Commit 312b1485fb509c9bc32eda28ad29537896658cb8 made __INIT_REFOK expand
into .section .section ".ref.text", "ax". Since the assembler doesn't
tolerate stuttering in the source that broke all MIPS builds.
Since with this change Sam downgraded __INIT_REFOK the best fix is to
get replace it by the modern days operator. With MIPS the only user
of __INIT_REFOK and __INITDATA_REFOK (which was equally broken) being
unused anyway these can be deleted but that's subject of a separate
commit.
The break_lock data structure and code for spinlocks is quite nasty.
Not only does it double the size of a spinlock but it changes locking to
a potentially less optimal trylock.
Put all of that under CONFIG_GENERIC_LOCKBREAK, and introduce a
__raw_spin_is_contended that uses the lock data itself to determine whether
there are waiters on the lock, to be used if CONFIG_GENERIC_LOCKBREAK is
not set.
Rename need_lockbreak to spin_needbreak, make it use spin_is_contended to
decouple it from the spinlock implementation, and make it typesafe (rwlocks
do not have any need_lockbreak sites -- why do they even get bloated up
with that break_lock then?).
Signed-off-by: Nick Piggin <npiggin@suse.de>
The timer code always calls the clock_event_device set_net_event and
set_mode methods with interrupts disabled, so no need to use
spin_lock_irqsave / spin_unlock_irqrestore for those.
Acked-by:Thomas Gleixner <tglx@linutronix.de>
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (68 commits)
[MIPS] remove Documentation/mips/GT64120.README
[MIPS] Malta: remaining bits of the board support code cleanup
[MIPS] Malta: make the helper function static
[MIPS] Malta: fix braces at single statement blocks
[MIPS] Malta, Atlas: move an extern function declaration to the header file
[MIPS] Malta: Use C89 style for comments
[MIPS] Malta: else should follow close brace in malta_int.c
[MIPS] Malta: remove a superfluous comment
[MIPS] Malta: include <linux/cpu.h> instead of <asm/cpu.h>
[MIPS] Malta, Atlas, Sead: remove an extern from .c files
[MIPS] Malta: fix oversized lines in malta_int.c
[MIPS] Malta: remove a dead function declaration
[MIPS] Malta: use tabs not spaces
[MIPS] Malta: set up the screen info in a separate function
[MIPS] Malta: check the PCI clock frequency in a separate function
[MIPS] Malta: use the KERN_ facility level in printk()
[MIPS] Malta: use Linux kernel style for structure initialization
[MIPS]: constify function pointer tables
[MIPS] compat: handle argument endianess of sys32_(f)truncate64 with merge_64
[MIPS] Cobalt 64-bits kernels can be safely unmarked experimental
This patch factors out the code, which handles the Bonito system
controller. The case of not supporting the DMA coherency is handled
separately to make the logic obvious. Besides, a couple of empty
lines added to beautify the code even further.
No functional changes introduced.
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com>
One helper function can become static. This patch adds the needed
keyword.
This patch fixes a couple of warnings reported by checkpatch.pl.
This was compile-tested using default configs for the boards
affected by this change.
This patch does not introduce any functional changes.
Remove comments in C99 style and make checkpatch.pl happy.
This patch fixes two errors reported by checkpatch.pl.
Using the "We die here" comment right before calling the die()
function is an extremely vivid example of overcommenting.
Remove the redundant comment and save one line.
The checkpatch.pl script reported a few warnings about header files.
This patch fixes these warnings.
Compile-tested using the default Malta config.
This patch moves the "extern" declaration for the function
mips_reboot_setup() from the board setup .c files to the
header file include/asm-mips/mips-boards/generic.h.
This fixes a warning produced by the checkpatch.pl script.
This was compile-tested by building the kernel for all
three boards affected by this change. All builds finished
successfully.
This patch fixes all "line over 80 characters" warnings found
in arch/mips/mips-boards/malta/malta_int.c by the checkpatch.pl
script.
Neither is the mips_rtc_get_time() routine defined anywhere in
the MIPS architecture-specific code, nor does anyone call it any
more. This patch removes the extern declaration of this fossil.
