Patch (b6c7a324df37b "MIPS: Fix get_frame_info() handling of
microMIPS function size.") introduces additional function size
check for microMIPS by only checking insn between ip and ip + func_size.
However, func_size in get_frame_info() is always 0 if KALLSYMS is not
enabled. This causes get_frame_info() to return immediately without
calculating correct frame_size, which in turn causes "Can't analyze
schedule() prologue" warning messages at boot time.
This patch removes func_size check, and let the frame_size check run
up to 128 insns for both MIPS and microMIPS.
Signed-off-by: Jun-Ru Chang <jrjang@realtek.com>
Signed-off-by: Tony Wu <tonywu@realtek.com>
Signed-off-by: Paul Burton <paul.burton@mips.com>
Fixes: b6c7a324df37b ("MIPS: Fix get_frame_info() handling of microMIPS function size.")
Cc: <ralf@linux-mips.org>
Cc: <jhogan@kernel.org>
Cc: <macro@mips.com>
Cc: <yamada.masahiro@socionext.com>
Cc: <peterz@infradead.org>
Cc: <mingo@kernel.org>
Cc: <linux-mips@vger.kernel.org>
Cc: <linux-kernel@vger.kernel.org>
The fp_mode_switching field in struct mm_context_t was left unused by
commit 8c8d953c2800 ("MIPS: Schedule on CPUs we need to lose FPU for a
mode switch") in v4.19, with nothing modifying its value & nothing
waiting on it having any particular value after that commit. Remove the
unused field & the one remaining reference to it.
When using the legacy mmap layout, for example triggered using ulimit -s
unlimited, get_unmapped_area() fills memory from bottom to top starting
from a fairly low address near TASK_UNMAPPED_BASE.
This placement is suboptimal if the user application wishes to allocate
large amounts of heap memory using the brk syscall. With the VDSO being
located low in the user's virtual address space, the amount of space
available for access using brk is limited much more than it was prior to
the introduction of the VDSO.
For example:
# ulimit -s unlimited; cat /proc/self/maps
00400000-004ec000 r-xp 00000000 08:00 71436 /usr/bin/coreutils
004fc000-004fd000 rwxp 000ec000 08:00 71436 /usr/bin/coreutils
004fd000-0050f000 rwxp 00000000 00:00 0
00cc3000-00ce4000 rwxp 00000000 00:00 0 [heap]
2ab96000-2ab98000 r--p 00000000 00:00 0 [vvar]
2ab98000-2ab99000 r-xp 00000000 00:00 0 [vdso]
2ab99000-2ab9d000 rwxp 00000000 00:00 0
Resolve this by adjusting STACK_TOP to reserve space for the VDSO &
providing an address hint to get_unmapped_area() causing it to use this
space even when using the legacy mmap layout.
We reserve enough space for the VDSO, plus 1MB or 256MB for 32 bit & 64
bit systems respectively within which we randomize the VDSO base
address. Previously this randomization was taken care of by the mmap
base address randomization performed by arch_mmap_rnd(). The 1MB & 256MB
sizes are somewhat arbitrary but chosen such that we have some
randomization without taking up too much of the user's virtual address
space, which is often in short supply for 32 bit systems.
With this the VDSO is always mapped at a high address, leaving lots of
space for statically linked programs to make use of brk:
00c28000-00c49000 rwxp 00000000 00:00 0 [heap]
7f67c000-7f69d000 rwxp 00000000 00:00 0 [stack]
7f7fc000-7f7fd000 rwxp 00000000 00:00 0
7fcf1000-7fcf3000 r--p 00000000 00:00 0 [vvar]
7fcf3000-7fcf4000 r-xp 00000000 00:00 0 [vdso]
Reported-by: Huacai Chen <chenhc@lemote.com>
Fixes: ebb5e78cc634 ("MIPS: Initial implementation of a VDSO")
Cc: Huacai Chen <chenhc@lemote.com>
Cc: linux-mips@linux-mips.org
Cc: stable@vger.kernel.org # v4.4+
git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux
Pull MIPS updates from Paul Burton:
"Here are the main MIPS changes for 4.19.
An overview of the general architecture changes:
- Massive DMA ops refactoring from Christoph Hellwig (huzzah for
deleting crufty code!).
- We introduce NT_MIPS_DSP & NT_MIPS_FP_MODE ELF notes &
corresponding regsets to expose DSP ASE & floating point mode state
respectively, both for live debugging & core dumps.
- We better optimize our code by hard-coding cpu_has_* macros at
compile time where their values are known due to the ISA revision
that the kernel build is targeting.
- The EJTAG exception handler now better handles SMP systems, where
it was previously possible for CPUs to clobber a register value
saved by another CPU.
- Our implementation of memset() gained a couple of fixes for MIPSr6
systems to return correct values in some cases where stores fault.
- We now implement ioremap_wc() using the uncached-accelerated cache
coherency attribute where supported, which is detected during boot,
and fall back to plain uncached access where necessary. The
MIPS-specific (and unused in tree) ioremap_uncached_accelerated() &
ioremap_cacheable_cow() are removed.
