path: root/arch/mips/mm
2012-03-28Disintegrate asm/system.h for MIPSDavid Howells
Disintegrate asm/system.h for MIPS. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org
2012-03-20highmem: kill all __kmap_atomic()Cong Wang
[swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename] Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-20mips: remove the second argument of k[un]map_atomic()Cong Wang
2012-02-20MIPS: fault.c: Port OOM changes to do_page_faultKautuk Consul
Commit d065bd810b6deb67d4897a14bfe21f8eb526ba99 (mm: retry page fault when blocking on disk transfer) and commit 37b23e0525d393d48a7d59f870b3bc061a30ccdb (x86,mm: make pagefault killable) The above commits introduced changes into the x86 pagefault handler for making the page fault handler retryable as well as killable. These changes reduce the mmap_sem hold time, which is crucial during OOM killer invocation. Port these changes to MIPS. Without these changes, my MIPS board encounters many hang and livelock scenarios. After applying this patch, OOM feature performance improves according to my testing. Signed-off-by: Mohd. Faris <mohdfarisq2010@gmail.com> Signed-off-by: Kautuk Consul <consul.kautuk@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/3217/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-01-11Merge branches 'next/ar7', 'next/ath79', 'next/bcm63xx', 'next/bmips', ↵Ralf Baechle
'next/cavium', 'next/generic', 'next/kprobes', 'next/lantiq', 'next/perf' and 'next/raza' into mips-for-linux-next
2012-01-11Merge branch 'next/generic' into mips-for-linux-nextRalf Baechle
2012-01-11MIPS: Delete unused function add_temporary_entry.Ralf Baechle
Only available for R4000 style TLBs anyway and proper ordering of initialization code made this crude interface unncecessary. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-01-11MIPS: Flush huge TLBHillf Danton
When flushing TLB, if @vma is backed by huge page, we could flush huge TLB, due to that huge page is defined to be far from normal page. Signed-off-by: Hillf Danton <dhillf@gmail.com> Acked-by: David Daney <david.daney@cavium.com> Cc: linux-mips@linux-mips.org Cc: "Jayachandran C." <jayachandranc@netlogicmicro.com> Patchwork: https://patchwork.linux-mips.org/patch/2825/ Signed-off-by: David Daney <david.daney@cavium.com> Acked-by: Hillf Danton <dhillf@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/3114/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-12-07MIPS: Netlogic: Add XLP makefiles and configJayachandran C
- Add CPU_XLP and NLM_XLR_BOARD to arch/mips/Kconfig for Netlogic XLP boards - Update mips Makefiles to add XLP Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2968/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-12-07MIPS: Netlogic: XLP CPU support.Jayachandran C
Add support for Netlogic's XLP MIPS SoC. This patch adds: * XLP processor ID in cpu_probe.c and asm/cpu.h * XLP case to asm/module.h * CPU_XLP case to mm/tlbex.c * minor change to r4k cache handling to ignore XLP secondary cache * XLP cpu overrides to mach-netlogic/cpu-feature-overrides.h Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2966/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-12-07MIPS: Handle initmem in systems with kernel not in add_memory_region() memDavid Daney
This patch addresses a couple of related problems: 1) The kernel may reside in physical memory outside of the ranges set by plat_mem_setup(). If this is the case, init mem cannot be reused as it resides outside of the range of pages that the kernel memory allocators control. 2) initrd images might be loaded in physical memory outside of the ranges set by plat_mem_setup(). The memory likewise cannot be reused. The patch doesn't handle this specific case, but the infrastructure is useful for future patches that do. The crux of the problem is that there are memory regions that need be memory_present(), but that cannot be free_bootmem() at the time of arch_mem_init(). We create a new type of memory (BOOT_MEM_INIT_RAM) for use with add_memory_region(). Then arch_mem_init() adds the init mem with this type if the init mem is not already covered by existing ranges. When memory is being freed into the bootmem allocator, we skip the BOOT_MEM_INIT_RAM ranges so they are not clobbered, but we do signal them as memory_present(). This way when they are later freed, the necessary memory manager structures have initialized and the Sparse allocater is prevented from crashing. The Octeon specific code that handled this case is removed, because the new general purpose code handles the case. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1988/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-12-07MIPS: Add fast get_user_pagesHillf Danton
