This patchset adds a flags variable to reserve_bootmem() and uses the
BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions
between crashkernel area and already used memory.
This patch:
Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE.
If that flag is set, the function returns with -EBUSY if the memory already
has been reserved in the past. This is to avoid conflicts.
Because that code runs before SMP initialisation, there's no race condition
inside reserve_bootmem_core().
[akpm@linux-foundation.org: fix powerpc build]
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: <linux-arch@vger.kernel.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Remove config variable DEBUG_RWLOCK, since it is not used.
Signed-off-by: Jiri Olsa <olsajiri@gmail.com>
Acked-by: Grant Grundler <grundler@parisc-linux.org>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (79 commits)
Jesper Juhl is the new trivial patches maintainer
Documentation: mention email-clients.txt in SubmittingPatches
fs/binfmt_elf.c: spello fix
do_invalidatepage() comment typo fix
Documentation/filesystems/porting fixes
typo fixes in net/core/net_namespace.c
typo fix in net/rfkill/rfkill.c
typo fixes in net/sctp/sm_statefuns.c
lib/: Spelling fixes
kernel/: Spelling fixes
include/scsi/: Spelling fixes
include/linux/: Spelling fixes
include/asm-m68knommu/: Spelling fixes
include/asm-frv/: Spelling fixes
fs/: Spelling fixes
drivers/watchdog/: Spelling fixes
drivers/video/: Spelling fixes
drivers/ssb/: Spelling fixes
drivers/serial/: Spelling fixes
drivers/scsi/: Spelling fixes
Signed-off-by: Adrian Bunk <bunk@kernel.org>
After seeing the filename I'd have expected something about the
implementation of SMP in the Linux kernel - not some notes on kernel
configuration and building trivialities noone would search at this
place.
Acked-by: Alan Cox <alan@redhat.com>
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com>
Move the instrumentation Kconfig to
arch/Kconfig for architecture dependent options
- oprofile
- kprobes
and
init/Kconfig for architecture independent options
- profiling
- markers
Remove the "Instrumentation Support" menu. Everything moves to "General setup".
Delete the kernel/Kconfig.instrumentation file.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Linus:
On the per-architecture side, I do think it would be better to *not* have
internal architecture knowledge in a generic file, and as such a line like
depends on X86_32 || IA64 || PPC || S390 || SPARC64 || X86_64 || AVR32
really shouldn't exist in a file like kernel/Kconfig.instrumentation.
It would be much better to do
depends on ARCH_SUPPORTS_KPROBES
in that generic file, and then architectures that do support it would just
have a
bool ARCH_SUPPORTS_KPROBES
default y
in *their* architecture files. That would seem to be much more logical,
and is readable both for arch maintainers *and* for people who have no
clue - and don't care - about which architecture is supposed to support
which interface...
Changelog:
Actually, I know I gave this as the magic incantation, but now that I see
it, I realize that I should have told you to just use
config ARCH_SUPPORTS_KPROBES
def_bool y
instead, which is a bit denser.
We seem to use both kinds of syntax for these things, but this is really
what "def_bool" is there for...
Changelog :
- Moving to HAVE_*.
- Add AVR32 oprofile.
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
The break_lock data structure and code for spinlocks is quite nasty.
Not only does it double the size of a spinlock but it changes locking to
a potentially less optimal trylock.
Put all of that under CONFIG_GENERIC_LOCKBREAK, and introduce a
__raw_spin_is_contended that uses the lock data itself to determine whether
there are waiters on the lock, to be used if CONFIG_GENERIC_LOCKBREAK is
not set.
Rename need_lockbreak to spin_needbreak, make it use spin_is_contended to
decouple it from the spinlock implementation, and make it typesafe (rwlocks
do not have any need_lockbreak sites -- why do they even get bloated up
with that break_lock then?).
Signed-off-by: Nick Piggin <npiggin@suse.de>
This patch consolidate all definitions of .init.text, .init.data
and .exit.text, .exit.data section definitions in
the generic vmlinux.lds.h.
This is a preparational patch - alone it does not buy
us much good.
There's really no reason not to print more than one character at a
time to the PDC console... Booting is measurably speedier, and now I don't
have to watch individual characters get drawn.
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
The timer interrupt had accidentally been marked IRQ_DISABLED since
IRQ_PER_CPU had been OR-ed in, instead of set. This had been working
by accident for quite a while.
Commit c642b8391cf8efc3622cc97329a0f46e7cbb70b8 changed the behaviour of
IRQ_PER_CPU interrupts, which previously weren't checked for IRQ_DISABLED.
This reverts commit efb80e7e097d0888e59fbbe4ded2ac5a256f556d, it turned
out to cause sporadic problems with the timer interrupt on 32-bit kernels.