- The prctl(PR_SET_FP_MODE, ...) syscall is better supported for SMP
systems by reworking the way we ensure remote CPUs that may be
running threads within the affected process switch mode.
- Systems using the MIPS Coherence Manager will now set the
MIPS_IC_SNOOPS_REMOTE flag to avoid some unnecessary cache
maintenance overhead when flushing the icache.
- A few fixes were made for building with clang/LLVM, which now
sucessfully builds kernels for many of our platforms.
- Miscellaneous cleanups all over.
And some platform-specific changes:
- ar7 gained stubs for a few clock API functions to fix build
failures for some drivers.
- ath79 gained support for a few new SoCs, a few fixes & better
gpio-keys support.
- Ci20 now exposes its SPI bus using the spi-gpio driver.
- The generic platform can now auto-detect a suitable value for
PHYS_OFFSET based upon the memory map described by the device tree,
allowing us to avoid wasting memory on page book-keeping for
systems where RAM starts at a non-zero physical address.
- Ingenic systems using the jz4740 platform code now link their
vmlinuz higher to allow for kernels of a realistic size.
- Loongson32 now builds the kernel targeting MIPSr1 rather than
MIPSr2 to avoid CPU errata.
- Loongson64 gains a couple of fixes, a workaround for a write
buffering issue & support for the Loongson 3A R3.1 CPU.
- Malta now uses the piix4-poweroff driver to handle powering down.
- Microsemi Ocelot gained support for its SPI bus & NOR flash, its
second MDIO bus and can now be supported by a FIT/.itb image.
- Octeon saw a bunch of header cleanups which remove a lot of
duplicate or unused code"
* tag 'mips_4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux: (123 commits)
MIPS: Remove remnants of UASM_ISA
MIPS: netlogic: xlr: Remove erroneous check in nlm_fmn_send()
MIPS: VDSO: Force link endianness
MIPS: Always specify -EB or -EL when using clang
MIPS: Use dins to simplify __write_64bit_c0_split()
MIPS: Use read-write output operand in __write_64bit_c0_split()
MIPS: Avoid using array as parameter to write_c0_kpgd()
MIPS: vdso: Allow clang's --target flag in VDSO cflags
MIPS: genvdso: Remove GOT checks
MIPS: Remove obsolete MIPS checks for DST node "chosen@0"
MIPS: generic: Remove input symbols from defconfig
MIPS: Delete unused code in linux32.c
MIPS: Remove unused sys_32_mmap2
MIPS: Remove nabi_no_regargs
mips: dts: mscc: enable spi and NOR flash support on ocelot PCB123
mips: dts: mscc: Add spi on Ocelot
MIPS: Loongson: Merge load addresses
MIPS: Loongson: Set Loongson32 to MIPS32R1
MIPS: mscc: ocelot: add interrupt controller properties to GPIO controller
MIPS: generic: Select MIPS_AUTO_PFN_OFFSET
The current MIPS implementation of arch_trigger_cpumask_backtrace() is
broken because it attempts to use synchronous IPIs despite the fact that
it may be run with interrupts disabled.
This means that when arch_trigger_cpumask_backtrace() is invoked, for
example by the RCU CPU stall watchdog, we may:
- Deadlock due to use of synchronous IPIs with interrupts disabled,
causing the CPU that's attempting to generate the backtrace output
to hang itself.
- Not succeed in generating the desired output from remote CPUs.
- Produce warnings about this from smp_call_function_many(), for
example:
[42760.526910] INFO: rcu_sched detected stalls on CPUs/tasks:
[42760.535755] 0-...!: (1 GPs behind) idle=ade/140000000000000/0 softirq=526944/526945 fqs=0
[42760.547874] 1-...!: (0 ticks this GP) idle=e4a/140000000000000/0 softirq=547885/547885 fqs=0
[42760.559869] (detected by 2, t=2162 jiffies, g=266689, c=266688, q=33)
[42760.568927] ------------[ cut here ]------------
[42760.576146] WARNING: CPU: 2 PID: 1216 at kernel/smp.c:416 smp_call_function_many+0x88/0x20c
[42760.587839] Modules linked in:
[42760.593152] CPU: 2 PID: 1216 Comm: sh Not tainted 4.15.4-00373-gee058bb4d0c2 #2
[42760.603767] Stack : 8e09bd20 8e09bd20 8e09bd20 fffffff0 00000007 00000006 00000000 8e09bca8
[42760.616937] 95b2b379 95b2b379 807a0080 00000007 81944518 0000018a 00000032 00000000
[42760.630095] 00000000 00000030 80000000 00000000 806eca74 00000009 8017e2b8 000001a0
[42760.643169] 00000000 00000002 00000000 8e09baa4 00000008 808b8008 86d69080 8e09bca0
[42760.656282] 8e09ad50 805e20aa 00000000 00000000 00000000 8017e2b8 00000009 801070ca
[42760.669424] ...
