Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
drivers/firmware/iscsi_ibft.c
This patch adds NOR Flash, LEDs and PIB support for MPC8568E-MDS
boards. Plus, move bcsr node into localbus node, and add bcsr5
gpio-controller node.
Some platform code modifications were also needed.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Add the MSI section to the DTS file for the GE PPC9A.
Signed-off-by: Malcolm Crossley <malcolm.crossley2@gefanuc.com>
Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com>
Support for the SBC610 VPX Single Board Computer from GE (PowerPC MPC8641D).
This patch adds basic support for the on-board flash.
Add the MSI section to the DTS file for the GE SBC610.
Correction to interrupt map mask for GE SBC310 XMC site and addition of
alias.
Add the MSI section to the DTS file for the GE SBC310.
The DIU driver should bind against "fsl,mpc5121-diu"
directly. Add this compatible property to the match
table and fix DTS and platform code accordingly.
Collects several changes needed after applying
previous mpc5121 platform and driver patches:
- Add mpc5121 reset module node
- Clean up and fix NAND description, remove unused properties
here and correct NAND flash chip size.
- Clean up I2C nodes: remove obsolete "cell-index" properties,
add "fsl,preserve-clocking" property
- Add I2C RTC node for m41t61 RTC
- Add I2C nodes for AD7414 temperature sensor and AT24C32CD3 EEPROM
- Fix compatible property in DMA node
- Clean up CAN nodes, remove unused "cell-index" properties
- Fix compatible property in DIU node
- USB node changes:
- use "fsl,mpc5121-usb2-dr" compatible property only
- remove "port0" and "port1" properties as these are only used
for multi-port host(MHP) module which is not available
on MPC5121.
- use 'fsl,invert-drvvbus' and 'fsl,invert-pwr-fault' in
USB node for internal PHY to specify polarities
of the appropriate port pins.
Signed-off-by: Piotr Ziecik <kosmo@semihalf.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
Sync Glacier dts with latest Canyonlands version:
- Add l2 cache support
- Add NDFC support
- Add RTC support
- Add AD7414 hwmon support
- Change EMAC compatible node from emac4 to emac4sync and correct the
register size
- Add support for ISA holes on 4xx PCI/X/E
(as done in Benjamin Herrenschmidt's patch for Canyonlands)
- Add Crypto device node
Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Sync Arches dts with latest Canyonlands version:
- Add 16k FIFO size to supported EMAC nodes
- Add next-level-cache property
This patch adds NOR FLASH MTD support to the Katmai (440SPe) dts file.
For this the OPB ranges address is mapped differently (base 0x00000000
-> 0xe0000000). This results in the address being identical to the lower
32bit of its physical address. This is needed for the MTD mapping to work
correctly, since U-Boot will insert the physical addresses of the EBC
chip selects into the EBC ranges property. This is the way its done in
most other 4xx dts files as well.
Additionally with a small whitespace cleanup.
In particular, several occurances of funny versions of 'success',
'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address',
'beginning', 'desirable', 'separate' and 'necessary' are fixed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
After these change, when need to work in rtbi mode,
just change phy-connection-type to "rtbi".
Also, this work can be done by u-boot.
Signed-off-by: Liu Yu <yu.liu@freescale.com>
mkuboot.sh provides a basic wrapper for the 'mkimage' utility. Using
mkuboot.sh provides clearer error reporting and allows a toolchain to
use its own 'mkimage' executable specified by ${CROSS_COMPILE}mkimage.
Additionally, this brings PowerPC in line with other architectures
which already call mkimage via mkuboot.sh.
The retry logic in ug_putc() is broken.
If the TX fifo is not ready and the counter runs out it will have a
value of -1 and no transfer should be attempted. Also, a counter
with a value of 0 means that the TX fifo got ready in the last try
and the transfer should be attempted.
Reported-by: "Juha Leppanen" <juha_motorsportcom@luukku.com>
Signed-off-by: "Juha Leppanen" <juha_motorsportcom@luukku.com>
Signed-off-by: Albert Herranz <albert_herranz@yahoo.es>
* 'next' of git://git.secretlab.ca/git/linux-2.6: (23 commits)
powerpc: fix up for mmu_mapin_ram api change
powerpc: wii: allow ioremap within the memory hole
powerpc: allow ioremap within reserved memory regions
wii: use both mem1 and mem2 as ram
wii: bootwrapper: add fixup to calc useable mem2
powerpc: gamecube/wii: early debugging using usbgecko
powerpc: reserve fixmap entries for early debug
powerpc: wii: default config
powerpc: wii: platform support
powerpc: wii: hollywood interrupt controller support
powerpc: broadway processor support
powerpc: wii: bootwrapper bits
powerpc: wii: device tree
powerpc: gamecube: default config
powerpc: gamecube: platform support
powerpc: gamecube/wii: flipper interrupt controller support
powerpc: gamecube/wii: udbg support for usbgecko
powerpc: gamecube/wii: do not include PCI support
powerpc: gamecube/wii: declare as non-coherent platforms
powerpc: gamecube/wii: introduce GAMECUBE_COMMON
Fix up conflicts in arch/powerpc/mm/fsl_booke_mmu.c.
Hopefully even close to correctly.
The top portion of MEM2 (the second 64MB memory block) in the Nintendo
Wii video game console is used by the firmware running on the Starlet
processor.
