This patch only moves the code. It doesn't make any changes, and the
code is still only compiled for powerpc. Follow-on patches will generalize
the code for other architectures.
Cc: Milton Miller <miltonm@bga.com>
Tested-by: Olof Johansson <olof@lixom.net>
lib: use generic pci_iomap on all architectures
Many architectures don't want to pull in iomap.c,
so they ended up duplicating pci_iomap from that file.
That function isn't trivial, and we are going to modify it
https://lkml.org/lkml/2011/11/14/183
so the duplication hurts.
This reduces the scope of the problem significantly,
by moving pci_iomap to a separate file and
referencing that from all architectures.
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
alpha: drop pci_iomap/pci_iounmap from pci-noop.c
mn10300: switch to GENERIC_PCI_IOMAP
mn10300: add missing __iomap markers
frv: switch to GENERIC_PCI_IOMAP
tile: switch to GENERIC_PCI_IOMAP
tile: don't panic on iomap
sparc: switch to GENERIC_PCI_IOMAP
sh: switch to GENERIC_PCI_IOMAP
powerpc: switch to GENERIC_PCI_IOMAP
parisc: switch to GENERIC_PCI_IOMAP
mips: switch to GENERIC_PCI_IOMAP
microblaze: switch to GENERIC_PCI_IOMAP
arm: switch to GENERIC_PCI_IOMAP
alpha: switch to GENERIC_PCI_IOMAP
lib: add GENERIC_PCI_IOMAP
lib: move GENERIC_IOMAP to lib/Kconfig
Fix up trivial conflicts due to changes nearby in arch/{m68k,score}/Kconfig
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (185 commits)
powerpc: fix compile error with 85xx/p1010rdb.c
powerpc: fix compile error with 85xx/p1023_rds.c
powerpc/fsl: add MSI support for the Freescale hypervisor
arch/powerpc/sysdev/fsl_rmu.c: introduce missing kfree
powerpc/fsl: Add support for Integrated Flash Controller
powerpc/fsl: update compatiable on fsl 16550 uart nodes
powerpc/85xx: fix PCI and localbus properties in p1022ds.dts
powerpc/85xx: re-enable ePAPR byte channel driver in corenet32_smp_defconfig
powerpc/fsl: Update defconfigs to enable some standard FSL HW features
powerpc: Add TBI PHY node to first MDIO bus
sbc834x: put full compat string in board match check
powerpc/fsl-pci: Allow 64-bit PCIe devices to DMA to any memory address
powerpc: Fix unpaired probe_hcall_entry and probe_hcall_exit
offb: Fix setting of the pseudo-palette for >8bpp
offb: Add palette hack for qemu "standard vga" framebuffer
offb: Fix bug in calculating requested vram size
powerpc/boot: Change the WARN to INFO for boot wrapper overlap message
powerpc/44x: Fix build error on currituck platform
powerpc/boot: Change the load address for the wrapper to fit the kernel
powerpc/44x: Enable CRASH_DUMP for 440x
Fix up a trivial conflict in arch/powerpc/include/asm/cputime.h due to
the additional sparse-checking code for cputime_t.
Integrated Flash Controller supports various flashes like NOR, NAND
and other devices using NOR, NAND and GPCM Machine available on it.
IFC supports four chip selects.
Signed-off-by: Dipen Dudhat <Dipen.Dudhat@freescale.com>
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Liu Shuo <b35362@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Now that we have relocatable kernel, supporting CRASH_DUMP only requires
turning the switches on for UP machines.
We don't have kexec support on 47x yet. Enabling SMP support would be done
as part of enabling the PPC_47x support.
Signed-off-by: Suzuki K. Poulose <suzuki@in.ibm.com>
Cc: Josh Boyer <jwboyer@gmail.com>
Cc: linuxppc-dev <linuxppc-dev@lists.ozlabs.org>
Signed-off-by: Josh Boyer <jwboyer@gmail.com>
The following patch adds relocatable kernel support - based on processing
of dynamic relocations - for PPC44x kernel.
