path: root/arch/mips
2008-05-12[MIPS] Pb1000: bury the remnants of the PCI codeSergei Shtylyov
Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Fix build failure in mips oprofile codeThiemo Seufer
This patch fixes a warning-as-error induced build failure of 64bit MIPS kernels. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] fix warning message on SMP kernelsThiemo Seufer
This patch fixes a (harmless) warning message. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] markeins: build fixAdrian Bunk
This patch fixes the following build errror caused by commit 7dffa3c673fbcf835cd7be80bb4aec8ad3f51168 (ntp: handle leap second via timer): <-- snip --> ... CC arch/mips/emma2rh/markeins/setup.o /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/mips/emma2rh/markeins/setup.c:79: error: conflicting types for 'clock' /home/bunk/linux/kernel-2.6/git/linux-2.6/include/linux/clocksource.h:96: error: previous declaration of 'clock' was here make[2]: *** [arch/mips/emma2rh/markeins/setup.o] Error 1 <-- snip --> [Ralf: reformated to 80 colums after the fix and marked emma2rh_clock as __initdata] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] ELF handling - use SELFMAG instead of numeric constantCyrill Gorcunov
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] XXS1500 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - remove needless parentheses; - remove unneeded numeric literal type cast; - insert spaces between operator and its operands; - remove excess new lines; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the structure initializer; - fix typos, capitalize acronyms, etc. in the comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] MTX-1 code style cleanupSergei Shtylyov
Fix many errors and warnings given by checkpatch.pl: - space after opening and before closing parentheses; - use of C99 // comments; - leading spaces instead of tabs; - brace not on the same line with 'else' in the 'if' statement; statement; - printk() without KERN_* facility level; - using simple_strtol() where strict_strtol() could be used. - including <asm/gpio.h> instead of <linux/gpio.h>. In addition to these changes, also do the following: - insert spaces between operator and its operands; - replace tab between the function type and name with space in mtx1_pci_idsel() declaration; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array/structure initializers; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1200/DBAu1200 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - initialization of a 'static' variable to 0; - space after opening and before closing parentheses; - missing space between 'for' and opening parenthesis; - macros with complex values not enclosed in parentheses; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used; - line over 80 characters. In addition to these changes, also do the following: - mention DBAu1200 board in the Makefile; - replace the group of #include/#ifdef directives by a single #include <au1xxx.h> since this header contains the needed stuff; - properly indent the blocks; - insert spaces between operator and its operands, remove excess spaces there; - remove needless parentheses and add some for clarity; - replace numeric literals/expressions with the matching macros; - remove space after the type cast's closing parenthesis; - reduce pb1200_setup_cascade() to the single 'return' statement; - reduce the number of printed empty lines in the so-called CPLD workaround; - remove #undef AU1X00_EXTERNAL_INT since that macro is not defined anywhere; - replace spaces after the macro name with tabs in the #define directives; - remove excess tabs after the macro name in the #define directives; - fix typo in the BCSR_RESETS_PWMR1mUX macro's name; - group all Pb1200 PCMCIA definitions together; - put the function's result type and name/parameters on the same line; - insert missing and remove excess new lines; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line and/or adding space/asterisk on their left side; - fix typos/errors, capitalize acronyms, etc. in the comments; - combine some comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1550 code style cleanupSergei Shtylyov
Fix a few errors and warnings given by checkpatch.pl: - macros with complex values not enclosed in parentheses; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - replace numeric literals with the matching macros; - properly indent the code and the array initializers; - insert spaces between operator and its operands, also remove excess spaces there; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array initializers; - replace spaces after the macro name with tabs in the #define directives, also sometimes insert space there for better looks; - remove excess tabs after the macro name in the #define directives; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1500 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - replace numeric literals/expressions with the matching macros; - insert spaces between operator and its operands; - properly indent the code and the array initializers; - remove useless #if dirctive from board_setup(); - remove needless parentheses; - remove unneeded type casts; - remove excess new lines; - make hexadecimal literals all lower case; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array initializers; - replace spaces after the macro name