Gup is used in a few cases, say futex. This work is derived from the x86 version, and operations of pte and pmd are adapted to the defines of MIPS in straight forward manner. [ralf@linux-mips.org: Fixed up reject in arch/mips/mm/Makefile due to whitespace formatting differences. Fixed build error in gup.c due to conflicting changes elsewhere in the kernel.] Signed-off-by: Hillf Danton <dhillf@gmail.com> Cc: David Daney <david.daney@cavium.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2859/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-12-07MIPS: Fix Jazz 64-bit build error.Ralf Baechle
Move add_wired_entry to its own header file from where it will be always included. Patch up other users of add_wired_entry to also include the header as needed. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-12-07MIPS: Fix up inconsistency in panic() string argument.Ralf Baechle
Panic() invokes printk() to add a \n internally, so panic arguments should not themselves end in \n. Panic invocations in arch/mips and elsewhere are inconsistently sometimes terminating in \n, sometimes not. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-24MIPS: Remove __init from add_wired_entry()Manuel Lauss
For Alchemy-PCI I need to add a wired entry after resuming from RAM; remove the __init from add_wired_entry() so that this actually works. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2684/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-20MIPS: cache: Provide cache flush operations for XFSRalf Baechle
Until now flush_kernel_vmap_range() and invalidate_kernel_vmap_range() did not exist on MIPS resulting in heavy cache corruption on XFS filesystems. Left for the post-3.0 time: optimization and make this work with highmem, too. Since the combination of highmem + cache aliases atm doesn't work this isn't a regression. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2505/
2011-09-21MIPS: No branches in delay slots for huge pages in handle_tlblDavid Daney
For the case PM_DEFAULT_MASK == 0, we were placing a branch in the delay slot of another branch. This leads to undefined behavior. Signed-off-by: David Daney <david.daney@cavium.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2775/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-09-21MIPS: tlbex: Fix build error in R3000 code.Ralf Baechle
Only some GCC versions such as gcc 4.2 notice that the variable wr in build_r3000_tlb_modify_handler is used uninitialized. When using one of those GCCs the build will fail due to -Werror. GCC 4.6 does not warn about the uninitialized use of wr. This issue was introduced by 7211f4d7a3dcbe57c5d396c334dca525315dceb2 [MIPS: Close races in TLB modify handlers.] Reported-by: Ganesan Ramalingam <ganesan18@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-09-17MIPS: Trivial style cleanups in mmap.cKevin Cernekee
Fix checkpatch warnings. Rename arch_get_unmapped_area_foo() to arch_get_unmapped_area_common(). Make indentations and spacing more consistent. Add <linux/compiler.h> for likely/unlikely. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: Jian Peng <jipeng2005@gmail.com> Cc: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2506/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-26Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (31 commits) MIPS: Close races in TLB modify handlers. MIPS: Add uasm UASM_i_SRL_SAFE macro. MIPS: RB532: Use hex_to_bin() MIPS: Enable cpu_has_clo_clz for MIPS Technologies' platforms MIPS: PowerTV: Provide cpu-feature-overrides.h MIPS: Remove pointless return statement from empty void functions. MIPS: Limit fixrange_init() to the FIXMAP region MIPS: Install handlers for software IRQs MIPS: Move FIXADDR_TOP into spaces.h MIPS: Add SYNC after cacheflush MIPS: pfn_valid() is broken on low memory HIGHMEM systems MIPS: HIGHMEM DMA on noncoherent MIPS32 processors MIPS: topdown mmap support MIPS: Remove redundant addr_limit assignment on exec. MIPS: AR7: Replace __attribute__((__packed__)) with __packed MIPS: AR7: Remove 'space before tabs' in platform.c MIPS: Lantiq: Add missing clk_enable and clk_disable functions. MIPS: AR7: Fix trailing semicolon bug in clock.c MAINTAINERS: Update MIPS entry. MIPS: BCM63xx: Remove duplicate PERF_IRQSTAT_REG definition ...
