path: root/arch/mips/txx9
2013-09-03MIPS: TXx9: Fix build error if CONFIG_TOSHIBA_JMR3927 is not selectedMarkos Chandras
The jmr3927_vec txx9_board_vec struct is defined in txx9/jmr3927/setup.c which is only built if CONFIG_TOSHIBA_JMR3927 is selected. This patch fixes the following build problem: arch/mips/txx9/generic/setup.c: In function 'select_board': arch/mips/txx9/generic/setup.c:354:20: error: 'jmr3927_vec' undeclared (first use in this function) arch/mips/txx9/generic/setup.c:354:20: note: each undeclared identifier is reported only once for each function it appears in make[3]: *** [arch/mips/txx9/generic/setup.o] Error 1 Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Acked-by: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5713/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-05-28net: pass info struct via netdevice notifierJiri Pirko
So far, only net_device * could be passed along with netdevice notifier event. This patch provides a possibility to pass custom structure able to provide info that event listener needs to know. Signed-off-by: Jiri Pirko <jiri@resnulli.us> v2->v3: fix typo on simeth shortened dev_getter shortened notifier_info struct name v1->v2: fix notifier_call parameter in call_netdevice_notifier() Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-22MIPS: Idle: Consolidate all declarations in <asm/idle.h>.Ralf Baechle
2013-03-20mips: txx9: change GENERIC_GPIO to GPIOLIBAlexandre Courbot
The GPIO driver for txx9 requires gpiolib, so this is more accurate and let us get rid of one mention of GENERIC_GPIO which is due to disappear. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-21Merge branch 'mips-next-3.9' of ↵Ralf Baechle
git://git.linux-mips.org/pub/scm/john/linux-john into mips-for-linux-next
2013-02-19MIPS: early_printk: drop __init annotationsAaro Koskinen
We cannot use __init for earlyprintk code or data, since the kernel parameter "keep_bootcon" allows leaving the boot console enabled. Currently MIPS will crash/hang/die if you use keep_bootcon. The patch fixes it at least on Lemote FuLoong mini-PC. Changes for other boards were done based on what I could find with grep... Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Patchwork: http://patchwork.linux-mips.org/patch/4935/ Signed-off-by: John Crispin <blogic@openwrt.org>
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-01-03MIPS: drivers: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-19treewide: fix typo of "suport" in various comments and KconfigMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-08-01MIPS: txx9: Fix redefinition of clk_* by adding select HAVE_CLKYoichi Yuasa
arch/mips/txx9/generic/setup.c:87:13: error: redefinition of 'clk_get' include/linux/clk.h:281:27: note: previous definition of 'clk_get' was here arch/mips/txx9/generic/setup.c:97:5: error: redefinition of 'clk_enable' include/linux/clk.h:295:19: note: previous definition of 'clk_enable' was here arch/mips/txx9/generic/setup.c:103:6: error: redefinition of 'clk_disable' include/linux/clk.h:300:20: note: previous definition of 'clk_disable' was here arch/mips/txx9/generic/setup.c:108:15: error: redefinition of 'clk_get_rate' include/linux/clk.h:302:29: note: previous definition of 'clk_get_rate' was here arch/mips/txx9/generic/setup.c:114:6: error: redefinition of 'clk_put' include/linux/clk.h:291:20: note: previous definition of 'clk_put' was here make[3]: *** [arch/mips/txx9/generic/setup.o] Error 1 Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips@linux-mips.org Reviewed-by: John Crispin <blogic@openwrt.org> Patchwork: https://patchwork.linux-mips.org/patch/4142/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-07-30Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "More hardware support across the field including a bunch of device drivers. The highlight however really are further steps towards device tree. This has been sitting in -next for ages. All MIPS _defconfigs have been tested to boot or where I don't have hardware available, to at least build fine." * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (77 commits) MIPS: Loongson 1B: Add defconfig MIPS: Loongson 1B: Add board support MIPS: Netlogic: early console fix MIPS: Netlogic: Fix indentation of smpboot.S MIPS: Netlogic: remove cpu_has_dc_aliases define for XLP MIPS: Netlogic: Remove unused pcibios_fixups MIPS: Netlogic: Add XLP SoC devices in FDT MIPS: Netlogic: Add IRQ mappings for more devices MIPS: Netlogic: USB support for XLP MIPS: Netlogic: XLP PCIe controller support. MIPS: Netlogic: Platform changes for XLR/XLS I2C MIPS: Netlogic: Platform NAND/NOR flash support MIPS: Netlogic: Platform changes for XLS USB MIPS: Netlogic: Remove NETLOGIC_ prefix MIPS: Netlogic: SMP wakeup code update MIPS: Netlogic: Update comments in smpboot.S MIPS: BCM63XX: Add 96328avng reference board MIPS: Expose PCIe drivers for MIPS MIPS: BCM63XX: Add PCIe Support for BCM6328 MIPS: BCM63XX: Move the PCI initialization into its own function ...