We find the runtime address of _stext and relocate ourselves based
on the following calculation.
virtual_base = ALIGN(KERNELBASE,256M) +
MODULO(_stext.run,256M)
relocate() is called with the Effective Virtual Base Address (as
shown below)
| Phys. Addr| Virt. Addr |
Page (256M) |------------------------|
Boundary | | |
Kernel Load |___________|_ __ _ _ _ _|<- Effective
Addr(_stext)| | ^ |Virt. Base Addr
| |reloc_offset|
| |______v_____|<-(KERNELBASE)%256M
Page(256M) |-----------|------------|
Boundary | | |
The virt_phys_offset is updated accordingly, i.e,
virt_phys_offset = effective. kernel virt base - kernstart_addr
I have tested the patches on 440x platforms only. However this should
work fine for PPC_47x also, as we only depend on the runtime address
and the current TLB XLAT entry for the startup code, which is available
in r25. I don't have access to a 47x board yet. So, it would be great if
somebody could test this on 47x.
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Tony Breeds <tony@bakeyournoodle.com>
The following patch implements the dynamic relocation processing for
PPC32 kernel. relocate() accepts the target virtual address and relocates
the kernel image to the same.
Currently the following relocation types are handled :
R_PPC_RELATIVE
R_PPC_ADDR16_LO
R_PPC_ADDR16_HI
R_PPC_ADDR16_HA
The last 3 relocations in the above list depends on value of Symbol indexed
whose index is encoded in the Relocation entry. Hence we need the Symbol
Table for processing such relocations.
Note: The GNU ld for ppc32 produces buggy relocations for relocation types
that depend on symbols. The value of the symbols with STB_LOCAL scope
should be assumed to be zero. - Alan Modra
Signed-off-by: Josh Poimboeuf <jpoimboe@linux.vnet.ibm.com>
Cc: Alan Modra <amodra@au1.ibm.com>
DYNAMIC_MEMSTART(old RELOCATABLE) was restricted only to PPC_47x variants
of 44x. This patch enables DYNAMIC_MEMSTART for 440x based chipsets.
Cc: linux ppc dev <linuxppc-dev@lists.ozlabs.org>
The current implementation of CONFIG_RELOCATABLE in BookE is based
on mapping the page aligned kernel load address to KERNELBASE. This
approach however is not enough for platforms, where the TLB page size
is large (e.g, 256M on 44x). So we are renaming the RELOCATABLE used
currently in BookE to DYNAMIC_MEMSTART to reflect the actual method.
The CONFIG_RELOCATABLE for PPC32(BookE) based on processing of the
dynamic relocations will be introduced in the later in the patch series.
This change would allow the use of the old method of RELOCATABLE for
platforms which can afford to enforce the page alignment (platforms with
smaller TLB size).
Changes since v3:
* Introduced a new config, NONSTATIC_KERNEL, to denote a kernel which is
either a RELOCATABLE or DYNAMIC_MEMSTART(Suggested by: Josh Boyer)
Suggested-by: Scott Wood <scottwood@freescale.com>
Tested-by: Scott Wood <scottwood@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
Now all ARCH_POPULATES_NODE_MAP archs select HAVE_MEBLOCK_NODE_MAP -
there's no user of early_node_map[] left. Kill early_node_map[] and
replace ARCH_POPULATES_NODE_MAP with HAVE_MEMBLOCK_NODE_MAP. Also,
relocate for_each_mem_pfn_range() and helper from mm.h to memblock.h
as page_alloc.c would no longer host an alternative implementation.
This change is ultimately one to one mapping and shouldn't cause any
observable difference; however, after the recent changes, there are
some functions which now would fit memblock.c better than page_alloc.c
and dependency on HAVE_MEMBLOCK_NODE_MAP instead of HAVE_MEMBLOCK
doesn't make much sense on some of them. Further cleanups for
functions inside HAVE_MEMBLOCK_NODE_MAP in mm.h would be nice.
