path: root/arch/mips/sibyte/bcm1480/irq.c
2011-03-29MIPS: Convert the irq functions to the new namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25MIPS: Sibyte: Convert to new irq_chip functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2205/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-23Merge branch 'master' into for-nextJiri Kosina
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-29Fix comment and Kconfig typos for 'require' and 'fragment'Gilles Espinasse
Signed-off-by: Gilles Espinasse <g.esp@free.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-27MIPS: SB1480: Convert IRQ controller lock to raw spinlock.Ralf Baechle
2010-02-27MIPS: Make various locks static.Ralf Baechle
2009-09-30MIPS: BCM1480: Re-apply patch lost due to bad resolution of merge conflict.Ralf Baechle
Patch 14275ccdb1e4b487cca745aba994699c426a31ee and d5dedd4507d307eb3f35f21b6e16f336fdc0d82a are conflicting and the conflict was resolved badly in merge 92241940be501f798cb21db344bbb3d1ec3c4f1c resulting in the BCM1480 changes of 14275ccdb1e4b487cca745aba994699c426a31ee getting lost. Sort out the damage. Reported and initial patch by Mark Mason <mmason@upwardaccess.com>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-01Merge branch 'linus' into irq/numaIngo Molnar
Conflicts: arch/mips/sibyte/bcm1480/irq.c arch/mips/sibyte/sb1250/irq.c Merge reason: we gathered a few conflicts plus update to latest upstream fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-14MIPS: Sibyte: Fix locking in set_irq_affinityThomas Bogendoerfer
Locking of irq_desc is now done in irq_set_affinity; don't lock it again in chip specific set_affinity function. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-04-28irq: change ->set_affinity() to return statusYinghai Lu
according to Ingo, change set_affinity() in irq_chip should return int, because that way we can handle failure cases in a much cleaner way, in the genirq layer. v2: fix two typos [ Impact: extend API ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: linux-arch@vger.kernel.org LKML-Reference: <49F654E9.4070809@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-30MIPS: Enable GENERIC_HARDIRQS_NO__DO_IRQ for all platformsRalf Baechle
__do_IRQ() is deprecated and will go away. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-12-13cpumask: make irq_set_affinity() take a const struct cpumaskRusty Russell
Impact: change existing irq_chip API Not much point with gentle transition here: the struct irq_chip's setaffinity method signature needs to change. Fortunately, not widely used code, but hits a few architectures. Note: In irq_select_affinity() I save a temporary in by mangling irq_desc[irq].affinity directly. Ingo, does this break anything? (Folded in fix from KOSAKI Motohiro) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Acked-by: Ingo Molnar <mingo@redhat.com> Cc: ralf@linux-mips.org Cc: grundler@parisc-linux.org Cc: jeremy@xensource.com Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
2008-07-30[MIPS] kgdb: Remove existing implementationJason Wessel
This patch explicitly removes the kgdb implementation, for mips which is intended to be followed by a patch that adds a kgdb implementation for MIPS that makes use of the kgdb core in the kernel. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-15[MIPS] Sibyte: Replace use of removed IO_SPACE_BASE with IOADDR.Ralf Baechle
2007-11-15[MIPS] BCM1480: Remove duplicate acknowledge of timer interrupt.Ralf Baechle
2007-11-02[MIPS] Sibyte: Remove blank line.Ralf Baechle
2007-11-02[MIPS] Sibyte: Build fixes / dead code removal.Ralf Baechle
2007-10-29[MIPS] Sibyte: Delete {sb1250,bcm1480}_steal_irq().Ralf Baechle
They break the timer interrupt initialization and only seem to be a kludge for initialization happening in the wrong order. Further testing done by Thiemo confirms the suspicion that the other invocations also seem to have useless. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-22[MIPS] time: SMP-proofing of Sibyte clockevent/clocksource code.Ralf Baechle
The BCM148 has 4 cores but there are also just 4 generic timers available so use the ZBbus cycle counter instead of it. In addition the ZBbus counter also offers a much higher resolution and 64-bit counting so I'm considering a later complete conversion to it once I figure out if all members of the Sibyte SOC family support it - the docs seem to agree but the headers files seem to disagree ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-10-11[MIPS] Implement clockevents for R4000-style cp0 count/compare interruptRalf Baechle