with tabs in the #define directives, also sometimes insert space there for better looks; - fix typos/errors, capitalize acronyms, etc. in the comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1100 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - space between asterisk and variable name; - use of C99 // comments; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - properly indent the code; - remove space after the type cast's closing parenthesis; - replace numeric literals/expressions with the matching macros; - replace spaces after the macro name with tabs in the #define directives, and sometimes insert spaces there; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1000 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - brace not on the same line with condition in the 'switch' statement; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - properly indent the 'switch' statement; - remove needless parentheses; - insert spaces between operator and its operands; - replace numeric literals/expressions with the matching macros; - remove useless #if dirctive from board_setup(); - remove unneeded numeric literal type casts; - remove space after the type cast's closing parenthesis; - replace spaces after the macro name with tabs in the #define directives, and sometimes insert spaces there; - remove excess new lines; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first/last line; - combine some comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] DBAu1xx0 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - macros with complex values not enclosed in parentheses; - leading spaces instead of tabs; - printk() without KERN_* facility level; - using simple_strtol() where strict_strtol() could be used; - line over 80 characters. In addition to these changes, also do the following: - initialize variable instead of assigning value later where it makes sense; - insert spaces between operator and its operands, also remove excess spaces there; - remove unneeded numeric literal type casts; - remove needless parentheses; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array initializers; - replace spaces after the macro name with tabs in the #define directives; - remove excess tabs after the macro name in the #define directives; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first/last line; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Alchemy PCI code style cleanupSergei Shtylyov
Fix 15 errors and 4 warnings given by checkpatch.pl: - space between the asterisk and variable name; - space after opening and before closing parentheses; - leading spaces instead of tabs; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - line over 80 characters. In addition to these changes, also do the following: - combine the nested 'if' statements into one when possible; - remove needless parentheses; - add missing and remove excess spaces between operator and its operands; - fix printk() format specifiers mismatching the argument types; - put the function's result type and name/parameters on the same line; - insert missing and remove excess new lines; - properly indent multi-line expressions; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line; - fix typos, capitalize acronyms, etc. in the comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Alchemy common code style cleanupSergei Shtylyov
Fix many errors and warnings given by checkpatch.pl: - use of C99 // comments; - missing space between the type and asterisk in a variable declaration; - space between the asterisk and function/variable name; - leading spaces instead of tabs; - space after opening and before closing parentheses; - initialization of a 'static' variable to 0; - missing spaces around assignement/comparison operator; - brace not on the same line with condition (or 'else') in the 'if'/'switch' statement; - missing space between 'if'/'for'/'while' and opening parenthesis; - use of assignement in 'if' statement's condition; - printk() without KERN_* facility level; - EXPORT_SYMBOL() not following its function immediately; - unnecessary braces for single-statement block; - adding new 'typedef' (where including <linux/types.h> will do); - use of 'extern' in the .c file (where it can be avoided by including header); - line over 80 characters. In addition to these changes, also do the following: - insert missing space after opening brace and/or before closing brace in the structure initializers; - insert spaces between operator and its operands; - put the function's result type and name/parameters on the same line; - properly indent multi-line expressions; - remove commented out code; - remove useless initializers and code; - remove needless parentheses; - fix broken/excess indentation; - add missing spaces between operator and its operands; - insert missing and remove excess new lines; - group 'else' and 'if' together where possible; - make au1xxx_platform_init() 'static'; - regroup variable declarations in pm_do_freq() for prettier look; - replace numeric literals with the matching macros; - fix printk() format specifiers mismatching the argument types; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line and/or adding space on their left side; - make two-line comments that only have one line of text one-line; - fix typos/errors, capitalize acronyms, etc. in the comments; - fix/remove obsolete references in the comments; - reformat some comments; - add comment about the CPU:counter clock ratio to calc_clock(); - update MontaVista copyright; - remove Pete Popov's and Steve Longerbeam's old email addresses... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Add empty argument parenthesis to GCC_IMM_ASMRalf Baechle