2012-07-23MIPS: PCI: Add missing __devinit attributions to fixup functions.Ralf Baechle
2012-07-23MIPS: TXX9: use IS_ENABLED() macroFlorian Fainelli
Signed-off-by: Florian Fainelli <florian@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3334/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-07-19MIPS: PCI: Move fixups from __init to __devinit.Sebastian Andrzej Siewior
Fixups are executed once the pci-device is found which is during boot process so __init seems fine as long as the platform does not support hotplug. However it is possible to remove the PCI bus at run time and have it rediscovered again via "echo 1 > /sys/bus/pci/rescan" and this will call the fixups again. [ralf@linux-mips.org: Made piixirqmap[] in malta_piix_func0_fixup() __initdata.] Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: linux-mips@linux-mips.org Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-07-09Merge branch 'pci/myron-final-fixups-v2' into nextBjorn Helgaas
* pci/myron-final-fixups-v2: PCI: call final fixups hot-added devices PCI: move final fixups from __init to __devinit x86/PCI: move final fixups from __init to __devinit MIPS/PCI: move final fixups from __init to __devinit PCI: never discard enable/suspend/resume_early/resume fixups PCI: release temporary reference in __nv_msi_ht_cap_quirk() PCI: restructure 'pci_do_fixups()'
2012-07-09MIPS/PCI: move final fixups from __init to __devinitMyron Stowe
Final fixups are executed during device enumeration. If we support hotplug, this may be after boot, so final fixups cannot be __init. [bhelgaas: changelog] Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-07-05MIPS/PCI: adjust section annotations for pcibios_setup()Myron Stowe
Make pcibios_setup() consistently use the "__init" section annotation. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-20MIPS: txx9 7segled fix struct device has no memberYoichi Yuasa
arch/mips/txx9/generic/7segled.c: In function 'tx_7segled_init_sysfs': arch/mips/txx9/generic/7segled.c:105:6: error: 'struct device' has no member named 'dev' make[3]: *** [arch/mips/txx9/generic/7segled.o] Error 1 Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/3250/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-01-14Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (119 commits) MIPS: Delete unused function add_temporary_entry. MIPS: Set default pci cache line size. MIPS: Flush huge TLB MIPS: Octeon: Remove SYS_SUPPORTS_HIGHMEM. MIPS: Octeon: Add support for OCTEON II PCIe MIPS: Octeon: Update PCI Latency timer and enable more error reporting. MIPS: Alchemy: Update cpu-feature-overrides MIPS: Alchemy: db1200: Improve PB1200 detection. MIPS: Alchemy: merge Au1000 and Au1300-style IRQ controller code. MIPS: Alchemy: chain IRQ controllers to MIPS IRQ controller MIPS: Alchemy: irq: register pm at irq init time MIPS: Alchemy: Touchscreen support on DB1100 MIPS: Alchemy: Hook up IrDA on DB1000/DB1100 net/irda: convert au1k_ir to platform driver. MIPS: Alchemy: remove unused board headers MTD: nand: make au1550nd.c a platform_driver MIPS: Netlogic: Mark Netlogic chips as SMT capable MIPS: Netlogic: Add support for XLP 3XX cores MIPS: Netlogic: Merge some of XLR/XLP wakup code MIPS: Netlogic: Add default XLP config. ... Fix up trivial conflicts in arch/mips/kernel/{perf_event_mipsxx.c, traps.c} and drivers/tty/serial/Makefile
2011-12-21driver-core: remove sysdev.h usage.Kay Sievers
The sysdev.h file should not be needed by any in-kernel code, so remove the .h file from these random files that seem to still want to include it. The sysdev code will be going away soon, so this include needs to be removed no matter what. Cc: Jiandong Zheng <jdzheng@broadcom.com> Cc: Scott Branden <sbranden@broadcom.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: "Venkatesh Pallipadi Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2011-12-21mips: txx9_sram - convert sysdev_class to a regular subsystemKay Sievers
After all sysdev classes are ported to regular driver core entities, the sysdev implementation will be entirely removed from the kernel. Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21mips: 7segled - convert sysdev_class to a regular subsystemKay Sievers
After all sysdev classes are ported to regular driver core entities, the sysdev implementation will be entirely removed from the kernel. Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-07MIPS: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. [ralf@linux-mips.org: Fixed up conflicts in arch/mips/alchemy/common/dbdma.c, arch/mips/cavium-octeon/smp.c and arch/mips/kernel/perf_event.c.] Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> To: linux-kernel@vger.kernel.org Cc: tglx@linutronix.de linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2835/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-31mips: add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
Or else we get lots of variations on this: arch/mips/pci/pci.c:330: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' scattered throughout the build. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-15net: consolidate and fix ethtool_ops->get_settings callingJiri Pirko
