commit 8712b27c5723c26400a2b350faf1d6d9fd7ffaad upstream.
The function_graph_enter() function does the work of calling the function
graph hook function and the management of the shadow stack, simplifying the
work done in the architecture dependent prepare_ftrace_return().
Have MIPS use the new code, and remove the shadow stack management as well as
having to set up the trace structure.
This is needed to prepare for a fix of a design bug on how the curr_ret_stack
is used.
Cc: Paul Burton <paul.burton@mips.com>
Cc: James Hogan <jhogan@kernel.org>
Cc: linux-mips@linux-mips.org
Cc: stable@kernel.org
Fixes: 03274a3ffb449 ("tracing/fgraph: Adjust fgraph depth before calling trace return callback")
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
[ Upstream commit dc57aaf95a516f70e2d527d8287a0332c481a226 ]
After changing CPU online status, it will not be sent any IPIs such as in
__flush_cache_all() on software coherency systems. Do this before disabling
local IRQ.
Signed-off-by: Dengcheng Zhu <dzhu@wavecomp.com>
Signed-off-by: Paul Burton <paul.burton@mips.com>
Patchwork: https://patchwork.linux-mips.org/patch/20571/
Cc: pburton@wavecomp.com
Cc: ralf@linux-mips.org
Cc: rachel.mozes@intel.com
Commit 8ce355cf2e38 ("MIPS: Setup boot_command_line before
plat_mem_setup") fixed a problem for systems which have
CONFIG_CMDLINE_BOOL=y & use a DT with a chosen node that has either no
bootargs property or an empty one. In this configuration
early_init_dt_scan_chosen() copies CONFIG_CMDLINE into
boot_command_line, but the MIPS code doesn't know this so it appends
CONFIG_CMDLINE (via builtin_cmdline) to boot_command_line again. The
result is that boot_command_line contains the arguments from
CONFIG_CMDLINE twice.
That commit took the approach of simply setting up boot_command_line
from the MIPS code before early_init_dt_scan_chosen() runs, causing it
not to copy CONFIG_CMDLINE to boot_command_line if a chosen node with no
bootargs property is found.
Unfortunately this is problematic for systems which do have a non-empty
bootargs property & CONFIG_CMDLINE_BOOL=y. There
early_init_dt_scan_chosen() will overwrite boot_command_line with the
arguments from DT, which means we lose those from CONFIG_CMDLINE
entirely. This breaks CONFIG_MIPS_CMDLINE_DTB_EXTEND. If we have
CONFIG_MIPS_CMDLINE_FROM_BOOTLOADER or
CONFIG_MIPS_CMDLINE_BUILTIN_EXTEND selected and the DT has a bootargs
property which we should ignore, it will instead be honoured breaking
those configurations too.
Fix this by reverting commit 8ce355cf2e38 ("MIPS: Setup
boot_command_line before plat_mem_setup") to restore the former
behaviour, and fixing the CONFIG_CMDLINE duplication issue by
initializing boot_command_line to a non-empty string that
early_init_dt_scan_chosen() will not overwrite with CONFIG_CMDLINE.
This is a little ugly, but cleanup in this area is on its way. In the
meantime this is at least easy to backport & contains the ugliness
within arch/mips/.
Fixes: 8ce355cf2e38 ("MIPS: Setup boot_command_line before plat_mem_setup")
References: https://patchwork.linux-mips.org/patch/18804/
Patchwork: https://patchwork.linux-mips.org/patch/20813/
Cc: Frank Rowand <frowand.list@gmail.com>
Cc: Jaedon Shin <jaedon.shin@gmail.com>
Cc: Mathieu Malaterre <malat@debian.org>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: devicetree@vger.kernel.org
Cc: stable@vger.kernel.org # v4.16+
When using the legacy mmap layout, for example triggered using ulimit -s
unlimited, get_unmapped_area() fills memory from bottom to top starting
from a fairly low address near TASK_UNMAPPED_BASE.
This placement is suboptimal if the user application wishes to allocate
large amounts of heap memory using the brk syscall. With the VDSO being
located low in the user's virtual address space, the amount of space
available for access using brk is limited much more than it was prior to
the introduction of the VDSO.
For example:
# ulimit -s unlimited; cat /proc/self/maps
00400000-004ec000 r-xp 00000000 08:00 71436 /usr/bin/coreutils
004fc000-004fd000 rwxp 000ec000 08:00 71436 /usr/bin/coreutils
004fd000-0050f000 rwxp 00000000 00:00 0
00cc3000-00ce4000 rwxp 00000000 00:00 0 [heap]
2ab96000-2ab98000 r--p 00000000 00:00 0 [vvar]
2ab98000-2ab99000 r-xp 00000000 00:00 0 [vdso]
2ab99000-2ab9d000 rwxp 00000000 00:00 0
Resolve this by adjusting STACK_TOP to reserve space for the VDSO &
providing an address hint to get_unmapped_area() causing it to use this
space even when using the legacy mmap layout.
We reserve enough space for the VDSO, plus 1MB or 256MB for 32 bit & 64
bit systems respectively within which we randomize the VDSO base
address. Previously this randomization was taken care of by the mmap
base address randomization performed by arch_mmap_rnd(). The 1MB & 256MB
sizes are somewhat arbitrary but chosen such that we have some
randomization without taking up too much of the user's virtual address
space, which is often in short supply for 32 bit systems.
With this the VDSO is always mapped at a high address, leaving lots of
space for statically linked programs to make use of brk:
00c28000-00c49000 rwxp 00000000 00:00 0 [heap]
7f67c000-7f69d000 rwxp 00000000 00:00 0 [stack]
7f7fc000-7f7fd000 rwxp 00000000 00:00 0
7fcf1000-7fcf3000 r--p 00000000 00:00 0 [vvar]
7fcf3000-7fcf4000 r-xp 00000000 00:00 0 [vdso]
Reported-by: Huacai Chen <chenhc@lemote.com>
Fixes: ebb5e78cc634 ("MIPS: Initial implementation of a VDSO")
Cc: Huacai Chen <chenhc@lemote.com>
Cc: stable@vger.kernel.org # v4.4+
When a system suffers from dcache aliasing a user program may observe
stale VDSO data from an aliased cache line. Notably this can break the
expectation that clock_gettime(CLOCK_MONOTONIC, ...) is, as its name
suggests, monotonic.
In order to ensure that users observe updates to the VDSO data page as
intended, align the user mappings of the VDSO data page such that their
cache colouring matches that of the virtual address range which the
kernel will use to update the data page - typically its unmapped address
within kseg0.
This ensures that we don't introduce aliasing cache lines for the VDSO
data page, and therefore that userland will observe updates without
requiring cache invalidation.
Reported-by: Hauke Mehrtens <hauke@hauke-m.de>
Reported-by: Rene Nielsen <rene.nielsen@microsemi.com>
Reported-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Patchwork: https://patchwork.linux-mips.org/patch/20344/
Tested-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Tested-by: Hauke Mehrtens <hauke@hauke-m.de>
git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux
Pull MIPS fixes from Paul Burton:
- Fix microMIPS build failures by adding a .insn directive to the
barrier_before_unreachable() asm statement in order to convince the
toolchain that the asm statement is a valid branch target rather
than a bogus attempt to switch ISA.
- Clean up our declarations of TLB functions that we overwrite with
generated code in order to prevent the compiler making assumptions
about alignment that cause microMIPS kernels built with GCC 7 &
above to die early during boot.
- Fix up a regression for MIPS32 kernels which slipped into the main
MIPS pull for 4.19, causing CONFIG_32BIT=y kernels to contain
inappropriate MIPS64 instructions.
- Extend our existing workaround for MIPSr6 builds that end up using
the __multi3 intrinsic to GCC 7 & below, rather than just GCC 7.
* tag 'mips_4.19_2' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux:
MIPS: lib: Provide MIPS64r6 __multi3() for GCC < 7
MIPS: Workaround GCC __builtin_unreachable reordering bug
compiler.h: Allow arch-specific asm/compiler.h
MIPS: Avoid move psuedo-instruction whilst using MIPS_ISA_LEVEL
MIPS: Consistently declare TLB functions
MIPS: Export tlbmiss_handler_setup_pgd near its definition
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
- Restructure of lockdep and latency tracers
This is the biggest change. Joel Fernandes restructured the hooks
from irqs and preemption disabling and enabling. He got rid of a lot
of the preprocessor #ifdef mess that they caused.
