path: root/arch/mips/sni
2015-12-22MIPS: Fix build error due to unused variables.Ralf Baechle
c861519fcf95b2d46cb4275903423b43ae150a40 ("MIPS: Fix delay loops which may be removed by GCC.") which made it upstream was an outdated version of the patch and is lacking some the removal of two variables that became unused thus resulting in further warnings and build breakage. The commit from ae878615d7cee5d7346946cf1ae1b60e427013c2 was correct however. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-11-27MIPS: Fix delay loops which may be removed by GCC.Ralf Baechle
GCC 4.1 and newer remove empty loops. This becomes a problem when delay loops get removed. Fixed by rewriting to user the proper Linux interface for such delays. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reported-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: John Crispin <blogic@openwrt.org>
2015-09-03MIPS: sni: Migrate to new 'set-state' interfaceViresh Kumar
Migrate sni driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: linux-mips@linux-mips.org Cc: linaro-kernel@lists.linaro.org Cc: Thomas Gleixner <tglx@linutronix.de> Patchwork: https://patchwork.linux-mips.org/patch/10612/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-09-18MIPS: Cleanup CP0 PRId and CP1 FPIR register access masksMaciej W. Rozycki
Replace hardcoded CP0 PRId and CP1 FPIR register access masks throughout. The change does not touch places that use shifted or partial masks. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5838/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-07-31serial: sccnxp: Using CLK API for getting UART clockAlexander Shiyan
This patch removes "frequency" parameter from SCCNXP platform_data and uses CLK API for getting clock. If CLK ommited, default IC frequency will be used instead. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-25MIPS: SNI: pcit: Fix build error with CONFIG_PCI=n disabled.Ralf Baechle
CC arch/mips/sni/pcit.o arch/mips/sni/pcit.c:150:30: warning: ‘sni_pcit_controller’ defined but not used [-Wunused-variable] Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-06-25MIPS: SNI: pcimt: Guard sni_controller with CONFIG_PCIMarkos Chandras
Fixes the following build problem: arch/mips/sni/pcimt.c:188:30: error: 'sni_controller' defined but not used [-Werror=unused-variable] Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Acked-by: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5547/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-03-02Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: o Add basic support for the Mediatek/Ralink Wireless SoC family. o The Qualcomm Atheros platform is extended by support for the new QCA955X SoC series as well as a bunch of patches that get the code ready for OF support. o Lantiq and BCM47XX platform have a few improvements and bug fixes. o MIPS has sent a few patches that get the kernel ready for the upcoming microMIPS support. o The rest of the series is made up of small bug fixes and cleanups that relate to various parts of the MIPS code. The biggy in there is a whitespace cleanup. After I was sent another set of whitespace cleanup patches I decided it was the time to clean the whitespace "issues" for once and and that touches many files below arch/mips/. Fix up silly conflicts, mostly due to whitespace cleanups. * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (105 commits) MIPS: Quit exporting kernel internel break codes to uapi/asm/break.h MIPS: remove broken conditional inside vpe loader code MIPS: SMTC: fix implicit declaration of set_vi_handler MIPS: early_printk: drop __init annotations MIPS: Probe for and report hardware virtualization support. MIPS: ath79: add support for the Qualcomm Atheros AP136-010 board MIPS: ath79: add USB controller registration code for the QCA955X SoCs MIPS: ath79: add PCI controller registration code for the QCA955X SoCs MIPS: ath79: add WMAC registration code for the QCA955X SoCs MIPS: ath79: register UART for the QCA955X SoCs MIPS: ath79: add QCA955X specific glue to ath79_device_reset_{set, clear} MIPS: ath79: add GPIO setup code for the QCA955X SoCs MIPS: ath79: add IRQ handling code for the QCA955X SoCs MIPS: ath79: add clock setup code for the QCA955X SoCs MIPS: ath79: add SoC detection code for the QCA955X SoCs MIPS: ath79: add early printk support for the QCA955X SoCs MIPS: ath79: fix WMAC IRQ resource assignment mips: reserve elfcorehdr mips: Make sure kernel memory is in iomem MIPS: ath79: use dynamically allocated USB platform devices ...
