path: root/arch/parisc/include
2009-01-29Documentation: move DMA-mapping.txt to Doc/PCI/Randy Dunlap
Move DMA-mapping.txt to Documentation/PCI/. DMA-mapping.txt was supposed to be moved from Documentation/ to Documentation/PCI/. The 00-INDEX files in those two directories were updated, along with a few other text files, but the file itself somehow escaped being moved, so move it and update more text files and source files with its new location. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14byteorder: make swab.h include asm/swab.h like a regular headerHarvey Harrison
Add swab.h to kbuild.asm and remove the individual entries from each arch, mark as unifdef as some arches have some kernel-only bits inside. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09parisc: introduce asm/swab.hHarvey Harrison
Fix for the linux/byteorder.h removal. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: export length of os_hpmc vector parisc: fix kernel crash (protection id trap) when compiling ruby1.9 parisc: Use DEFINE_SPINLOCK parisc: add uevent helper for parisc bus parisc: fix ipv6 checksum parisc: quiet palo not-found message from "which" parisc: Replace NR_CPUS in parisc code parisc: trivial fixes parisc: fix braino in commit adding __space_to_prot parisc: factor out sid to protid conversion parisc: use leX_to_cpu in place of __fswabX parisc: fix GFP_KERNEL use while atomic in unwinder parisc: remove dead BIO_VMERGE_BOUNDARY and BIO_VMERGE_MAX_SIZE definitions parisc: set_time() catch errors parisc: use the new byteorder headers parisc: drivers/parisc/: make code static parisc: lib/: make code static
2009-01-06atomic_t: unify all arch definitionsMatthew Wilcox
The atomic_t type cannot currently be used in some header files because it would create an include loop with asm/atomic.h. Move the type definition to linux/types.h to break the loop. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05parisc: fix kernel crash (protection id trap) when compiling ruby1.9Kyle McMartin
On Wed, Dec 17, 2008 at 11:46:05PM +0100, Helge Deller wrote: > Honestly, I can't decide whether to apply this. It really should never happen in the kernel, since the kernel can guarantee it won't get the access rights failure (highest privilege level, and can set %sr and %protid to whatever it wants.) It really genuinely is a bug that probably should panic the kernel. The only precedent I can easily see is x86 fixing up a bad iret with a general protection fault, which is more or less analogous to code 27 here. On the other hand, taking the exception on a userspace access really isn't all that critical, and there's fundamentally little reason for the kernel not to SIGSEGV the process, and continue... Argh. (btw, I've instrumented my do_sys_poll with a pile of assertions that %cr8 << 1 == %sr3 == current->mm.context... let's see if where we're getting corrupted is deterministic, though, I would guess that it won't be.) Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-05parisc: fix ipv6 checksumKyle McMartin
ipv6 recently started exhibiting the same symptoms as ipv4 was, add a memory clobber around inline checksum assembly that fribbles memory to ensure gcc doesn't erroneously cache across it. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-05parisc: Replace NR_CPUS in parisc codeHelge Deller
parisc: Replace most arrays sized by NR_CPUS with percpu variables. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-05parisc: fix braino in commit adding __space_to_protKyle McMartin
Shouldn't commit without building before morning coffee... Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-05parisc: factor out sid to protid conversionKyle McMartin
Create a new __space_to_prot inline to convert the space id (mmu context) to a protection id. Sadly it doesn't look like the #ifdef can be eliminated since relying on the compiler to not truncate a bit on return (ctx >> SPACEID_SHIFT) << 1; seems a little dodgy. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-05parisc: use leX_to_cpu in place of __fswabXKyle McMartin
2009-01-05parisc: remove dead BIO_VMERGE_BOUNDARY and BIO_VMERGE_MAX_SIZE definitionsFUJITA Tomonori
The block layer dropped the virtual merge feature (b8b3e16cfe6435d961f6aaebcfd52a1ff2a988c5). BIO_VMERGE_BOUNDARY and BIO_VMERGE_MAX_SIZE definitions are meaningless now. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-05parisc: use the new byteorder headersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-05parisc: fix module loading failure of large kernel modulesHelge Deller
On 32bit (and sometimes 64bit) and with big kernel modules like xfs or ipv6 the relocation types R_PARISC_PCREL17F and R_PARISC_PCREL22F may fail to reach their PLT stub if we only create one big stub array for all sections at the beginning of the core or init section. With this patch we now instead add individual PLT stub entries directly in front of the code sections where the stubs are actually called. This reduces the distance between the PCREL location and the stub entry so that the relocations can be fulfilled. While calculating the final layout of the kernel module in memory, the kernel module loader calls arch_mod_section_prepend() to request the to be reserved amount of memory in front of each individual section. Tested with 32- and 64bit kernels. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-01-01parisc: remove gratuitous cpu_online_map declaration.Rusty Russell
