commit b5d89408b9fb21258f7c371d6d48a674f60f7181 upstream.
Signed-off-by: Helge Deller <deller@gmx.de>
commit 567b35159e76997e95b643b9a8a5d9d2198f2522 upstream.
This change simplifies the randomization of file mapping regions. It
reworks the code to remove duplication. The flow is now similar to
that for mips. Finally, we consistently use the do_color_align variable
to determine when color alignment is needed.
Tested on rp3440.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
commit 71bdea6f798b425bc0003780b13e3fdecb16a010 upstream.
Adjust some MADV_XXX constants to be in sync what their values are on
all other platforms. There is currently no reason to have an own
numbering on parisc, but it requires workarounds in many userspace
sources (e.g. glibc, qemu, ...) - which are often forgotten and thus
introduce bugs and different behaviour on parisc.
A wrapper avoids an ABI breakage for existing userspace applications by
translating any old values to the new ones, so this change allows us to
move over all programs to the new ABI over time.
The prandom_u32() function has been a deprecated inline wrapper around
get_random_u32() for several releases now, and compiles down to the
exact same code. Replace the deprecated wrapper with a direct call to
the real function. The same also applies to get_random_int(), which is
just a wrapper around get_random_u32(). This was done as a basic find
and replace.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Yury Norov <yury.norov@gmail.com>
Reviewed-by: Jan Kara <jack@suse.cz> # for ext4
Acked-by: Toke Høiland-Jørgensen <toke@toke.dk> # for sch_cake
Acked-by: Chuck Lever <chuck.lever@oracle.com> # for nfsd
Acked-by: Jakub Kicinski <kuba@kernel.org>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> # for thunderbolt
Acked-by: Darrick J. Wong <djwong@kernel.org> # for xfs
Acked-by: Helge Deller <deller@gmx.de> # for parisc
Acked-by: Heiko Carstens <hca@linux.ibm.com> # for s390
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Instead of showing only the very first application which needs
recompile, show all of them, but print them only once.
Includes typo fix noticed by Colin Ian King.
Signed-off-by: Colin Ian King <colin.i.king@gmail.com>
On parisc we need to initialize the memory layout for the user stack at
process start time to a fixed size, which up until now was limited to
the size as given by CONFIG_MAX_STACK_SIZE_MB at compile time.
This hard limit was too small and showed problems when compiling
ruby2.7, qmlcachegen and some Qt packages.
This patch changes two things:
a) It increases the default maximum stack size to 100MB.
b) Users can modify the stack hard limit size with ulimit and then newly
forked processes will use the given stack size which can even be bigger
than the default 100MB.
Reported-by: John David Anglin <dave.anglin@bell.net>
The commit 75ae04206a4d ("parisc: Define O_NONBLOCK to become
000200000") changed the O_NONBLOCK constant to have only one bit set
(like all other architectures). This change broke some existing
userspace code (e.g. udevadm, systemd-udevd, elogind) which called
specific syscalls which do strict value checking on their flag
parameter.
This patch adds wrapper functions for the relevant syscalls. The
wrappers masks out any old invalid O_NONBLOCK flags, reports in the
syslog if the old O_NONBLOCK value was used and then calls the target
syscall with the new O_NONBLOCK value.
Fixes: 75ae04206a4d ("parisc: Define O_NONBLOCK to become 000200000")
Tested-by: Meelis Roos <mroos@linux.ee>
Tested-by: Jeroen Roovers <jer@xs4all.nl>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details you
should have received a copy of the gnu general public license along
with this program if not write to the free software foundation inc
59 temple place suite 330 boston ma 02111 1307 usa
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1334 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de
Do not offset mmap base address because of stack randomization if
current task does not want randomization.
Signed-off-by: Alexandre Ghiti <alex@ghiti.fr>
Executing 64-bit applications was broken. This patch restores this
support and cleans up some code paths.
Patch series "exec: Pin stack limit during exec".
Attempts to solve problems with the stack limit changing during exec
continue to be frustrated[1][2]. In addition to the specific issues
around the Stack Clash family of flaws, Andy Lutomirski pointed out[3]
other places during exec where the stack limit is used and is assumed to
be unchanging. Given the many places it gets used and the fact that it
can be manipulated/raced via setrlimit() and prlimit(), I think the only
way to handle this is to move away from the "current" view of the stack
limit and instead attach it to the bprm, and plumb this down into the
functions that need to know the stack limits. This series implements
the approach.
[1] 04e35f4495dd ("exec: avoid RLIMIT_STACK races with prlimit()")
[2] 779f4e1c6c7c ("Revert "exec: avoid RLIMIT_STACK races with prlimit()"")
[3] to security@kernel.org, "Subject: existing rlimit races?"
This patch (of 3):
Since it is possible that the stack rlimit can change externally during
exec (either via another thread calling setrlimit() or another process
calling prlimit()), provide a way to pass the rlimit down into the
per-architecture mm layout functions so that the rlimit can stay in the
bprm structure instead of sitting in the signal structure until exec is
finalized.
