Now LOONGSON_CHIPCFG register definition doesn't depend on CPUFREQ any
more, so CPU_SUPPORTS_CPUFREQ is no longer needed for suspend/resume.
Remove CONFIG_LOONGSON_SUSPEND and use CONFIG_SUSPEND instead.
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Cc: John Crispin <john@phrozen.org>
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/11274/
Commit 3adeb2566b9b ("MIPS: Loongson: Improve LEFI firmware interface")
made the number of UARTs dynamic if LEFI_FIRMWARE_INTERFACE is configured.
Unfortunately, it did not initialize the number of UARTs if
LEFI_FIRMWARE_INTERFACE is not configured. As a result, the Fulong2e
system has no console.
Fixes: 3adeb2566b9b ("MIPS: Loongson: Improve LEFI firmware interface")
Acked-by: Huacai Chen <chenhc@lemote.com>
Tested-by: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/11076/
Almost everyone implements dma_set_mask the same way, although some time
that's hidden in ->set_dma_mask methods.
This patch consolidates those into a common implementation that either
calls ->set_dma_mask if present or otherwise uses the default
implementation. Some architectures used to only call ->set_dma_mask
after the initial checks, and those instance have been fixed to do the
full work. h8300 implemented dma_set_mask bogusly as a no-ops and has
been fixed.
Unfortunately some architectures overload unrelated semantics like changing
the dma_ops into it so we still need to allow for an architecture override
for now.
[jcmvbkbc@gmail.com: fix xtensa]
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Since 2009 we have a nice asm-generic header implementing lots of DMA API
functions for architectures using struct dma_map_ops, but unfortunately
it's still missing a lot of APIs that all architectures still have to
duplicate.
This series consolidates the remaining functions, although we still need
arch opt outs for two of them as a few architectures have very
non-standard implementations.
This patch (of 5):
The coherent DMA allocator works the same over all architectures supporting
dma_map operations.
This patch consolidates them and converges the minor differences:
- the debug_dma helpers are now called from all architectures, including
those that were previously missing them
- dma_alloc_from_coherent and dma_release_from_coherent are now always
called from the generic alloc/free routines instead of the ops
dma-mapping-common.h always includes dma-coherent.h to get the defintions
for them, or the stubs if the architecture doesn't support this feature
- checks for ->alloc / ->free presence are removed. There is only one
magic instead of dma_map_ops without them (mic_dma_ops) and that one
is x86 only anyway.
Besides that only x86 needs special treatment to replace a default devices
if none is passed and tweak the gfp_flags. An optional arch hook is provided
for that.
[linux@roeck-us.net: fix build]
Migrate loongson driver to the new 'set-state' interface provided by
clockevents core, the earlier 'set-mode' interface is marked obsolete
now.
This also enables us to implement callbacks for new states of clockevent
devices, for example: ONESHOT_STOPPED.
[ralf@linux-mips.org: Folded in Viresh's followon fix.]
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Cc: Hongliang Tao <taohl@lemote.com>
Cc: Valentin Rothberg <valentinrothberg@gmail.com>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: linaro-kernel@lists.linaro.org
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Patchwork: https://patchwork.linux-mips.org/patch/10608/
Patchwork: https://patchwork.linux-mips.org/patch/10883/
The majority of SMP platforms handle their IPIs through do_IRQ()
which calls irq_{enter/exit}(). When a call function IPI is received,
smp_call_function_interrupt() is called which also calls
irq_{enter,exit}(), meaning irq_count is raised twice.
When tick broadcasting is used (which is implemented via a call
function IPI), this incorrectly causes all CPU idle time on the core
receiving broadcast ticks to be accounted as time spent servicing
IRQs, as account_process_tick() will account as such if irq_count is
greater than 1. This results in 100% CPU usage being reported on a
core which receives its ticks via broadcast.
This patch removes the SMP smp_call_function_interrupt() wrapper which
calls irq_{enter,exit}(). Platforms which handle their IPIs through
do_IRQ() now call generic_smp_call_function_interrupt() directly to
avoid incrementing irq_count a second time. Platforms which don't
(loongson, sgi-ip27, sibyte) call generic_smp_call_function_interrupt()
wrapped in irq_{enter,exit}().
Signed-off-by: Alex Smith <alex.smith@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/10770/
CC arch/mips/loongson64/lemote-2f/clock.o
/home/ralf/src/linux/linux-mips/arch/mips/loongson64/lemote-2f/clock.c:18:40: fatal error: asm/mach-loongson/loongson.h: No such file or directory
#include <asm/mach-loongson/loongson.h>
compilation terminated.
The file looks as if it is non-modular, but it piggy-backs
off CONFIG_SERIAL_8250 which is tristate. If set to "=m"
we will get this after the init/module header cleanup:
arch/mips/loongson/common/serial.c:76:1: error: data definition has no type or storage class [-Werror]
arch/mips/loongson/common/serial.c:76:1: error: type defaults to 'int' in declaration of 'device_initcall' [-Werror=implicit-int]
arch/mips/loongson/common/serial.c:76:1: error: parameter names (without types) in function declaration [-Werror]
arch/mips/loongson/common/serial.c:58:19: error: 'serial_init' defined but not used [-Werror=unused-function]
cc1: all warnings being treated as errors
make[3]: *** [arch/mips/loongson/common/serial.o] Error 1
Make it clearly modular, and add a module_exit function,
so that we avoid the above breakage.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Currently, code of Loongson-2/3 is under loongson directory and code of
Loongson-1 is under loongson1 directory. Besides, there are Kconfig
options such as MACH_LOONGSON and MACH_LOONGSON1. This naming style is
very ugly and confusing. Since Loongson-2/3 are both 64-bit general-
purpose CPU while Loongson-1 is 32-bit SoC, we rename both file names
and Kconfig symbols from loongson/loongson1 to loongson64/loongson32.
[ralf@linux-mips.org: Resolve a number of simple conflicts.]
Cc: Kelvin Cheung <keguang.zhang@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/9790/
