path: root/arch/parisc/hpux
2013-06-29[readdir] constify ->actorAl Viro
2013-06-29[readdir] introduce ->iterate(), ctx->pos, dir_emit()Al Viro
New method - ->iterate(file, ctx). That's the replacement for ->readdir(); it takes callback from ctx->actor, uses ctx->pos instead of file->f_pos and calls dir_emit(ctx, ...) instead of filldir(data, ...). It does *not* update file->f_pos (or look at it, for that matter); iterate_dir() does the update. Note that dir_emit() takes the offset from ctx->pos (and eventually filldir_t will lose that argument). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] introduce iterate_dir() and dir_contextAl Viro
iterate_dir(): new helper, replacing vfs_readdir(). struct dir_context: contains the readdir callback (and will get more stuff in it), embedded into whatever data that callback wants to deal with; eventually, we'll be passing it to ->readdir() replacement instead of (data,filldir) pair. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-01-30[PARISC] hpux: Remove obsolete regs parameter from do_execve() in hpux_execve()Geert Uytterhoeven
commit da3d4c5fa56236dd924d77ffc4f982356816b93b ("get rid of pt_regs argument of do_execve()") removed the parameter, but forgot to update hpux_execve(): arch/parisc/hpux/fs.c: In function 'hpux_execve': arch/parisc/hpux/fs.c:47:6: error: too many arguments to function 'do_execve' Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-10-12vfs: define struct filename and have getname() return itJeff Layton
getname() is intended to copy pathname strings from userspace into a kernel buffer. The result is just a string in kernel space. It would however be quite helpful to be able to attach some ancillary info to the string. For instance, we could attach some audit-related info to reduce the amount of audit-related processing needed. When auditing is enabled, we could also call getname() on the string more than once and not need to recopy it from userspace. This patchset converts the getname()/putname() interfaces to return a struct instead of a string. For now, the struct just tracks the string in kernel space and the original userland pointer for it. Later, we'll add other information to the struct as it becomes convenient. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull pile 2 of execve and kernel_thread unification work from Al Viro: "Stuff in there: kernel_thread/kernel_execve/sys_execve conversions for several more architectures plus assorted signal fixes and cleanups. There'll be more (in particular, real fixes for the alpha do_notify_resume() irq mess)..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (43 commits) alpha: don't open-code trace_report_syscall_{enter,exit} Uninclude linux/freezer.h m32r: trim masks avr32: trim masks tile: don't bother with SIGTRAP in setup_frame microblaze: don't bother with SIGTRAP in setup_rt_frame() mn10300: don't bother with SIGTRAP in setup_frame() frv: no need to raise SIGTRAP in setup_frame() x86: get rid of duplicate code in case of CONFIG_VM86 unicore32: remove pointless test h8300: trim _TIF_WORK_MASK parisc: decide whether to go to slow path (tracesys) based on thread flags parisc: don't bother looping in do_signal() parisc: fix double restarts bury the rest of TIF_IRET sanitize tsk_is_polling() bury _TIF_RESTORE_SIGMASK unicore32: unobfuscate _TIF_WORK_MASK mips: NOTIFY_RESUME is not needed in TIF masks mips: merge the identical "return from syscall" per-ABI code ... Conflicts: arch/arm/include/asm/thread_info.h
2012-10-01parisc: fix double restartsAl Viro
Don't bother restoring r28 on syscall restarts; it's clobbered by syscall anyway. Reuse (now unused) ->orig_r28 as "no restarts allowed" flag. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-26switch simple cases of fget_light to fdgetAl Viro
2012-09-26switch hpux_getdents() to fget_light()Al Viro
2012-05-15userns: Convert stat to return values mapped from kuids and kgidsEric W. Biederman
- Store uids and gids with kuid_t and kgid_t in struct kstat - Convert uid and gids to userspace usable values with from_kuid and from_kgid Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-01-03vfs: new helper - vfs_ustat()Al Viro
... and bury user_get_super()/statfs_by_dentry() - they are purely internal now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14clean statfs-like syscalls upAl Viro
New helpers: user_statfs() and fd_statfs(), taking userland pathname and descriptor resp. and filling struct kstatfs. Syscalls of statfs family (native, compat and foreign - osf and hpux on alpha and parisc resp.) switched to those. Removes some boilerplate code, simplifies cleanup on errors... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09pass a struct path to vfs_statfsChristoph Hellwig