2011-07-26MIPS: Close races in TLB modify handlers.David Daney
Page table entries are made invalid by writing a zero into the the PTE slot in a page table. This creates a race condition with the TLB modify handlers when they are updating the PTE. CPU0 CPU1 Test for _PAGE_PRESENT . set to not _PAGE_PRESENT (zero) Set to _PAGE_VALID So now the page not present value (zero) is suddenly valid and user space programs have access to physical page zero. We close the race by putting the test for _PAGE_PRESENT and setting of _PAGE_VALID into an atomic LL/SC section. This requires more registers than just K0 and K1 in the handlers, so we need to save some registers to a save area and then restore them when we are done. The save area is an array of cacheline aligned structures that should not suffer cache line bouncing as they are CPU private. [ralf@linux-mips.org: Fix !defined(CONFIG_MIPS_PGD_C0_CONTEXT) build error.] Signed-off-by: David Daney <david.daney@cavium.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2577/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-25MIPS: Limit fixrange_init() to the FIXMAP regionKevin Cernekee
fixrange_init() allocates page tables for all addresses higher than FIXADDR_TOP. On processors that override the default FIXADDR_TOP address of 0xfffe_0000, this can consume up to 4 pages (1 page per 4MB) for pgd's that are never used. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1980/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-25MIPS: Add SYNC after cacheflushKevin Cernekee
On processors with deep write buffers, it is likely that many cycles will pass between a CACHE instruction and the time the data actually gets written out to DRAM. Add a SYNC instruction to ensure that the buffers get emptied before the flush functions return. Actual problem seen in the wild: 1) dma_alloc_coherent() allocates cached memory 2) memset() is called to clear the new pages 3) dma_cache_wback_inv() is called to flush the zero data out to memory 4) dma_alloc_coherent() returns an uncached (kseg1) pointer to the freshly allocated pages 5) Caller writes data through the kseg1 pointer 6) Buffered writeback data finally gets flushed out to DRAM 7) Part of caller's data is inexplicably zeroed out This patch adds SYNC between steps 3 and 4, which fixed the problem. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-25MIPS: pfn_valid() is broken on low memory HIGHMEM systemsKevin Cernekee
pfn_valid() compares the PFN to max_mapnr: __pfn >= min_low_pfn && __pfn < max_mapnr; On HIGHMEM kernels, highend_pfn is used to set the value of max_mapnr. Unfortunately, highend_pfn is left at zero if the system does not actually have enough RAM to reach into the HIGHMEM range. This causes pfn_valid() to always return false, and when debug checks are enabled the kernel will fail catastrophically: Memory: 22432k/32768k available (2249k kernel code, 10336k reserved, 653k data, 1352k init, 0k highmem) NR_IRQS:128 kfree_debugcheck: out of range ptr 81c02900h. Kernel bug detected[#1]: Cpu 0 $ 0 : 00000000 10008400 00000034 00000000 $ 4 : 8003e160 802a0000 8003e160 00000000 $ 8 : 00000000 0000003e 00000747 00000747 ... On such a configuration, max_low_pfn should be used to set max_mapnr. This was seen on 2.6.34. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> To: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1992/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-25MIPS: HIGHMEM DMA on noncoherent MIPS32 processorsDezhong Diao
[v4: Patch applies to linux-queue.git with kmap_atomic patches: https://patchwork.kernel.org/patch/189932/ https://patchwork.kernel.org/patch/194552/ https://patchwork.kernel.org/patch/189912/ ] The MIPS DMA coherency functions do not work properly (i.e. kernel oops) when HIGHMEM pages are passed in as arguments. Use kmap_atomic() to temporarily map high pages for cache maintenance operations. Tested on a 2.6.36-rc7 1GB HIGHMEM SMP no-alias system. Signed-off-by: Dezhong Diao <dediao@cisco.com> Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: Dezhong Diao <dediao@cisco.com> Cc: David Daney <ddaney@caviumnetworks.com> Cc: David VomLehn <dvomlehn@cisco.com> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1695/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-25MIPS: topdown mmap supportJian Peng