This is to clarify that GCC_IMM_ASM does not take an argument as the context of the macro's invocation seems to imply. As suggested by Maciej W. Rozycki (macro@linux-mips.org). Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] msp_hwbutton.c: minor irq handler cleanupsJeff Garzik
- remove always-true test - neaten request_irq() indentation This change's main purpose is to prepare for the patchset in jgarzik/misc-2.6.git#irq-remove, that explores removal of the never-used 'irq' argument in each interrupt handler. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] unexport __kmap_atomic_to_pageAdrian Bunk
This patch removes the no longer used export of __kmap_atomic_to_page. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Initialize max_pfn again.Ralf Baechle
This was dropped by commit a0d9e2d891e4cf54676c430da63bd4a17d1cdb80 (lmo) commit b6f1f0dea1469e0c956eb89399916d60dd2a3808 (ko) Author: Franck Bui-Huu <vagabon.xyz@gmail.com> Date: Fri Aug 11 17:51:48 2006 +0200 Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] IRIX: Handle do_brk() error return correctly.Ralf Baechle
do_brk's return value was stored in an unsigned long variable before being tested for less than zero making the test always fail. Also do_brk's called irix_map_prda_page wasn't forwarding do_brk() success. Bug checking the return value of do_brk() and initial fix for it found by Roel Kluin <12o3l@tiscali.nl>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] MT: Functional fixes and a little reformatting of APRP supportKevin D. Kissell
Signed-off-by: Kevin D. Kissell <kevink@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Don't use max_pfn which is no longer initialized these days.Ralf Baechle
Still won't play nicely with esotheric configurations such as discontig memory ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] ip27-timer: fix unsigned irq < 0Roel Kluin
Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Acked-By: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Fixes necessary for non-SMP kernels and non-relocatable binariesKevin D. Kissell
2008-05-12[MIPS] Alchemy: SMBus resource fixSergei Shtylyov
The Alchemy platform code registers the SMBus device using the virtual address of its registers instead of the physical one -- fix this, taking into account that actually the whole megabyte is decoded by any of the programmable serial controllers (one of which is SMBus), and that all the Alchemy peripherals are directly mappable into KSEG1 kernel space and therefore ioremap() call would just boil down to CKSEG1ADDR() invocation. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: [PATCH] fix sysctl_nr_open bugs [PATCH] sanitize anon_inode_getfd() [PATCH] split linux/file.h [PATCH] make osf_select() use core_sys_select() [PATCH] remove horrors with irix tty ioctls handling [PATCH] fix file and descriptor handling in perfmon
2008-05-01[PATCH] split linux/file.hAl Viro
Initial splitoff of the low-level stuff; taken to fdtable.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-01[PATCH] remove horrors with irix tty ioctls handlingAl Viro
Existing code in there (get_tty(), etc.) is both severely racy *and* pointless: ioctls in question have Linux equivalents and there's no need to play silly buggers in irix_ioctl() - just need to replace arguments and, in case of TIOCGSID, deal with API differences - Linux one expects pid_t __user * while Irix one does unsigned long __user *. BFD... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-01remove div_long_long_remRoman Zippel
x86 is the only arch right now, which provides an optimized for div_long_long_rem and it has the downside that one has to be very careful that the divide doesn't overflow. The API is a little akward, as the arguments for the unsigned divide are signed. The signed version also doesn't handle a negative divisor and produces worse code on 64bit archs. There is little incentive to keep this API alive, so this converts the few users to the new API. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits) ACPI: Fix acpi_processor_idle and idle= boot parameters interaction acpi: fix section mismatch warning in pnpacpi intel_menlo: fix build warning ACPI: Cleanup: Remove unneeded, multiple local dummy variables ACPI: video - fix permissions on some proc entries ACPI: video - properly handle errors when registering proc elements ACPI: video - do not store invalid entries in attached_array list ACPI: re-name acpi_pm_ops to acpi_suspend_ops ACER_WMI/ASUS_LAPTOP: fix build bug thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed ACPI: check a return value correctly in acpi_power_get_context() #if 0 acpi/bay.c:eject_removable_drive() eeepc-laptop: add hwmon fan control eeepc-laptop: add backlight eeepc-laptop: add base driver ACPI: thinkpad-acpi: bump up version to 0.20 ACPI: thinkpad-acpi: fix selects in Kconfig ACPI: thinkpad-acpi: use a private workqueue ACPI: thinkpad-acpi: fluff really minor fix ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation ... Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c manually.