We'll need the path to implement the flags field for statvfs support. We do have it available in all callers except: - ecryptfs_statfs. This one doesn't actually need vfs_statfs but just needs to do a caller to the lower filesystem statfs method. - sys_ustat. Add a non-exported statfs_by_dentry helper for it which doesn't won't be able to fill out the flags field later on. In addition rename the helpers for statfs vs fstatfs to do_*statfs instead of the misleading vfs prefix. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-16sanitize do_pipe_flags() callers in archAl Viro
* hpux_pipe() - no need to take BKL * sys32_pipe() in arch/x86/ia32 and xtensa_pipe() in arch/xtensa - no need at all, since both functions are open-coded sys_pipe() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-18ptrace: remove PT_DTRACE from avr32, mn10300, parisc, s390, sh, xtensaOleg Nesterov
avr32, mn10300, parisc, s390, sh, xtensa: They never set PT_DTRACE, but clear it after do_execve(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Chris Zankel <chris@zankel.net> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-13parisc: remove unused local out_putf labelHelge Deller
Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-10-23[PATCH] prepare vfs_readdir() callers to returning filldir resultAl Viro
It's not the final state, but it allows moving ->readdir() instances to passing filldir return value to caller of vfs_readdir(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-09-02fix typo in arch/parisc/hpux/fs.cStephen Rothwell
A parisc allmodconfig build produces this: arch/parisc/hpux/fs.c:107: error: 'buffer' undeclared (first use in this function) Introduced by commit da574983de9f9283ba35662c8723627096e160de ("[PATCH] fix hpux_getdents()"). Helge Dille also reported this in bugzilla 11461: http://bugzilla.kernel.org/show_bug.cgi?id=11461 and he posted an identical patch. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-25[PATCH] fix hpux_getdents()Al Viro
Missing checks for -EFAULT, broken handling of overflow. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] sanitize __user_walk_fd() et.al.Al Viro
* do not pass nameidata; struct path is all the callers want. * switch to new helpers: user_path_at(dfd, pathname, flags, &path) user_path(pathname, &path) user_lpath(pathname, &path) user_path_dir(pathname, &path) (fail if not a directory) The last 3 are trivial macro wrappers for the first one. * remove nameidata in callers. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-24flag parameters: pipeUlrich Drepper
This patch introduces the new syscall pipe2 which is like pipe but it also takes an additional parameter which takes a flag value. This patch implements the handling of O_CLOEXEC for the flag. I did not add support for the new syscall for the architectures which have a special sys_pipe implementation. I think the maintainers of those archs have the chance to go with the unified implementation but that's up to them. The implementation introduces do_pipe_flags. I did that instead of changing all callers of do_pipe because some of the callers are written in assembler. I would probably screw up changing the assembly code. To avoid breaking code do_pipe is now a small wrapper around do_pipe_flags. Once all callers are changed over to do_pipe_flags the old do_pipe function can be removed. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_pipe2 # ifdef __x86_64__ # define __NR_pipe2 293 # elif defined __i386__ # define __NR_pipe2 331 # else # error "need __NR_pipe2" # endif #endif int main (void) { int fd[2]; if (syscall (__NR_pipe2, fd, 0) != 0) { puts ("pipe2(0) failed"); return 1; } for (int i = 0; i < 2; ++i) { int coe = fcntl (fd[i], F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { printf ("pipe2(0) set close-on-exit for fd[%d]\n", i); return 1; } } close (fd[0]); close (fd[1]); if (syscall (__NR_pipe2, fd, O_CLOEXEC) != 0) { puts ("pipe2(O_CLOEXEC) failed"); return 1; } for (int i = 0; i < 2; ++i) { int coe = fcntl (fd[i], F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { printf ("pipe2(O_CLOEXEC) does not set close-on-exit for fd[%d]\n", i); return 1; } } close (fd[0]); close (fd[1]); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-13Revert "parisc: fix trivial section name warnings"Kyle McMartin
This reverts commit bd3bb8c15b9a80dbddfb7905b237a4a11a4725b4. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-15parisc: fix trivial section name warningsHelge Deller
