- Two 8-channel DMA engines
- Single source clocking implementation
- Deep Sleep power implementaion (wakeup from GPIO/Timer/Ethernet/USB)
Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com>
Updated the device trees according to the corenet-cf
binding definition.
Signed-off-by: Diana Craciun <Diana.Craciun@freescale.com>
binding definition.
OCA4080 overview:
- 1.466 GHz Freescale QorIQ P4080E Processor
- 4Gbyte DDR3 on board
- 8Mbyte Nor flash
- Serial RapidIO 1.2
- 1 x 10/100/1000 BASE-T front ethernet
- 1 x 1000 BASE-BX ethernet on AMC connector
Signed-off-by: Martijn de Gouw <martijn.de.gouw@prodrive.nl>
[scottwood@freescale.com: minor conflict-related changes]
This patch introduces the support for Keymile's kmcoge4 board which is
the internal reference design for boards based on Freescale's
P2040/P2041 SoCs. This internal reference design is named kmp204x.
The peripherals used on this board are:
- SPI NOR Flash as bootloader medium
- NAND Flash with a ubi partition
- 2 PCIe busses (hosts 1 and 3)
- 3 FMAN Ethernet devices (FMAN1 DTSEC1/2/5)
- 4 Local Bus windows, with one dedicated to the QRIO reset/power mgmt
CPLD
- 2 I2C busses
- last but not least, the mandatory serial port
The patch also adds a defconfig file for this reference design that is
necessary because of the lowmem option that must be set higher due to
the number of PCIe devices with big ioremapped mem ranges on the boad.
This series adds support for building the powerpc 64-bit
LE kernel using the new ABI v2. We already supported
running ABI v2 userspace programs but this adds support
for building the kernel itself using the new ABI.
MPC512x and MPC8308 have similar DMA controllers, but are independent SoCs.
DMA controller driver should have separate 'compatible' values for these SoCs.
Signed-off-by: Alexander Popov <a13xp0p0v88@gmail.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
The PPC476GTR SoC supports message signalled interrupts (MSI) by writing
to special addresses within the High Speed Transfer Assist (HSTA) module.
This patch adds support for PCI MSI with a new system device. The DMA
window is also updated to allow access to the entire 42-bit address range
to allow PCI devices write access to the HSTA module.
Signed-off-by: Alistair Popple <alistair@popple.id.au>
This patch adds support for the IBM Akebono board.
The code is only slightly modified : entry points now use the
FIXUP_ENDIAN trampoline to switch endian order. The 32bit wrapper
is kept for big endian kernels and 64bit is enforced for little
endian kernels with a PPC64_BOOT_WRAPPER config option.
The linker script is generated using the kernel preprocessor flags
to make use of the CONFIG_* definitions and the wrapper script is
modified to take into account the new elf64ppc format.
Finally, the zImage file is compiled as a position independent
executable (-pie) which makes it loadable at any address by the
firmware.
Signed-off-by: Cédric Le Goater <clg@fr.ibm.com>
When entering the boot wrapper in little endian, we will need to fix
the endian order using a fixup trampoline like in the kernel. This
patch overrides the _zimage_start entry point for this purpose.
This patch adds support a 64bit wrapper entry point. As in 32bit, the
entry point does its own relocation and can be loaded at any address
by the firmware.
This patch defines a 'prom' routine similar to 'enter_prom' in the
kernel.
The difference is in the MSR which is built before entering prom. Big
endian order is enforced as in the kernel but 32bit mode is not. It
prepares ground for the next patches which will introduce Little endian
order.
It could certainly be improved using Elf macros and byteswapping
routines, but the initial version of the code is organised to be a
single file program with limited dependencies. yaboot is the same.
Please scream if you want a total rewrite.
These are not the most efficient versions of swab but the wrapper does
not do much byte swapping. On a big endian cpu, these routines are
a no-op.
arch/powerpc/boot/oflib.c:211:9: warning: cast to pointer from integer of \
different size [-Wint-to-pointer-cast]
return (phandle) of_call_prom("finddevice", 1, 1, name);
This is a work around. The definite solution would be to define the
phandle typedef as a u32, as in the kernel, but this would break the
device tree ops API.
Let it be for the moment.
This makes ihandle 64bit friendly.
This patch fixes 64bit compile warnings and updates the wrapper code
to converge the kernel code in prom_init.
This is mostly useful to make to the boot wrapper code closer with
Values will need to be byte-swapped when calling prom (big endian) from
a little endian boot wrapper.
This patch updates the wrapper code to converge with the kernel code in
prom_init.
This patch fixes warnings when the wrapper is compiled in 64bit and
updates the boot wrapper code related to prom to converge with the
kernel code in prom_init. This should make the review of changes easier.
The kernel has a different number of possible arguments (10) when
entering prom. There does not seem to be any good reason to have
12 in the wrapper, so the patch changes this value to args[10] in
the prom_args struct.
When the boot wrapper is compiled in 64bit, there is no need to
use __div64_32.