This is defined in linux/cpumask.h (included in this file already), and this is now defined differently. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: linux-parisc@vger.kernel.org
2008-12-23parisc: disable UP-optimized flush_tlb_mmKyle McMartin
flush_tlb_mm's "optimized" uniprocessor case of allocating a new context for userspace is exposing a race where we can suddely return to a syscall with the protection id and space id out of sync, trapping on the next userspace access. Debugged-by: James Bottomley <James.Bottomley@HansenPartnership.com> Tested-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: struct device - replace bus_id with dev_name(), dev_set_name() parisc: fix kernel crash when unwinding a userspace process parisc: __kernel_time_t is always long
2008-11-30remove __ARCH_WANT_COMPAT_SYS_PTRACEChristoph Hellwig
All architectures now use the generic compat_sys_ptrace, as should every new architecture that needs 32bit compat (if we'll ever get another). Remove the now superflous __ARCH_WANT_COMPAT_SYS_PTRACE define, and also kill a comment about __ARCH_SYS_PTRACE that was added after __ARCH_SYS_PTRACE was already gone. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-26parisc: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
(I did not compile or test it, please let me know, or help fixing it, if something is wrong with the conversion) This patch is part of a larger patch series which will remove the "char bus_id[20]" name string from struct device. The device name is managed in the kobject anyway, and without any size limitation, and just needlessly copied into "struct device". To set and read the device name dev_name(dev) and dev_set_name(dev) must be used. If your code uses static kobjects, which it shouldn't do, "const char *init_name" can be used to statically provide the name the registered device should have. At registration time, the init_name field is cleared, to enforce the use of dev_name(dev) to access the device name at a later time. We need to get rid of all occurrences of bus_id in the entire tree to be able to enable the new interface. Please apply this patch, and possibly convert any remaining remaining occurrences of bus_id. We want to submit a patch to -next, which will remove bus_id from "struct device", to find the remaining pieces to convert, and finally switch over to the new api, which will remove the 20 bytes array and does no longer have a size limitation. Thanks, Kay Cc: Matthew Wilcox <matthew@wil.cx> Cc: linux-parisc@vger.kernel.org Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-11-26parisc: __kernel_time_t is always longGeert Uytterhoeven
__kernel_time_t is always long on PA-RISC, irrespective of CONFIG_64BIT, hence move it out of the #ifdef CONFIG_64BIT / #else / #endif block. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-11-13fix cpumask build breakage on pariscHelge Deller
Commit 2d3854a37e8b767a51aba38ed6d22817b0631e33 ("cpumask: introduce new API, without changing anything") introduced a build breakage on parisc. This trivial patch fixes it. Signed-off-by: Helge Deller <deller@gmx.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Kyle Mc Martin <kyle@hera.kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: convert to generic compat_sys_ptrace parisc: add rtc platform driver parisc: initialize unwinder much earlier parisc: add new syscalls parisc: hijack jump to start_kernel parisc: add pdc_coproc_cfg_unlocked and set_firmware_width_unlocked parisc: move include/asm-parisc to arch/parisc/include/asm parisc: move pdc_result to real2.S parisc: unify CCIO_COLLECT_STATS implementation parisc: add arch/parisc/kernel/.gitignore parisc: ropes.h - fix <asm-parisc/*> -> <asm/*> parisc: parisc-agp - fix <asm-parisc/*> -> <asm/*> Resolve remove/rename conflict: include/asm-parisc/a.out.h is no longer relevant.
2008-10-17parisc: convert to generic compat_sys_ptraceHelge Deller
This patch does the compat_sys_ptrace conversion for parisc. In addition it does convert the parisc ptrace code to use the architecture-independent ptrace infrastructure instead of own coding. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-10-10parisc: initialize unwinder much earlierJames Bottomley
The unwinder was being initialized way too late to be any use debugging early boot crashes. Instead of relying on module_init initcalls to initialize it, let's do it explicitly as early as we can. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-10-10parisc: add new syscallsKyle McMartin
2008-10-10parisc: add pdc_coproc_cfg_unlocked and set_firmware_width_unlockedKyle McMartin
These functions are called only when bringing up the monarch cpu, so it is safe to call them without taking the pdc spinlock. In the future, this may become relevant for lockdep, since these functions were taking spinlocks before start_kernel called the lockdep initializers.
2008-10-10parisc: move include/asm-parisc to arch/parisc/include/asmKyle McMartin