He turned both lockdep and the latency tracers to use trace events
inserted in the preempt/irqs disabling paths. But unfortunately,
these started to cause issues in corner cases. Thus, parts of the
code was reverted back to where lockdep and the latency tracers just
get called directly (without using the trace events). But because the
original change cleaned up the code very nicely we kept that, as well
as the trace events for preempt and irqs disabling, but they are
limited to not being called in NMIs.
- Have trace events use SRCU for "rcu idle" calls. This was required
for the preempt/irqs off trace events. But it also had to not allow
them to be called in NMI context. Waiting till Paul makes an NMI safe
SRCU API.
- New notrace SRCU API to allow trace events to use SRCU.
- Addition of mcount-nop option support
- SPDX headers replacing GPL templates.
- Various other fixes and clean ups.
- Some fixes are marked for stable, but were not fully tested before
the merge window opened.
* tag 'trace-v4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (44 commits)
tracing: Fix SPDX format headers to use C++ style comments
tracing: Add SPDX License format tags to tracing files
tracing: Add SPDX License format to bpf_trace.c
blktrace: Add SPDX License format header
s390/ftrace: Add -mfentry and -mnop-mcount support
tracing: Add -mcount-nop option support
tracing: Avoid calling cc-option -mrecord-mcount for every Makefile
tracing: Handle CC_FLAGS_FTRACE more accurately
Uprobe: Additional argument arch_uprobe to uprobe_write_opcode()
Uprobes: Simplify uprobe_register() body
tracepoints: Free early tracepoints after RCU is initialized
uprobes: Use synchronize_rcu() not synchronize_sched()
tracing: Fix synchronizing to event changes with tracepoint_synchronize_unregister()
ftrace: Remove unused pointer ftrace_swapper_pid
tracing: More reverting of "tracing: Centralize preemptirq tracepoints and unify their usage"
tracing/irqsoff: Handle preempt_count for different configs
tracing: Partial revert of "tracing: Centralize preemptirq tracepoints and unify their usage"
tracing: irqsoff: Account for additional preempt_disable
trace: Use rcu_dereference_raw for hooks from trace-event subsystem
tracing/kprobes: Fix within_notrace_func() to check only notrace functions
Pull MIPS updates from Paul Burton:
"Here are the main MIPS changes for 4.19.
An overview of the general architecture changes:
- Massive DMA ops refactoring from Christoph Hellwig (huzzah for
deleting crufty code!).
- We introduce NT_MIPS_DSP & NT_MIPS_FP_MODE ELF notes &
corresponding regsets to expose DSP ASE & floating point mode state
respectively, both for live debugging & core dumps.
- We better optimize our code by hard-coding cpu_has_* macros at
compile time where their values are known due to the ISA revision
that the kernel build is targeting.
- The EJTAG exception handler now better handles SMP systems, where
it was previously possible for CPUs to clobber a register value
saved by another CPU.
- Our implementation of memset() gained a couple of fixes for MIPSr6
systems to return correct values in some cases where stores fault.
- We now implement ioremap_wc() using the uncached-accelerated cache
coherency attribute where supported, which is detected during boot,
and fall back to plain uncached access where necessary. The
MIPS-specific (and unused in tree) ioremap_uncached_accelerated() &
ioremap_cacheable_cow() are removed.
- The prctl(PR_SET_FP_MODE, ...) syscall is better supported for SMP
systems by reworking the way we ensure remote CPUs that may be
running threads within the affected process switch mode.
- Systems using the MIPS Coherence Manager will now set the
MIPS_IC_SNOOPS_REMOTE flag to avoid some unnecessary cache
maintenance overhead when flushing the icache.
- A few fixes were made for building with clang/LLVM, which now
sucessfully builds kernels for many of our platforms.
- Miscellaneous cleanups all over.
And some platform-specific changes:
- ar7 gained stubs for a few clock API functions to fix build
failures for some drivers.
- ath79 gained support for a few new SoCs, a few fixes & better
gpio-keys support.
- Ci20 now exposes its SPI bus using the spi-gpio driver.
- The generic platform can now auto-detect a suitable value for
PHYS_OFFSET based upon the memory map described by the device tree,
allowing us to avoid wasting memory on page book-keeping for
systems where RAM starts at a non-zero physical address.
- Ingenic systems using the jz4740 platform code now link their
vmlinuz higher to allow for kernels of a realistic size.
- Loongson32 now builds the kernel targeting MIPSr1 rather than
MIPSr2 to avoid CPU errata.
- Loongson64 gains a couple of fixes, a workaround for a write
buffering issue & support for the Loongson 3A R3.1 CPU.
- Malta now uses the piix4-poweroff driver to handle powering down.
- Microsemi Ocelot gained support for its SPI bus & NOR flash, its
second MDIO bus and can now be supported by a FIT/.itb image.
- Octeon saw a bunch of header cleanups which remove a lot of
duplicate or unused code"
* tag 'mips_4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux: (123 commits)
MIPS: Remove remnants of UASM_ISA
MIPS: netlogic: xlr: Remove erroneous check in nlm_fmn_send()
MIPS: VDSO: Force link endianness
MIPS: Always specify -EB or -EL when using clang
MIPS: Use dins to simplify __write_64bit_c0_split()
MIPS: Use read-write output operand in __write_64bit_c0_split()
MIPS: Avoid using array as parameter to write_c0_kpgd()
MIPS: vdso: Allow clang's --target flag in VDSO cflags
MIPS: genvdso: Remove GOT checks
MIPS: Remove obsolete MIPS checks for DST node "chosen@0"
MIPS: generic: Remove input symbols from defconfig
MIPS: Delete unused code in linux32.c
MIPS: Remove unused sys_32_mmap2
MIPS: Remove nabi_no_regargs
mips: dts: mscc: enable spi and NOR flash support on ocelot PCB123
mips: dts: mscc: Add spi on Ocelot
MIPS: Loongson: Merge load addresses
MIPS: Loongson: Set Loongson32 to MIPS32R1
MIPS: mscc: ocelot: add interrupt controller properties to GPIO controller
MIPS: generic: Select MIPS_AUTO_PFN_OFFSET
Add addition argument 'arch_uprobe' to uprobe_write_opcode().
We need this in later set of patches.
Link: http://lkml.kernel.org/r/20180809041856.1547-3-ravi.bangoria@linux.ibm.com
Reviewed-by: Song Liu <songliubraving@fb.com>
Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.ibm.com>
Since at least the beginning of the git era we've declared our TLB
exception handling functions inconsistently. They're actually functions,
but we declare them as arrays of u32 where each u32 is an encoded
instruction. This has always been the case for arch/mips/mm/tlbex.c, and
has also been true for arch/mips/kernel/traps.c since commit
86a1708a9d54 ("MIPS: Make tlb exception handler definitions and
declarations match.") which aimed for consistency but did so by
consistently making the our C code inconsistent with our assembly.
This is all usually harmless, but when using GCC 7 or newer to build a
kernel targeting microMIPS (ie. CONFIG_CPU_MICROMIPS=y) it becomes
problematic. With microMIPS bit 0 of the program counter indicates the
ISA mode. When bit 0 is zero instructions are decoded using the standard
MIPS32 or MIPS64 ISA. When bit 0 is one instructions are decoded using
microMIPS. This means that function pointers become odd - their least
significant bit is one for microMIPS code. We work around this in cases
where we need to access code using loads & stores with our
msk_isa16_mode() macro which simply clears bit 0 of the value it is
given:
#define msk_isa16_mode(x) ((x) & ~0x1)
For example we do this for our TLB load handler in
build_r4000_tlb_load_handler():
u32 *p = (u32 *)msk_isa16_mode((ulong)handle_tlbl);
We then write code to p, expecting it to be suitably aligned (our LEAF
macro aligns functions on 4 byte boundaries, so (ulong)handle_tlbl will
give a value one greater than a multiple of 4 - ie. the start of a
function on a 4 byte boundary, with the ISA mode bit 0 set).
This worked fine up to GCC 6, but GCC 7 & onwards is smart enough to
presume that handle_tlbl which we declared as an array of u32s must be
aligned sufficiently that bit 0 of its address will never be set, and as
a result optimize out msk_isa16_mode(). This leads to p having an
address with bit 0 set, and when we go on to attempt to store code at
that address we take an address error exception due to the unaligned
memory access.
This leads to an exception prior to the kernel having configured its own
exception handlers, so we jump to whatever handlers the bootloader
configured. In the case of QEMU this results in a silent hang, since it
has no useful general exception vector.