[42760.673919] Call Trace:
[42760.678672] [<27fde568>] show_stack+0x70/0xf0
[42760.685417] [<84751641>] dump_stack+0xaa/0xd0
[42760.692188] [<699d671c>] __warn+0x80/0x92
[42760.698549] [<68915d41>] warn_slowpath_null+0x28/0x36
[42760.705912] [<f7c76c1c>] smp_call_function_many+0x88/0x20c
[42760.713696] [<6bbdfc2a>] arch_trigger_cpumask_backtrace+0x30/0x4a
[42760.722216] [<f845bd33>] rcu_dump_cpu_stacks+0x6a/0x98
[42760.729580] [<796e7629>] rcu_check_callbacks+0x672/0x6ac
[42760.737476] [<059b3b43>] update_process_times+0x18/0x34
[42760.744981] [<6eb94941>] tick_sched_handle.isra.5+0x26/0x38
[42760.752793] [<478d3d70>] tick_sched_timer+0x1c/0x50
[42760.759882] [<e56ea39f>] __hrtimer_run_queues+0xc6/0x226
[42760.767418] [<e88bbcae>] hrtimer_interrupt+0x88/0x19a
[42760.775031] [<6765a19e>] gic_compare_interrupt+0x2e/0x3a
[42760.782761] [<0558bf5f>] handle_percpu_devid_irq+0x78/0x168
[42760.790795] [<90c11ba2>] generic_handle_irq+0x1e/0x2c
[42760.798117] [<1b6d462c>] gic_handle_local_int+0x38/0x86
[42760.805545] [<b2ada1c7>] gic_irq_dispatch+0xa/0x14
[42760.812534] [<90c11ba2>] generic_handle_irq+0x1e/0x2c
[42760.820086] [<c7521934>] do_IRQ+0x16/0x20
[42760.826274] [<9aef3ce6>] plat_irq_dispatch+0x62/0x94
[42760.833458] [<6a94b53c>] except_vec_vi_end+0x70/0x78
[42760.840655] [<22284043>] smp_call_function_many+0x1ba/0x20c
[42760.848501] [<54022b58>] smp_call_function+0x1e/0x2c
[42760.855693] [<ab9fc705>] flush_tlb_mm+0x2a/0x98
[42760.862730] [<0844cdd0>] tlb_flush_mmu+0x1c/0x44
[42760.869628] [<cb259b74>] arch_tlb_finish_mmu+0x26/0x3e
[42760.877021] [<1aeaaf74>] tlb_finish_mmu+0x18/0x66
[42760.883907] [<b3fce717>] exit_mmap+0x76/0xea
[42760.890428] [<c4c8a2f6>] mmput+0x80/0x11a
[42760.896632] [<a41a08f4>] do_exit+0x1f4/0x80c
[42760.903158] [<ee01cef6>] do_group_exit+0x20/0x7e
[42760.909990] [<13fa8d54>] __wake_up_parent+0x0/0x1e
[42760.917045] [<46cf89d0>] smp_call_function_many+0x1a2/0x20c
[42760.924893] [<8c21a93b>] syscall_common+0x14/0x1c
[42760.931765] ---[ end trace 02aa09da9dc52a60 ]---
[42760.938342] ------------[ cut here ]------------
[42760.945311] WARNING: CPU: 2 PID: 1216 at kernel/smp.c:291 smp_call_function_single+0xee/0xf8
This patch switches MIPS' arch_trigger_cpumask_backtrace() to use async
IPIs & smp_call_function_single_async() in order to resolve this
problem. We ensure use of the pre-allocated call_single_data_t
structures is serialized by maintaining a cpumask indicating that
they're busy, and refusing to attempt to send an IPI when a CPU's bit is
set in this mask. This should only happen if a CPU hasn't responded to a
previous backtrace IPI - ie. if it's hung - and we print a warning to
the console in this case.
I've marked this for stable branches as far back as v4.9, to which it
applies cleanly. Strictly speaking the faulty MIPS implementation can be
traced further back to commit 856839b76836 ("MIPS: Add
arch_trigger_all_cpu_backtrace() function") in v3.19, but kernel
versions v3.19 through v4.8 will require further work to backport due to
the rework performed in commit 9a01c3ed5cdb ("nmi_backtrace: add more
trigger_*_cpu_backtrace() methods").
Patchwork: https://patchwork.linux-mips.org/patch/19597/
Cc: James Hogan <jhogan@kernel.org>
Cc: stable@vger.kernel.org # v4.9+
Fixes: 856839b76836 ("MIPS: Add arch_trigger_all_cpu_backtrace() function")
Fixes: 9a01c3ed5cdb ("nmi_backtrace: add more trigger_*_cpu_backtrace() methods")
The generic nmi_cpu_backtrace() function calls show_regs() when a struct
pt_regs is available, and dump_stack() otherwise. If we were to make use
of the generic nmi_cpu_backtrace() with MIPS' current implementation of
show_regs() this would mean that we see only register data with no
accompanying stack information, in contrast with our current
implementation which calls dump_stack() regardless of whether register
state is available.