2008-04-30Merge branches 'release', 'acpica', 'bugzilla-10224', 'bugzilla-9772', ↵Len Brown
'bugzilla-9916', 'ec', 'eeepc', 'idle', 'misc', 'pm-legacy', 'sysfs-links-2.6.26', 'thermal', 'thinkpad' and 'video' into release
2008-04-29mips: use kbuild.h instead of macros in asm-offsets.cChristoph Lameter
Use the macros provided in kbuild.h Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: switch /proc/excite/unit_id to seq_file interfaceAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Thomas Koeller <thomas.koeller@baslerweb.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root from driversAlexey Dobriyan
Remove proc_root export. Creation and removal works well if parent PDE is supplied as NULL -- it worked always that way. So, one useless export removed and consistency added, some drivers created PDEs with &proc_root as parent but removed them as NULL and so on. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proper extern for late_time_initAdrian Bunk
Add a proper extern for late_time_init in include/linux/init.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29iomap: fix 64 bits resources on 32 bitsBenjamin Herrenschmidt
Almost all implementations of pci_iomap() in the kernel, including the generic lib/iomap.c one, copies the content of a struct resource into unsigned long's which will break on 32 bits platforms with 64 bits resources. This fixes all definitions of pci_iomap() to use resource_size_t. I also "fixed" the 64bits arch for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (45 commits) [MIPS] Pb1200/DBAu1200: move platform code to its proper place [MIPS] Fix handling of trap and breakpoint instructions [MIPS] Pb1200: do register SMC 91C111 [MIPS] DBAu1200: fix bad SMC 91C111 resource size [NET] Kconfig: Rename MIKROTIK_RB500 -> MIKROTIK_RB532 [MIPS] IP27: Fix build bug due to missing include [MIPS] Fix some sparse warnings on traps.c and irq-msc01.c [MIPS] cevt-gt641xx: Kill unnecessary include [MIPS] DS1287: Add clockevent driver [MIPS] add DECstation I/O ASIC clocksource [MIPS] rbtx4938: minor cleanup [MIPS] Alchemy: kill unused PCI_IRQ_TABLE_LOOKUP macro [MIPS] rbtx4938: misc cleanups [MIPS] jmr3927: use generic txx9 gpio [MIPS] rbhma4500: use generic txx9 gpio [MIPS] generic txx9 gpio support [MIPS] make fallback gpio.h gpiolib-friendly [MIPS] unexport null_perf_irq() and make it static [MIPS] unexport rtc_mips_set_time() [MIPS] unexport copy_from_user_page() ...
2008-04-28[MIPS] Pb1200/DBAu1200: move platform code to its proper placeSergei Shtylyov
Since both the IDE interface and SMC 91C111 Ethernet chip are on-board devices, not SOC devices, move the platform device registration form the common to the board specific code. While at it, remove semicolon (which didn't break compilation only by chance) from the AU1XXX_ATA_DDMA_REQ macro and do some renaming: - change 'au1200_ide0_' variable name prefix to the mere 'ide_'; - change 'smc91x_' variable name prefix to 'smc91c111_' since that's the name of the chip used on the boards; - drop 'AU1XXX_' prefix from the names of macros describing IDE and Ethernet on-board devices; - change 'SMC91111_' to 'SMC91C111_', change 'IRQ' to 'INT' in the names of the macros describing the Ethernet chip for consistency with the IDE macros; - change 'ATA_' to 'IDE_' and 'OFFSET' to 'SHIFT' (since this value is indeed a shift count) in the names of the macros describing the IDE interface. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Fix handling of trap and breakpoint instructionsRalf Baechle
With fixes and cleanups from Atsushi Nemoto (anemo@mba.ocn.ne.jp). Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Pb1200: do register SMC 91C111Sergei Shtylyov
Pb1200 does have SMC 91C111 Ethernet chip on board but the platform code did not register it, so one couldn't mount NFS... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] DBAu1200: fix bad SMC 91C111 resource sizeSergei Shtylyov
The on-board SMC 91C111 chip only decodes 16 bytes of memory (obviously, it can not decode a whole megabyte starting from address 0x19000300). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Fix some sparse warnings on traps.c and irq-msc01.cAtsushi Nemoto
* Declare board_bind_eic_interrupt, board_watchpoint_handler in traps.h * Make msc_bind_eic_interrupt static and fix its argument types. * Make msc_levelirq_type, msc_edgeirq_type static. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] cevt-gt641xx: Kill unnecessary includeAtsushi Nemoto
2008-04-28[MIPS] DS1287: Add clockevent driverYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] add DECstation I/O ASIC clocksourceYoichi Yuasa
Add DECstation I/O ASIC clocksource Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] rbtx4938: minor cleanupAtsushi Nemoto
Do not initialize res->parent for platform device. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] rbtx4938: misc cleanupsAtsushi Nemoto
* Do not use non-standard I/O accessors, such as reg_rd08, etc. * Kill unnecessary wbflush() * Kill tx4938_mips.h * Kill unnecessary includes Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] jmr3927: use generic txx9 gpioAtsushi Nemoto
Use generic txx9 gpio (and gpiolib) for JMR3927 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] rbhma4500: use generic txx9 gpioAtsushi Nemoto
Use generic txx9 gpio (and gpiolib) for RBHMA4500 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] generic txx9 gpio supportAtsushi Nemoto
This is a board-independent TXx9 gpio API implementation using gpiolib. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
