path: root/arch/mips/qemu/Makefile
2007-07-31[MIPS] Use -Werror on subdirectories which build cleanly.Ralf Baechle
2006-06-19[MIPS] Qemu system shutdown supportThiemo Seufer
Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] Rewrite all the assembler interrupt handlers to C.Ralf Baechle
Saves like 1,600 lines of code, is way easier to debug, compilers frequently do a better job than the cut and paste type of handlers many boards had. And finally having all the stuff done in a single place also means alot of bug potencial for the MT ASE is gone. The only surviving handler in assembler is the DECstation one; I hope Maciej will rewrite it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-03-21[MIPS] Symmetric Uniprocessor support for Qemu.Ralf Baechle
SMP bits needed to builds and run an SMP kernel. While only a single processor is supported ATM it's still useful for some SMP debugging using Qemu. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: add support for Qemu system architectureRalf Baechle
Add support for the virtual MIPS system that is emulated by Qemu. See http://www.linux-mips.org/wiki/Qemu for a detailed current status. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
