[ Upstream commit 250f5402e636a5cec9e0e95df252c3d54307210f ]
Fixes a bug revealed by -Wmissing-prototypes when
CONFIG_FUNCTION_GRAPH_TRACER is enabled but not CONFIG_DYNAMIC_FTRACE:
arch/parisc/kernel/ftrace.c:82:5: error: no previous prototype for 'ftrace_enable_ftrace_graph_caller' [-Werror=missing-prototypes]
82 | int ftrace_enable_ftrace_graph_caller(void)
arch/parisc/kernel/ftrace.c:88:5: error: no previous prototype for 'ftrace_disable_ftrace_graph_caller' [-Werror=missing-prototypes]
88 | int ftrace_disable_ftrace_graph_caller(void)
Signed-off-by: Max Kellermann <max.kellermann@ionos.com>
Signed-off-by: Helge Deller <deller@gmx.de>
commit 82b143aeb169b8b55798d7d2063032e1a6ceeeb0 upstream.
This reverts commit 0921244f6f4f0d05698b953fe632a99b38907226.
It broke CPU hotplugging because it modifies the __cpu_possible_mask
after bootup, so that it will be different than nr_cpu_ids, which
then effictively breaks the workqueue setup code and triggers crashes
when shutting down CPUs at runtime.
Guenter was the first who noticed the wrong values in __cpu_possible_mask,
since the cpumask Kunit tests were failig.
Reverting this commit fixes both issues, but sadly brings back this
uncritical runtime warning:
register_cpu_capacity_sysctl: too early to get CPU4 device!
Reported-by: Guenter Roeck <linux@roeck-us.net>
Link: https://lkml.org/lkml/2024/2/4/146
Link: https://lore.kernel.org/lkml/Zb0mbHlIud_bqftx@slm.duckdns.org/t/
Cc: stable@vger.kernel.org # 6.0+
commit 8b1d72395635af45410b66cc4c4ab37a12c4a831 upstream.
The current exception handler implementation, which assists when accessing
user space memory, may exhibit random data corruption if the compiler decides
to use a different register than the specified register %r29 (defined in
ASM_EXCEPTIONTABLE_REG) for the error code. If the compiler choose another
register, the fault handler will nevertheless store -EFAULT into %r29 and thus
trash whatever this register is used for.
Looking at the assembly I found that this happens sometimes in emulate_ldd().
To solve the issue, the easiest solution would be if it somehow is
possible to tell the fault handler which register is used to hold the error
code. Using %0 or %1 in the inline assembly is not posssible as it will show
up as e.g. %r29 (with the "%r" prefix), which the GNU assembler can not
convert to an integer.
This patch takes another, better and more flexible approach:
We extend the __ex_table (which is out of the execution path) by one 32-word.
In this word we tell the compiler to insert the assembler instruction
"or %r0,%r0,%reg", where %reg references the register which the compiler
choosed for the error return code.
In case of an access failure, the fault handler finds the __ex_table entry and
can examine the opcode. The used register is encoded in the lowest 5 bits, and
the fault handler can then store -EFAULT into this register.
Since we extend the __ex_table to 3 words we can't use the BUILDTIME_TABLE_SORT
config option any longer.
Cc: <stable@vger.kernel.org> # v6.0+
commit c8708d758e715c3824a73bf0cda97292b52be44d upstream.
Printing the inventory on a serial console can be quite slow and thus may
trigger the hung task detector (CONFIG_DETECT_HUNG_TASK=y) and possibly
reboot the machine. Adding a cond_resched() prevents this.
commit 68fb3ca0e408e00db1c3f8fccdfa19e274c033be upstream.
We've had issues with gcc and 'asm goto' before, and we created a
'asm_volatile_goto()' macro for that in the past: see commits
3f0116c3238a ("compiler/gcc4: Add quirk for 'asm goto' miscompilation
bug") and a9f180345f53 ("compiler/gcc4: Make quirk for
asm_volatile_goto() unconditional").
Then, much later, we ended up removing the workaround in commit
43c249ea0b1e ("compiler-gcc.h: remove ancient workaround for gcc PR
58670") because we no longer supported building the kernel with the
affected gcc versions, but we left the macro uses around.
Now, Sean Christopherson reports a new version of a very similar
problem, which is fixed by re-applying that ancient workaround. But the
problem in question is limited to only the 'asm goto with outputs'
cases, so instead of re-introducing the old workaround as-is, let's
rename and limit the workaround to just that much less common case.