In preparation for making use of the generic nmi_cpu_backtrace() to
implement arch_trigger_cpumask_backtrace(), have our implementation of
show_regs() call dump_stack() and drop the explicit dump_stack() call in
arch_dump_stack() which is invoked by arch_trigger_cpumask_backtrace().
This will allow the output we produce to remain the same after a later
patch switches to using nmi_cpu_backtrace(). It may mean that we produce
extra stack output in other uses of show_regs(), but this:
1) Seems harmless.
2) Is good for consistency between arch_trigger_cpumask_backtrace()
and other users of show_regs().
3) Matches the behaviour of the ARM & PowerPC architectures.
Marked for stable back to v4.9 as a prerequisite of the following patch
"MIPS: Call dump_stack() from show_regs()".
Patchwork: https://patchwork.linux-mips.org/patch/19596/
Commit 6b8322576e9d ("MIPS: Force CPUs to lose FP context during mode
switches") ensures that we react to PR_SET_FP_MODE prctl syscalls
quickly by broadcasting an IPI in order to cause CPUs to lose FPU access
when necessary. Whilst it achieves that, unfortunately it causes all
sorts of strange race conditions because:
1) The IPI may arrive at a point where the FPU is in the process of
being enabled, but that process is not yet complete leading to a
state we aren't prepared to handle. For example:
[ 370.215903] do_cpu invoked from kernel context![#1]:
[ 370.221064] CPU: 0 PID: 963 Comm: fp-prctl Not tainted 4.9.0-rc5-00323-g210db32-dirty #226
[ 370.229420] task: a8000000fd672e00 task.stack: a8000000fd630000
[ 370.235399] $ 0 : 0000000000000000 0000000000000001 0000000000000001 a8000000fd630000
[ 370.243882] $ 4 : a8000000fd672e00 0000000000000000 0000000000000453 0000000000000000
[ 370.252317] $ 8 : 0000000000000000 a8000000fd637c28 1000000000000000 0000000000000010
[ 370.260753] $12 : 00000000140084e0 ffffffff80109c00 0000000000000000 0000000000000002
[ 370.269179] $16 : ffffffff8092f080 a8000000fd672e00 ffffffff80107fe8 a8000000fd485000
[ 370.277612] $20 : ffffffff8084d328 ffffffff80940000 0000000000000009 ffffffff80930000
[ 370.286038] $24 : 0000000000000000 900000001612048c
[ 370.294476] $28 : a8000000fd630000 a8000000fd637ac0 ffffffff80937300 ffffffff8010807c
[ 370.302909] Hi : 0000000000000000
[ 370.306595] Lo : 0000000000000200
[ 370.310376] epc : ffffffff80115d38 _save_fp+0x10/0xa0
[ 370.315784] ra : ffffffff8010807c prepare_for_fp_mode_switch+0x94/0x1b0
[ 370.322707] Status: 140084e2 KX SX UX KERNEL EXL
[ 370.327980] Cause : 1080002c (ExcCode 0b)
[ 370.332091] PrId : 0001a428 (MIPS P6600)
[ 370.336179] Modules linked in:
[ 370.339486] Process fp-prctl (pid: 963, threadinfo=a8000000fd630000, task=a8000000fd672e00, tls=00000000756e67d0)
[ 370.349724] Stack : 0000000000000000 a8000000fd557dc0 0000000000000000 ffffffff801ca8e0
[ 370.358161] 0000000000000000 a8000000fd637b9c 0000000000000009 ffffffff80923780
[ 370.366575] ffffffff80850000 ffffffff8011610c 00000000000000b8 ffffffff801a5084
[ 370.374989] ffffffff8084a370 ffffffff8084a388 ffffffff80923780 ffffffff80923828
[ 370.383395] 0000000000010000 ffffffff809237a8 0000000000020000 ffffffff80a40000
[ 370.391817] 000000000000007c 00000000004a0000 00000000756dedd0 ffffffff801a5188
[ 370.400230] a800000002014900 0000000000000001 ffffffff80923780 0000000080923828
[ 370.408644] ffffffff80923780 ffffffff80923780 ffffffff80923828 ffffffff801a521c
[ 370.417066] ffffffff80923780 ffffffff80923828 0000000000010000 ffffffff801a8f84
[ 370.425472] ffffffff80a40000 a8000000fd637c20 ffffffff80a39240 0000000000000001
[ 370.433885] ...