-v2: Fix compile bug introduced by mis-spelling
CONFIG_HAVE_MEMBLOCK_NODE_MAP to CONFIG_MEMBLOCK_HAVE_NODE_MAP in
mmzone.h. Reported by Stephen Rothwell.
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
powerpc doesn't access early_node_map[] directly and enabling
HAVE_MEMBLOCK_NODE_MAP is trivial - replacing add_active_range() calls
with memblock_set_node() and selecting HAVE_MEMBLOCK_NODE_MAP is
enough.
This patch provides cpu_idle_wait() routine for the powerpc
platform which is required by the cpuidle subsystem. This
routine is required to change the idle handler on SMP systems.
The equivalent routine for x86 is in arch/x86/kernel/process.c
but the powerpc implementation is different.
cpuidle_disable variable is to enable/disable cpuidle
framework if power_save option is set during the boot
time.
Signed-off-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Signed-off-by: Trinabh Gupta <g.trinabh@gmail.com>
Signed-off-by: Arun R Bharadwaj <arun.r.bharadwaj@gmail.com>
powerpc copied pci_iomap from generic code, probably to avoid
pulling the rest of iomap.c in. Since that's in
a separate file now, we can reuse the common implementation.
The only difference is handling of nocache flag,
that turns out to be done correctly by the
generic code since arch/powerpc/include/asm/io.h
defines ioremap_nocache same as ioremap.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
All interrupts which must be non threaded are marked
IRQF_NO_THREAD. So it's safe to allow force threaded handlers.
Kexec is not supported on 47x. 47x is a variant of 44x with slightly
different MMU and SMP support. There was a typo in the config dependency
for kexec. This patch fixes the same.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
* 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
scsi: drop unused Kconfig symbol
pci: drop unused Kconfig symbol
stmmac: drop unused Kconfig symbol
x86: drop unused Kconfig symbol
powerpc: drop unused Kconfig symbols
powerpc: 40x: drop unused Kconfig symbol
mips: drop unused Kconfig symbols
openrisc: drop unused Kconfig symbols
arm: at91: drop unused Kconfig symbol
samples: drop unused Kconfig symbol
m32r: drop unused Kconfig symbol
score: drop unused Kconfig symbols
sh: drop unused Kconfig symbol
um: drop unused Kconfig symbol
sparc: drop unused Kconfig symbol
alpha: drop unused Kconfig symbol
Fix up trivial conflict in drivers/net/ethernet/stmicro/stmmac/Kconfig
as per Michal: the STMMAC_DUAL_MAC config variable is still unused and
should be deleted.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits)
powerpc/p3060qds: Add support for P3060QDS board
powerpc/83xx: Add shutdown request support to MCU handling on MPC8349 MITX
powerpc/85xx: Make kexec to interate over online cpus
powerpc/fsl_booke: Fix comment in head_fsl_booke.S
powerpc/85xx: issue 15 EOI after core reset for FSL CoreNet devices
powerpc/8xxx: Fix interrupt handling in MPC8xxx GPIO driver
powerpc/85xx: Add 'fsl,pq3-gpio' compatiable for GPIO driver
powerpc/86xx: Correct Gianfar support for GE boards
powerpc/cpm: Clear muram before it is in use.