Fix this by consistently declaring our TLB-related functions as
functions. For handle_tlbl(), handle_tlbs() & handle_tlbm() we do this
in asm/tlbex.h & we make use of the existing declaration of
tlbmiss_handler_setup_pgd() in asm/mmu_context.h. Our TLB handler
generation code in arch/mips/mm/tlbex.c is adjusted to deal with these
definitions, in most cases simply by casting the function pointers to
u32 pointers.
This allows us to include asm/mmu_context.h in arch/mips/mm/tlbex.c to
get the definitions of tlbmiss_handler_setup_pgd & pgd_current, removing
some needless duplication. Consistently using msk_isa16_mode() on
function pointers means we no longer need the
tlbmiss_handler_setup_pgd_start symbol so that is removed entirely.
Now that we're declaring our functions as functions GCC stops optimizing
out msk_isa16_mode() & a microMIPS kernel built with either GCC 7.3.0 or
8.1.0 boots successfully.
The A() & AA() macros have been unused since commit 05e4396651ca
("[MIPS] Use SYSVIPC_COMPAT to fix various problems on N32"), which
switched to the more standard compat_ptr().
RLIM_INFINITY32, RESOURCE32() & struct rlimit32 have been present but
unused since the beginning of the git era.
Remove the dead code.
Patchwork: https://patchwork.linux-mips.org/patch/20108/
The sys_32_mmap2 function has been unused since we started using syscall
wrappers in commit dbda6ac08976 ("MIPS: CVE-2009-0029: Enable syscall
wrappers."), and is indeed identical to the sys_mips_mmap2 function that
replaced it in sys32_call_table.
Patchwork: https://patchwork.linux-mips.org/patch/20107/
Our sigreturn functions make use of a macro named nabi_no_regargs to
declare 8 dummy arguments to a function, forcing the compiler to expect
a pt_regs structure on the stack rather than in argument registers. This
is an ugly hack which unnecessarily causes these sigreturn functions to
need to care about the calling convention of the ABI the kernel is built
for. Although this is abstracted via nabi_no_regargs, it's still ugly &
unnecessary.
Remove nabi_no_regargs & the struct pt_regs argument from sigreturn
functions, and instead use current_pt_regs() to find the struct pt_regs
on the stack, which works cleanly regardless of ABI.
Patchwork: https://patchwork.linux-mips.org/patch/20106/
On systems where physical memory begins at a non-zero address, defining
PHYS_OFFSET (which influences ARCH_PFN_OFFSET) can save us time & memory
by avoiding book-keeping for pages from address zero to the start of
memory.
Some MIPS platforms already make use of this, but with the definition of
PHYS_OFFSET being compile-time constant it hasn't been possible to
enable this optimization for a kernel which may run on systems with
varying physical memory base addresses.
Introduce a new Kconfig option CONFIG_MIPS_AUTO_PFN_OFFSET which, when
enabled, makes ARCH_PFN_OFFSET a variable & detects it from the boot
memory map (which for example may have been populated from DT). The
relationship with PHYS_OFFSET is reversed, with PHYS_OFFSET now being
based on ARCH_PFN_OFFSET. This is because ARCH_PFN_OFFSET is used far
more often, so avoiding the need for runtime calculation gives us a
smaller impact on kernel text size (0.1% rather than 0.15% for
64r6el_defconfig).
Suggested-by: Vladimir Kondratiev <vladimir.kondratiev@intel.com>
Patchwork: https://patchwork.linux-mips.org/patch/20048/
Loongson-3A R3.1 is the bugfix revision of Loongson-3A R3.
All Loongson-3 CPU family:
Code-name Brand-name PRId
Loongson-3A R1 Loongson-3A1000 0x6305
Loongson-3A R2 Loongson-3A2000 0x6308
Loongson-3A R3 Loongson-3A3000 0x6309
Loongson-3A R3.1 Loongson-3A3000 0x630d
Loongson-3B R1 Loongson-3B1000 0x6306
Loongson-3B R2 Loongson-3B1500 0x6307
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Patchwork: https://patchwork.linux-mips.org/patch/19263/
Cc: James Hogan <james.hogan@mips.com>
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Cc: Huacai Chen <chenhuacai@gmail.com>
Define an NT_MIPS_FP_MODE core file note and implement a corresponding
regset holding the state handled by PR_SET_FP_MODE and PR_GET_FP_MODE
prctl(2) requests. This lets debug software correctly interpret the
contents of floating-point general registers both in live debugging and
in core files, and also switch floating-point modes of a live process.
[paul.burton@mips.com:
- Changed NT_MIPS_FP_MODE to 0x801 to match first nibble of
NT_MIPS_DSP, which was also changed to avoid a conflict.]
Signed-off-by: Maciej W. Rozycki <macro@mips.com>
Patchwork: https://patchwork.linux-mips.org/patch/19331/
Define an NT_MIPS_DSP core file note type and implement a corresponding
regset holding the DSP ASE register context, following the layout of the
`mips_dsp_state' structure, except for the DSPControl register stored as
a 64-bit rather than 32-bit quantity in a 64-bit note.
The lack of DSP ASE register saving to core files can be considered a
design flaw with commit e50c0a8fa60d ("Support the MIPS32 / MIPS64 DSP
ASE."), leading to an incomplete state being saved. Consequently no DSP
ASE regset has been created with commit 7aeb753b5353 ("MIPS: Implement
task_user_regset_view."), when regset support was added to the MIPS
port.
Additionally there is no way for ptrace(2) to correctly access the DSP
accumulator registers in n32 processes with the existing interfaces.
This is due to 32-bit truncation of data passed with PTRACE_PEEKUSR and
PTRACE_POKEUSR requests, which cannot be avoided owing to how the data
types for ptrace(3) have been defined. This new NT_MIPS_DSP regset
fills the missing interface gap.
- Change NT_MIPS_DSP to 0x800 to avoid conflict with NT_VMCOREDD
introduced by commit 2724273e8fd0 ("vmcore: add API to collect
hardware dump in second kernel").
- Drop stable tag. Whilst I agree the lack of this functionality can
be considered a flaw in earlier DSP ASE support, it's still new
functionality which doesn't meet up to the requirements set out in
Documentation/process/stable-kernel-rules.rst.]
References: 7aeb753b5353 ("MIPS: Implement task_user_regset_view.")
Patchwork: https://patchwork.linux-mips.org/patch/19330/
Cc: linux-fsdevel@vger.kernel.org
Use the `unsigned long' rather than `__u32' type for DSP accumulator
registers, like with the regular MIPS multiply/divide accumulator and
general-purpose registers, as all are 64-bit in 64-bit implementations
and using a 32-bit data type leads to contents truncation on context
saving.
Update `arch_ptrace' and `compat_arch_ptrace' accordingly, removing
casts that are similarly not used with multiply/divide accumulator or
general-purpose register accesses.
Fixes: e50c0a8fa60d ("Support the MIPS32 / MIPS64 DSP ASE.")
Patchwork: https://patchwork.linux-mips.org/patch/19329/
Cc: stable@vger.kernel.org # 2.6.15+
prom_putchar() is used centrally in early printk infrastructure therefore
at least MIPS should agree on the function return type.
- Include linux/types.h in asm/setup.h to gain the bool typedef before
we start include asm/setup.h elsewhere.
- Include asm/setup.h in all files that use or define prom_putchar().
- Also standardise on signed rather than unsigned char argument.]
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Patchwork: https://patchwork.linux-mips.org/patch/19842/
Cc: Jonas Gorski <jonas.gorski@gmail.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Annotate cpu_wait implementations using the __cpuidle macro which
places these functions in the .cpuidle.text section. This allows
cpu_in_idle() to return true for PC values which fall within these
functions, allowing nmi_backtrace() to produce cleaner output for CPUs
running idle functions. For example:
# echo l >/proc/sysrq-trigger
[ 38.587170] sysrq: SysRq : Show backtrace of all active CPUs
[ 38.593657] NMI backtrace for cpu 1
[ 38.597611] CPU: 1 PID: 161 Comm: sh Not tainted 4.18.0-rc1+ #27
[ 38.604306] Stack : 00000000 00000004 00000006 80486724 00000000 00000000 00000000 00000000
[ 38.613647] 80e17eda 00000034 00000000 00000000 80d20000 80b67e98 8e559c90 0ffe1e88
[ 38.622986] 00000000 00000000 80e70000 00000000 8f61db18 38312e34 722d302e 202b3163
[ 38.632324] 8e559d3c 8e559adc 00000001 6b636162 80d20000 80000000 00000000 80d1cfa4
[ 38.641664] 00000001 80d20000 80d19520 00000000 00000003 80836724 00000004 80e10004
[ 38.650993] ...