This patch introduced topdown mmap support in user process address space allocation policy. Recently, we ran some large applications that use mmap heavily and lead to OOM due to inflexible mmap allocation policy on MIPS32. Since most other major archs supported it for years, it is reasonable to follow the trend and reduce the pain of porting applications. Due to cache aliasing concern, arch_get_unmapped_area_topdown() and other helper functions are implemented in arch/mips/kernel/syscall.c. Signed-off-by: Jian Peng <jipeng2005@gmail.com> Cc: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2389/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-01perf: Remove the nmi parameter from the swevent and overflow interfacePeter Zijlstra
The nmi parameter indicated if we could do wakeups from the current context, if not, we would set some state and self-IPI and let the resulting interrupt do the wakeup. For the various event classes: - hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from the PMI-tail (ARM etc.) - tracepoint: nmi=0; since tracepoint could be from NMI context. - software: nmi=[0,1]; some, like the schedule thing cannot perform wakeups, and hence need 0. As one can see, there is very little nmi=1 usage, and the down-side of not using it is that on some platforms some software events can have a jiffy delay in wakeup (when arch_irq_work_raise isn't implemented). The up-side however is that we can remove the nmi parameter and save a bunch of conditionals in fast paths. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Michael Cree <mcree@orcon.net.nz> Cc: Will Deacon <will.deacon@arm.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Don Zickus <dzickus@redhat.com> Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-19MIPS: Move arch_get_unmapped_area and gang to new file.Ralf Baechle
It never really belonged into syscall.c and it's about to become well more complex. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Kconfig and Makefile update for Netlogic XLR/XLSJayachandran C
Add NLM_XLR_BOARD, CPU_XLR and other config options Makefile updates, mostly based on r4k Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2334/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Netlogic: Cache, TLB support and feature overrides for XLRJayachandran C
CPU_XLR case added to mm/tlbex.c CPU_XLR case added to mm/c-r4k.c for PINDEX attribute Feature overrides for XLR cpu. Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2333/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: tlbex: Fix GCC 4.6.0 build errorRalf Baechle
CC arch/mips/mm/tlbex.o arch/mips/mm/tlbex.c: In function 'build_r4000_tlb_refill_handler': arch/mips/mm/tlbex.c:1155:22: error: variable 'vmalloc_mode' set but not used [-Werror=unused-but-set-variable] arch/mips/mm/tlbex.c:1154:28: error: variable 'htlb_info' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: c-r4k: Fix GCC 4.6.0 build errorRalf Baechle
CC arch/mips/mm/c-r4k.o arch/mips/mm/c-r4k.c: In function 'probe_scache': arch/mips/mm/c-r4k.c:1078:6: error: variable 'tmp' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Older GCC versions didn't warn about the unused variable tmp because it was getting initialized. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-06update David Miller's old email addressJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-14MIPS: Fix GCC-4.6 'set but not used' warning in arch/mips/mm/init.cDavid Daney
Under some combinations of CONFIG_*, lastpfn in page_is_ram is 'set but not used'. Mark it as __maybe_unused to quiet the warning/error. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2033/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Add an unreachable return statement to satisfy buggy GCCs.David Daney
It was reported that GCC-4.3.3 (with CodeSourcery extensions) fails without this. Reported-by: Jonas Gorski <jonas.gorski@gmail.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2010/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Use WARN() in uasm for better diagnostics.David Daney
On the off chance that uasm ever warns about overflow, there is no way to know what the offending instruction is. Change the printks to WARNs, so we can get a nice stack trace. It has the added benefit of being much more noticeable than the short single line warning message, so is less likely to be ignored. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1905/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Optimize TLB handlers for Octeon CPUsDavid Daney
Octeon can use scratch registers in the TLB handlers. Octeon II can use LDX instructions. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1904/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Add LDX and LWX instructions to uasm.David Daney