It looks like there are at least two separate issues that all hit in
this area:
(a) some versions of gcc don't mark the asm goto as 'volatile' when it
has outputs:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=98619
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=110420
which is easy to work around by just adding the 'volatile' by hand.
(b) Internal compiler errors:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=110422
which are worked around by adding the extra empty 'asm' as a
barrier, as in the original workaround.
but the problem Sean sees may be a third thing since it involves bad
code generation (not an ICE) even with the manually added 'volatile'.
The same old workaround works for this case, even if this feels a
bit like voodoo programming and may only be hiding the issue.
Reported-and-tested-by: Sean Christopherson <seanjc@google.com>
Link: https://lore.kernel.org/all/20240208220604.140859-1-seanjc@google.com/
Cc: Nick Desaulniers <ndesaulniers@google.com>
Cc: Uros Bizjak <ubizjak@gmail.com>
Cc: Jakub Jelinek <jakub@redhat.com>
Cc: Andrew Pinski <quic_apinski@quicinc.com>
commit 735ae74f73e55c191d48689bd11ff4a06ea0508f upstream.
When running with narrow firmware (64-bit kernel using a 32-bit
firmware), extend PDC addresses into the 0xfffffff0.00000000
region instead of the 0xf0f0f0f0.00000000 region.
This fixes the power button on the C3700 machine in qemu (64-bit CPU
with 32-bit firmware), and my assumption is that the previous code was
really never used (because most 64-bit machines have a 64-bit firmware),
or it just worked on very old machines because they may only decode
40-bit of virtual addresses.
[ Upstream commit 487635756198cad563feb47539c6a37ea57f1dae ]
Build is broken if CONFIG_DEBUG_BUGVERBOSE=n.
Fix it be using the correct asm operand number.
Reported-by: Linux Kernel Functional Testing <lkft@linaro.org>
Fixes: fe76a1349f23 ("parisc: Use natural CPU alignment for bug_table")
Cc: stable@vger.kernel.org # v6.0+
[ Upstream commit 43266838515d30dc0c45d5c7e6e7edacee6cce92 ]
Enable GENERIC_BUG_RELATIVE_POINTERS which will store 32-bit relative
offsets to the bug address and the source file name instead of 64-bit
absolute addresses. This effectively reduces the size of the
bug_table[] array by half on 64-bit kernels.
Stable-dep-of: 487635756198 ("parisc: Fix asm operand number out of range build error in bug table")
commit 33f806da2df68606f77d7b892cd1298ba3d463e8 upstream.
commit c9fcb2b65c2849e8ff3be23fd8828312fb68dc19 upstream.
Make sure the .PARISC.unwind section will be 32-bit aligned.
commit 07eecff8ae78df7f28800484d31337e1f9bfca3a upstream.
The jump_table stores two 32-bit words and one 32- (on 32-bit kernel)
or one 64-bit word (on 64-bit kernel).
Ensure that the last word is always 64-bit aligned on a 64-bit kernel
by aligning the whole structure on sizeof(long).
commit e5f3e299a2b1e9c3ece24a38adfc089aef307e8a upstream.
Those return codes are only defined for the parisc architecture and
are leftovers from when we wanted to be HP-UX compatible.
They are not returned by any Linux kernel syscall but do trigger
problems with the glibc strerrorname_np() and strerror() functions as
reported in glibc issue #31080.
There is no need to keep them, so simply remove them.
Reported-by: Bruno Haible <bruno@clisp.org>
Closes: https://sourceware.org/bugzilla/show_bug.cgi?id=31080
commit b28fc0d8739c03e7b6c44914a9d00d4c6dddc0ea upstream.
On parisc we need 16-byte alignment for variables which are used for
locking. Mark the __lock_aligned attribute acordingly so that the
.data..lock_aligned section will get that alignment in the generated
object files.
commit fe76a1349f235969381832c83d703bc911021eb6 upstream.
Make sure that the __bug_table section gets 32- or 64-bit aligned,
depending if a 32- or 64-bit kernel is being built.
Mark it non-writeable and use .blockz instead of the .org assembler
directive to pad the struct.
commit a80aeb86542a50aa8521729ea4cc731ee7174f03 upstream.
Add an align statement to tell the linker that all ex_table entries and as
such the whole ex_table section should be 32-bit aligned in vmlinux and modules.
commit e11d4cccd094a7cd4696c8c42e672c76c092dad5 upstream.
commit 166b0110d1ee53290bd11618df6e3991c117495a upstream.