[ 38.653724] Call Trace:
[ 38.656499] [<8040cdd0>] show_stack+0xa0/0x144
[ 38.661475] [<80b67e98>] dump_stack+0xe8/0x120
[ 38.666455] [<80b6f6d4>] nmi_cpu_backtrace+0x1b4/0x1cc
[ 38.672189] [<80b6f81c>] nmi_trigger_cpumask_backtrace+0x130/0x1e4
[ 38.679081] [<808295d8>] __handle_sysrq+0xc0/0x180
[ 38.684421] [<80829b84>] write_sysrq_trigger+0x50/0x64
[ 38.690176] [<8061c984>] proc_reg_write+0xd0/0xfc
[ 38.695447] [<805aac1c>] __vfs_write+0x54/0x194
[ 38.700500] [<805aaf24>] vfs_write+0xe0/0x18c
[ 38.705360] [<805ab190>] ksys_write+0x7c/0xf0
[ 38.710238] [<80416018>] syscall_common+0x34/0x58
[ 38.715558] Sending NMI from CPU 1 to CPUs 0,2-3:
[ 38.720916] NMI backtrace for cpu 0 skipped: idling at r4k_wait_irqoff+0x2c/0x34
[ 38.729186] NMI backtrace for cpu 3 skipped: idling at r4k_wait_irqoff+0x2c/0x34
[ 38.737449] NMI backtrace for cpu 2 skipped: idling at r4k_wait_irqoff+0x2c/0x34
Without this we get register value & backtrace output from all CPUs,
which is generally useless for those running the idle function & serves
only to overwhelm & obfuscate the meaningful output from non-idle CPUs.
Patchwork: https://patchwork.linux-mips.org/patch/19598/
The current MIPS implementation of arch_trigger_cpumask_backtrace() is
broken because it attempts to use synchronous IPIs despite the fact that
it may be run with interrupts disabled.
This means that when arch_trigger_cpumask_backtrace() is invoked, for
example by the RCU CPU stall watchdog, we may:
- Deadlock due to use of synchronous IPIs with interrupts disabled,
causing the CPU that's attempting to generate the backtrace output
to hang itself.
- Not succeed in generating the desired output from remote CPUs.
- Produce warnings about this from smp_call_function_many(), for
example:
[42760.526910] INFO: rcu_sched detected stalls on CPUs/tasks:
[42760.535755] 0-...!: (1 GPs behind) idle=ade/140000000000000/0 softirq=526944/526945 fqs=0
[42760.547874] 1-...!: (0 ticks this GP) idle=e4a/140000000000000/0 softirq=547885/547885 fqs=0
[42760.559869] (detected by 2, t=2162 jiffies, g=266689, c=266688, q=33)
[42760.568927] ------------[ cut here ]------------
[42760.576146] WARNING: CPU: 2 PID: 1216 at kernel/smp.c:416 smp_call_function_many+0x88/0x20c
[42760.587839] Modules linked in:
[42760.593152] CPU: 2 PID: 1216 Comm: sh Not tainted 4.15.4-00373-gee058bb4d0c2 #2
[42760.603767] Stack : 8e09bd20 8e09bd20 8e09bd20 fffffff0 00000007 00000006 00000000 8e09bca8
[42760.616937] 95b2b379 95b2b379 807a0080 00000007 81944518 0000018a 00000032 00000000
[42760.630095] 00000000 00000030 80000000 00000000 806eca74 00000009 8017e2b8 000001a0
[42760.643169] 00000000 00000002 00000000 8e09baa4 00000008 808b8008 86d69080 8e09bca0
[42760.656282] 8e09ad50 805e20aa 00000000 00000000 00000000 8017e2b8 00000009 801070ca
[42760.669424] ...
[42760.673919] Call Trace:
[42760.678672] [<27fde568>] show_stack+0x70/0xf0
[42760.685417] [<84751641>] dump_stack+0xaa/0xd0
[42760.692188] [<699d671c>] __warn+0x80/0x92
[42760.698549] [<68915d41>] warn_slowpath_null+0x28/0x36
[42760.705912] [<f7c76c1c>] smp_call_function_many+0x88/0x20c
[42760.713696] [<6bbdfc2a>] arch_trigger_cpumask_backtrace+0x30/0x4a
[42760.722216] [<f845bd33>] rcu_dump_cpu_stacks+0x6a/0x98
[42760.729580] [<796e7629>] rcu_check_callbacks+0x672/0x6ac
[42760.737476] [<059b3b43>] update_process_times+0x18/0x34
[42760.744981] [<6eb94941>] tick_sched_handle.isra.5+0x26/0x38
[42760.752793] [<478d3d70>] tick_sched_timer+0x1c/0x50
[42760.759882] [<e56ea39f>] __hrtimer_run_queues+0xc6/0x226
[42760.767418] [<e88bbcae>] hrtimer_interrupt+0x88/0x19a
[42760.775031] [<6765a19e>] gic_compare_interrupt+0x2e/0x3a
[42760.782761] [<0558bf5f>] handle_percpu_devid_irq+0x78/0x168
[42760.790795] [<90c11ba2>] generic_handle_irq+0x1e/0x2c
[42760.798117] [<1b6d462c>] gic_handle_local_int+0x38/0x86
[42760.805545] [<b2ada1c7>] gic_irq_dispatch+0xa/0x14
[42760.812534] [<90c11ba2>] generic_handle_irq+0x1e/0x2c
[42760.820086] [<c7521934>] do_IRQ+0x16/0x20
[42760.826274] [<9aef3ce6>] plat_irq_dispatch+0x62/0x94
[42760.833458] [<6a94b53c>] except_vec_vi_end+0x70/0x78
[42760.840655] [<22284043>] smp_call_function_many+0x1ba/0x20c
[42760.848501] [<54022b58>] smp_call_function+0x1e/0x2c
[42760.855693] [<ab9fc705>] flush_tlb_mm+0x2a/0x98
[42760.862730] [<0844cdd0>] tlb_flush_mmu+0x1c/0x44
[42760.869628] [<cb259b74>] arch_tlb_finish_mmu+0x26/0x3e
[42760.877021] [<1aeaaf74>] tlb_finish_mmu+0x18/0x66
[42760.883907] [<b3fce717>] exit_mmap+0x76/0xea
[42760.890428] [<c4c8a2f6>] mmput+0x80/0x11a
[42760.896632] [<a41a08f4>] do_exit+0x1f4/0x80c
[42760.903158] [<ee01cef6>] do_group_exit+0x20/0x7e
[42760.909990] [<13fa8d54>] __wake_up_parent+0x0/0x1e
[42760.917045] [<46cf89d0>] smp_call_function_many+0x1a2/0x20c
[42760.924893] [<8c21a93b>] syscall_common+0x14/0x1c
[42760.931765] ---[ end trace 02aa09da9dc52a60 ]---
[42760.938342] ------------[ cut here ]------------
[42760.945311] WARNING: CPU: 2 PID: 1216 at kernel/smp.c:291 smp_call_function_single+0xee/0xf8
This patch switches MIPS' arch_trigger_cpumask_backtrace() to use async
IPIs & smp_call_function_single_async() in order to resolve this
problem. We ensure use of the pre-allocated call_single_data_t
structures is serialized by maintaining a cpumask indicating that
they're busy, and refusing to attempt to send an IPI when a CPU's bit is
set in this mask. This should only happen if a CPU hasn't responded to a
previous backtrace IPI - ie. if it's hung - and we print a warning to
the console in this case.
I've marked this for stable branches as far back as v4.9, to which it
applies cleanly. Strictly speaking the faulty MIPS implementation can be
traced further back to commit 856839b76836 ("MIPS: Add
arch_trigger_all_cpu_backtrace() function") in v3.19, but kernel
versions v3.19 through v4.8 will require further work to backport due to
the rework performed in commit 9a01c3ed5cdb ("nmi_backtrace: add more
trigger_*_cpu_backtrace() methods").
