path: root/arch/mips/lantiq/prom.h
2014-04-30of/fdt: consolidate built-in dtb section variablesRob Herring
Unify the various architectures __dtb_start and __dtb_end definitions moving them into of_fdt.h. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: James Hogan <james.hogan@imgtec.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: linux-metag@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux@lists.openrisc.net Cc: linux-xtensa@linux-xtensa.org Tested-by: Grant Likely <grant.likely@linaro.org> Tested-by: Stephen Chivers <schivers@csc.com>
2014-04-30mips: convert fdt pointers to opaque pointersRob Herring
The architecture code does not need to access the internals of the FDT blob directly, so make the pointers to it void * and use char arrays for section variables. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Ralf Baechle <ralf@linux-mips.org> Tested-by: Grant Likely <grant.likely@linaro.org>
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-05-21OF: MIPS: lantiq: implement OF supportJohn Crispin
Activate USE_OF, add a sample DTS file and convert the core soc code to OF. Signed-off-by: John Crispin <blogic@openwrt.org> Cc: linux-mips@linux-mips.org Cc: devicetree-discuss@lists.ozlabs.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3803/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-05-21MIPS: lantiq: drop mips_machine supportJohn Crispin
Before we are able to add OF support, we really want to drop all the bloat needed to register all the platform devices. Signed-off-by: John Crispin <blogic@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3800/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-05-15MIPS: lantiq: add xway soc idsJohn Crispin
Add the soc ids for additional xway socs. The patch also merges the amazon_se code with the other socs. Signed-off-by: John Crispin <blogic@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3707/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add mips_machine supportJohn Crispin
This patch adds support for Gabor's mips_machine patch. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: Gabor Juhos <juhosg@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2251/ Patchwork: https://patchwork.linux-mips.org/patch/2358/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add initial support for Lantiq SoCsJohn Crispin
Add initial support for Mips based SoCs made by Lantiq. This series will add support for the XWAY family. The series allows booting a minimal system using a initramfs or NOR. Missing drivers and support for Amazon and GPON family will be provided in a later series. [Ralf: Remove some cargo cult programming and fixed formatting.] Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2252/ Patchwork: https://patchwork.linux-mips.org/patch/2371/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