When calculating the pfn for the iitlbt/idtlbt instruction, do not
drop the upper 5 address bits. This doesn't seem to have an effect
on physical hardware which uses less physical address bits, but in
qemu the missing bits are visible.
commit a406b8b424fa01f244c1aab02ba186258448c36b upstream.
Bail out early with error message when trying to boot a 64-bit kernel on
32-bit machines. This fixes the previous commit to include the check for
true 64-bit kernels as well.
Fixes: 591d2108f3abc ("parisc: Add runtime check to prevent PA2.0 kernels on PA1.x machines")
commit 6240553b52c475d9fc9674de0521b77e692f3764 upstream.
PDC2.0 specifies the additional PSW-bit field.
commit 914988e099fc658436fbd7b8f240160c352b6552 upstream.
Back in 2005, Kyle McMartin removed the 16-byte alignment for
ldcw semaphores on PA 2.0 machines (CONFIG_PA20). This broke
spinlocks on pre PA8800 processors. The main symptom was random
faults in mmap'd memory (e.g., gcc compilations, etc).
Unfortunately, the errata for this ldcw change is lost.
The issue is the 16-byte alignment required for ldcw semaphore
instructions can only be reduced to natural alignment when the
ldcw operation can be handled coherently in cache. Only PA8800
and PA8900 processors actually support doing the operation in
cache.
Aligning the spinlock dynamically adds two integer instructions
to each spinlock.
Tested on rp3440, c8000 and a500.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Link: https://lore.kernel.org/linux-parisc/6b332788-2227-127f-ba6d-55e99ecf4ed8@bell.net/T/#t
Link: https://lore.kernel.org/linux-parisc/20050609050702.GB4641@roadwarrior.mcmartin.ca/
commit d3b3c637e4eb8d3bbe53e5692aee66add72f9851 upstream.
John David Anglin reported that giving "nr_cpus=1" on the command
line causes a crash, while "maxcpus=1" works.
Reported-by: John David Anglin <dave.anglin@bell.net>
Cc: stable@vger.kernel.org # v5.18+
[ Upstream commit b1bef1388c427cdad7331a9c8eb4ebbbe5b954b0 ]
[ Upstream commit b137b9d60b8add5620a06c687a71ce18776730b0 ]
Fix "warning: directive in macro's argument list" warning.
[ Upstream commit eb3255ee8f6f4691471a28fbf22db5e8901116cd ]
Fix this makecheck warning:
drivers/parisc/sba_iommu.c:98:19: warning: symbol 'sba_list'
was not declared. Should it be static?
commit 4db89524b084f712a887256391fc19d9f66c8e55 upstream.
Fix the LAN receive and LAN transmit LEDs, which where swapped
up to now.
commit 9f5ba4b3e1b3c123eeca5d2d09161e8720048b5c upstream.
The lscpu command is broken since commit cab56b51ec0e ("parisc: Fix
device names in /proc/iomem") added the PA pathname to all PA
devices, includig the CPUs.
lscpu parses /proc/cpuinfo and now believes it found different CPU
types since every CPU is listed with an unique identifier (PA
pathname).
Fix this problem by simply dropping the PA pathname when listing the
CPUs in /proc/cpuinfo. There is no need to show the pathname in this
procfs file.
Fixes: cab56b51ec0e ("parisc: Fix device names in /proc/iomem")
Cc: <stable@vger.kernel.org> # v4.9+
commit b5d89408b9fb21258f7c371d6d48a674f60f7181 upstream.
commit 567b35159e76997e95b643b9a8a5d9d2198f2522 upstream.
This change simplifies the randomization of file mapping regions. It
reworks the code to remove duplication. The flow is now similar to
that for mips. Finally, we consistently use the do_color_align variable
to determine when color alignment is needed.
Tested on rp3440.
commit 61235b24b9cb37c13fcad5b9596d59a1afdcec30 upstream
Everything is converted over to arch_cpu_finalize_init(). Remove the
check_bugs() leftovers including the empty stubs in asm-generic, alpha,
parisc, powerpc and xtensa.
Reviewed-by: Richard Henderson <richard.henderson@linaro.org>
Link: https://lore.kernel.org/r/20230613224545.553215951@linutronix.de
Signed-off-by: Daniel Sneddon <daniel.sneddon@linux.intel.com>
commit ea3f8272876f2958463992f6736ab690fde7fa9c upstream.
In commit 8d7071af8907 ("mm: always expand the stack with the mmap write
lock held") I tried to deal with the remaining odd page fault handling
cases. The oddest one is ia64, which has stacks that grow both up and
down. And because ia64 was _so_ odd, I asked people to verify the end
result.