Link: http://lkml.kernel.org/r/1518638796-20819-2-git-send-email-keescook@chromium.org
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Willy Tarreau <w@1wt.eu>
Cc: "Jason A. Donenfeld" <Jason@zx2c4.com>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Greg KH <greg@kroah.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
Cc: Brad Spengler <spender@grsecurity.net>
Using this helper allows us to avoid the in-kernel calls to the
sys_readahead() syscall. The ksys_ prefix denotes that this function is
meant as a drop-in replacement for the syscall. In particular, it uses the
same calling convention as sys_readahead().
This patch is part of a series which removes in-kernel calls to syscalls.
On this basis, the syscall entry path can be streamlined. For details, see
http://lkml.kernel.org/r/20180325162527.GA17492@light.dominikbrodowski.net
Cc: linux-mm@kvack.org
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
sys_mmap_pgoff() syscall. The ksys_ prefix denotes that this function is
same calling convention as sys_mmap_pgoff().
Using the ksys_fadvise64_64() helper allows us to avoid the in-kernel
calls to the sys_fadvise64_64() syscall. The ksys_ prefix denotes that
this function is meant as a drop-in replacement for the syscall. In
particular, it uses the same calling convention as ksys_fadvise64_64().
Some compat stubs called sys_fadvise64(), which then just passed through
the arguments to sys_fadvise64_64(). Get rid of this indirection, and call
ksys_fadvise64_64() directly.
Using the ksys_fallocate() wrapper allows us to get rid of in-kernel
calls to the sys_fallocate() syscall. The ksys_ prefix denotes that this
particular, it uses the same calling convention as sys_fallocate().
Using the ksys_p{read,write}64() wrappers allows us to get rid of
in-kernel calls to the sys_pread64() and sys_pwrite64() syscalls.
The ksys_ prefix denotes that this function is meant as a drop-in
replacement for the syscall. In particular, it uses the same calling
convention as sys_p{read,write}64().
Using the ksys_truncate() wrapper allows us to get rid of in-kernel
calls to the sys_truncate() syscall. The ksys_ prefix denotes that this
particular, it uses the same calling convention as sys_truncate().
sys_sync_file_range() syscall. The ksys_ prefix denotes that this function
is meant as a drop-in replacement for the syscall. In particular, it uses
the same calling convention as sys_sync_file_range().
Using the ksys_ftruncate() wrapper allows us to get rid of in-kernel
calls to the sys_ftruncate() syscall. The ksys_ prefix denotes that this
particular, it uses the same calling convention as sys_ftruncate().
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
to <linux/sched/mm.h>
We are going to split more MM APIs out of <linux/sched.h>, which
will have to be picked up from a couple of .c files.
The APIs that we are going to move are:
arch_pick_mmap_layout()
arch_get_unmapped_area_topdown()
mm_update_next_owner()
Include the header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
<linux/sched/signal.h>
We are going to split <linux/sched/signal.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/signal.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Add missing code for userspace executable address randomization, e.g.
applications compiled with the gcc -pie option.
The system calls alloc_hugepages() and free_hugepages() were introduced
in Linux 2.5.36 and removed again in 2.5.54. They were never implemented
on parisc, so let's drop them now.
architectures
On architectures where the stack grows upwards (CONFIG_STACK_GROWSUP=y,
currently parisc and metag only) stack randomization sometimes leads to crashes
when the stack ulimit is set to lower values than STACK_RND_MASK (which is 8 MB
by default if not defined in arch-specific headers).
The problem is, that when the stack vm_area_struct is set up in fs/exec.c, the
additional space needed for the stack randomization (as defined by the value of
STACK_RND_MASK) was not taken into account yet and as such, when the stack
randomization code added a random offset to the stack start, the stack
effectively got smaller than what the user defined via rlimit_max(RLIMIT_STACK)
which then sometimes leads to out-of-stack situations and crashes.
This patch fixes it by adding the maximum possible amount of memory (based on
STACK_RND_MASK) which theoretically could be added by the stack randomization
code to the initial stack size. That way, the user-defined stack size is always
guaranteed to be at minimum what is defined via rlimit_max(RLIMIT_STACK).
This bug is currently not visible on the metag architecture, because on metag
STACK_RND_MASK is defined to 0 which effectively disables stack randomization.
The changes to fs/exec.c are inside an "#ifdef CONFIG_STACK_GROWSUP"
section, so it does not affect other platformws beside those where the
stack grows upwards (parisc and metag).
Cc: linux-parisc@vger.kernel.org
Cc: James Hogan <james.hogan@imgtec.com>
Cc: linux-metag@vger.kernel.org
Cc: stable@vger.kernel.org # v3.16+
This patch affects only architectures where the stack grows upwards
(currently parisc and metag only). On those do not hardcode the maximum
initial stack size to 1GB for 32-bit processes, but make it configurable
via a config option.
The main problem with the hardcoded stack size is, that we have two
memory regions which grow upwards: stack and heap. To keep most of the
memory available for heap in a flexmap memory layout, it makes no sense
to hard allocate up to 1GB of the memory for stack which can't be used
as heap then.