Needs more investigation.
arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_map_sg':
arch/parisc/kernel/pci-dma.c:487: error: 'struct scatterlist' has no member named 'page'
arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_unmap_sg':
arch/parisc/kernel/pci-dma.c:508: error: 'struct scatterlist' has no member named 'page'
arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_sync_sg_for_cpu':
arch/parisc/kernel/pci-dma.c:535: error: 'struct scatterlist' has no member named 'page'
arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_sync_sg_for_device':
arch/parisc/kernel/pci-dma.c:545: error: 'struct scatterlist' has no member named 'page'
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
hera.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6
* 'master' of hera.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (29 commits)
[PARISC] fix uninitialized variable warning in asm/rtc.h
[PARISC] Port checkstack.pl to parisc
[PARISC] Make palo target work when $obj != $src
[PARISC] Zap unused variable warnings in pci.c
[PARISC] Fix tests in palo target
[PARISC] Fix palo target
[PARISC] Restore palo target
[PARISC] Attempt to clean up parisc/Makefile
[PARISC] Fix infinite loop in /proc/iomem
[PARISC] Quiet sysfs_create_link __must_check warnings in pdc_stable
[PARISC] Squelch pci_enable_device __must_check warning in superio
[PARISC] Kill off broken irqstack code
[PARISC] Remove hardcoded uses of PAGE_SIZE
[PARISC] Clean up pointless ASM_PAGE_SIZE_DIV use
[PARISC] Kill off the last vestiges of ASM_PAGE_SIZE
[PARISC] Kill off ASM_PAGE_SIZE use
[PARISC] Beautify parisc vmlinux.lds.S
[PARISC] Clean up a resource_size_t warning in sba_iommu
[PARISC] Kill incorrect cast warning in unwinder
[PARISC] Kill zone_to_nid printk warning
Fixed trivial conflict in include/asm-parisc/tlbflush.h manually
Stumbled upon when I was testing it out and using
make O=... to build.
'bus' was basically useless and 'hba' is only applicable on
64bit. Sigh, there's got to be a cleaner way to do this...
Quoting Randy:
"It seems sad that this patch sources Kconfig.marker, a 7-line file,
20-something times. Yes, you (we) don't want to put those 7 lines into
20-something different files, so sourcing is the right thing.
However, what you did for avr32 seems more on the right track to me: make
_one_ Instrumentation support menu that includes PROFILING, OPROFILE, KPROBES,
and MARKERS and then use (source) that in all of the arches."
One of the easiest things to isolate is the pid printed in kernel log.
There was a patch, that made this for arch-independent code, this one makes
so for arch/xxx files.
It took some time to cross-compile it, but hopefully these are all the
printks in arch code.
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
This is the largest patch in the set. Make all (I hope) the places where
the pid is shown to or get from user operate on the virtual pids.
The idea is:
- all in-kernel data structures must store either struct pid itself
or the pid's global nr, obtained with pid_nr() call;
- when seeking the task from kernel code with the stored id one
should use find_task_by_pid() call that works with global pids;
- when showing pid's numerical value to the user the virtual one
should be used, but however when one shows task's pid outside this
task's namespace the global one is to be used;
- when getting the pid from userspace one need to consider this as
the virtual one and use appropriate task/pid-searching functions.
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: nuther build fix]
[akpm@linux-foundation.org: yet nuther build fix]
[akpm@linux-foundation.org: remove unneeded casts]
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Paul Menage <menage@google.com>
Hunk missing from previous commit, oops.
Turns out, people were still using it, and it accidently works.
pcibios_link_hba_resources() could corrupt the resource tree by inserting
resources in the wrong place. Fix this by calling pci_claim_resource()
for PCI-PCI bridges. Delete pcibios_link_hba_resources as we shouldn't
need it any more. Also get rid of lba_claim_dev_resources() and just
call pci_claim_resource() directly.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
It's been unfinished and broken long enough, and I have some ideas on how
to do it more cleanly.
Sam's previous patch missed a few uses of ASM_PAGE_SIZE.
We have the macro _AC() generally available now
so the calculation of PAGE_SIZE can be made
assembler compatible.
Introduce use of _AC() and kill all users of
ASM_PAGE_SIZE.
Introduce a consistent layout of vmlinux.
The same layout has been introduced for most
architectures.
And the same time move a few label definitions inside
the curly brackets so they are assigned the correct
starting address. Before a ld inserted alignment
would have casued the label to pint before the actual
start of the section.
zone_to_nid returns int, always.
If we already have NR_CPUS worth of cpus online, we obviously shouldn't
be trying to bring up more... Fixes a particularly vexing issue I had when
running another machines kernel on my rp3440.