This trivial patch fixes the following section warnings on PARISC: > WARNING: vmlinux.o (.text.1): unexpected section name. >The (.[number]+) following section name are ld generated and not expected. > Did you forget to use "ax"/"aw" in a .S file? > Note that for example <linux/init.h> contains > section definitions for use in .S files. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-02-14Introduce path_put()Jan Blunck
* Add path_put() functions for releasing a reference to the dentry and vfsmount of a struct path in the right order * Switch from path_release(nd) to path_put(&nd->path) * Rename dput_path() to path_put_conditional() [akpm@linux-foundation.org: fix cifs] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: <linux-fsdevel@vger.kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Embed a struct path into struct nameidata instead of nd->{dentry,mnt}Jan Blunck
This is the central patch of a cleanup series. In most cases there is no good reason why someone would want to use a dentry for itself. This series reflects that fact and embeds a struct path into nameidata. Together with the other patches of this series - it enforced the correct order of getting/releasing the reference count on <dentry,vfsmount> pairs - it prepares the VFS for stacking support since it is essential to have a struct path in every place where the stack can be traversed - it reduces the overall code size: without patch series: text data bss dec hex filename 5321639 858418 715768 6895825 6938d1 vmlinux with patch series: text data bss dec hex filename 5320026 858418 715768 6894212 693284 vmlinux This patch: Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix cifs] [akpm@linux-foundation.org: fix smack] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18[PARISC] Remove hardcoded uses of PAGE_SIZEKyle McMartin
2007-07-29Remove fs.h from mm.hAlexey Dobriyan
Remove fs.h from mm.h. For this, 1) Uninline vma_wants_writenotify(). It's pretty huge anyway. 2) Add back fs.h or less bloated headers (err.h) to files that need it. As result, on x86_64 allyesconfig, fs.h dependencies cut down from 3929 files rebuilt down to 3444 (-12.3%). Cross-compile tested without regressions on my two usual configs and (sigh): alpha arm-mx1ads mips-bigsur powerpc-ebony alpha-allnoconfig arm-neponset mips-capcella powerpc-g5 alpha-defconfig arm-netwinder mips-cobalt powerpc-holly alpha-up arm-netx mips-db1000 powerpc-iseries arm arm-ns9xxx mips-db1100 powerpc-linkstation arm-assabet arm-omap_h2_1610 mips-db1200 powerpc-lite5200 arm-at91rm9200dk arm-onearm mips-db1500 powerpc-maple arm-at91rm9200ek arm-picotux200 mips-db1550 powerpc-mpc7448_hpc2 arm-at91sam9260ek arm-pleb mips-ddb5477 powerpc-mpc8272_ads arm-at91sam9261ek arm-pnx4008 mips-decstation powerpc-mpc8313_rdb arm-at91sam9263ek arm-pxa255-idp mips-e55 powerpc-mpc832x_mds arm-at91sam9rlek arm-realview mips-emma2rh powerpc-mpc832x_rdb arm-ateb9200 arm-realview-smp mips-excite powerpc-mpc834x_itx arm-badge4 arm-rpc mips-fulong powerpc-mpc834x_itxgp arm-carmeva arm-s3c2410 mips-ip22 powerpc-mpc834x_mds arm-cerfcube arm-shannon mips-ip27 powerpc-mpc836x_mds arm-clps7500 arm-shark mips-ip32 powerpc-mpc8540_ads arm-collie arm-simpad mips-jazz powerpc-mpc8544_ds arm-corgi arm-spitz mips-jmr3927 powerpc-mpc8560_ads arm-csb337 arm-trizeps4 mips-malta powerpc-mpc8568mds arm-csb637 arm-versatile mips-mipssim powerpc-mpc85xx_cds arm-ebsa110 i386 mips-mpc30x powerpc-mpc8641_hpcn arm-edb7211 i386-allnoconfig mips-msp71xx powerpc-mpc866_ads arm-em_x270 i386-defconfig mips-ocelot powerpc-mpc885_ads arm-ep93xx i386-up mips-pb1100 powerpc-pasemi arm-footbridge ia64 mips-pb1500 powerpc-pmac32 arm-fortunet ia64-allnoconfig mips-pb1550 powerpc-ppc64 arm-h3600 ia64-bigsur mips-pnx8550-jbs powerpc-prpmc2800 arm-h7201 ia64-defconfig mips-pnx8550-stb810 powerpc-ps3 arm-h7202 ia64-gensparse mips-qemu powerpc-pseries arm-hackkit ia64-sim mips-rbhma4200 powerpc-up arm-integrator ia64-sn2 mips-rbhma4500 s390 arm-iop13xx ia64-tiger mips-rm200 s390-allnoconfig arm-iop32x ia64-up mips-sb1250-swarm s390-defconfig arm-iop33x ia64-zx1 mips-sead s390-up arm-ixp2000 m68k mips-tb0219 sparc arm-ixp23xx m68k-amiga mips-tb0226 sparc-allnoconfig arm-ixp4xx m68k-apollo mips-tb0287 sparc-defconfig arm-jornada720 m68k-atari mips-workpad sparc-up arm-kafa m68k-bvme6000 mips-wrppmc sparc64 arm-kb9202 m68k-hp300 mips-yosemite sparc64-allnoconfig arm-ks8695 m68k-mac parisc sparc64-defconfig arm-lart m68k-mvme147 parisc-allnoconfig sparc64-up arm-lpd270 m68k-mvme16x parisc-defconfig um-x86_64 arm-lpd7a400 m68k-q40 parisc-up x86_64 arm-lpd7a404 m68k-sun3 powerpc x86_64-allnoconfig arm-lubbock m68k-sun3x powerpc-cell x86_64-defconfig arm-lusl7200 mips powerpc-celleb x86_64-up arm-mainstone mips-atlas powerpc-chrp32 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-22[PARISC] ROUND_UP macro cleanup in arch/pariscMilind Arun Choudhary