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-01-15serial: sccnxp: Rename header file to match functionalityAlexander Shiyan
2013-01-03MIPS: drivers: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-13MIPS: Kconfig: Rename several firmware related config symbols.Ralf Baechle
With the upcoming merge of the ARC architecture there is a small likelyhood of conflicting use for the CONFIG_ARC config symbol. Rename it to CONFIG_FW_ARC. Also rename CONFIG_ARC32 to CONFIG_FW_ARC32, CONFIG_ARC64 to CONFIG_FW_ARC64. For consistence also rename CONFIG_SNIPROM to CONFIG_FW_SNIPROM and CONFIG_CFE to CONFIG_FW_CFE. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-10-11MIPS: SNI: Switch RM400 serial to SCCNXP driverThomas Bogendoerfer
The new SCCNXP driver supports the SC2681 chips used in RM400 machines. We now use the new driver instead of the old SC26xx driver. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/4417/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-09-05serial: Add note about migration to driver SCCNXPAlexander Shiyan
This patch adds note about migration to driver SCCNXP in the code of driver SC26XX and in MIPS SNI board initialization with example. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-29Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "The whole series has been sitting in -next for quite a while with no complaints. The last change to the series was before the weekend the removal of an SPI patch which Grant - even though previously acked by himself - appeared to raise objections. So I removed it until the situation is clarified. Other than that all the patches have the acks from their respective maintainers, all MIPS and x86 defconfigs are building fine and I'm not aware of any problems introduced by this series. Among the key features for this patch series is a sizable patchset for Lantiq which among other things introduces support for Lantiq's flagship product, the FALCON SOC. It also means that the opensource developers behind this patchset have overtaken Lantiq's competing inhouse development team that was working behind closed doors. Less noteworthy the ath79 patchset which adds support for a few more chip variants, cleanups and fixes. Finally the usual dose of tweaking of generic code." Fix up trivial conflicts in arch/mips/lantiq/xway/gpio_{ebu,stp}.c where printk spelling fixes clashed with file move and eventual removal of the printk. * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (81 commits) MIPS: lantiq: remove orphaned code MIPS: Remove all -Wall and almost all -Werror usage from arch/mips. MIPS: lantiq: implement support for FALCON soc MTD: MIPS: lantiq: verify that the NOR interface is available on falcon soc MTD: MIPS: lantiq: implement OF support watchdog: MIPS: lantiq: implement OF support and minor fixes SERIAL: MIPS: lantiq: implement OF support GPIO: MIPS: lantiq: convert gpio-stp-xway to OF GPIO: MIPS: lantiq: convert gpio-mm-lantiq to OF and of_mm_gpio GPIO: MIPS: lantiq: move gpio-stp and gpio-ebu to the subsystem folder MIPS: pci: convert lantiq driver to OF MIPS: lantiq: convert dma to platform driver MIPS: lantiq: implement support for clkdev api MIPS: lantiq: drop ltq_gpio_request() and gpio_to_irq() OF: MIPS: lantiq: implement irq_domain support OF: MIPS: lantiq: implement OF support MIPS: lantiq: drop mips_machine support OF: PCI: const usage needed by MIPS MIPS: Cavium: Remove smp_reserve_lock. MIPS: Move cache setup to setup_arch(). ...