drivers/virt: add ioctl for 32-bit compat on 64-bit to fsl-hv-manager
powerpc/fsl_msi: add support for "msi-address-64" property
powerpc/85xx: Setup secondary cores PIR with hard SMP id
powerpc/fsl-booke: Fix settlbcam for 64-bit
powerpc/85xx: Adding DCSR node to dtsi device trees
powerpc/85xx: clean up FPGA device tree nodes for Freecsale QorIQ boards
powerpc/85xx: fix PHYS_64BIT selection for P1022DS
powerpc/fsl-booke: Fix setup_initial_memory_limit to not blindly map
powerpc: respect mem= setting for early memory limit setup
powerpc: Update corenet64_smp_defconfig
powerpc: Update mpc85xx/corenet 32-bit defconfigs
Fix up trivial conflicts in:
- arch/powerpc/configs/40x/hcu4_defconfig
removed stale file, edited elsewhere
- arch/powerpc/include/asm/udbg.h, arch/powerpc/kernel/udbg.c:
added opal and gelic drivers vs added ePAPR driver
- drivers/tty/serial/8250.c
moved UPIO_TSI to powerpc vs removed UPIO_DWAPB support
Unplugged CPU go into NAP mode in a loop until woken up
Enable hugepages on Freescale BookE processors. This allows the kernel to
use huge TLB entries to map pages, which can greatly reduce the number of
TLB misses and the amount of TLB thrashing experienced by applications with
large memory footprints. Care should be taken when using this on FSL
processors, as the number of large TLB entries supported by the core is low
(16-64) on current processors.
The supported set of hugepage sizes include 4m, 16m, 64m, 256m, and 1g.
Page sizes larger than the max zone size are called "gigantic" pages and
must be allocated on the command line (and cannot be deallocated).
This is currently only fully implemented for Freescale 32-bit BookE
processors, but there is some infrastructure in the code for
64-bit BooKE.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Allow the p1010 processor to select the flexcan network driver.
Signed-off-by: Robin Holt <holt@sgi.com>
Acked-by: Marc Kleine-Budde <mkl@pengutronix.de>,
Acked-by: Wolfgang Grandegger <wg@grandegger.com>,
Cc: U Bhaskar-B22300 <B22300@freescale.com>
Cc: socketcan-core@lists.berlios.de,
Cc: netdev@vger.kernel.org,
Cc: PPC list <linuxppc-dev@lists.ozlabs.org>
This patch adds kexec support for PPC440 based chipsets. This work is based
on the KEXEC patches for FSL BookE.
The FSL BookE patch and the code flow could be found at the link below:
http://patchwork.ozlabs.org/patch/49359/
Steps:
1) Invalidate all the TLB entries except the one this code is run from
2) Create a tmp mapping for our code in the other address space and jump to it
3) Invalidate the entry we used
4) Create a 1:1 mapping for 0-2GiB in blocks of 256M
5) Jump to the new 1:1 mapping and invalidate the tmp mapping
I have tested this patches on Ebony, Sequoia boards and Virtex on QEMU.
You need kexec-tools commit e8b7939b1e or newer for ppc440x support,
available at:
git://git.kernel.org/pub/scm/utils/kernel/kexec/kexec-tools.git
Signed-off-by: Suzuki Poulose <suzuki@in.ibm.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Some trivial conflicts due to other various merges
adding to the end of common lists sooner than this one.
arch/ia64/Kconfig
arch/powerpc/Kconfig
arch/x86/Kconfig
lib/Kconfig
lib/Makefile
Signed-off-by: Len Brown <len.brown@intel.com>
cmpxchg() is widely used by lockless code, including NMI-safe lockless
code. But on some architectures, the cmpxchg() implementation is not
NMI-safe, on these architectures the lockless code may need a
spin_trylock_irqsave() based implementation.
This patch adds a Kconfig option: ARCH_HAVE_NMI_SAFE_CMPXCHG, so that
NMI-safe lockless code can depend on it or provide different
implementation according to it.
On many architectures, cmpxchg is only NMI-safe for several specific
operand sizes. So, ARCH_HAVE_NMI_SAFE_CMPXCHG define in this patch
only guarantees cmpxchg is NMI-safe for sizeof(unsigned long).