[ 370.436562] Call Trace:
[ 370.439222] [<ffffffff80115d38>] _save_fp+0x10/0xa0
[ 370.444305] [<ffffffff8010807c>] prepare_for_fp_mode_switch+0x94/0x1b0
[ 370.451035] [<ffffffff801ca8e0>] flush_smp_call_function_queue+0xf8/0x230
[ 370.457991] [<ffffffff8011610c>] ipi_call_interrupt+0xc/0x20
[ 370.463814] [<ffffffff801a5084>] __handle_irq_event_percpu+0xc4/0x1a8
[ 370.470404] [<ffffffff801a5188>] handle_irq_event_percpu+0x20/0x68
[ 370.476734] [<ffffffff801a521c>] handle_irq_event+0x4c/0x88
[ 370.482486] [<ffffffff801a8f84>] handle_edge_irq+0x12c/0x210
[ 370.488316] [<ffffffff801a47a0>] generic_handle_irq+0x38/0x48
[ 370.494280] [<ffffffff804a2dbc>] gic_handle_shared_int+0x194/0x268
[ 370.500616] [<ffffffff801a47a0>] generic_handle_irq+0x38/0x48
[ 370.506529] [<ffffffff80107e60>] do_IRQ+0x18/0x28
[ 370.511445] [<ffffffff804a1524>] plat_irq_dispatch+0xc4/0x140
[ 370.517339] [<ffffffff80106230>] ret_from_irq+0x0/0x4
[ 370.522583] [<ffffffff8010fad4>] do_ri+0x4fc/0x7e8
[ 370.527546] [<ffffffff80106220>] ret_from_exception+0x0/0x10
2) The IPI may arrive during kernel use of the FPU, since we generally
only disable preemption around use of the FPU & leave interrupts
enabled. This can lead to us unexpectedly losing access to the FPU
in places where it previously had not been possible. For example:
do_cpu invoked from kernel context![#2]:
CPU: 2 PID: 7338 Comm: fp-prctl Tainted: G D 4.7.0-00424-g49b0c82
#2
task: 838e4000 ti: 88d38000 task.ti: 88d38000
$ 0 : 00000000 00000001 ffffffff 88d3fef8
$ 4 : 838e4000 88d38004 00000000 00000001
$ 8 : 3400fc01 801f8020 808e9100 24000000
$12 : dbffffff 807b69d8 807b0000 00000000
$16 : 00000000 80786150 00400fc4 809c0398
$20 : 809c0338 0040273c 88d3ff28 808e9d30
$24 : 808e9d30 00400fb4
$28 : 88d38000 88d3fe88 00000000 8011a2ac
Hi : 0040273c
Lo : 88d3ff28
epc : 80114178 _restore_fp+0x10/0xa0
ra : 8011a2ac mipsr2_decoder+0xd5c/0x1660
Status: 1400fc03 KERNEL EXL IE
PrId : 0001a920 (MIPS I6400)
Modules linked in:
Process fp-prctl (pid: 7338, threadinfo=88d38000, task=838e4000, tls=766527d0)
Stack : 00000000 00000000 00000000 88d3fe98 00000000 00000000 809c0398 809c0338
808e9100 00000000 88d3ff28 00400fc4 00400fc4 0040273c 7fb69e18 004a0000
004a0000 004a0000 7664add0 8010de18 00000000 00000000 88d3fef8 88d3ff28
808e9100 00000000 766527d0 8010e534 000c0000 85755000 8181d580 00000000
00000000 00000000 004a0000 00000000 766527d0 7fb69e18 004a0000 80105c20
Call Trace:
[<80114178>] _restore_fp+0x10/0xa0
[<8011a2ac>] mipsr2_decoder+0xd5c/0x1660
[<8010de18>] do_ri+0x90/0x6b8
[<80105c20>] ret_from_exception+0x0/0x10
At first glance a simple fix may seem to be to disable interrupts around
kernel use of the FPU rather than merely preemption, however this would
introduce further overhead outside of the mode switch path & doesn't
solve the third problem:
3) The IPI may arrive whilst the kernel is running code that will lead
to a preempt_disable() call & FPU usage soon. If this happens then
the IPI will be serviced & we'll proceed to enable an FPU whilst the
mode switch is in progress, leading to strange & inconsistent
behaviour.
Further to all of this is a separate but related problem:
4) There are various paths through which we may enable the FPU without
the user having triggered a coprocessor 1 disabled exception. These
paths are those in which we emulate instructions & then enable the
FPU with the expectation that the user might execute an FP
instruction shortly afterwards. However these paths have not
previously checked whether an FP mode switch is underway for the
task, and therefore could enable the FPU whilst such a mode switch
is in progress leading to strange & inconsistent behaviour for user
code.
This patch fixes all of the above by taking a step back & re-examining
our approach to FP mode switches. Up until now we have taken these basic
steps:
a) Prevent any threads that are part of the affected process from being
able to obtain ownership of the FPU.
b) Cause any threads that are part of the affected process and already
have ownership of an FPU to lose it.
c) Set the thread flags for each thread that is part of the affected
process to reflect the new FP mode.
d) Allow threads to obtain ownership of the FPU again.
This approach is however more complex than necessary. All that we really
require is that the mode switch has occurred for all threads that are
part of the affected process before mips_set_process_fp_mode(), and thus
the PR_SET_FP_MODE prctl() syscall, returns. This doesn't require that
we stop threads from owning or using an FPU whilst a mode switch occurs,
only that we force them to relinquish it after the mode switch has
occurred such that they next own an FPU with the correct mode
configured. Our basic steps therefore simplify to:
A) Set the thread flags for each thread that is part of the affected
B) Cause any threads that are part of the affected process and already
We implement B) by forcing each CPU which might be running a thread
which is part of the affected process to schedule a no-op function,
which causes the affected thread to lose its FPU ownership when it is
descheduled.