This patch does several things: - introduces __ethtool_get_settings which is called from ethtool code and from drivers as well. Put ASSERT_RTNL there. - dev_ethtool_get_settings() is replaced by __ethtool_get_settings() - changes calling in drivers so rtnl locking is respected. In iboe_get_rate was previously ->get_settings() called unlocked. This fixes it. Also prb_calc_retire_blk_tmo() in af_packet.c had the same problem. Also fixed by calling __dev_get_by_index() instead of dev_get_by_index() and holding rtnl_lock for both calls. - introduces rtnl_lock in bnx2fc_vport_create() and fcoe_vport_create() so bnx2fc_if_create() and fcoe_if_create() are called locked as they are from other places. - use __ethtool_get_settings() in bonding code Signed-off-by: Jiri Pirko <jpirko@redhat.com> v2->v3: -removed dev_ethtool_get_settings() -added ASSERT_RTNL into __ethtool_get_settings() -prb_calc_retire_blk_tmo - use __dev_get_by_index() and lock around it and __ethtool_get_settings() call v1->v2: add missing export_symbol Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> [except FCoE bits] Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-27Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (97 commits) mtd: kill CONFIG_MTD_PARTITIONS mtd: remove add_mtd_partitions, add_mtd_device and friends mtd: convert remaining users to mtd_device_register() mtd: samsung onenand: convert to mtd_device_register() mtd: omap2 onenand: convert to mtd_device_register() mtd: txx9ndfmc: convert to mtd_device_register() mtd: tmio_nand: convert to mtd_device_register() mtd: socrates_nand: convert to mtd_device_register() mtd: sharpsl: convert to mtd_device_register() mtd: s3c2410 nand: convert to mtd_device_register() mtd: ppchameleonevb: convert to mtd_device_register() mtd: orion_nand: convert to mtd_device_register() mtd: omap2: convert to mtd_device_register() mtd: nomadik_nand: convert to mtd_device_register() mtd: ndfc: convert to mtd_device_register() mtd: mxc_nand: convert to mtd_device_register() mtd: mpc5121_nfc: convert to mtd_device_register() mtd: jz4740_nand: convert to mtd_device_register() mtd: h1910: convert to mtd_device_register() mtd: fsmc_nand: convert to mtd_device_register() ... Fixed up trivial conflicts in - drivers/mtd/maps/integrator-flash.c: removed in ARM tree - drivers/mtd/maps/physmap.c: addition of afs partition probe type clashing with removal of CONFIG_MTD_PARTITIONS
2011-05-25mips: tx99: remove CONFIG_MTD_PARTITIONS checkJamie Iles
CONFIG_MTD_PARTITIONS no longer exists as MTD partitioning is always enabled now. Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-04-29ethtool: Call ethtool's get/set_settings callbacks with cleaned dataDavid Decotigny
This makes sure that when a driver calls the ethtool's get/set_settings() callback of another driver, the data passed to it is clean. This guarantees that speed_hi will be zeroed correctly if the called callback doesn't explicitely set it: we are sure we don't get a corrupted speed from the underlying driver. We also take care of setting the cmd field appropriately (ETHTOOL_GSET/SSET). This applies to dev_ethtool_get_settings(), which now makes sure it sets up that ethtool command parameter correctly before passing it to drivers. This also means that whoever calls dev_ethtool_get_settings() does not have to clean the ethtool command parameter. This function also becomes an exported symbol instead of an inline. All drivers visible to make allyesconfig under x86_64 have been updated. Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-29MIPS: Convert the irq functions to the new namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25MIPS: TXx9: Convert to new irq_chip functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2207/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Use printf extension %pR for struct resourceJoe Perches
Using %pR standardizes the struct resource output. Signed-off-by: Joe Perches <joe@perches.com> To: Jiri Kosina <trivial@kernel.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1772/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-07MIPS: Add missing #inclusions of <linux/irq.h>David Howells
Add missing #inclusions of <linux/irq.h> to a whole bunch of files that should really include it. Note that this can replace #inclusions of <asm/irq.h>. This is required for the patch to sort out irqflags handling function naming to compile on MIPS. The problem is that these files require access to things like setup_irq() - which isn't available by #including <linux/interrupt.h> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: TXx9: Migrate to new platform makefile style.Ralf Baechle
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-14init dynamic bin_attribute structuresWolfram Sang
