o Move current_cpu_type() to a separate header file
o #ifdefing on supported CPU types lets modern GCC know that certain
code in callers may be discarded ideally turning current_cpu_type() into
a function returning a constant.
o Use current_cpu_type() rather than direct access to struct cpuinfo_mips.
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/5833/
OCTEON2 need the same code.
Signed-off-by: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/5637/
Pull MIPS fixes from Ralf Baechle:
"MIPS fixes for 3.11. Half of then is for Netlogic the remainder
touches things across arch/mips.
Nothing really dramatic and by rc1 standards MIPS will be in fairly
good shape with this applied. Tested by building all MIPS defconfigs
of which with this pull request four platforms won't build. And yes,
it boots also on my favorite test systems"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MIPS: kvm: Kconfig: Drop HAVE_KVM dependency from VIRTUALIZATION
MIPS: Octeon: Fix DT pruning bug with pip ports
MIPS: KVM: Mark KVM_GUEST (T&E KVM) as BROKEN_ON_SMP
MIPS: tlbex: fix broken build in v3.11-rc1
MIPS: Netlogic: Add XLP PIC irqdomain
MIPS: Netlogic: Fix USB block's coherent DMA mask
MIPS: tlbex: Fix typo in r3000 tlb store handler
MIPS: BMIPS: Fix thinko to release slave TP from reset
MIPS: Delete dead invocation of exception_exit().
Commit 6ba045f9fbdafb48da42aa8576ea7a3980443136 (MIPS: Move generated code
to .text for microMIPS) deleted tlbmiss_handler_setup_pgd_array, but some
references were not converted. Fix that to enable building a MIPS kernel.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Acked-by: Jayachandran C. <jchandra@broadcom.com>
Acked-by: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/5589/
commit 6ba045f (MIPS: Move generated code to .text for microMIPS)
causes a panic at boot. The handler builder should test against
handle_tlbs_end, not handle_tlbs.
Signed-off-by: Tony Wu <tung7970@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/5600/
commit 3747069b25e419f6b51395f48127e9812abc3596 upstream.
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
and are flagged as __cpuinit -- so if we remove the __cpuinit from
the arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
related content into no-ops as early as possible, since that will get
rid of these warnings. In any case, they are temporary and harmless.
Here, we remove all the MIPS __cpuinit from C code and __CPUINIT
from asm files. MIPS is interesting in this respect, because there
are also uasm users hiding behind their own renamed versions of the
__cpuinit macros.
[1] https://lkml.org/lkml/2013/5/20/589
[ralf@linux-mips.org: Folded in Paul's followup fix.]
Patchwork: https://patchwork.linux-mips.org/patch/5494/
Patchwork: https://patchwork.linux-mips.org/patch/5495/
Patchwork: https://patchwork.linux-mips.org/patch/5509/
This that should have been fixed but weren't, way to much, intrusive
and late.
Patchwork: https://patchwork.linux-mips.org/patch/5535/
Prepare of a next patch which will call tlbmiss_handler_setup_pgd on
microMIPS. MicroMIPS complains if the called code s not in the .text
section. To fix this we generate code into space reserved in
arch/mips/mm/tlb-funcs.S
While there, move the rest of the generated functions (handle_tlbl,
handle_tlbs, handle_tlbm) to the same file.
Signed-off-by: Jayachandran C <jchandra@broadcom.com>
Patchwork: https://patchwork.linux-mips.org/patch/5542/
When having enabled MIPS_PGD_C0_CONTEXT, trap_init() might call the
generated tlbmiss_handler_setup_pgd before it was committed to memory,
causing boot failures:
trap_init()
|- per_cpu_trap_init()
| |- TLBMISS_HANDLER_SETUP()
| |- tlbmiss_handler_setup_pgd()
|- flush_tlb_handlers()
To avoid this, move flush_tlb_handlers() into build_tlb_refill_handler()
right after they were generated. We can do this as the cache handling is
initialized just before creating the tlb handlers.
This issue was introduced in 3d8bfdd0307223de678962f1c1907a7cec549136
("MIPS: Use C0_KScratch (if present) to hold PGD pointer.").
Signed-off-by: Jonas Gorski <jogo@openwrt.org>
Cc: Jayachandran C <jchandra@broadcom.com>
Cc: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/5539/
MIPS R2 documents state that an execution hazard barrier is needed
after a TLBR before reading EntryLo.
Original patch by Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>.
Patchwork: https://patchwork.linux-mips.org/patch/5526/
The invalid value for scratch register is -1, so update the checks of
the form (scratch_reg > 0) to be (scratch_reg >= 0). This will fix
the case in Netlogic XLP where the scratch_reg can be 0.
Patchwork: https://patchwork.linux-mips.org/patch/5444/
XLR/XLP COP0 scratch is register 22, sel 0-7. Add a function
c0_kscratch() which returns the scratch register for the platform,
and use the return value while generating TLB handlers.
Setup kscratch_mask to 0xf for XLR/XLP since the config4 register
does not exist. This allows the kernel to allocate scratch registers
0-3 if needed.