This patch fixes all "use tabs not spaces" warnings reported by
the checkpatch.pl script on the board-specific files.
This patch adds a separate short and sweet function to initialize
the screen_info global variable.
This improves readability of the Malta board setup code.
This patch adds a separate short and sweet function to check the
PCI clock frequency. This is to improve readability of the Malta
setup code.
Along the way, a couple of coding style violations are fixed.
This patch adds the KERN_ macros to printk() calls. Where applicable,
spaces are replaced by tabs.
These changes noticeably reduce the number of errors and warnings
reported by the checkpatch.pl script for the malta_int.c file.
Before the patch: total: 47 errors, 20 warnings, 354 lines checked
After the patch: total: 34 errors, 7 warnings, 355 lines checked
This patch reformats the structure initialization code thus
making the latter look idiomatic.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
64-bits Cobalt kernels run fine.
Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu>
The Qemu platform was originally implemented to have an easily supportable
platform until Qemu reaches a state where it emulates a real world system.
Since the latest release Qemu is capable of emulating the MIPSsim and
Malta platforms, so this goal has been reached. The Qemu plaform is also
rather underfeatured so less useful than a Malta emulation.
Signed-off-by: Vitaly Wool <vitalywool@gmail.com>
I also changed the name to pvc_mutex, and moved the define to the file
it's used in which allows it to be static.
Signed-off-by: Daniel Walker <dwalker@mvista.com>
This patch adds support for the GPIO connected system button on the MTX-1
boards. Default configuration is updated accordingly.
Moved the eXcite local config to excite directory.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Added cpu_wait() to machine_halt().
For the power reduction in halt.
Removed unneeded button check for reset.
Because, the Cobalt has power switch.
Moved vr41xx_calculate_clock_frequency() to plat_time_init().
This function relates to the timer function.
A raw binary boots about twice as fast as SREC.
The possibility to generate SREC binaries remains by simply using the
vmlinux.srec target but seems only useful for the probably hypothetical
case where one of these systems is booted over a serial interface.
The latest draft version of the MIPS Architecture Specification extends the
6 bit event field by adding a directly adjacent 4-bit EventExt field for a
total of 10 bits.
- EISA support for non PCI RMs (RM200 and RM400-xxx). The major part
is the splitting of the EISA and onboard ISA of the RM200, which
makes the EISA bus on the RM200 look like on other RMs.
- 64bit kernel support
- system type detection is now common for big and little endian
- moved sniprom code to arch/mips/fw
- added call_o32 function to arch/mips/fw/lib, which uses a private
stack for calling prom functions
- fix problem with ISA interrupts, which makes using PIT clockevent
possible
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
This patch adds IDs for new Au1200 variants: Au1210 and Au1250.
They are essentially identical to the Au1200 except for the Au1210
which has a different SoC-ID in the PRId register [bits 31:24].
The Au1250 is a "Au1200 V0.2".
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
These symbols appear in oprofile output, stacktraces and similar but only
make the output harder to read. Many identical symbol names such as
"both_aligned" were also being used in multiple source files making it
impossible to see which file actually was meant. So let's get rid of them.
Add support for SGI IP28 machines (Indigo 2 with R10k CPUs)
This work is mainly based on Peter Fuersts work.
According to Broadcom the PT systems are production test systems which
never reached customers so no need to keep the fragmentary support we
currently have.
Not cache coherent R10k systems (like IP28) need to do real cache
invalidates in dma_cache_sync().
IP28 needs special treatment to avoid speculative accesses. gcc
takes care for .c code, but for assembly code we need to do it
manually.
This is taken from Peter Fuersts IP28 patches.
This patch adds support for txx9wdt driver to rbhma3100, rbhma4200 and
rbhma4500 platform.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
R10k non coherent machines need a real dma cache invalidate to get rid of
speculative stores in cache. For other machines this promises a slight
speedup.
Move registration into the actual platform code instead of making a
desparate attempt at sharing the hand full of likes of code in pcspeaker.c.
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com>
