path: root/arch/mips/oprofile/Makefile
2009-09-17MIPS: Loongson: Add oprofile supportWu Zhangjin
This kernel support is needed by the user-space tool:oprofile to profile linux kernel or applications via loongson2 performance counters. you can enable this driver via CONFIG_OPROFILE = y or m. On Loongson2 there are two performance counters, each one can count 16 events respectively. when anyone of the performance counter overflows, an interrupt will be generated and is routed to the IRQ MIPS_CPU_IRQ_BASE + 6. Signed-off-by: Yanhua <yanh@lemote.com> Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] Oprofile: kernel support for the R10000.Ralf Baechle
2006-02-07[MIPS] SB1: Add oprofile support.Mark Mason
Signed-off-by: Mark Mason <mason@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