Patchwork: https://patchwork.linux-mips.org/patch/19597/
Cc: stable@vger.kernel.org # v4.9+
Fixes: 856839b76836 ("MIPS: Add arch_trigger_all_cpu_backtrace() function")
Fixes: 9a01c3ed5cdb ("nmi_backtrace: add more trigger_*_cpu_backtrace() methods")
The generic nmi_cpu_backtrace() function calls show_regs() when a struct
pt_regs is available, and dump_stack() otherwise. If we were to make use
of the generic nmi_cpu_backtrace() with MIPS' current implementation of
show_regs() this would mean that we see only register data with no
accompanying stack information, in contrast with our current
implementation which calls dump_stack() regardless of whether register
state is available.
In preparation for making use of the generic nmi_cpu_backtrace() to
implement arch_trigger_cpumask_backtrace(), have our implementation of
show_regs() call dump_stack() and drop the explicit dump_stack() call in
arch_dump_stack() which is invoked by arch_trigger_cpumask_backtrace().
This will allow the output we produce to remain the same after a later
patch switches to using nmi_cpu_backtrace(). It may mean that we produce
extra stack output in other uses of show_regs(), but this:
1) Seems harmless.
2) Is good for consistency between arch_trigger_cpumask_backtrace()
and other users of show_regs().
3) Matches the behaviour of the ARM & PowerPC architectures.
Marked for stable back to v4.9 as a prerequisite of the following patch
"MIPS: Call dump_stack() from show_regs()".
Patchwork: https://patchwork.linux-mips.org/patch/19596/
Commit 784e0300fe9f ("rseq: Avoid infinite recursion when delivering
SIGSEGV") added a new ksig argument to the rseq_signal_deliver() &
rseq_handle_notify_resume() functions, and was merged in v4.18-rc2.
Meanwhile MIPS support for restartable sequences was also merged in
v4.18-rc2 with commit 9ea141ad5471 ("MIPS: Add support for restartable
sequences"), and therefore didn't get updated for the API change.
This results in build failures like the following:
CC arch/mips/kernel/signal.o
arch/mips/kernel/signal.c: In function 'handle_signal':
arch/mips/kernel/signal.c:804:22: error: passing argument 1 of
'rseq_signal_deliver' from incompatible pointer type
[-Werror=incompatible-pointer-types]
rseq_signal_deliver(regs);
In file included from ./include/linux/context_tracking.h:5,
from arch/mips/kernel/signal.c:12:
./include/linux/sched.h:1811:56: note: expected 'struct ksignal *' but
argument is of type 'struct pt_regs *'
static inline void rseq_signal_deliver(struct ksignal *ksig,
arch/mips/kernel/signal.c:804:2: error: too few arguments to function
Fix this by adding the ksig argument as was done for other architectures
in commit 784e0300fe9f ("rseq: Avoid infinite recursion when delivering
SIGSEGV").
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Patchwork: https://patchwork.linux-mips.org/patch/19603/
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Boqun Feng <boqun.feng@gmail.com>
Commit 6b8322576e9d ("MIPS: Force CPUs to lose FP context during mode
switches") ensures that we react to PR_SET_FP_MODE prctl syscalls
quickly by broadcasting an IPI in order to cause CPUs to lose FPU access
when necessary. Whilst it achieves that, unfortunately it causes all
sorts of strange race conditions because:
1) The IPI may arrive at a point where the FPU is in the process of
being enabled, but that process is not yet complete leading to a
state we aren't prepared to handle. For example:
[ 370.215903] do_cpu invoked from kernel context![#1]:
[ 370.221064] CPU: 0 PID: 963 Comm: fp-prctl Not tainted 4.9.0-rc5-00323-g210db32-dirty #226
[ 370.229420] task: a8000000fd672e00 task.stack: a8000000fd630000
[ 370.235399] $ 0 : 0000000000000000 0000000000000001 0000000000000001 a8000000fd630000
[ 370.243882] $ 4 : a8000000fd672e00 0000000000000000 0000000000000453 0000000000000000
[ 370.252317] $ 8 : 0000000000000000 a8000000fd637c28 1000000000000000 0000000000000010
[ 370.260753] $12 : 00000000140084e0 ffffffff80109c00 0000000000000000 0000000000000002
[ 370.269179] $16 : ffffffff8092f080 a8000000fd672e00 ffffffff80107fe8 a8000000fd485000
[ 370.277612] $20 : ffffffff8084d328 ffffffff80940000 0000000000000009 ffffffff80930000
[ 370.286038] $24 : 0000000000000000 900000001612048c
[ 370.294476] $28 : a8000000fd630000 a8000000fd637ac0 ffffffff80937300 ffffffff8010807c
[ 370.302909] Hi : 0000000000000000
[ 370.306595] Lo : 0000000000000200
[ 370.310376] epc : ffffffff80115d38 _save_fp+0x10/0xa0
[ 370.315784] ra : ffffffff8010807c prepare_for_fp_mode_switch+0x94/0x1b0
[ 370.322707] Status: 140084e2 KX SX UX KERNEL EXL
[ 370.327980] Cause : 1080002c (ExcCode 0b)
[ 370.332091] PrId : 0001a428 (MIPS P6600)
[ 370.336179] Modules linked in:
[ 370.339486] Process fp-prctl (pid: 963, threadinfo=a8000000fd630000, task=a8000000fd672e00, tls=00000000756e67d0)
[ 370.349724] Stack : 0000000000000000 a8000000fd557dc0 0000000000000000 ffffffff801ca8e0
[ 370.358161] 0000000000000000 a8000000fd637b9c 0000000000000009 ffffffff80923780
[ 370.366575] ffffffff80850000 ffffffff8011610c 00000000000000b8 ffffffff801a5084
[ 370.374989] ffffffff8084a370 ffffffff8084a388 ffffffff80923780 ffffffff80923828
[ 370.383395] 0000000000010000 ffffffff809237a8 0000000000020000 ffffffff80a40000
[ 370.391817] 000000000000007c 00000000004a0000 00000000756dedd0 ffffffff801a5188
[ 370.400230] a800000002014900 0000000000000001 ffffffff80923780 0000000080923828
[ 370.408644] ffffffff80923780 ffffffff80923780 ffffffff80923828 ffffffff801a521c
[ 370.417066] ffffffff80923780 ffffffff80923828 0000000000010000 ffffffff801a8f84
[ 370.425472] ffffffff80a40000 a8000000fd637c20 ffffffff80a39240 0000000000000001
[ 370.433885] ...
[ 370.436562] Call Trace:
[ 370.439222] [<ffffffff80115d38>] _save_fp+0x10/0xa0
[ 370.444305] [<ffffffff8010807c>] prepare_for_fp_mode_switch+0x94/0x1b0
[ 370.451035] [<ffffffff801ca8e0>] flush_smp_call_function_queue+0xf8/0x230
[ 370.457991] [<ffffffff8011610c>] ipi_call_interrupt+0xc/0x20
[ 370.463814] [<ffffffff801a5084>] __handle_irq_event_percpu+0xc4/0x1a8
[ 370.470404] [<ffffffff801a5188>] handle_irq_event_percpu+0x20/0x68
[ 370.476734] [<ffffffff801a521c>] handle_irq_event+0x4c/0x88
[ 370.482486] [<ffffffff801a8f84>] handle_edge_irq+0x12c/0x210
[ 370.488316] [<ffffffff801a47a0>] generic_handle_irq+0x38/0x48
[ 370.494280] [<ffffffff804a2dbc>] gic_handle_shared_int+0x194/0x268
[ 370.500616] [<ffffffff801a47a0>] generic_handle_irq+0x38/0x48
[ 370.506529] [<ffffffff80107e60>] do_IRQ+0x18/0x28
[ 370.511445] [<ffffffff804a1524>] plat_irq_dispatch+0xc4/0x140
[ 370.517339] [<ffffffff80106230>] ret_from_irq+0x0/0x4
[ 370.522583] [<ffffffff8010fad4>] do_ri+0x4fc/0x7e8
[ 370.527546] [<ffffffff80106220>] ret_from_exception+0x0/0x10
2) The IPI may arrive during kernel use of the FPU, since we generally
only disable preemption around use of the FPU & leave interrupts
enabled. This can lead to us unexpectedly losing access to the FPU
in places where it previously had not been possible. For example:
do_cpu invoked from kernel context![#2]:
CPU: 2 PID: 7338 Comm: fp-prctl Tainted: G D 4.7.0-00424-g49b0c82
#2
task: 838e4000 ti: 88d38000 task.ti: 88d38000
$ 0 : 00000000 00000001 ffffffff 88d3fef8
$ 4 : 838e4000 88d38004 00000000 00000001
$ 8 : 3400fc01 801f8020 808e9100 24000000
$12 : dbffffff 807b69d8 807b0000 00000000
$16 : 00000000 80786150 00400fc4 809c0398
$20 : 809c0338 0040273c 88d3ff28 808e9d30
$24 : 808e9d30 00400fb4
$28 : 88d38000 88d3fe88 00000000 8011a2ac
Hi : 0040273c
Lo : 88d3ff28
epc : 80114178 _restore_fp+0x10/0xa0
ra : 8011a2ac mipsr2_decoder+0xd5c/0x1660
Status: 1400fc03 KERNEL EXL IE
PrId : 0001a920 (MIPS I6400)
Modules linked in:
Process fp-prctl (pid: 7338, threadinfo=88d38000, task=838e4000, tls=766527d0)
Stack : 00000000 00000000 00000000 88d3fe98 00000000 00000000 809c0398 809c0338
808e9100 00000000 88d3ff28 00400fc4 00400fc4 0040273c 7fb69e18 004a0000
004a0000 004a0000 7664add0 8010de18 00000000 00000000 88d3fef8 88d3ff28
808e9100 00000000 766527d0 8010e534 000c0000 85755000 8181d580 00000000
00000000 00000000 004a0000 00000000 766527d0 7fb69e18 004a0000 80105c20
Call Trace:
[<80114178>] _restore_fp+0x10/0xa0
[<8011a2ac>] mipsr2_decoder+0xd5c/0x1660
[<8010de18>] do_ri+0x90/0x6b8
[<80105c20>] ret_from_exception+0x0/0x10
At first glance a simple fix may seem to be to disable interrupts around
kernel use of the FPU rather than merely preemption, however this would
introduce further overhead outside of the mode switch path & doesn't
solve the third problem:
3) The IPI may arrive whilst the kernel is running code that will lead
to a preempt_disable() call & FPU usage soon. If this happens then
the IPI will be serviced & we'll proceed to enable an FPU whilst the
mode switch is in progress, leading to strange & inconsistent
behaviour.