Needed by Octeon II optimized TLB handlers. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Pachwork: https://patchwork.linux-mips.org/patch/1903/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Use BBIT instructions in TLB handlersDavid Daney
If the CPU supports BBIT0 and BBIT1, use them in TLB handlers as they are more efficient than an AND followed by an branch and then restoring the clobbered register. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1873/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Use C0_KScratch (if present) to hold PGD pointer.David Daney
Decide at runtime to use either Context or KScratch to hold the PGD pointer. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1876/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Add DINSM to uasm.David Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1875/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-12-17MIPS: Fix build errors in sc-mips.cKevin Cernekee
Seen with malta_defconfig on Linus' tree: CC arch/mips/mm/sc-mips.o arch/mips/mm/sc-mips.c: In function 'mips_sc_is_activated': arch/mips/mm/sc-mips.c:77: error: 'config2' undeclared (first use in this function) arch/mips/mm/sc-mips.c:77: error: (Each undeclared identifier is reported only once arch/mips/mm/sc-mips.c:77: error: for each function it appears in.) arch/mips/mm/sc-mips.c:81: error: 'tmp' undeclared (first use in this function) make[2]: *** [arch/mips/mm/sc-mips.o] Error 1 make[1]: *** [arch/mips/mm] Error 2 make: *** [arch/mips] Error 2 [Ralf: Cosmetic changes to minimize the number of arguments passed to mips_sc_is_activated] Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/1752/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-12-16MIPS: Rename mips_dma_cache_sync back to dma_cache_syncRalf Baechle
This fixes IP22 and IP28 build errors. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Honor L2 bypass bitKevin Cernekee
On many of the newer MIPS32 cores, CP0 CONFIG2 bit 12 (L2B) indicates that the L2 cache is disabled and therefore Linux should not attempt to use it. [Ralf: Moved the code added by Kevin's original patch into a separate function that can easily be replaced for platforms that need more a different probe.] Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: linux-mips@linux-mips.org> Cc: <linux-kernel@vger.kernel.org> Patchwork: https://patchwork.linux-mips.org/patch/1723/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Decouple BMIPS CPU support from bcm47xx/bcm63xx SoC codeKevin Cernekee
BMIPS processor cores are used in 50+ different chipsets spread across 5+ product lines. In many cases the chipsets do not share the same peripheral register layouts, the same register blocks, the same interrupt controllers, the same memory maps, or much of anything else. But, across radically different SoCs that share nothing more than the same BMIPS CPU, a few things are still mostly constant: SMP operations Access to performance counters DMA cache coherency quirks Cache and memory bus configuration So, it makes sense to treat each BMIPS processor type as a generic "building block," rather than tying it to a specific SoC. This makes it easier to support a large number of BMIPS-based chipsets without unnecessary duplication of code, and provides the infrastructure needed to support BMIPS-proprietary features. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: mbizon@freebox.fr Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Tested-by: Florian Fainelli <ffainelli@freebox.fr> Patchwork: https://patchwork.linux-mips.org/patch/1706/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org
2010-10-29MIPS: add support for software performance eventsDeng-Cheng Zhu
Software events are required as part of the measurable stuff by the Linux performance counter subsystem. Here is the list of events added by this patch: PERF_COUNT_SW_PAGE_FAULTS PERF_COUNT_SW_PAGE_FAULTS_MIN PERF_COUNT_SW_PAGE_FAULTS_MAJ PERF_COUNT_SW_ALIGNMENT_FAULTS PERF_COUNT_SW_EMULATION_FAULTS Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: linux-mips@linux-mips.org Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: jamie.iles@picochip.com Acked-by: David Daney <ddaney@caviumnetworks.com> Reviewed-by: Matt Fleming <matt@console-pimps.org> Patchwork: https://patchwork.linux-mips.org/patch/1686/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