Patchwork: https://patchwork.linux-mips.org/patch/5445/
In C, one definition is sufficient.
Patchwork: https://patchwork.linux-mips.org/patch/5304/
This reverts commit d532f3d26716a39dfd4b88d687bd344fbe77e390.
The original commit has several problems:
1) Doesn't work with 64-bit kernels.
2) Calls TLBMISS_HANDLER_SETUP() before the code is generated.
3) Calls TLBMISS_HANDLER_SETUP() twice in per_cpu_trap_init() when
only one call is needed.
[ralf@linux-mips.org: Also revert the bits of the ASID patch which were
hidden in the KVM merge.]
Cc: "Steven J. Hill" <Steven.Hill@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/5242/
This reverts commit f6b06d9361a008afb93b97fb3683a6e92d69d0f4.
The next revert depends on this one, so this has to go too.
Patchwork: https://patchwork.linux-mips.org/patch/5241/
git://git.linux-mips.org/pub/scm/sjhill/linux-sjhill into mips-for-linux-next
All exceptions must be taken in microMIPS mode, never in classic
MIPS mode or the kernel falls apart. A few NOP instructions are
used to maintain the correct alignment of microMIPS versions of
the exception vectors.
Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com>
Changes for pure microMIPS cores to dynamically determine the ASID
size at boot time.
Includes bug fix https://patchwork.linux-mips.org/patch/5230/
Original patch by Ralf Baechle and removed by Harold Koerfgen
with commit f67e4ffc79905482c3b9b8c8dd65197bac7eb508. This
allows for more generic kernels since the size of the ASID
and corresponding masks can be determined at run-time. This
patch is also required for the new Aptiv cores and has been
tested on Malta and Malta Aptiv platforms.
[ralf@linux-mips.org: Added relevant part of fix
https://patchwork.linux-mips.org/patch/5213/]
git://git.linux-mips.org/pub/scm/john/linux-john into mips-for-linux-next
This and the next patch resolve memory corruption problems while CPU
hotplug. Without these patches, memory corruption can triggered easily
as below:
On a quad-core MIPS platform, use "spawn" of UnixBench-5.1.3 (http://
code.google.com/p/byte-unixbench/) and a CPU hotplug script like this
(hotplug.sh):
while true; do
echo 0 >/sys/devices/system/cpu/cpu1/online
echo 0 >/sys/devices/system/cpu/cpu2/online
echo 0 >/sys/devices/system/cpu/cpu3/online
sleep 1
echo 1 >/sys/devices/system/cpu/cpu1/online
echo 1 >/sys/devices/system/cpu/cpu2/online
echo 1 >/sys/devices/system/cpu/cpu3/online
sleep 1
done
Run "hotplug.sh" and then run "spawn 10000", spawn will get segfault
after a few minutes.
This patch:
Currently, clear_page()/copy_page() are generated by Micro-assembler
dynamically. But they are unavailable until uasm_resolve_relocs() has
finished because jump labels are illegal before that. Since these
functions are shared by every CPU, we only call build_clear_page()/
build_copy_page() only once at boot time. Without this patch, programs
will get random memory corruption (segmentation fault, bus error, etc.)
while CPU Hotplug (e.g. one CPU is using clear_page() while another is
generating it in cpu_cache_init()).
For similar reasons we modify build_tlb_refill_handler()'s invocation.
V2:
1, Rework the code to make CPU#0 can be online/offline.
2, Introduce cpu_has_local_ebase feature since some types of MIPS CPU
need a per-CPU tlb_refill_handler().
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Signed-off-by: Hongbing Hu <huhb@lemote.com>
Patchwork: http://patchwork.linux-mips.org/patch/4994/
Acked-by: John Crispin <blogic@openwrt.org>
tlbmiss_handler_setup_pgd is run-time generated code and it was convenient
to pretend the symbol was an array in the generator but a function for
the users. LTO gcc won't tolerate this kind of lie anymore so solve the
problem through a cast and function pointer instead.
Signed-off-by: Steven J. Hill <sjhill@mips.com>
Patchwork: http://patchwork.linux-mips.org/patch/4682/
Signed-off-by: John Crispin <blogic@openwrt.org>
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
This reverts commit ff401e52100dcdc85e572d1ad376d3307b3fe28e.
This breaks on MIPS64 R2 cores such as Broadcom's.
mips-for-linux-next
Nobody seems to be interested anymore and upstream also never had an
ethernet driver.
We need Huge TLBs for HUGETLB_PAGE, or the soon to follow
TRANSPARENT_HUGEPAGE. collect this information under a single Kconfig
symbol.
Pgtable bits are assigned dynamically depending on processor feature and
statically based on kernel configuration. To make sense out of the
disassembled TLB exception handlers a list of the actual assignments
used for a particular configuration and hardware setup can be very useful.
Output the actual TLB exception handlers in a format that simplifies their
post processsing from dmesg output.
From a software perspective R5000 and R5000A are the same thing which is
why the symbol CPU_R5000A never got used, so finally delete it.