But a close second oddity is parisc, which is the only one that has a
main stack growing up (our "CONFIG_STACK_GROWSUP" config option). But
it looked obvious enough that I didn't worry about it.
I should have worried a bit more. Not because it was particularly
complex, but because I just used the wrong variable name.
The previous vma isn't called "prev", it's called "prev_vma". Blush.
Fixes: 8d7071af8907 ("mm: always expand the stack with the mmap write lock held")
commit 8d7071af890768438c14db6172cc8f9f4d04e184 upstream
This finishes the job of always holding the mmap write lock when
extending the user stack vma, and removes the 'write_locked' argument
from the vm helper functions again.
For some cases, we just avoid expanding the stack at all: drivers and
page pinning really shouldn't be extending any stacks. Let's see if any
strange users really wanted that.
It's worth noting that architectures that weren't converted to the new
lock_mm_and_find_vma() helper function are left using the legacy
"expand_stack()" function, but it has been changed to drop the mmap_lock
and take it for writing while expanding the vma. This makes it fairly
straightforward to convert the remaining architectures.
As a result of dropping and re-taking the lock, the calling conventions
for this function have also changed, since the old vma may no longer be
valid. So it will now return the new vma if successful, and NULL - and
the lock dropped - if the area could not be extended.
[6.1: Patch drivers/iommu/io-pgfault.c instead]
Signed-off-by: Samuel Mendoza-Jonas <samjonas@amazon.com>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit b5b2a02bcaac7c287694aa0db4837a07bf178626 upstream.
We define sp and ipsw in <asm/asmregs.h> using ".reg", and when using
current binutils (snapshot 2.40.50.20230611) the definitions in
<asm/assembly.h> using "=" conflict with those:
arch/parisc/include/asm/assembly.h: Assembler messages:
arch/parisc/include/asm/assembly.h:93: Error: symbol `sp' is already defined
arch/parisc/include/asm/assembly.h:95: Error: symbol `ipsw' is already defined
Delete the duplicate definitions in <asm/assembly.h>.
Also delete the definition of gp, which isn't used anywhere.
Signed-off-by: Ben Hutchings <benh@debian.org>
[ Upstream commit 59fa12646d9f56c842b4d5b6418ed77af625c588 ]
Add comment in arch_sync_dma_for_device() and handle the direction flag in
arch_sync_dma_for_cpu().
When receiving data from the device (DMA_FROM_DEVICE) unconditionally
purge the data cache in arch_sync_dma_for_cpu().
commit df419492e428b6a2bce98d0f613c58a13da6666c upstream.
The kernel kprobes break instructions should only be handled when running
in kernel context.
Cc: <stable@vger.kernel.org> # v5.18+
commit adf8e96a7ea670d45b5de7594acc67e8f4787ae6 upstream.
commit 2028315cf59bb899a5ac7e87dc48ecb8fac7ac24 upstream.
In case a machine can't power-off itself on system shutdown,
allow the user to reboot it by pressing the RETURN key.
Cc: <stable@vger.kernel.org> # v4.14+
commit 61e150fb310729c98227a5edf6e4a3619edc3702 upstream.
Since at least kernel 6.1, flush_dcache_page() is called with IRQs
disabled, e.g. from aio_complete().
But the current implementation for flush_dcache_page() on parisc
unintentionally re-enables IRQs, which may lead to deadlocks.
Fix it by using xa_lock_irqsave() and xa_unlock_irqrestore()
for the flush_dcache_mmap_*lock() macros instead.
Cc: linux-parisc@vger.kernel.org
Cc: stable@kernel.org # 5.18+
commit 6888ff04e37d01295620a73f3f7efbc79f6ef152 upstream.
The kernel kgdb break instructions should only be handled when running
in kernel context.
Cc: <stable@vger.kernel.org> # v5.4+
commit b6405f0829d7b1dd926ba3ca5f691cab835abfaa upstream.
When patching the kernel code some alternatives depend on SMP vs. !SMP.
Use the value of num_present_cpus() instead of num_online_cpus() to
decide, otherwise we may run into issues if and additional CPU is
enabled after having loaded a module while only one CPU was enabled.
Cc: <stable@vger.kernel.org> # v6.1+
[ Upstream commit 829632dae8321787525ee37dc4828bbe6edafdae ]
The panic notifiers' callbacks execute in an atomic context, with
interrupts/preemption disabled, and all CPUs not running the panic
function are off, so it's very dangerous to wait on a regular
spinlock, there's a risk of deadlock.