Further to all of this is a separate but related problem:
4) There are various paths through which we may enable the FPU without
the user having triggered a coprocessor 1 disabled exception. These
paths are those in which we emulate instructions & then enable the
FPU with the expectation that the user might execute an FP
instruction shortly afterwards. However these paths have not
previously checked whether an FP mode switch is underway for the
task, and therefore could enable the FPU whilst such a mode switch
is in progress leading to strange & inconsistent behaviour for user
code.
This patch fixes all of the above by taking a step back & re-examining
our approach to FP mode switches. Up until now we have taken these basic
steps:
a) Prevent any threads that are part of the affected process from being
able to obtain ownership of the FPU.
b) Cause any threads that are part of the affected process and already
have ownership of an FPU to lose it.
c) Set the thread flags for each thread that is part of the affected
process to reflect the new FP mode.
d) Allow threads to obtain ownership of the FPU again.
This approach is however more complex than necessary. All that we really
require is that the mode switch has occurred for all threads that are
part of the affected process before mips_set_process_fp_mode(), and thus
the PR_SET_FP_MODE prctl() syscall, returns. This doesn't require that
we stop threads from owning or using an FPU whilst a mode switch occurs,
only that we force them to relinquish it after the mode switch has
occurred such that they next own an FPU with the correct mode
configured. Our basic steps therefore simplify to:
A) Set the thread flags for each thread that is part of the affected
B) Cause any threads that are part of the affected process and already
We implement B) by forcing each CPU which might be running a thread
which is part of the affected process to schedule a no-op function,
which causes the affected thread to lose its FPU ownership when it is
descheduled.
The end result is simpler FP mode switching with less overhead in the
FPU enable path (ie. enable_restore_fp_context()) and fewer moving
parts.
Fixes: 9791554b45a2 ("MIPS,prctl: add PR_[GS]ET_FP_MODE prctl options for MIPS")
Fixes: 6b8322576e9d ("MIPS: Force CPUs to lose FP context during mode switches")
Cc: stable <stable@vger.kernel.org> # v4.0+
On SMP systems, the shared ejtag debug buffer may be overwritten by
other cores, because every cores can generate ejtag exception at
same time.
Unfortunately, in that context, it's difficult to relax more registers
to access per cpu buffers. so use ll/sc to serialize the access.
This could in theory be backported at least as far back as the
beginning of the git era, however in general it's exceedingly rare
that anyone would hit this without further changes, so it doesn't seem
worthwhile marking for backport.]
Signed-off-by: Heiher <r@hev.cc>
Patchwork: https://patchwork.linux-mips.org/patch/19507/
Cc: jhogan@kernel.org
We want to be able to use it even when not building dma-default.c
in the near future.
Patchwork: https://patchwork.linux-mips.org/patch/19543/
Cc: David Daney <david.daney@cavium.com>
Cc: Kevin Cernekee <cernekee@gmail.com>
Cc: Jiaxun Yang <jiaxun.yang@flygoat.com>
Cc: Tom Bogendoerfer <tsbogend@alpha.franken.de>
Cc: iommu@lists.linux-foundation.org
Correct a couple of typos within comments in
arch/mips/kernel/relocate_kernel.S.
[paul.burton@mips.com: Add a commit message.]
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
Patchwork: https://patchwork.linux-mips.org/patch/19218/
Clear current_kprobe and enable preemption in kprobe
even if pre_handler returns !0.
This simplifies function override using kprobes.
Jprobe used to require to keep the preemption disabled and
keep current_kprobe until it returned to original function
entry. For this reason kprobe_int3_handler() and similar
arch dependent kprobe handers checks pre_handler result
and exit without enabling preemption if the result is !0.
After removing the jprobe, Kprobes does not need to
keep preempt disabled even if user handler returns !0
anymore.
But since the function override handler in error-inject
and bpf is also returns !0 if it overrides a function,
to balancing the preempt count, it enables preemption
and reset current kprobe by itself.
That is a bad design that is very buggy. This fixes
such unbalanced preempt-count and current_kprobes setting
in kprobes, bpf and error-inject.
Note: for powerpc and x86, this removes all preempt_disable
from kprobe_ftrace_handler because ftrace callbacks are
called under preempt disabled.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com>
Cc: Josef Bacik <jbacik@fb.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Rich Felker <dalias@libc.org>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: linux-ia64@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linux-snps-arc@lists.infradead.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: sparclinux@vger.kernel.org
Link: https://lore.kernel.org/lkml/152942494574.15209.12323837825873032258.stgit@devbox
Don't call the ->break_handler() from the MIPS kprobes code,
because it was only used by jprobes which got removed.
Link: https://lore.kernel.org/lkml/152942482953.15209.843924518200700137.stgit@devbox
Remove arch dependent setjump/longjump functions
and unused fields in kprobe_ctlblk for jprobes
from arch/mips.
Link: https://lore.kernel.org/lkml/152942451058.15209.3459785416221980965.stgit@devbox
Wire up the io_pgetevents syscall that was introduced by commit
7a074e96dee6 ("aio: implement io_pgetevents").
Patchwork: https://patchwork.linux-mips.org/patch/19593/
Wire up the restartable sequences (rseq) syscall for MIPS. This was
introduced by commit d7822b1e24f2 ("rseq: Introduce restartable
sequences system call") & MIPS now supports the prerequisites.
Reviewed-by: James Hogan <jhogan@kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/19525/
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Syscalls are not allowed inside restartable sequences, so add a call to
rseq_syscall() at the very beginning of the system call exit path when
CONFIG_DEBUG_RSEQ=y. This will help us to detect whether there is a
syscall issued erroneously inside a restartable sequence.
Patchwork: https://patchwork.linux-mips.org/patch/19522/
Implement support for restartable sequences on MIPS, which requires 3
simple things:
- Call rseq_handle_notify_resume() on return to userspace if
TIF_NOTIFY_RESUME is set.
- Call rseq_signal_deliver() to fixup the pre-signal stack frame when
a signal is delivered whilst executing a restartable sequence
critical section.
- Select CONFIG_HAVE_RSEQ.
Patchwork: https://patchwork.linux-mips.org/patch/19523/
ftrace_graph_caller was never run after calling ftrace_trace_function,
breaking the function graph tracer. Fix this, bringing it in line with the
x86 implementation.
While we're at it, also streamline the control flow of _mcount a bit to
reduce the number of branches.