The new functions introduced in commit 02a5417751 (MIPS: tlbex: Deal with
re-definition of label) should be marked __cpuinit, to eliminate a
warning that can pop up when CONFIG_EXPORT_UASM is disabled:
LD arch/mips/mm/built-in.o
WARNING: arch/mips/mm/built-in.o(.text+0x2a4c): Section mismatch in reference from the function uasm_bgezl_hazard() to the function .cpuinit.text:uasm_il_bgezl()
The function uasm_bgezl_hazard() references
the function __cpuinit uasm_il_bgezl().
This is often because uasm_bgezl_hazard lacks a __cpuinit
annotation or the annotation of uasm_il_bgezl is wrong.
WARNING: arch/mips/mm/built-in.o(.text+0x2a68): Section mismatch in reference from the function uasm_bgezl_label() to the function .cpuinit.text:uasm_build_label()
The function uasm_bgezl_label() references
the function __cpuinit uasm_build_label().
This is often because uasm_bgezl_label lacks a __cpuinit
annotation or the annotation of uasm_build_label is wrong.
(This warning might not occur if the function was inlined.)
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Patchwork: http://patchwork.linux-mips.org/patch/4517
R5000 and the Nevada CPUs (RM5230, RM5231, RM5260, RM5261, RM5270 and
RM5271) are basically the same CPU core and all are documented to require
two instructions separating a write to c0_pagemask, c0_entryhi, c0_entrylo0,
c0_entrylo1 or c0_index.
So far we were only providing on cycle before / after a TLBR/TLBWI
for R5000 but 3 cycles before and 1 cycles after for the Nevadas.
The microassembler used in tlbex.c does not notice if a label is redefined
resulting in relocations against such labels silently missrelocated.
The issues exists since commit add6eb04776db4189ea89f596cbcde31b899be9d
[Synthesize TLB exception handlers at runtime.] in 2.6.10 and went unnoticed
for so long because the relocations for the affected branches got computed
to do something *almost* sensible.
The issue affects R4000, R4400, QED/IDT RM5230, RM5231, RM5260, RM5261,
RM5270 and RM5271 processors.
We don't have to do a separate shift to eliminate the software bits,
just rotate them into the fill and they will be ignored.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Patchwork: https://patchwork.linux-mips.org/patch/4294/
Remove usage of the 'kernel_uses_smartmips_rixi' macro from all files
and use new 'cpu_has_rixi' instead.
The EXT and INS instructions can be used to decrease code size and
thus speed up TLB handlers on MIPS32R2 and MIPS64R2 cores.
The architecture specification says that an EHB instruction is
needed to avoid a hazard when writing TLB entries. However, some
cores do not have this hazard, and thus the EHB instruction causes
a costly pipeline stall. Detect these cores and do not use the EHB
instruction.
[ralf@linux-mips.org: Fixed whitespace damage.]
Patchwork: https://patchwork.linux-mips.org/patch/3773/
Disintegrate asm/system.h for MIPS.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
cc: linux-mips@linux-mips.org
For the case PM_DEFAULT_MASK == 0, we were placing a branch in the
delay slot of another branch. This leads to undefined behavior.
Patchwork: https://patchwork.linux-mips.org/patch/2775/
Only some GCC versions such as gcc 4.2 notice that the variable wr in
build_r3000_tlb_modify_handler is used uninitialized. When using one
of those GCCs the build will fail due to -Werror. GCC 4.6 does not
warn about the uninitialized use of wr.
This issue was introduced by 7211f4d7a3dcbe57c5d396c334dca525315dceb2
[MIPS: Close races in TLB modify handlers.]
Reported-by: Ganesan Ramalingam <ganesan18@gmail.com>
Page table entries are made invalid by writing a zero into the the PTE
slot in a page table. This creates a race condition with the TLB
modify handlers when they are updating the PTE.
CPU0 CPU1
Test for _PAGE_PRESENT
. set to not _PAGE_PRESENT (zero)
Set to _PAGE_VALID
So now the page not present value (zero) is suddenly valid and user
space programs have access to physical page zero.
We close the race by putting the test for _PAGE_PRESENT and setting of
_PAGE_VALID into an atomic LL/SC section. This requires more registers
than just K0 and K1 in the handlers, so we need to save some registers
to a save area and then restore them when we are done.
The save area is an array of cacheline aligned structures that should
not suffer cache line bouncing as they are CPU private.
[ralf@linux-mips.org: Fix !defined(CONFIG_MIPS_PGD_C0_CONTEXT) build error.]
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2577/
CPU_XLR case added to mm/tlbex.c
CPU_XLR case added to mm/c-r4k.c for PINDEX attribute
Feature overrides for XLR cpu.
Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com>
Patchwork: https://patchwork.linux-mips.org/patch/2333/
CC arch/mips/mm/tlbex.o
arch/mips/mm/tlbex.c: In function 'build_r4000_tlb_refill_handler':
arch/mips/mm/tlbex.c:1155:22: error: variable 'vmalloc_mode' set but not used [-Werror=unused-but-set-variable]
arch/mips/mm/tlbex.c:1154:28: error: variable 'htlb_info' set but not used [-Werror=unused-but-set-variable]
cc1: all warnings being treated as errors