Clean up a pointless use of a variable in update_cr16_clocksource. It just
looks silly.
Currently we're hacking libs-y to include libgcc.a, but this has
unforeseen consequences since the userspace libgcc is linked with fpregs
enabled. We need the kernel to stop using fpregs in an uncontrolled manner
to implement lazy fpu state saves.
Slab pages obtained via kmalloc are not cacheline aligned. Nor is it
advisable to perform VM operations designed for page allocator pages on
memory obtained via kmalloc.
So replace the page sized allocations in kernel/pci-dma.c with page allocator
pages.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Matthew Wilcox <willy@debian.org>
"extern inline" will have different semantics with gcc 4.3, and "static
inline" is correct here.
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits)
kbuild: introduce ccflags-y, asflags-y and ldflags-y
kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP
kbuild: enable use of AFLAGS and CFLAGS on commandline
kbuild: enable 'make AFLAGS=...' to add additional options to AS
kbuild: fix AFLAGS use in h8300 and m68knommu
kbuild: check for wrong use of CFLAGS
kbuild: enable 'make CFLAGS=...' to add additional options to CC
kbuild: fix up CFLAGS usage
kbuild: make modpost detect unterminated device id lists
kbuild: call export_report from the Makefile
kbuild: move Kai Germaschewski to CREDITS
kconfig/menuconfig: distinguish between selected-by-another options and comments
kconfig: tristate choices with mixed tristate and boolean values
include/linux/Kbuild: remove duplicate entries
kbuild: kill backward compatibility checks
kbuild: kill EXTRA_ARFLAGS
kbuild: fix documentation in makefiles.txt
kbuild: call make once for all targets when O=.. is used
kbuild: pass -g to assembler under CONFIG_DEBUG_INFO
kbuild: update _shipped files for kconfig syntax cleanup
Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
We have had complaints where a threaded application is left in a bad state
after one of it's threads is killed when we hit a VM: out_of_memory
condition.
Killing just one of the process threads can leave the application in a bad
state, whereas killing the entire process group would allow for the
application to restart, or be otherwise handled, and makes it very obvious
that something has gone wrong.
This change allows the entire process group to be taken down, rather
than just the one thread.
Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com>
Cc: Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Andi Kleen <ak@suse.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Cc: Richard Curnow <rc@rc0.org.uk>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Chris Zankel <chris@zankel.net>
Identical handlers of PTRACE_DETACH go into ptrace_request().
Not touching compat code.
Not touching archs that don't call ptrace_request.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Acked-by: Christoph Hellwig <hch@infradead.org>
The variable CFLAGS is a wellknown variable and the usage by
kbuild may result in unexpected behaviour.
On top of that several people over time has asked for a way to
pass in additional flags to gcc.
This patch replace use of CFLAGS with KBUILD_CFLAGS all over the
tree and enabling one to use:
make CFLAGS=...
to specify additional gcc commandline options.
One usecase is when trying to find gcc bugs but other
use cases has been requested too.
Patch was tested on following architectures:
alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k
Test was simple to do a defconfig build, apply the patch and check
that nothing got rebuild.
Only in very rare cases is it needed to change CFLAGS
outside of arch/*/Makefile.
Fix up all wrong cases - in most cases
the use of EXTRA_CFLAGS is the only thing needed.
Bisected bizarre kernel-space nullptr dereference in udev to commit
18991197b4b588255ccabf472ebc84db7b66a19c, adding the NOTES section fixes
it.
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
Switch to using the generic compat_sys_getdents instead of a
homebrew one.
Remove fs.h from mm.h. For this,
1) Uninline vma_wants_writenotify(). It's pretty huge anyway.
2) Add back fs.h or less bloated headers (err.h) to files that need it.
As result, on x86_64 allyesconfig, fs.h dependencies cut down from 3929 files
rebuilt down to 3444 (-12.3%).