Refactor the panic notifier of parisc/power driver to make use
of spin_trylock - for that, we've added a second version of the
soft-power function. Also, some comments were reorganized and
trailing white spaces, useless header inclusion and blank lines
were removed.
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: Jeroen Roovers <jer@xs4all.nl>
Acked-by: Helge Deller <deller@gmx.de> # parisc
Signed-off-by: Guilherme G. Piccoli <gpiccoli@igalia.com>
commit d755bd2caeb47fd806e12399fe8b56798fa5d2cc upstream.
Matthew Wilcox noticed, that if ARCH_HAS_FLUSH_ON_KUNMAP is defined
(which is the case for PA-RISC), __kunmap_local() calls
kunmap_flush_on_unmap(), which may call the parisc flush functions with
a non-page-aligned address and thus the page might not be fully flushed.
This patch ensures that flush_kernel_dcache_page_asm() and
flush_kernel_dcache_page_asm() will always operate on page-aligned
addresses.
commit 6e3220ba3323a2c24be834aebf5d6e9f89d0993f upstream.
Fix the argument pointer (ap) to point to real-mode memory
instead of virtual memory.
It's interesting that this issue hasn't shown up earlier, as this could
have happened with any 64-bit PDC ROM code.
I just noticed it because I suddenly faced a HPMC while trying to execute
the 64-bit STI ROM code of an Visualize-FXe graphics card for the STI
text console.
commit 316f1f42b5cc1d95124c1f0387c867c1ba7b6d0e upstream.
Wire up the missing ptrace requests PTRACE_GETREGS, PTRACE_SETREGS,
PTRACE_GETFPREGS and PTRACE_SETFPREGS when running 32-bit applications
on 64-bit kernels.
Cc: stable@vger.kernel.org # 4.7+
commit 3f0c17809a098d3f0c1ec83f1fb3ca61638d3dcd upstream.
Prefer usage of the PRIV_USER constant over the hard-coded value to set
the lowest 2 bits for the userspace privilege.
Cc: stable@vger.kernel.org # 5.16+
commit 5d1335dabb3c493a3d6d5b233953b6ac7b6c1ff2 upstream.
There is an off-by-one if the printed string includes a new-line
char.
commit 71bdea6f798b425bc0003780b13e3fdecb16a010 upstream.
Adjust some MADV_XXX constants to be in sync what their values are on
all other platforms. There is currently no reason to have an own
numbering on parisc, but it requires workarounds in many userspace
sources (e.g. glibc, qemu, ...) - which are often forgotten and thus
introduce bugs and different behaviour on parisc.
A wrapper avoids an ABI breakage for existing userspace applications by
translating any old values to the new ones, so this change allows us to
move over all programs to the new ABI over time.
commit fe94cb1a614d2df2764d49ac959d8b7e4cb98e15 upstream.
PMD_SHIFT isn't defined if CONFIG_PGTABLE_LEVELS == 3, and as
such the kernel test robot found this warning:
In file included from include/linux/pgtable.h:6,
from arch/parisc/kernel/head.S:23:
arch/parisc/include/asm/pgtable.h:169:32: warning: "PMD_SHIFT" is not defined, evaluates to 0 [-Wundef]
169 | #if (KERNEL_INITIAL_ORDER) >= (PMD_SHIFT)
Avoid the warning by using PLD_SHIFT and BITS_PER_PTE.
Reported-by: kernel test robot <lkp@intel.com>
Cc: <stable@vger.kernel.org> # 6.0+
commit 7e6652c79ecd74e1112500668d956367dc3772a5 upstream.
The kgdb console is already implemented and registered in pdc_cons.c,
so the duplicate code can be dropped.
Cc: <stable@vger.kernel.org> # 6.1+
commit 9086e6017957c5cd6ea28d94b70e0d513d6b7800 upstream.
Fix those make warnings:
arch/parisc/kernel/vdso32/Makefile:30: FORCE prerequisite is missing
arch/parisc/kernel/vdso64/Makefile:30: FORCE prerequisite is missing
Add the missing FORCE prerequisites for all build targets identified by
"make help".
Fixes: e1f86d7b4b2a5213 ("kbuild: warn if FORCE is missing for if_changed(_dep,_rule) and filechk")
Cc: <stable@vger.kernel.org> # 5.18+
commit 7236aae5f81f3efbd93d0601e74fc05994bc2580 upstream.
Utilize pdc_lock spinlock to protect parallel modifications of the
iodc_dbuf[] buffer, check length to prevent buffer overflow of
iodc_dbuf[], drop the iodc_retbuf[] buffer and fix some wrong
indentings.