Bump the boot wrapper BOOT_COMMAND_LINE_SIZE to match the
kernel.
We have two definitions of COMMAND_LINE_SIZE, one for the kernel
and one for the boot wrapper. I assume this is so the boot
wrapper can be self sufficient and not rely on kernel headers.
Having two defines with the same name is confusing, I just
updated the wrong one when trying to bump it.
Make the boot wrapper define unique by calling it
BOOT_COMMAND_LINE_SIZE.
binutils is smart enough to know that a branch to a function
descriptor is actually a branch to the functions text address.
Alan tells me that binutils has been doing this for 9 years.
Add power sensor chip ina220 node in dts to support
power monitor
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
The following SoCs will be affected: p2041, p3041, p4080,
p5020, p5040, b4420, b4860, t4240
Signed-off-by: Li Yang <leoli@freescale.com>
This processor/memory module was mostly used on ATCA blades and
before that, on cPCI blades. It wasn't really user friendly, with
custom non u-boot bootloaders (powerboot/motload) and no real way
to recover corrupted boot flash (which was a common problem).
As such, it had its day back before the big ppc --> powerpc move
to device trees, and that was largely through commercial BSPs that
started to dry up around 2007.
Systems using one were largely in a "deploy and sustain" mode,
so interest in upgrading to new kernels in the field was nil.
Also, requiring 50A, 48V power supplies and a 2'x2'x2' ATCA
chassis largely rules out any hobbyist/enthusiast interest.
The point of all this, is that we might as well delete the in
kernel files relating to this platform. No point in continuing
to build it via walking the defconfigs or via linux-next testing.
Cc: linuxppc-dev@lists.ozlabs.org
Switch mpc512x to the common clock framework and adapt mpc512x
drivers to use the new clock driver. Old PPC_CLOCK code is
removed entirely since there are no users any more.
"So here's my next branch for powerpc. A bit late as I was on vacation
last week. It's mostly the same stuff that was in next already, I
just added two patches today which are the wiring up of lockref for
powerpc, which for some reason fell through the cracks last time and
is trivial.
The highlights are, in addition to a bunch of bug fixes:
- Reworked Machine Check handling on kernels running without a
hypervisor (or acting as a hypervisor). Provides hooks to handle
some errors in real mode such as TLB errors, handle SLB errors,
etc...
- Support for retrieving memory error information from the service
processor on IBM servers running without a hypervisor and routing
them to the memory poison infrastructure.
- _PAGE_NUMA support on server processors
- 32-bit BookE relocatable kernel support
- FSL e6500 hardware tablewalk support
- A bunch of new/revived board support
- FSL e6500 deeper idle states and altivec powerdown support
You'll notice a generic mm change here, it has been acked by the
relevant authorities and is a pre-req for our _PAGE_NUMA support"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (121 commits)
powerpc: Implement arch_spin_is_locked() using arch_spin_value_unlocked()
powerpc: Add support for the optimised lockref implementation
powerpc/powernv: Call OPAL sync before kexec'ing
powerpc/eeh: Escalate error on non-existing PE
powerpc/eeh: Handle multiple EEH errors
powerpc: Fix transactional FP/VMX/VSX unavailable handlers
powerpc: Don't corrupt transactional state when using FP/VMX in kernel
powerpc: Reclaim two unused thread_info flag bits
powerpc: Fix races with irq_work
Move precessing of MCE queued event out from syscall exit path.
pseries/cpuidle: Remove redundant call to ppc64_runlatch_off() in cpu idle routines
powerpc: Make add_system_ram_resources() __init
powerpc: add SATA_MV to ppc64_defconfig
powerpc/powernv: Increase candidate fw image size
powerpc: Add debug checks to catch invalid cpu-to-node mappings
powerpc: Fix the setup of CPU-to-Node mappings during CPU online
powerpc/iommu: Don't detach device without IOMMU group
powerpc/eeh: Hotplug improvement
powerpc/eeh: Call opal_pci_reinit() on powernv for restoring config space
powerpc/eeh: Add restore_config operation
device_type is deprecated. There is no need to check for it in device
driver code and no need to specify it in the device tree. Remove the
property from stock .dts files and remove the check for it from device
drivers. This change should be 100% backwards compatible with old device
trees.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
device_type is a deprecated property, but some MDIO bus nodes still have
it. Except for a couple of old binding (compatible="gianfar" and
compatible="ucc_geth_phy") the kernel doesn't look for
device_type="mdio" at all.
This patch removes all instances of device_type="mdio" from the binding
documentation and the .dts files.
The device_type property is deprecated for the flattened device tree and
the value "ethernet-phy" has never been defined as having a useful
meaning. Neither the kernel nor u-boot depend on it. It should never
have appeared in PHY bindings. This patch removes all references to
"ethernet-phy" as a device_type value from the documentation and the
.dts files.
This patch was generated mechanically with the following command and
then verified by looking at the diff.
sed -i '/"ethernet-phy"/d' `git grep -l '"ethernet-phy"'`
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