Commit 6992f5334995af474c2b58d010d08bc597f0f2fe ("sysfs: Use one lockdep class per sysfs attribute.") introduced this requirement. First, at25 was fixed manually. Then, other occurences were found with coccinelle and the following semantic patch. Results were reviewed and fixed up: @ init @ identifier struct_name, bin; @@ struct struct_name { ... struct bin_attribute bin; ... }; @ main extends init @ expression E; statement S; identifier name, err; @@ ( struct struct_name *name; | - struct struct_name *name = NULL; + struct struct_name *name; ) ... ( sysfs_bin_attr_init(&name->bin); | + sysfs_bin_attr_init(&name->bin); if (sysfs_create_bin_file(E, &name->bin)) S | + sysfs_bin_attr_init(&name->bin); err = sysfs_create_bin_file(E, &name->bin); ) Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-07sysdev: Pass attribute in sysdev_class attributes show/storeAndi Kleen
Passing the attribute to the low level IO functions allows all kinds of cleanups, by sharing low level IO code without requiring an own function for every piece of data. Also drivers can extend the attributes with own data fields and use that in the low level function. Similar to sysdev_attributes and normal attributes. This is a tree-wide sweep, converting everything in one go. No functional changes in this patch other than passing the new argument everywhere. Tested on x86, the non x86 parts are uncompiled. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-27MIPS: TXx9: Remove forced serial console settingYoichi Yuasa
It is not always used, even if it is available. Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/933/ Acked-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: TXx9: Cleanup builtin-cmdline processingAtsushi Nemoto
Since commit 898d357b5262f9e26bc2418e01f8676e80d9867e (lmo) / 6acc7d485c24c00e111c61b2e6dff9180faebcae (kernel.org) ("Fix and enhance built-in kernel command line") arcs_cmdline[] does not contain built-in command line. The commit introduce CONFIG_CMDLINE_BOOL and CONFIG_CMDLINE_OVERRIDE to control built-in command line, and now we can use them instead of platform-specific built-in command line processing. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Patchwork: http://patchwork.linux-mips.org/patch/802/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Replace all usages of CL_SIZE by COMMAND_LINE_SIZEDmitri Vorobiev
The MIPS-specific macro CL_SIZE is merely aliasing the macro COMMAND_LINE_SIZE. Other architectures use the latter; also, COMMAND_LINE_SIZE is documented in kernel-parameters.txt, so let's use it, and remove the alias. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-13MIPS: Make local arrays with CL_SIZE static __initdataAtsushi Nemoto
Since commit 22242681cff52bfb7cba5d2a37b91802be7a4e4c ("MIPS: Extend COMMAND_LINE_SIZE"), CL_SIZE is 4096 and local array variables with this size will cause an build failure with default CONFIG_FRAME_WARN settings. Although current users of such array variables are all early bootstrap code and not likely to cause real stack overflow (thread_info corruption), it is preferable to to declare these arrays static with __initdata. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-11-02MIPS: TXx9: Fix spi-baseclk valueAtsushi Nemoto
TXx9 SPI bit rate is calculated by: fBR = fSPI / 2 / (n + 1) (fSPI is SPI master clock freq, i.e. imbusclk freq.) So use imbus_clk / 2 as a spi-baseclk. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-11-02MIPS: TXx9: Fix error handling / Fix for noenexisting gpio_remove.Ralf Roesch
Error was introduced by commit 0385d1f3d394c6814be0b165c153fc3fc254469a. Signed-off-by: Ralf Roesch <ralf.roesch@rw-gmbh.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: TXx9: Fix error handling.Julia Lawall
Error handling code following a kzalloc should free the allocated data. Error handling code following an ioremap should iounmap the allocated data. The semantic match that finds the first problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; statement S; expression E; identifier f,f1,l; position p1,p2; expression *ptr != NULL; @@ x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...); ... if (x == NULL) S <... when != x when != if (...) { <+...x...+> } ( x->f1 = E | (x->f1 == NULL || ...) | f(...,x->f1,...) ) ...> ( return \(0\|<+...x...+>\|ptr\); | return@p2 ...; ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: TXx9: Disable PM capability of TX493[89] internal etherAtsushi Nemoto
Some TC35815 variants (i.e. TX493[89] internal ether) report existance of PM registers though they are not supported. Disable PM features by clearing pdev->pm_cap. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: RBTX4939: Fix IOC pin-enable register updatingAtsushi Nemoto
The rbtx4939_update_ioc_pen() expects txx9_ce_res[] already initialized. Call it after tx4939_setup(). Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: Eleminate filenames from commentsRalf Baechle
They tend to get not updated when files are moved around or copied and lack any obvious use. While at it zap some only too obvious comments and as per Shinya's suggestion, add a copyright header to extable.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Acked-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