ROUND_UP macro cleanup, use ALIGN where ever appropriate Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] add ENTRY()/ENDPROC() and simplify assembly of HP/UX emulation codeHelge Deller
Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17Merge branch 'parisc' from /home/kyle/repos/parisc-2.6.gitKyle McMartin
Conflicts: arch/parisc/hpux/sys_hpux.c arch/parisc/mm/ioremap.c
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert pariscJosef Sipek
2006-12-08[PARISC] more sparse fixesMatthew Wilcox
0/NULL changes, __user annotations, __iomem annotations Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-05[PA-RISC] Fix filldir warningsMatthew Wilcox
filldir_t now takes a u64, not an ino_t. Signed-off-by: Matthew Wilcox <matthew@wil.cx>
2006-10-04[PARISC] Fix HPUX compat compile with current GCCMatthew Wilcox
GCC no longer allows a cast as lvalue; fix the same way fs/readdir.c was Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-03[PATCH] VFS: Make filldir_t and struct kstat deal in 64-bit inode numbersDavid Howells
These patches make the kernel pass 64-bit inode numbers internally when communicating to userspace, even on a 32-bit system. They are required because some filesystems have intrinsic 64-bit inode numbers: NFS3+ and XFS for example. The 64-bit inode numbers are then propagated to userspace automatically where the arch supports it. Problems have been seen with userspace (eg: ld.so) using the 64-bit inode number returned by stat64() or getdents64() to differentiate files, and failing because the 64-bit inode number space was compressed to 32-bits, and so overlaps occur. This patch: Make filldir_t take a 64-bit inode number and struct kstat carry a 64-bit inode number so that 64-bit inode numbers can be passed back to userspace. The stat functions then returns the full 64-bit inode number where available and where possible. If it is not possible to represent the inode number supplied by the filesystem in the field provided by userspace, then error EOVERFLOW will be issued. Similarly, the getdents/readdir functions now pass the full 64-bit inode number to userspace where possible, returning EOVERFLOW instead when a directory entry is encountered that can't be properly represented. Note that this means that some inodes will not be stat'able on a 32-bit system with old libraries where they were before - but it does mean that there will be no ambiguity over what a 32-bit inode number refers to. Note similarly that directory scans may be cut short with an error on a 32-bit system with old libraries where the scan would work before for the same reasons. It is judged unlikely that this situation will occur because modern glibc uses 64-bit capable versions of stat and getdents class functions exclusively, and that older systems are unlikely to encounter unrepresentable inode numbers anyway. [akpm: alpha build fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: switch to using uts namespacesSerge E. Hallyn
Replace references to system_utsname to the per-process uts namespace where appropriate. This includes things like uname. Changes: Per Eric Biederman's comments, use the per-process uts namespace for ELF_PLATFORM, sunrpc, and parts of net/ipv4/ipconfig.c [jdike@addtoit.com: UML fix] [clg@fr.ibm.com: cleanup] [akpm@osdl.org: build fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] sys_hpux: fix strlen_user() raceKyle McMartin
Userspace can alter the string after the kernel has run strlen_user(). Also: the strlen_user() return value includes the \0, so fix that. Also: handle EFAULT from strlen_user(). It's unlikely anyone is using this code. Very, very unlikely. If I remember correctly, CONFIG_HPUX turns this code on, but one would actually need CONFIG_BINFMT_SOM to load a binary that could cause a problem, and BINFMT_SOM has had an #error in it for quite some time. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-22[PARISC] Add CONFIG_DEBUG_RODATA to protect read-only dataHelge Deller
Add the parisc version of the "mark rodata section read only" patches. Based on code from and Signed-off-by Arjan van de Ven <arjan@infradead.org>, Ingo Molnar <mingo@elte.hu>, Andi Kleen <ak@muc.de>, Andrew Morton <akpm@osdl.org>, Linus Torvalds <torvalds@osdl.org>. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-11[PATCH] capable/capability.h (arch/)Randy Dunlap
arch: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09kbuild: m68k,parisc,ppc,ppc64,s390,xtensa use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted parts form arch makefiles and rename to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