Add code to calculate the portion of MEM2 safely useable by the
Broadway processor. When running under the 'mini' firmware this is
easily determined from an in-memory header. Otherwise, a safe default
is used.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Add support for the Nintendo Wii video game console to the powerpc
bootwrapper.
dtbImage.wii is a wrapped image that contains a flat device tree,
an entry point compatible with the Homebrew Channel and BootMii,
and an optional initrd.
Acked-by: Segher Boessenkool <segher@kernel.crashing.org>
Add a device tree source file for the Nintendo Wii video game console.
Add support for the Nintendo GameCube video game console to the powerpc
bootwrapper.
dtbImage.gamecube is a wrapped image that contains a flat device tree,
an entry point compatible with SDload, and an optional initrd.
Add a device tree source file for the Nintendo GameCube video game console.
Add support for using the USB Gecko adapter as a bootwrapper console on
the Nintendo GameCube and Wii video game consoles.
The USB Gecko is a 3rd party memory card interface adapter that provides
a EXI (External Interface) to USB serial converter.
Newer revs of the FPGA have a larger SD buffer.
Signed-off-by: Sean MacLennan <smaclennan@pikatech.com>
Add nodes for PPC440SPe DMA, I2O, XOR engines and Memory
Queue module which are used in the updated PPC440SPe ADMA
driver. Also extend plb ranges property to specify address
ranges for DMA0/1 and I2O engines.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
- Add nodes for PMC and GTM controllers. GTM4 can be used as a wakeup
source;
- Add fsl,magic-packet properties to eTSEC nodes, i.e. wake-on-lan
support. Unlike MPC8313 processors, MPC8315 can resume from deep
sleep upon magic packet reception.
Acked-by: Scott Wood <scottwood@freescale.com>
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Describe all LocalBus chipselects on MPC8349E-MITX board. Also add flash
bindings.
Add OF descriptions of EEPROM, two GPIO extenders and SPD hanging on I2C
on this board.
mpc8349 bears two GPIO controllers. Enable support for them.
The stanza for PCI was copied from Bamboo which has four PCI slots. Yosemite
only has one PCI slot which is mapped to IDSEL 12, ADDR 22, IRQ2 Vector 25,
INTA.
Signed-off-by: Curtis Wald <cwald@watchguardvideo.com>
Set PCI-E node inbound DMA ranges size to 4GB for correct boot up of Katmai.
Signed-off-by: Pravin Bathija <pbathija@amcc.com>
Acked-by: Feng Kan <fkan@amcc.com>
Acked-by: Prodyut Hazarika <phazarika@amcc.com>
Acked-by: Loc Ho <lho@amcc.com>
Acked-by: Tirumala Reddy Marri <tmarri@amcc.com>
Acked-by: Victor Gallardo <vgallardo@amcc.com>
Add basic support for the P4080 DS reference board. None of the data
path devices (ethernet, crypto, pme) are support at this time.
Add support for NVRAM on GE Fanuc's PPC9A.
Add support for NVRAM on GE Fanuc's SBC310.
This patch enables the NVRAM found on the GE Fanuc SBC610
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc
* 'hostprogs-wmissing-prototypes' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc:
Makefile: Add -Wmising-prototypes to HOSTCFLAGS
oss: Mark loadhex static in hex2hex.c
dtc: Mark various internal functions static
dtc: Set "noinput" in the lexer to avoid an unused function
drm: radeon: Mark several functions static in mkregtable
arch/sparc/boot/*.c: Mark various internal functions static
arch/powerpc/boot/addRamDisk.c: Mark several internal functions static
arch/alpha/boot/tools/objstrip.c: Mark "usage" static
Documentation/vm/page-types.c: Declare checked_open static
genksyms: Mark is_reserved_word static
kconfig: Mark various internal functions static
kconfig: Make zconf.y work with current bison
Nothing outside of arch/powerpc/boot/addRamDisk.c references the
functions "get4k", "put4k", or "death".
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Simply add power management controller nodes and sleep properties.
This patch adds needed nodes and properties to support suspend/resume
on the MPC8610HPCD boards.
There is a dedicated switch (SW9) that is used to wake up the boards.
By default the SW9 button is routed to IRQ8, but could be re-routed
(via PIXIS) to sreset.
With 'no_console_suspend' kernel command line argument specified, the
board is also able to wakeup upon serial port input.
Acked-by: Scott Wood <scottwood@freescale.com> [dts]
- Add power management controller nodes;
- Add interrupts for RTC nodes, the RTC interrupt may be used as a
wakeup source;
- Add sleep properties (DEVDISR bit mask) and sleep-nexus nodes.
P1020 is another member of Freescale QorIQ series of processors.
It is an e500 based dual core SOC.
Being a scaled down version of P2020 it has following differences from P2020:
- 533MHz - 800MHz core frequency.
- 256Kbyte L2 cache
- Ethernet controllers with classification capabilities(new controller).
From board perspective P1020RDB is same as P2020RDB.
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
This patch creates the dts files for each core and splits the devices
between the two cores for P2020RDB.
core0 has memory, L2, i2c, spi, dma1, usb, eth0, eth1, crypto,
global-util, pci0,
core1 has L2, dma2, eth0, pci1, msi.
MPIC is shared between two cores but each core will protect its
interrupts from other core by using "protected-sources" of mpic.