The end result is simpler FP mode switching with less overhead in the
FPU enable path (ie. enable_restore_fp_context()) and fewer moving
parts.
Fixes: 9791554b45a2 ("MIPS,prctl: add PR_[GS]ET_FP_MODE prctl options for MIPS")
Fixes: 6b8322576e9d ("MIPS: Force CPUs to lose FP context during mode switches")
Cc: stable <stable@vger.kernel.org> # v4.0+
The changes to automatically test for working stack protector compiler
support in the Kconfig files removed the special STACKPROTECTOR_AUTO
option that picked the strongest stack protector that the compiler
supported.
That was all a nice cleanup - it makes no sense to have the AUTO case
now that the Kconfig phase can just determine the compiler support
directly.
HOWEVER.
It also meant that doing "make oldconfig" would now _disable_ the strong
stackprotector if you had AUTO enabled, because in a legacy config file,
the sane stack protector configuration would look like
CONFIG_HAVE_CC_STACKPROTECTOR=y
# CONFIG_CC_STACKPROTECTOR_NONE is not set
# CONFIG_CC_STACKPROTECTOR_REGULAR is not set
# CONFIG_CC_STACKPROTECTOR_STRONG is not set
CONFIG_CC_STACKPROTECTOR_AUTO=y
and when you ran this through "make oldconfig" with the Kbuild changes,
it would ask you about the regular CONFIG_CC_STACKPROTECTOR (that had
been renamed from CONFIG_CC_STACKPROTECTOR_REGULAR to just
CONFIG_CC_STACKPROTECTOR), but it would think that the STRONG version
used to be disabled (because it was really enabled by AUTO), and would
disable it in the new config, resulting in:
CONFIG_CC_HAS_STACKPROTECTOR_NONE=y
CONFIG_CC_STACKPROTECTOR=y
CONFIG_CC_HAS_SANE_STACKPROTECTOR=y
That's dangerously subtle - people could suddenly find themselves with
the weaker stack protector setup without even realizing.
The solution here is to just rename not just the old RECULAR stack
protector option, but also the strong one. This does that by just
removing the CC_ prefix entirely for the user choices, because it really
is not about the compiler support (the compiler support now instead
automatially impacts _visibility_ of the options to users).
This results in "make oldconfig" actually asking the user for their
choice, so that we don't have any silent subtle security model changes.
The end result would generally look like this:
CONFIG_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR_STRONG=y
where the "CC_" versions really are about internal compiler
infrastructure, not the user selections.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Having PR_FP_MODE_FRE (i.e. Config5.FRE) set without PR_FP_MODE_FR (i.e.
Status.FR) is not supported as the lone purpose of Config5.FRE is to
emulate Status.FR=0 handling on FPU hardware that has Status.FR=1
hardwired[1][2]. Also we do not handle this case elsewhere, and assume
throughout our code that TIF_HYBRID_FPREGS and TIF_32BIT_FPREGS cannot
be set both at once for a task, leading to inconsistent behaviour if
this does happen.
Return unsuccessfully then from prctl(2) PR_SET_FP_MODE calls requesting
PR_FP_MODE_FRE to be set with PR_FP_MODE_FR clear. This corresponds to
modes allowed by `mips_set_personality_fp'.
References:
[1] "MIPS Architecture For Programmers, Vol. III: MIPS32 / microMIPS32
Privileged Resource Architecture", Imagination Technologies,
Document Number: MD00090, Revision 6.02, July 10, 2015, Table 9.69
"Config5 Register Field Descriptions", p. 262
[2] "MIPS Architecture For Programmers, Volume III: MIPS64 / microMIPS64
Document Number: MD00091, Revision 6.03, December 22, 2015, Table
9.72 "Config5 Register Field Descriptions", p. 288
Signed-off-by: Maciej W. Rozycki <macro@mips.com>
Cc: <stable@vger.kernel.org> # 4.0+
Patchwork: https://patchwork.linux-mips.org/patch/19327/
Signed-off-by: James Hogan <jhogan@kernel.org>
wait_var_event() API
The old wait_on_atomic_t() is going to get removed, use the more
flexible wait_var_event() API instead.
And while there, fix a bug and add the missing wakeup...
Fix an API loophole introduced with commit 9791554b45a2 ("MIPS,prctl:
add PR_[GS]ET_FP_MODE prctl options for MIPS"), where the caller of
prctl(2) is incorrectly allowed to make a change to CP0.Status.FR or
CP0.Config5.FRE register bits even if CONFIG_MIPS_O32_FP64_SUPPORT has
not been enabled, despite that an executable requesting the mode
requested via ELF file annotation would not be allowed to run in the
first place, or for n64 and n64 ABI tasks which do not have non-default
modes defined at all. Add suitable checks to `mips_set_process_fp_mode'
and bail out if an invalid mode change has been requested for the ABI in
effect, even if the FPU hardware or emulation would otherwise allow it.