This issue was reported before:
https://www.linux-mips.org/archives/linux-mips/2014-11/msg00295.html
Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net>
Tested-by: Matt Redfearn <matt.redfearn@mips.com>
Patchwork: https://patchwork.linux-mips.org/patch/18929/
Cc: stable@vger.kernel.org # v3.17+
With PHYS_ADDR_MAX there is now a type safe variant for all bits set.
Make use of it.
Patch created using a semantic patch as follows:
// <smpl>
typedef phys_addr_t;
-(phys_addr_t)ULLONG_MAX
+PHYS_ADDR_MAX
// </smpl>
Link: http://lkml.kernel.org/r/20180419214204.19322-1-stefan@agner.ch
Signed-off-by: Stefan Agner <stefan@agner.ch>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com> [arm64]
The changes to automatically test for working stack protector compiler
support in the Kconfig files removed the special STACKPROTECTOR_AUTO
option that picked the strongest stack protector that the compiler
supported.
That was all a nice cleanup - it makes no sense to have the AUTO case
now that the Kconfig phase can just determine the compiler support
directly.
HOWEVER.
It also meant that doing "make oldconfig" would now _disable_ the strong
stackprotector if you had AUTO enabled, because in a legacy config file,
the sane stack protector configuration would look like
CONFIG_HAVE_CC_STACKPROTECTOR=y
# CONFIG_CC_STACKPROTECTOR_NONE is not set
# CONFIG_CC_STACKPROTECTOR_REGULAR is not set
# CONFIG_CC_STACKPROTECTOR_STRONG is not set
CONFIG_CC_STACKPROTECTOR_AUTO=y
and when you ran this through "make oldconfig" with the Kbuild changes,
it would ask you about the regular CONFIG_CC_STACKPROTECTOR (that had
been renamed from CONFIG_CC_STACKPROTECTOR_REGULAR to just
CONFIG_CC_STACKPROTECTOR), but it would think that the STRONG version
used to be disabled (because it was really enabled by AUTO), and would
disable it in the new config, resulting in:
CONFIG_CC_HAS_STACKPROTECTOR_NONE=y
CONFIG_CC_STACKPROTECTOR=y
CONFIG_CC_HAS_SANE_STACKPROTECTOR=y
That's dangerously subtle - people could suddenly find themselves with
the weaker stack protector setup without even realizing.
The solution here is to just rename not just the old RECULAR stack
protector option, but also the strong one. This does that by just
removing the CC_ prefix entirely for the user choices, because it really
is not about the compiler support (the compiler support now instead
automatially impacts _visibility_ of the options to users).
This results in "make oldconfig" actually asking the user for their
choice, so that we don't have any silent subtle security model changes.
The end result would generally look like this:
CONFIG_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR_STRONG=y
where the "CC_" versions really are about internal compiler
infrastructure, not the user selections.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Pull MIPS updates from James Hogan:
"These are the main MIPS changes for 4.18.
Rough overview:
- MAINTAINERS: Add Paul Burton as MIPS co-maintainer
- Misc: Generic compiler intrinsics, Y2038 improvements, Perf+MT fixes
- Platform support: Netgear WNR1000 V3, Microsemi Ocelot integrated
switch, Ingenic watchdog cleanups
More detailed summary:
Maintainers:
- Add Paul Burton as MIPS co-maintainer, as I soon won't have access
to much MIPS hardware, nor enough time to properly maintain MIPS on
my own.
Miscellaneous:
- Use generic GCC library routines from lib/
- Add notrace to generic ucmpdi2 implementation
- Rename compiler intrinsic selects to GENERIC_LIB_*
- vmlinuz: Use generic ashldi3
- y2038: Convert update/read_persistent_clock() to *_clock64()
- sni: Remove read_persistent_clock()
- perf: Fix perf with MT counting other threads
- Probe for per-TC perf counters in cpu-probe.c
- Use correct VPE ID for VPE tracing
Minor cleanups:
- Avoid unneeded built-in.a in DTS dirs
- sc-debugfs: Re-use kstrtobool_from_user
- memset.S: Reinstate delay slot indentation
- VPE: Fix spelling "uneeded" -> "Unneeded"
Platform support:
BCM47xx:
- Add support for Netgear WNR1000 V3
- firmware: Support small NVRAM partitions
- Use __initdata for LEDs platform data
Ingenic:
- Watchdog driver & platform code improvements:
- Disable clock after stopping counter
- Use devm_* functions
- Drop module remove function
- Move platform reset code to restart handler in driver
- JZ4740: Convert watchdog instantiation to DT
- JZ4780: Fix watchdog DT node
- qi_lb60_defconfig: Enable watchdog driver
Microsemi:
- Ocelot: Add support for integrated switch
- pcb123: Connect phys to ports"
* tag 'mips_4.18' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux: (30 commits)
MIPS: ptrace: Make FPU context layout comments match reality
MIPS: memset.S: Reinstate delay slot indentation
MIPS: perf: Fix perf with MT counting other threads
MIPS: perf: Use correct VPE ID when setting up VPE tracing
MIPS: perf: More robustly probe for the presence of per-tc counters
MIPS: Probe for MIPS MT perf counters per TC
MIPS: mscc: Connect phys to ports on ocelot_pcb123
MIPS: mscc: Add switch to ocelot
MIPS: JZ4740: Drop old platform reset code
MIPS: qi_lb60: Enable the jz4740-wdt driver
MIPS: JZ4780: dts: Fix watchdog node
MIPS: JZ4740: dts: Add bindings for the jz4740-wdt driver
watchdog: JZ4740: Drop module remove function
watchdog: JZ4740: Register a restart handler
watchdog: JZ4740: Use devm_* functions
watchdog: JZ4740: Disable clock after stopping counter
MIPS: VPE: Fix spelling mistake: "uneeded" -> "unneeded"
MIPS: Re-use kstrtobool_from_user()
MIPS: Convert update_persistent_clock() to update_persistent_clock64()
Pull timers and timekeeping updates from Thomas Gleixner:
- Core infrastucture work for Y2038 to address the COMPAT interfaces:
+ Add a new Y2038 safe __kernel_timespec and use it in the core
code
+ Introduce config switches which allow to control the various
compat mechanisms
+ Use the new config switch in the posix timer code to control the
32bit compat syscall implementation.
- Prevent bogus selection of CPU local clocksources which causes an
endless reselection loop
- Remove the extra kthread in the clocksource code which has no value
and just adds another level of indirection
- The usual bunch of trivial updates, cleanups and fixlets all over the
place
- More SPDX conversions
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits)
clocksource/drivers/mxs_timer: Switch to SPDX identifier
clocksource/drivers/timer-imx-tpm: Switch to SPDX identifier
clocksource/drivers/timer-imx-gpt: Switch to SPDX identifier
clocksource/drivers/timer-imx-gpt: Remove outdated file path
clocksource/drivers/arc_timer: Add comments about locking while read GFRC
clocksource/drivers/mips-gic-timer: Add pr_fmt and reword pr_* messages
clocksource/drivers/sprd: Fix Kconfig dependency
clocksource: Move inline keyword to the beginning of function declarations
timer_list: Remove unused function pointer typedef
timers: Adjust a kernel-doc comment
tick: Prefer a lower rating device only if it's CPU local device
clocksource: Remove kthread
time: Change nanosleep to safe __kernel_* types
time: Change types to new y2038 safe __kernel_* types
time: Fix get_timespec64() for y2038 safe compat interfaces
time: Add new y2038 safe __kernel_timespec
posix-timers: Make compat syscalls depend on CONFIG_COMPAT_32BIT_TIME
time: Introduce CONFIG_COMPAT_32BIT_TIME
time: Introduce CONFIG_64BIT_TIME in architectures
compat: Enable compat_get/put_timespec64 always
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull siginfo updates from Eric Biederman:
"This set of changes close the known issues with setting si_code to an
invalid value, and with not fully initializing struct siginfo. There
remains work to do on nds32, arc, unicore32, powerpc, arm, arm64, ia64
and x86 to get the code that generates siginfo into a simpler and more
maintainable state. Most of that work involves refactoring the signal
handling code and thus careful code review.
Also not included is the work to shrink the in kernel version of
struct siginfo. That depends on getting the number of places that
directly manipulate struct siginfo under control, as it requires the
introduction of struct kernel_siginfo for the in kernel things.