2012-05-15MIPS: Fix several implicit uses of export.h/module.hPaul Gortmaker
These will show up as a build failure once we clean up a misuse of module.h in the mips termios header. Uses export.h: (EXPORT_SYMBOL) arch/mips/cavium-octeon/setup.c arch/mips/pmc-sierra/yosemite/setup.c arch/mips/rb532/devices.c arch/mips/sni/setup.c Uses module.h: (symbol_get/put) arch/mips/alchemy/devboards/db1200.c Uses module.h: (print_modules) arch/mips/kernel/traps.c Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3448/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-04-08Merge branch 'master' into for-nextJiri Kosina
Merge with latest Linus' tree, as I have incoming patches that fix code that is newer than current HEAD of for-next. Conflicts: drivers/net/ethernet/realtek/r8169.c
2012-04-05mips: Fix printk typos in arc/mipsMasanari Iida
Correct spelling "platfom" to "platform", "deactived" to "deactivated" and "deprectated" to "deprecated" in arch/mips directory. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-28Disintegrate asm/system.h for MIPSDavid Howells
Disintegrate asm/system.h for MIPS. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org
2011-12-07MIPS: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. [ralf@linux-mips.org: Fixed up conflicts in arch/mips/alchemy/common/dbdma.c, arch/mips/cavium-octeon/smp.c and arch/mips/kernel/perf_event.c.] Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> To: linux-kernel@vger.kernel.org Cc: tglx@linutronix.de linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2835/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-09-21MIPS: Mark cascade and low level interrupts IRQF_NO_THREADWu Zhangjin
Mark interrupts with no_action handler, cascade interrupts, low level interrupts (bus error, halt ..) with IRQF_NO_THREAD to exclude them from forced threading. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org Cc: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-06-09i8253: Create linux/i8253.h and use it in all 8253 related filesRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Link: http://lkml.kernel.org/r/20110601180610.054254048@duck.linux-mips.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de> arch/arm/mach-footbridge/isa-timer.c | 2 +- arch/mips/cobalt/time.c | 2 +- arch/mips/jazz/irq.c | 2 +- arch/mips/kernel/i8253.c | 2 +- arch/mips/mti-malta/malta-time.c | 2 +- arch/mips/sgi-ip22/ip22-time.c | 2 +- arch/mips/sni/time.c | 2 +- arch/x86/kernel/apic/apic.c | 2 +- arch/x86/kernel/apm_32.c | 2 +- arch/x86/kernel/hpet.c | 2 +- arch/x86/kernel/i8253.c | 2 +- arch/x86/kernel/time.c | 2 +- drivers/block/hd.c | 2 +- drivers/clocksource/i8253.c | 2 +- drivers/input/gameport/gameport.c | 2 +- drivers/input/joystick/analog.c | 2 +- drivers/input/misc/pcspkr.c | 2 +- include/linux/i8253.h | 11 +++++++++++ sound/drivers/pcsp/pcsp.h | 2 +- 19 files changed, 29 insertions(+), 18 deletions(-)
2011-05-10MIPS: SNI: Fix GCC 4.6.0 build errorRalf Baechle
CC arch/mips/sni/time.o arch/mips/sni/time.c: In function 'dosample': arch/mips/sni/time.c:98:19: error: variable 'lsb' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-29MIPS: Convert the irq functions to the new namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25MIPS: SNI: Convert to new irq_chip functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2206/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-07MIPS: Add missing #inclusions of <linux/irq.h>David Howells
Add missing #inclusions of <linux/irq.h> to a whole bunch of files that should really include it. Note that this can replace #inclusions of <asm/irq.h>. This is required for the patch to sort out irqflags handling function naming to compile on MIPS. The problem is that these files require access to things like setup_irq() - which isn't available by #including <linux/interrupt.h> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: SNI: Migrate to new platform makefile style.Ralf Baechle
2010-02-27MIPS: SNI: Convert sni_rm200_i8259A_lock to raw spinlock.Ralf Baechle
2010-02-27MIPS: Make various locks static.Ralf Baechle
2010-02-10MIPS: SNI: Correct NULL testJulia Lawall
Test the value that was just allocated rather than the previously tested one. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ expression *x; expression e; identifier l; @@ if (x == NULL || ...) { ... when forall return ...; } ... when != goto l; when != x = e when != &x *x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> To: linux-mips@linux-mips.org To: linux-kernel@vger.kernel.org To: kernel-janitors@vger.kernel.org Patchwork: http://patchwork.linux-mips.org/patch/945/ Acked-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Move several variables from .bss to .init.dataDmitri Vorobiev