Always succeed however without taking any further action if the mode
requested is the same as one already in effect, regardless of whether
any mode change, should it be requested, would actually be allowed for
the task concerned.
Reviewed-by: Paul Burton <paul.burton@mips.com>
Cc: James Hogan <james.hogan@mips.com>
Cc: stable@vger.kernel.org # 4.0+
Patchwork: https://patchwork.linux-mips.org/patch/17800/
The only user of thread_saved_pc() in non-arch-specific code was removed
in commit 8243d5597793 ("sched/core: Remove pointless printout in
sched_show_task()"), so it no longer needs to be globally defined for
MIPS and can be made static.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Patchwork: https://patchwork.linux-mips.org/patch/17303/
Commit 34c2f668d0f6 ("MIPS: microMIPS: Add unaligned access support.")
added handling of microMIPS instructions to manipulate the stack
pointer. The code that was added violates code style rules with long
lines caused by lots of nested conditionals.
The added code interprets (inline) any known stack pointer manipulation
instruction to find the stack frame size. Handling the microMIPS cases
added quite a bit of complication to this function.
Refactor is_sp_move_ins to perform the interpretation of the immediate
as the instruction manipulating the stack pointer is found. This reduces
the amount of indentation required in get_frame_info, and more closely
matches the operation of is_ra_save_ins.
Suggested-by: Maciej W. Rozycki <macro@imgtec.com>
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: Marcin Nowakowski <marcin.nowakowski@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/16958/
The stack unwinding code uses the mips_instuction union to decode the
instructions it finds. That union uses the __BITFIELD_FIELD macro to
reorder depending on endianness. The stack unwinding code always places
16bit instructions in halfword 1 of the union. This makes the union
accesses correct for little endian systems. Similarly, 32bit
instructions are reordered such that they are correct for little endian
systems. This handling leaves unwinding the stack on big endian systems
broken, as the mips_instruction union will then look for the fields in
the wrong halfword.
To fix this, use a logical shift to place the 16bit instruction into the
correct position in the word field of the union. Use the same shifting
to order the 2 halfwords of 32bit instuctions. Then replace accesses to
the halfword with accesses to the shifted word.
In the case of the ADDIUS5 instruction, switch to using the
mm16_r5_format union member to avoid the need for a 16bit shift.
Fixes: 34c2f668d0f6 ("MIPS: microMIPS: Add unaligned access support.")
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/16956/
When the immediate encoded in the instruction is accessed, it is sign
extended due to being a signed value being assigned to a signed integer.
The ISA specifies that this operation is an unsigned operation.
The sign extension leads us to incorrectly decode:
801e9c8e: cbf1 sw ra,68(sp)
As having an immediate of 1073741809.
Since the instruction format does not specify signed/unsigned, and this
is currently the only location to use this instuction format, change it
to an unsigned immediate.
Fixes: bb9bc4689b9c ("MIPS: Calculate microMIPS ra properly when unwinding the stack")
Suggested-by: Paul Burton <paul.burton@imgtec.com>
Cc: Miodrag Dinic <miodrag.dinic@imgtec.com>
Cc: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/16957/
pointer. Unfortunately the decoding of the addiusp instruction was
incorrect, and performed a left shift by 2 bits to the raw immediate,
rather than decoding the immediate and then performing the shift, as
documented in the ISA.
This led to incomplete stack traces, due to incorrect frame sizes being
calculated. For example the instruction:
801faee0 <do_sys_poll>:
801faee0: 4e25 addiu sp,sp,-952
As decoded by objdump, would be interpreted by the existing code as
having manipulated the stack pointer by +1096.
Fix this by changing the order of decoding the immediate and applying
the left shift. Also change to accessing the instuction through the
union to avoid the endianness problem of accesing halfword[0], which
will fail on big endian systems.
Cope with the special behaviour of immediates 0x0, 0x1, 0x1fe and 0x1ff
by XORing with 0x100 again if mod(immediate) < 4. This logic was tested
with the following test code:
int main(int argc, char **argv)
unsigned int enc;
int imm;
for (enc = 0; enc < 512; ++enc) {
int tmp = enc << 2;
imm = -(signed short)(tmp | ((tmp & 0x100) ? 0xfe00 : 0));
unsigned short tmp = enc;
tmp = (tmp ^ 0x100) - 0x100;
if ((unsigned short)(tmp + 2) < 4)
tmp ^= 0x100;
imm = -(signed short)(tmp << 2);
printf("%#x\t%d\t->\t(%#x\t%d)\t%#x\t%d\n",
enc, enc,
(short)tmp, (short)tmp,
imm, imm);
return EXIT_SUCCESS;
Which generates the table:
input encoding -> tmp (matching manual) frame size
0 0 -> (0x100 256) 0xfffffc00 -1024
0x1 1 -> (0x101 257) 0xfffffbfc -1028
0x2 2 -> (0x2 2) 0xfffffff8 -8
0x3 3 -> (0x3 3) 0xfffffff4 -12
0xfe 254 -> (0xfe 254) 0xfffffc08 -1016
0xff 255 -> (0xff 255) 0xfffffc04 -1020
0x100 256 -> (0xffffff00 -256) 0x400 1024
0x101 257 -> (0xffffff01 -255) 0x3fc 1020
0x1fc 508 -> (0xfffffffc -4) 0x10 16
0x1fd 509 -> (0xfffffffd -3) 0xc 12
0x1fe 510 -> (0xfffffefe -258) 0x408 1032
0x1ff 511 -> (0xfffffeff -257) 0x404 1028
Thanks to James Hogan for the test code & verifying the logic.