Overall this set of changes looks like it is making good progress, and
with a little luck I will be wrapping up the siginfo work next
development cycle"
* 'siginfo-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (46 commits)
signal/sh: Stop gcc warning about an impossible case in do_divide_error
signal/mips: Report FPE_FLTUNK for undiagnosed floating point exceptions
signal/um: More carefully relay signals in relay_signal.
signal: Extend siginfo_layout with SIL_FAULT_{MCEERR|BNDERR|PKUERR}
signal: Remove unncessary #ifdef SEGV_PKUERR in 32bit compat code
signal/signalfd: Add support for SIGSYS
signal/signalfd: Remove __put_user from signalfd_copyinfo
signal/xtensa: Use force_sig_fault where appropriate
signal/xtensa: Consistenly use SIGBUS in do_unaligned_user
signal/um: Use force_sig_fault where appropriate
signal/sparc: Use force_sig_fault where appropriate
signal/sparc: Use send_sig_fault where appropriate
signal/sh: Use force_sig_fault where appropriate
signal/s390: Use force_sig_fault where appropriate
signal/riscv: Replace do_trap_siginfo with force_sig_fault
signal/riscv: Use force_sig_fault where appropriate
signal/parisc: Use force_sig_fault where appropriate
signal/parisc: Use force_sig_mceerr where appropriate
signal/openrisc: Use force_sig_fault where appropriate
signal/nios2: Use force_sig_fault where appropriate
Use 64-bit accesses for 64-bit floating-point general registers with
PTRACE_PEEKUSR, removing the truncation of their upper halves in the
FR=1 mode, caused by commit bbd426f542cb ("MIPS: Simplify FP context
access"), which inadvertently switched them to using 32-bit accesses.
The PTRACE_POKEUSR side is fine as it's never been broken and continues
using 64-bit accesses.
Fixes: bbd426f542cb ("MIPS: Simplify FP context access")
Cc: <stable@vger.kernel.org> # 3.15+
Patchwork: https://patchwork.linux-mips.org/patch/19334/
Signed-off-by: James Hogan <jhogan@kernel.org>
Having PR_FP_MODE_FRE (i.e. Config5.FRE) set without PR_FP_MODE_FR (i.e.
Status.FR) is not supported as the lone purpose of Config5.FRE is to
emulate Status.FR=0 handling on FPU hardware that has Status.FR=1
hardwired[1][2]. Also we do not handle this case elsewhere, and assume
throughout our code that TIF_HYBRID_FPREGS and TIF_32BIT_FPREGS cannot
be set both at once for a task, leading to inconsistent behaviour if
this does happen.
Return unsuccessfully then from prctl(2) PR_SET_FP_MODE calls requesting
PR_FP_MODE_FRE to be set with PR_FP_MODE_FR clear. This corresponds to
modes allowed by `mips_set_personality_fp'.
References:
[1] "MIPS Architecture For Programmers, Vol. III: MIPS32 / microMIPS32
Privileged Resource Architecture", Imagination Technologies,
Document Number: MD00090, Revision 6.02, July 10, 2015, Table 9.69
"Config5 Register Field Descriptions", p. 262
[2] "MIPS Architecture For Programmers, Volume III: MIPS64 / microMIPS64
Document Number: MD00091, Revision 6.03, December 22, 2015, Table
9.72 "Config5 Register Field Descriptions", p. 288
Cc: <stable@vger.kernel.org> # 4.0+
Patchwork: https://patchwork.linux-mips.org/patch/19327/
Correct comments across ptrace(2) handlers about an FPU register context
layout discrepancy between MIPS I and later ISAs, which was fixed with
`linux-mips.org' (LMO) commit 42533948caac ("Major pile of FP emulator
changes."), the fix corrected with LMO commit 849fa7a50dff ("R3k FPU
ptrace() handling fixes."), and then broken and fixed over and over
again, until last time fixed with commit 80cbfad79096 ("MIPS: Correct
MIPS I FP context layout").
NB running the GDB test suite for the relevant ABI/ISA and watching out
for regressions is advisable when poking around ptrace(2).
Patchwork: https://patchwork.linux-mips.org/patch/19326/
Most mips builds fail with
arch/mips/kernel/traps.c: In function ‘force_fcr31_sig’:
arch/mips/kernel/traps.c:732:2: error:
‘si_code’ may be used uninitialized in this function
Fix the problem by initializing si_code with FPE_FLTUNK (undiagnosed
floating point exception).
Fixes: f43a54a0d916 ("signal/mips: Use force_sig_fault where appropriate")
Cc: linux-mips@linux-mips.org
Cc: Eric W. Biederman <ebiederm@xmission.com>
When perf is used in non-system mode, i.e. without specifying CPUs to
count on, check_and_calc_range falls into the case when it sets
M_TC_EN_ALL in the counter config_base. This has the impact of always
counting for all of the threads in a core, even when the user has not
requested it. For example this can be seen with a test program which
executes 30002 instructions and 10000 branches running on one VPE and a
busy load on the other VPE in the core. Without this commit, the
expected count is not returned:
taskset 4 dd if=/dev/zero of=/dev/null count=100000 & taskset 8 perf
stat -e instructions:u,branches:u ./test_prog
Performance counter stats for './test_prog':
103235 instructions:u
17015 branches:u
In order to fix this, remove check_and_calc_range entirely and perform
all of the logic in mipsxx_pmu_enable_event. Since
mipsxx_pmu_enable_event now requires the range of the event, ensure that
it is set by mipspmu_perf_event_encode in the same circumstances as
before (i.e. #ifdef CONFIG_MIPS_MT_SMP && num_possible_cpus() > 1).
The logic of mipsxx_pmu_enable_event now becomes:
If the CPU is a BMIPS5000, then use the special vpe_id() implementation
to select which VPE to count.
If the counter has a range greater than a single VPE, i.e. it is a
core-wide counter, then ensure that the counter is set up to count
events from all TCs (though, since this is true by definition, is this
necessary? Just enabling a core-wide counter in the per-VPE case appears
experimentally to return the same counts. This is left in for now as the
logic was present before).
If the event is set up to count a particular CPU (i.e. system mode),
then the VPE ID of that CPU is used for the counter.
Otherwise, the event should be counted on the CPU scheduling this thread
(this was the critical bit missing from the previous implementation) so
the VPE ID of this CPU is used for the counter.
With this commit, the same test as before returns the counts expected:
30002 instructions:u
10000 branches:u
Signed-off-by: Matt Redfearn <matt.redfearn@mips.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/19138/
There are a couple of FIXME's in the perf code which state that
cpu_data[event->cpu].vpe_id reports 0 for both CPUs. This is no longer
the case, since the vpe_id is used extensively by SMP CPS.
VPE local counting gets around this by using smp_processor_id() instead.
As it happens this does work correctly to count events on the right VPE,
but relies on 2 assumptions:
a) Always having 2 VPEs / core.
b) The hardware only paying attention to the least significant bit of
the PERFCTL.VPEID field.
If either of these assumptions change then the incorrect VPEs events
will be counted.
Fix this by replacing smp_processor_id() with
cpu_vpe_id(¤t_cpu_data), in the vpe_id() macro, and pass vpe_id()
to M_PERFCTL_VPEID() when setting up PERFCTL.VPEID. The FIXME's can also
be removed since they no longer apply.
Patchwork: https://patchwork.linux-mips.org/patch/19137/
The presence of per TC performance counters is now detected by
cpu-probe.c and indicated by MIPS_CPU_MT_PER_TC_PERF_COUNTERS in
cpu_data. Switch detection of the feature to use this new flag rather
than blindly testing the implementation specific config7 register with a
magic number.
Cc: Maciej W. Rozycki <macro@mips.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Robert Richter <rric@kernel.org>
Cc: oprofile-list@lists.sf.net
Patchwork: https://patchwork.linux-mips.org/patch/19142/
Processors implementing the MIPS MT ASE may have performance counters
implemented per core or per TC. Processors implemented by MIPS
Technologies signify presence per TC through a bit in the implementation
specific Config7 register. Currently the code which probes for their
presence blindly reads a magic number corresponding to this bit, despite
it potentially having a different meaning in the CPU implementation.
Since CPU features are generally detected by cpu-probe.c, perform the
detection here instead. Introduce cpu_set_mt_per_tc_perf which checks
the bit in config7 and call it from MIPS CPUs known to implement this
bit and the MT ASE, specifically, the 34K, 1004K and interAptiv.
Once the presence of the per-tc counter is indicated in cpu_data, tests
for it can be updated to use this flag.
Suggested-by: James Hogan <jhogan@kernel.org>
Cc: Matt Redfearn <matt.redfearn@mips.com>
Cc: linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/19136/