Signed-off-by: Huang Ying <ying.huang@intel.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Richard Henderson <rth@twiddle.net>
CC: Mikael Starvik <starvik@axis.com>
CC: Yoshinori Sato <ysato@users.sourceforge.jp>
CC: Tony Luck <tony.luck@intel.com>
CC: Hirokazu Takata <takata@linux-m32r.org>
CC: Geert Uytterhoeven <geert@linux-m68k.org>
CC: Michal Simek <monstr@monstr.eu>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
CC: Kyle McMartin <kyle@mcmartin.ca>
CC: Martin Schwidefsky <schwidefsky@de.ibm.com>
CC: Chen Liqin <liqin.chen@sunplusct.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: Ingo Molnar <mingo@redhat.com>
CC: Chris Zankel <chris@zankel.net>
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits)
drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c
powerpc/85xx: fix mpic configuration in CAMP mode
powerpc: Copy back TIF flags on return from softirq stack
powerpc/64: Make server perfmon only built on ppc64 server devices
powerpc/pseries: Fix hvc_vio.c build due to recent changes
powerpc: Exporting boot_cpuid_phys
powerpc: Add CFAR to oops output
hvc_console: Add kdb support
powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon
powerpc/irq: Quieten irq mapping printks
powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs
powerpc: Add mpt2sas driver to pseries and ppc64 defconfig
powerpc: Disable IRQs off tracer in ppc64 defconfig
powerpc: Sync pseries and ppc64 defconfigs
powerpc/pseries/hvconsole: Fix dropped console output
hvc_console: Improve tty/console put_chars handling
powerpc/kdump: Fix timeout in crash_kexec_wait_realmode
powerpc/mm: Fix output of total_ram.
powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards
powerpc: Correct annotations of pmu registration functions
Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and
drivers/cpufreq
An implementation of a code generator for BPF programs to speed up packet
filtering on PPC64, inspired by Eric Dumazet's x86-64 version.
Filter code is generated as an ABI-compliant function in module_alloc()'d mem
with stackframe & prologue/epilogue generated if required (simple filters don't
need anything more than an li/blr). The filter's local variables, M[], live in
registers. Supports all BPF opcodes, although "complicated" loads from negative
packet offsets (e.g. SKF_LL_OFF) are not yet supported.
There are a couple of further optimisations left for future work; many-pass
assembly with branch-reach reduction and a register allocator to push M[]
variables into volatile registers would improve the code quality further.
This currently supports big-endian 64-bit PowerPC only (but is fairly simple
to port to PPC32 or LE!).
Enabled in the same way as x86-64:
echo 1 > /proc/sys/net/core/bpf_jit_enable
Or, enabled with extra debug output:
echo 2 > /proc/sys/net/core/bpf_jit_enable
Signed-off-by: Matt Evans <matt@ozlabs.org>
The 44x code (which is shared by 47x) assumes the available physical memory
begins at 0x00000000. This is not necessarily the case in an AMP
environment.
Support CONFIG_RELOCATABLE for 476 in order to allow the kernel to be
loaded into a higher memory range.
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Cc: linuxppc-dev@lists.ozlabs.org
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
This patch adds support for the new "jump label" feature.
Unlike x86 and sparc we just merrily patch the code with no locks etc,
as far as I know this is safe, but I'm not really sure what the x86/sparc
code is protecting against so maybe it's not.
I also don't see any reason for us to implement the poke_early() routine,
even though sparc does.
[BenH: Updated the patch to upstream generic changes]
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT,
CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used
to test for existence of find bitops anymore.
Acked-by: Greg Ungerer <gerg@uclinux.org>
This patch implements the raw syscall tracepoints on PowerPC and exports
them for ftrace syscalls to use.
To minimise reworking existing code, I slightly re-ordered the thread
info flags such that the new TIF_SYSCALL_TRACEPOINT bit would still fit
within the 16 bits of the andi. instruction's UI field. The instructions
in question are in /arch/powerpc/kernel/entry_{32,64}.S to and the
_TIF_SYSCALL_T_OR_A with the thread flags to see if system call tracing
is enabled.
In the case of 64bit PowerPC, arch_syscall_addr and
arch_syscall_match_sym_name are overridden to allow ftrace syscalls to
work given the unusual system call table structure and symbol names that
start with a period.