Cross-compile tested without regressions on my two usual configs and (sigh):
alpha arm-mx1ads mips-bigsur powerpc-ebony
alpha-allnoconfig arm-neponset mips-capcella powerpc-g5
alpha-defconfig arm-netwinder mips-cobalt powerpc-holly
alpha-up arm-netx mips-db1000 powerpc-iseries
arm arm-ns9xxx mips-db1100 powerpc-linkstation
arm-assabet arm-omap_h2_1610 mips-db1200 powerpc-lite5200
arm-at91rm9200dk arm-onearm mips-db1500 powerpc-maple
arm-at91rm9200ek arm-picotux200 mips-db1550 powerpc-mpc7448_hpc2
arm-at91sam9260ek arm-pleb mips-ddb5477 powerpc-mpc8272_ads
arm-at91sam9261ek arm-pnx4008 mips-decstation powerpc-mpc8313_rdb
arm-at91sam9263ek arm-pxa255-idp mips-e55 powerpc-mpc832x_mds
arm-at91sam9rlek arm-realview mips-emma2rh powerpc-mpc832x_rdb
arm-ateb9200 arm-realview-smp mips-excite powerpc-mpc834x_itx
arm-badge4 arm-rpc mips-fulong powerpc-mpc834x_itxgp
arm-carmeva arm-s3c2410 mips-ip22 powerpc-mpc834x_mds
arm-cerfcube arm-shannon mips-ip27 powerpc-mpc836x_mds
arm-clps7500 arm-shark mips-ip32 powerpc-mpc8540_ads
arm-collie arm-simpad mips-jazz powerpc-mpc8544_ds
arm-corgi arm-spitz mips-jmr3927 powerpc-mpc8560_ads
arm-csb337 arm-trizeps4 mips-malta powerpc-mpc8568mds
arm-csb637 arm-versatile mips-mipssim powerpc-mpc85xx_cds
arm-ebsa110 i386 mips-mpc30x powerpc-mpc8641_hpcn
arm-edb7211 i386-allnoconfig mips-msp71xx powerpc-mpc866_ads
arm-em_x270 i386-defconfig mips-ocelot powerpc-mpc885_ads
arm-ep93xx i386-up mips-pb1100 powerpc-pasemi
arm-footbridge ia64 mips-pb1500 powerpc-pmac32
arm-fortunet ia64-allnoconfig mips-pb1550 powerpc-ppc64
arm-h3600 ia64-bigsur mips-pnx8550-jbs powerpc-prpmc2800
arm-h7201 ia64-defconfig mips-pnx8550-stb810 powerpc-ps3
arm-h7202 ia64-gensparse mips-qemu powerpc-pseries
arm-hackkit ia64-sim mips-rbhma4200 powerpc-up
arm-integrator ia64-sn2 mips-rbhma4500 s390
arm-iop13xx ia64-tiger mips-rm200 s390-allnoconfig
arm-iop32x ia64-up mips-sb1250-swarm s390-defconfig
arm-iop33x ia64-zx1 mips-sead s390-up
arm-ixp2000 m68k mips-tb0219 sparc
arm-ixp23xx m68k-amiga mips-tb0226 sparc-allnoconfig
arm-ixp4xx m68k-apollo mips-tb0287 sparc-defconfig
arm-jornada720 m68k-atari mips-workpad sparc-up
arm-kafa m68k-bvme6000 mips-wrppmc sparc64
arm-kb9202 m68k-hp300 mips-yosemite sparc64-allnoconfig
arm-ks8695 m68k-mac parisc sparc64-defconfig
arm-lart m68k-mvme147 parisc-allnoconfig sparc64-up
arm-lpd270 m68k-mvme16x parisc-defconfig um-x86_64
arm-lpd7a400 m68k-q40 parisc-up x86_64
arm-lpd7a404 m68k-sun3 powerpc x86_64-allnoconfig
arm-lubbock m68k-sun3x powerpc-cell x86_64-defconfig
arm-lusl7200 mips powerpc-celleb x86_64-up
arm-mainstone mips-atlas powerpc-chrp32
per cpu data section contains two types of data. One set which is
exclusively accessed by the local cpu and the other set which is per cpu,
but also shared by remote cpus. In the current kernel, these two sets are
not clearely separated out. This can potentially cause the same data
cacheline shared between the two sets of data, which will result in
unnecessary bouncing of the cacheline between cpus.
One way to fix the problem is to cacheline align the remotely accessed per
cpu data, both at the beginning and at the end. Because of the padding at
both ends, this will likely cause some memory wastage and also the
interface to achieve this is not clean.
This patch:
Moves the remotely accessed per cpu data (which is currently marked
as ____cacheline_aligned_in_smp) into a different section, where all the data
elements are cacheline aligned. And as such, this differentiates the local
only data and remotely accessed data cleanly.
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Christoph Lameter <clameter@sgi.com>
This patch completes Linus's wish that the fault return codes be made into
bit flags, which I agree makes everything nicer. This requires requires
all handle_mm_fault callers to be modified (possibly the modifications
should go further and do things like fault accounting in handle_mm_fault --
however that would be for another patch).
[akpm@linux-foundation.org: fix alpha build]
[akpm@linux-foundation.org: fix s390 build]
[akpm@linux-foundation.org: fix sparc build]
[akpm@linux-foundation.org: fix sparc64 build]
[akpm@linux-foundation.org: fix ia64 build]
Cc: Bryan Wu <bryan.wu@analog.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Andi Kleen <ak@muc.de>
[ Still apparently needs some ARM and PPC loving - Linus ]