This patch makes the stack size for 32-bit processes configurable and
uses 80MB as default value which has been in use during the last few
years on parisc and which hasn't showed any problems yet.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: John David Anglin <dave.anglin@bell.net>
On parisc, SHMLBA was defined to 0x00400000 (4MB) to reflect that we need to
take care of our caches for shared mappings. But actually, we can map a file at
any multiple address of PAGE_SIZE, so let us correct that now with a value of
PAGE_SIZE for SHMLBA. Instead we now take care of this cache colouring via the
constant SHM_COLOUR while we map shared pages.
CC: Jeroen Roovers <jer@gentoo.org>
CC: John David Anglin <dave.anglin@bell.net>
CC: Carlos O'Donell <carlos@systemhalted.org>
Cc: stable@kernel.org [3.13+]
Add support for the flexible mmap memory layout (as described in
http://lwn.net/Articles/91829). This is especially very interesting on
parisc since we currently only support 32bit userspace (even with a
64bit Linux kernel).
locale-gen on Debian showed a strange problem on parisc:
mmap2(NULL, 536870912, PROT_NONE, MAP_SHARED, 3, 0) = 0x42a54000
mmap2(0x42a54000, 103860, PROT_READ|PROT_WRITE, MAP_SHARED|MAP_FIXED, 3, 0) = -1 EINVAL (Invalid argument)
Basically it was just trying to re-mmap() a file at the same address
which it was given by a previous mmap() call. But this remapping failed
with EINVAL.
The problem is, that when MAP_FIXED and MAP_SHARED flags were used, we didn't
included the mapping-based offset when we verified the alignment of the given
fixed address against the offset which we calculated it in the previous call.
Cc: <stable@vger.kernel.org> # 3.10+
Update the parisc arch_get_unmapped_area function to make use of
vm_unmapped_area() instead of implementing a brute force search.
[akpm@linux-foundation.org: remove now-unused DCACHE_ALIGN(), per James]
Signed-off-by: Michel Lespinasse <walken@google.com>
fallocate(off_t) gets redirected by glibc to fallocate64(loff_t)
where the 64bit loff_t values get splitted into two 32bit (hi/lo)
values. This patch fixes this syscall for the 32- and 64bit kernel.
On Thu, 2012-11-01 at 16:45 -0700, Michel Lespinasse wrote:
> Looking at the arch/parisc/kernel/sys_parisc.c implementation of
> get_shared_area(), I do have a concern though. The function basically
> ignores the pgoff argument, so that if one creates a shared mapping of
> pages 0-N of a file, and then a separate shared mapping of pages 1-N
> of that same file, both will have the same cache offset for their
> starting address.
> This looks like this would create obvious aliasing issues. Am I
> misreading this ? I can't understand how this could work good enough
> to be undetected, so there must be something I'm missing here ???
This turns out to be correct and we need to pay attention to the pgoff as
well as the address when creating the virtual address for the area.
Fortunately, the bug is rarely triggered as most applications which use pgoff
tend to use large values (git being the primary one, and it uses pgoff in
multiples of 16MB) which are larger than our cache coherency modulus, so the
problem isn't often seen in practise.
Reported-by: Michel Lespinasse <walken@google.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Directly comparing task_struct->personality against PER_* is not fully
correct, as it doesn't take flags potentially stored in top three bytes
into account.
Analogically, directly forcefully setting personality to PER_LINUX32 or
PER_LINUX discards any flags stored in the top three bytes.
On an architecture that supports 32-bit compat we need to override the
reported machine in uname with the 32-bit value. Instead of doing this
separately in every architecture introduce a COMPAT_UTS_MACHINE define in
<asm/compat.h> and apply it directly in sys_newuname().
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andreas Schwab <schwab@linux-m68k.org>
New helper - sys_mmap_pgoff(); switch syscalls to using it.
This replaces the duplicated arch-specific versions of "sys_pipe()" with
one unified implementation. This removes almost 250 lines of duplicated
code.
It's marked __weak, so that *if* an architecture wants to override the
default implementation it can do so by simply having its own replacement
version, since many architectures use alternate calling conventions for
the 'pipe()' system call for legacy reasons (ie traditional UNIX
implementations often return the two file descriptors in registers)
I still haven't changed the cris version even though Linus says the BKL
isn't needed. The arch maintainer can easily do it if there are really
no obstacles.
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Handle MAP_FIXED in parisc arch_get_unmapped_area(), just return the address.
We might want to also check for possible cache aliasing issues now that we get
called in that case (like ARM or MIPS), leave a comment for the maintainers to
pick up.
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Matthew Wilcox <willy@debian.org>
The utsname virtualisation broke parisc_newuname compilation.
Rewrite the implementation to call sys_newuname() like sparc64 does.
Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
And now suddenly, linux32 works on parisc...
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
Most are easy, but sync_file_range needed special handling when entering
through the 32-bit syscall table.
infrastructure for it.
Let it rip!