Signed-off-by: Ian Munsie <imunsie@au1.ibm.com>
In case other architectures require RCU freed page-tables to implement
gup_fast() and software filled hashes and similar things, provide the
means to do so by moving the logic into generic code.
Requested-by: David Miller <davem@davemloft.net>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
This is a first cut at making bootwrapper code which will
produce a zImage compliant with the requirements set down
by ePAPR.
This is a very simple bootwrapper, taking the device tree
blob supplied by the ePAPR boot program and passing it on
to the kernel. It builds on the earlier patch to build a
relocatable ET_DYN zImage to meet the other ePAPR image
requirements.
For good measure we have some paranoid checks which will
generate warnings if some of the ePAPR entry condition
guarantees are not met.
We currently dont have CPU Hotplug support working on 85xx so we need to
disable Suspsend support as it will force enabling of CPU Hotplug.
arch/powerpc/kernel/built-in.o: In function `cpu_die': arch/powerpc/kernel/smp.c:702: undefined reference to `start_secondary_resume'
make: *** [.tmp_vmlinux1] Error 1
1. Add an option to include RapidIO support if the PCI is available.
2. Add FSL_RIO configuration option to enable controller selection.
3. Add RapidIO support option into x86 and MIPS architectures.
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
Cc: Thomas Moll <thomas.moll@sysgo.com>
Cc: Micha Nelissen <micha@neli.hopto.org>
This introduces CONFIG_GENERIC_FIND_BIT_LE to tell whether to use generic
implementation of find_*_bit_le() in lib/find_next_bit.c or not.
For now we select CONFIG_GENERIC_FIND_BIT_LE for all architectures which
enable CONFIG_GENERIC_FIND_NEXT_BIT.
But m68knommu wants to define own faster find_next_zero_bit_le() and
continues using generic find_next_{,zero_}bit().
(CONFIG_GENERIC_FIND_NEXT_BIT and !CONFIG_GENERIC_FIND_BIT_LE)
Cc: Greg Ungerer <gerg@uclinux.org>
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
No functional change.
All architectures are finally converted. Remove the cruft.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Chris Metcalf <cmetcalf@tilera.com>
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (72 commits)
powerpc/pseries: Fix build of topology stuff without CONFIG_NUMA
powerpc/pseries: Fix VPHN build errors on non-SMP systems
powerpc/83xx: add mpc8308_p1m DMA controller device-tree node
powerpc/83xx: add DMA controller to mpc8308 device-tree node
powerpc/512x: try to free dma descriptors in case of allocation failure
powerpc/512x: add MPC8308 dma support
powerpc/512x: fix the hanged dma transfer issue
powerpc/512x: scatter/gather dma fix
powerpc/powermac: Make auto-loading of therm_pm72 possible
of/address: Use propper endianess in get_flags
powerpc/pci: Use printf extension %pR for struct resource
powerpc: Remove unnecessary casts of void ptr
powerpc: Disable VPHN polling during a suspend operation
powerpc/pseries: Poll VPA for topology changes and update NUMA maps
powerpc: iommu: Add device name to iommu error printks
powerpc: Record vma->phys_addr in ioremap()
powerpc: Update compat_arch_ptrace
powerpc: Fix PPC_PTRACE_SETHWDEBUG on PPC_BOOK3S
powerpc/time: printk time stamp init not correct
powerpc: Minor cleanups for machdep.h
The device tree code is now in two pieces: some which can be used generically
on any platform which selects CONFIG_OF_FLATTREE, and some early which is used
at boot time on only a few architectures. This patch segregates the early
code so that only those architectures which care about it need compile it.
This also means that some of the requirements in the early code (such as
a cmd_line variable) that most architectures (e.g. X86) don't provide
can be ignored.
Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com>
[grant.likely@secretlab.ca: remove extra blank line addition]
[grant.likely@secretlab.ca: fixed incorrect #ifdef CONFIG_EARLY_FLATTREE check]
[grant.likely@secretlab.ca: Made OF_EARLY_FLATTREE select instead of depend
on OF_FLATTREE]
Add suspend/resume support for 4xx compatible CPUs.