2007-09-10[MIPS] BCM1480: Fix computation of interrupt mask address register.Ralf Baechle
CC arch/mips/sibyte/bcm1480/irq.o arch/mips/sibyte/bcm1480/irq.c: In function 'bcm1480_mask_irq': arch/mips/sibyte/bcm1480/irq.c:112: warning: cast to pointer from integer of different size arch/mips/sibyte/bcm1480/irq.c:114: warning: cast to pointer from integer of different size arch/mips/sibyte/bcm1480/irq.c: In function 'bcm1480_unmask_irq': arch/mips/sibyte/bcm1480/irq.c:130: warning: cast to pointer from integer of different size arch/mips/sibyte/bcm1480/irq.c:132: warning: cast to pointer from integer of different size Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Sibyte: CONFIG_SIBYTE_SB1250_DUART -> CONFIG_SERIAL_SB1250_DUARTRalf Baechle
This is needed since the Sibyte serial driver was exchanged. Issue report by Imre Kaloz <kaloz@openwrt.org>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-29[MIPS] BCM1480: Fix setting of irq affinity.Mark Mason
Signed-off-by: Mark Mason <mason@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] Fix and cleanup the mess that a dozen prom_printf variants are.Ralf Baechle
early_printk is a so much saner thing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] use name instead of typename for each irq_chipAtsushi Nemoto
The "typename" field was obsoleted by the "name" field. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] IRQ cleanupsAtsushi Nemoto
This is a big irq cleanup patch. * Use set_irq_chip() to register irq_chip. * Initialize .mask, .unmask, .mask_ack field. Functions for these method are already exist in most case. * Do not initialize .startup, .shutdown, .enable, .disable fields if default routines provided by irq_chip_set_defaults() were suitable. * Remove redundant irq_desc initializations. * Remove unnecessary local_irq_save/local_irq_restore, spin_lock. With this cleanup, it would be easy to switch to slightly lightwait irq flow handlers (handle_level_irq(), etc.) instead of __do_IRQ(). Though whole this patch is quite large, changes in each irq_chip are not quite simple. Please review and test on your platform. Thanks. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-09[MIPS] Cleanup unnecessary <asm/ptrace.h> inclusions.Ralf Baechle
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-10-03[MIPS] BCM1480: Mask pending interrupts against c0_status.im.Ralf Baechle
2006-09-27[MIPS] Fix 32-bit kernel by replacing 64-bit-only code.Ralf Baechle
dclz() expects its 64-bit argument being passed as a single register but on 32-bit kernels it'll actually be in a register pair. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] BCM1480: Fix fatal typo in the rewritten interrupt handler.Thiemo Seufer
Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Sibyte: Improve interrupt latency again for sb1250/bcm1480Thiemo Seufer
this patch restores the behaviour of the old (assembly-written) interrupt handler, the handler is left as soon as a single interrupt cause is handled. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Eleminate interrupt migration helper use.Ralf Baechle
> #define hw_interrupt_type irq_chip > typedef struct irq_chip hw_irq_controller; > #define no_irq_type no_irq_chip > typedef struct irq_desc irq_desc_t; Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[MIPS] Rewrite all the assembler interrupt handlers to C.Ralf Baechle
Saves like 1,600 lines of code, is way easier to debug, compilers frequently do a better job than the cut and paste type of handlers many boards had. And finally having all the stuff done in a single place also means alot of bug potencial for the MT ASE is gone. The only surviving handler in assembler is the DECstation one; I hope Maciej will rewrite it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-21[MIPS] Fix compiler warnings in arch/mips/sibyte/bcm1480/irq.cMartin Michlmayr
Fix the following compiler warnings: CC arch/mips/sibyte/bcm1480/irq.o arch/mips/sibyte/bcm1480/irq.c: In function ‘bcm1480_set_affinity’: arch/mips/sibyte/bcm1480/irq.c:168: warning: ISO C90 forbids mixed declarations and code arch/mips/sibyte/bcm1480/irq.c: In function ‘ack_bcm1480_irq’: arch/mips/sibyte/bcm1480/irq.c:230: warning: ISO C90 forbids mixed declarations and code Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Add support for BCM1480 family of chips.Andrew Isaacson
- Kconfig and Makefile changes - arch/mips/sibyte/bcm1480/ - changes to sibyte common code to support 1480 Signed-Off-By: Andy Isaacson <adi@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
