The [user space] interface does not filter out offline cpus. It merily
guarantees that the mask contains at least one online cpu.
So the selector in the irq chip implementation needs to make sure to
pick only an online cpu because otherwise:
Offline Core 1
Set affinity to 0xe (is valid due to online mask 0xd)
cpumask_first will pick core 1, which is offline
Cc: linux-mips@linux-mips.org
Link: http://lkml.kernel.org/r/20140304203100.744800502@linutronix.de
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
Disintegrate asm/system.h for MIPS.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
cc: linux-mips@linux-mips.org
Commit d6d5d5c4a (MIPS: Sibyte: Convert to new irq_chip functions)
removed the mask function which breaks irq_shutdown(). Restore it.
Reported-by: Matt Turner <mattst88@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/2460/
Tested-by: Matt Turner <mattst88@gmail.com>
Scripted with coccinelle.
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2205/
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Signed-off-by: Gilles Espinasse <g.esp@free.fr>
A wrong resolution of a merge conflict made the recently deleted wrong
error check in sb1250_set_affinity. Send the zombie back to the empire
of the undead.
arch/mips/sibyte/bcm1480/irq.c
arch/mips/sibyte/sb1250/irq.c
Merge reason: we gathered a few conflicts plus update to latest upstream fixes.
Locking of irq_desc is now done in irq_set_affinity; don't lock it again
in chip specific set_affinity function.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
according to Ingo, change set_affinity() in irq_chip should return int,
because that way we can handle failure cases in a much cleaner way, in
the genirq layer.
v2: fix two typos
[ Impact: extend API ]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
LKML-Reference: <49F654E9.4070809@kernel.org>
__do_IRQ() is deprecated and will go away.
Impact: change existing irq_chip API
Not much point with gentle transition here: the struct irq_chip's
setaffinity method signature needs to change.
Fortunately, not widely used code, but hits a few architectures.
Note: In irq_select_affinity() I save a temporary in by mangling
irq_desc[irq].affinity directly. Ingo, does this break anything?
(Folded in fix from KOSAKI Motohiro)
Signed-off-by: Mike Travis <travis@sgi.com>
Reviewed-by: Grant Grundler <grundler@parisc-linux.org>
Acked-by: Ingo Molnar <mingo@redhat.com>
Cc: ralf@linux-mips.org
Cc: grundler@parisc-linux.org
Cc: jeremy@xensource.com
This patch explicitly removes the kgdb implementation, for mips which
is intended to be followed by a patch that adds a kgdb implementation
for MIPS that makes use of the kgdb core in the kernel.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
They break the timer interrupt initialization and only seem to be a kludge
for initialization happening in the wrong order. Further testing done by
Thiemo confirms the suspicion that the other invocations also seem to have
useless.
The BCM148 has 4 cores but there are also just 4 generic timers available
so use the ZBbus cycle counter instead of it. In addition the ZBbus
counter also offers a much higher resolution and 64-bit counting so I'm
considering a later complete conversion to it once I figure out if all
members of the Sibyte SOC family support it - the docs seem to agree but
the headers files seem to disagree ...
This is needed since the Sibyte serial driver was exchanged.
Issue report by Imre Kaloz <kaloz@openwrt.org>.
o adds missing ST0_IM masks, which caused the logging of valid interrupts
as spurious
o stops pnx8550 to log every interrupt as spurious
o adds cause register masks for ip22/ip32, which caused handling of masked
interrupts
o removes some superfluous parentheses in the SNI interrupt code
Signed-Off-By: Thiemo Seufer <ths@networkno.de>
The "typename" field was obsoleted by the "name" field.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
This is a big irq cleanup patch.
* Use set_irq_chip() to register irq_chip.
* Initialize .mask, .unmask, .mask_ack field. Functions for these
method are already exist in most case.
* Do not initialize .startup, .shutdown, .enable, .disable fields if
default routines provided by irq_chip_set_defaults() were suitable.
* Remove redundant irq_desc initializations.
* Remove unnecessary local_irq_save/local_irq_restore, spin_lock.
With this cleanup, it would be easy to switch to slightly lightwait
irq flow handlers (handle_level_irq(), etc.) instead of __do_IRQ().
Though whole this patch is quite large, changes in each irq_chip are
not quite simple. Please review and test on your platform. Thanks.
Mask cp0.status against cp0.cause. Additionally, spurious interrupts are
not recorded.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
dclz() expects its 64-bit argument being passed as a single register
but on 32-bit kernels it'll actually be in a register pair.
this patch restores the behaviour of the old (assembly-written)
interrupt handler, the handler is left as soon as a single interrupt
cause is handled.
Signed-off-by: Thiemo Seufer <ths@networkno.de>
> #define hw_interrupt_type irq_chip
> typedef struct irq_chip hw_irq_controller;
> #define no_irq_type no_irq_chip
> typedef struct irq_desc irq_desc_t;
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This patch-queue improves the generic IRQ layer to be truly generic, by adding
various abstractions and features to it, without impacting existing
functionality.
While the queue can be best described as "fix and improve everything in the
generic IRQ layer that we could think of", and thus it consists of many
smaller features and lots of cleanups, the one feature that stands out most is
the new 'irq chip' abstraction.
The irq-chip abstraction is about describing and coding and IRQ controller
driver by mapping its raw hardware capabilities [and quirks, if needed] in a
straightforward way, without having to think about "IRQ flow"
(level/edge/etc.) type of details.
This stands in contrast with the current 'irq-type' model of genirq
architectures, which 'mixes' raw hardware capabilities with 'flow' details.
The patchset supports both types of irq controller designs at once, and
converts i386 and x86_64 to the new irq-chip design.
As a bonus side-effect of the irq-chip approach, chained interrupt controllers
(master/slave PIC constructs, etc.) are now supported by design as well.
The end result of this patchset intends to be simpler architecture-level code
and more consolidation between architectures.
We reused many bits of code and many concepts from Russell King's ARM IRQ
layer, the merging of which was one of the motivations for this patchset.
This patch:
rename desc->handler to desc->chip.
Originally i did not want to do this, because it's a big patch. But having
both "desc->handler", "desc->handle_irq" and "action->handler" caused a
large degree of confusion and made the code appear alot less clean than it
truly is.
I have also attempted a dual approach as well by introducing a
desc->chip alias - but that just wasnt robust enough and broke
frequently.
So lets get over with this quickly. The conversion was done automatically
via scripts and converts all the code in the kernel.
This renaming patch is the first one amongst the patches, so that the
remaining patches can stay flexible and can be merged and split up
without having some big monolithic patch act as a merge barrier.
[akpm@osdl.org: build fix]
[akpm@osdl.org: another build fix]
Random improvements for sb1250: Silence compiler warnings, a bugfix for
the profiling code, and a comment typo.
Saves like 1,600 lines of code, is way easier to debug, compilers
frequently do a better job than the cut and paste type of handlers many
boards had. And finally having all the stuff done in a single place
also means alot of bug potencial for the MT ASE is gone.
The only surviving handler in assembler is the DECstation one; I hope
Maciej will rewrite it.
Signed-Off-By: Andrew Isaacson <adi@broadcom.com>
initializers.
infrastructure for it.
Let it rip!