Several static uninitialized variables are used in the scope of __init functions but are themselves not marked as __initdata. This patch is to put those variables to where they belong and to reduce the memory footprint a little bit. Also, a couple of lines with spaces instead of tabs were fixed. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/698/ Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Fixup last users of irq_chip->typename Thomas Gleixner
The typename member of struct irq_chip was kept for migration purposes and is obsolete since more than 2 years. Fix up the leftovers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org To: LKML <linux-kernel@vger.kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Patchwork: http://patchwork.linux-mips.org/patch/661/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-11-02MIPS: Add IRQF_TIMER flag for timer interruptsWu Zhangjin
Along the lines of d6c585a4342a2ff627a29f9aea77c5ed4cd76023, add IRQF_TIMER flag for all timer interrupts This ensures that timer interrupts won't be disabled on suspend and not threaded for PREEMPT_RT. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-15timekeeping: Increase granularity of read_persistent_clock()Martin Schwidefsky
The persistent clock of some architectures (e.g. s390) have a better granularity than seconds. To reduce the delta between the host clock and the guest clock in a virtualized system change the read_persistent_clock function to return a struct timespec. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134811.013873340@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-15mips: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Cc: linux-mips@linux-mips.org Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumaskLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask: oprofile: Thou shalt not call __exit functions from __init functions cpumask: remove the now-obsoleted pcibus_to_cpumask(): generic cpumask: remove cpumask_t from core cpumask: convert rcutorture.c cpumask: use new cpumask_ functions in core code. cpumask: remove references to struct irqaction's mask field. cpumask: use mm_cpumask() wrapper: kernel/fork.c cpumask: use set_cpu_active in init/main.c cpumask: remove node_to_first_cpu cpumask: fix seq_bitmap_*() functions. cpumask: remove dangerous CPU_MASK_ALL_PTR, &CPU_MASK_ALL
2009-03-30MIPS: Enable GENERIC_HARDIRQS_NO__DO_IRQ for all platformsRalf Baechle
__do_IRQ() is deprecated and will go away. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-30cpumask: remove references to struct irqaction's mask field.Rusty Russell
Impact: cleanup It's unused, since about 1995. So remove all initialization of it in preparation for actually removing the field. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2008-12-13cpumask: convert struct clock_event_device to cpumask pointers.Rusty Russell
Impact: change calling convention of existing clock_event APIs struct clock_event_timer's cpumask field gets changed to take pointer, as does the ->broadcast function. Another single-patch change. For safety, we BUG_ON() in clockevents_register_device() if it's not set. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2008-07-15[MIPS] Remove obsolete isa_slot_offsetMaciej W. Rozycki
The isa_slot_offset variable and its __ISA_IO_base macro is not used anywhere anymore. It does not look like a decent interface per today's standards either. Remove both including all places of initialization. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] RM: Collected changesThomas Bogendoerfer
- EISA support for non PCI RMs (RM200 and RM400-xxx). The major part is the splitting of the EISA and onboard ISA of the RM200, which makes the EISA bus on the RM200 look like on other RMs. - 64bit kernel support - system type detection is now common for big and little endian - moved sniprom code to arch/mips/fw - added call_o32 function to arch/mips/fw/lib, which uses a private stack for calling prom functions - fix problem with ISA interrupts, which makes using PIT clockevent possible Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Cleanup pcspeaker platform device registration.Ralf Baechle
Move registration into the actual platform code instead of making a desparate attempt at sharing the hand full of likes of code in pcspeaker.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-15[MIPS] SNI: s/achknowledge/acknowledge/Maciej W. Rozycki
2007-11-02[MIPS] SNI: register a02r clockevent; don't use PIT timerThomas Bogendoerfer
Register A20R clockevent. Remove PIT timer setup because it doesn't work Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] SNI: Convert a20r timer to clockevent device.Ralf Baechle
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19[MIPS] Kill duplicated setup_irq() for cp0 timerAtsushi Nemoto
Also many plat_timer_setup() can be killed too. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