See /sys/power/state for available power states configured in.
Add two different idle states (idle-wait and idle-doze) controlled via sysfs.
Default is idle-wait.
cat /sys/devices/system/cpu/cpu0/idle
[wait] doze
To save additional power, use idle-doze.
echo doze > /sys/devices/system/cpu/cpu0/idle
wait [doze]
Signed-off-by: Victor Gallardo <vgallardo@apm.com>
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
commit ffe8018c3424892c9590048fc36caa6c3e0c8a76 of the -mm tree
fixes the initramfs size calculation for e.g. s390 but breaks it
for 32bit architectures which do not define CONFIG_32BIT.
This patch fix the problem for PPC32 which will elsewise end up
with a __initramfs_size of 0.
Signed-off-by: Kerstin Jonsson <kerstin.jonsson@ericsson.com>
* git://git.infradead.org/mtd-2.6: (82 commits)
mtd: fix build error in m25p80.c
mtd: Remove redundant mutex from mtd_blkdevs.c
MTD: Fix wrong check register_blkdev return value
Revert "mtd: cleanup Kconfig dependencies"
mtd: cfi_cmdset_0002: make sector erase command variable
mtd: cfi_cmdset_0002: add CFI detection for SST 38VF640x chips
mtd: cfi_util: add support for switching SST 39VF640xB chips into QRY mode
mtd: cfi_cmdset_0001: use defined value of P_ID_INTEL_PERFORMANCE instead of hardcoded one
block2mtd: dubious assignment
P4080/mtd: Fix the freescale lbc issue with 36bit mode
P4080/eLBC: Make Freescale elbc interrupt common to elbc devices
mtd: phram: use KBUILD_MODNAME
mtd: OneNAND: S5PC110: Fix double call suspend & resume function
mtd: nand: fix MTD_MODE_RAW writes
jffs2: use kmemdup
mtd: sm_ftl: cosmetic, use bool when possible
mtd: r852: remove useless pci powerup/down from suspend/resume routines
mtd: blktrans: fix a race vs kthread_stop
mtd: blktrans: kill BKL
mtd: allow to unload the mtdtrans module if its block devices aren't open
Fix up trivial whitespace-introduced conflict in drivers/mtd/mtdchar.c
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git
drivers/mtd/mtd_blkdevs.c
Merge Grant's device-tree bits so that we can apply the subsequent fixes.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits)
kbuild: convert `arch/tile' to the kconfig mainmenu upgrade
README: cite nconfig
Revert "kconfig: Temporarily disable dependency warnings"
kconfig: Use PATH_MAX instead of 128 for path buffer sizes.
kconfig: Fix realloc usage()
kconfig: Propagate const
kconfig: Don't go out from read config loop when you read new symbol
kconfig: fix menuconfig on debian lenny
kbuild: migrate all arch to the kconfig mainmenu upgrade
kconfig: expand file names
kconfig: use the file's name of sourced file
kconfig: constify file name
kconfig: don't emit warning upon rootmenu's prompt redefinition
kconfig: replace KERNELVERSION usage by the mainmenu's prompt
kconfig: delay gconf window initialization
kconfig: expand by default the rootmenu's prompt
kconfig: add a symbol string expansion helper
kconfig: regen parser
kconfig: implement the `mainmenu' directive
kconfig: allow PACKAGE to be defined on the compiler's command-line
Fix up trivial conflict in arch/mn10300/Kconfig
Move Freescale elbc interrupt from nand driver to elbc driver.
Then all elbc devices can use the interrupt instead of ONLY nand.
For former nand driver, it had the two functions:
1. detecting nand flash partitions;
2. registering elbc interrupt.
Now, second function is removed to fsl_lbc.c.
Signed-off-by: Lan Chunhe-B25806 <b25806@freescale.com>
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com>
Cc: Wood Scott-B07421 <B07421@freescale.com>
