Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled],
We run all interrupt handlers with interrupts disabled and we even check
and yell when an interrupt handler returns with interrupts enabled (see
commit [b738a50a: genirq: Warn when handler enables interrupts]).
So now this flag is a NOOP and can be removed.
[ralf@linux-mips.org: Fixed up conflicts in
arch/mips/alchemy/common/dbdma.c, arch/mips/cavium-octeon/smp.c and
arch/mips/kernel/perf_event.c.]
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
To: linux-kernel@vger.kernel.org
Cc: tglx@linutronix.de
linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2835/
Cc: linux-mips@linux-mips.org
Link: http://lkml.kernel.org/r/20110601180610.054254048@duck.linux-mips.net
arch/arm/mach-footbridge/isa-timer.c | 2 +-
arch/mips/cobalt/time.c | 2 +-
arch/mips/jazz/irq.c | 2 +-
arch/mips/kernel/i8253.c | 2 +-
arch/mips/mti-malta/malta-time.c | 2 +-
arch/mips/sgi-ip22/ip22-time.c | 2 +-
arch/mips/sni/time.c | 2 +-
arch/x86/kernel/apic/apic.c | 2 +-
arch/x86/kernel/apm_32.c | 2 +-
arch/x86/kernel/hpet.c | 2 +-
arch/x86/kernel/i8253.c | 2 +-
arch/x86/kernel/time.c | 2 +-
drivers/block/hd.c | 2 +-
drivers/clocksource/i8253.c | 2 +-
drivers/input/gameport/gameport.c | 2 +-
drivers/input/joystick/analog.c | 2 +-
drivers/input/misc/pcspkr.c | 2 +-
include/linux/i8253.h | 11 +++++++++++
sound/drivers/pcsp/pcsp.h | 2 +-
19 files changed, 29 insertions(+), 18 deletions(-)
CC arch/mips/sni/time.o
arch/mips/sni/time.c: In function 'dosample':
arch/mips/sni/time.c:98:19: error: variable 'lsb' set but not used [-Werror=unused-but-set-variable]
cc1: all warnings being treated as errors
Add missing #inclusions of <linux/irq.h> to a whole bunch of files that should
really include it. Note that this can replace #inclusions of <asm/irq.h>.
This is required for the patch to sort out irqflags handling function naming to
compile on MIPS.
The problem is that these files require access to things like setup_irq() -
which isn't available by #including <linux/interrupt.h>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Along the lines of d6c585a4342a2ff627a29f9aea77c5ed4cd76023, add IRQF_TIMER
flag for all timer interrupts This ensures that timer interrupts won't be
disabled on suspend and not threaded for PREEMPT_RT.
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
The persistent clock of some architectures (e.g. s390) have a
better granularity than seconds. To reduce the delta between the
host clock and the guest clock in a virtualized system change the
read_persistent_clock function to return a struct timespec.
Acked-by: John Stultz <johnstul@us.ibm.com>
Cc: Daniel Walker <dwalker@fifo99.com>
LKML-Reference: <20090814134811.013873340@de.ibm.com>
Some of the were relying into smp.h being dragged in by another header
which of course is fragile. <asm/cpu-info.h> uses smp_processor_id()
only in macros and including smp.h there leads to an include loop, so
don't change cpu-info.h.
Impact: change calling convention of existing clock_event APIs
struct clock_event_timer's cpumask field gets changed to take pointer,
as does the ->broadcast function.
Another single-patch change. For safety, we BUG_ON() in
clockevents_register_device() if it's not set.
- EISA support for non PCI RMs (RM200 and RM400-xxx). The major part
is the splitting of the EISA and onboard ISA of the RM200, which
makes the EISA bus on the RM200 look like on other RMs.
- 64bit kernel support
- system type detection is now common for big and little endian
- moved sniprom code to arch/mips/fw
- added call_o32 function to arch/mips/fw/lib, which uses a private
stack for calling prom functions
- fix problem with ISA interrupts, which makes using PIT clockevent
possible
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Register A20R clockevent.
Remove PIT timer setup because it doesn't work
Also many plat_timer_setup() can be killed too.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Derived from the i386 variant with a few x86 complexities chopped off.
Hard to follow who is pointing what to where and why so it's simply getting
in the way of the time code renovation.