Suggested-by: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/16955/
The addiusp instruction uses the pool16d opcode, with bit 0 of the
immediate set. The test for the addiusp opcode erroneously did a logical
and of the immediate with mm_addiusp_func, which has value 1, so this
test always passes when the immediate is non-zero.
Fix the test by replacing the logical and with a bitwise and.
Patchwork: https://patchwork.linux-mips.org/patch/16954/
Commit 34c2f668d0f6b ("MIPS: microMIPS: Add unaligned access support.")
added fairly broken support for handling 16bit microMIPS instructions in
get_frame_info(). It adjusts the instruction pointer by 16bits in the
case of a 16bit sp move instruction, but not any other 16bit
instruction.
Commit b6c7a324df37 ("MIPS: Fix get_frame_info() handling of microMIPS
function size") goes some way to fixing get_frame_info() to iterate over
microMIPS instuctions, but the instruction pointer is still manipulated
using a postincrement, and is of union mips_instruction type. Since the
union is sized to the largest member (a word), but microMIPS
instructions are a mix of halfword and word sizes, the function does not
always iterate correctly, ending up misaligned with the instruction
stream and interpreting it incorrectly.
Since the instruction modifying the stack pointer is usually the first
in the function, that one is usually handled correctly. But the
instruction which saves the return address to the sp is some variable
number of instructions into the frame and is frequently missed due to
not being on a word boundary, leading to incomplete walking of the
stack.
Fix this by incrementing the instruction pointer based on the size of
the previously decoded instruction (& remove the hack introduced by
commit 34c2f668d0f6b ("MIPS: microMIPS: Add unaligned access support.")
which adjusts the instruction pointer in the case of a 16bit sp move
instruction, but not any other).
Fixes: 34c2f668d0f6b ("MIPS: microMIPS: Add unaligned access support.")
Cc: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/16953/
I saw two problems when doing backtraces:
The compiler was putting a "fast return" at the top of some
functions, before it set up the frame. The backtrace code
would stop when it saw a jump instruction, so it would never
get to the stack frame setup and would thus misinterpret it.
To fix this, don't look for jump instructions until the
frame setup has been seen.
The assembly code here is:
ffffffff80b885a0 <serial8250_handle_irq>:
ffffffff80b885a0: c8a00003 bbit0 a1,0x0,ffffffff80b885b0 <serial8250_handle_irq+0x10>
ffffffff80b885a4: 0000102d move v0,zero
ffffffff80b885a8: 03e00008 jr ra
ffffffff80b885ac: 00000000 nop
ffffffff80b885b0: 67bdffd0 daddiu sp,sp,-48
ffffffff80b885b4: ffb00008 sd s0,8(sp)
The second problem was the compiler was putting the last
instruction of the frame save in the delay slot of the
jump instruction. If it saved the RA in there, the
backtrace could would miss it and misinterpret the frame.
To fix this, make sure to process the instruction after
the first jump seen.
The assembly code for this is:
ffffffff80806fd0 <plat_irq_dispatch>:
ffffffff80806fd0: 67bdffd0 daddiu sp,sp,-48
ffffffff80806fd4: ffb30020 sd s3,32(sp)
ffffffff80806fd8: 24130018 li s3,24
ffffffff80806fdc: ffb20018 sd s2,24(sp)
ffffffff80806fe0: 3c12811c lui s2,0x811c
ffffffff80806fe4: ffb10010 sd s1,16(sp)
ffffffff80806fe8: 3c11811c lui s1,0x811c
ffffffff80806fec: ffb00008 sd s0,8(sp)
ffffffff80806ff0: 3c10811c lui s0,0x811c
ffffffff80806ff4: 08201c03 j ffffffff8080700c <plat_irq_dispa
tch+0x3c>
ffffffff80806ff8: ffbf0028 sd ra,40(sp)
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Patchwork: https://patchwork.linux-mips.org/patch/16992/
This fixes a regression in commit 4d6501dce079 where I didn't notice
that MIPS and OpenRISC were reinitialising p->{set,clear}_child_tid to
NULL after our initialisation in copy_process().
We can simply get rid of the arch-specific initialisation here since it
is now always done in copy_process() before hitting copy_thread{,_tls}().
Review notes:
- As far as I can tell, copy_process() is the only user of
copy_thread_tls(), which is the only caller of copy_thread() for
architectures that don't implement copy_thread_tls().
- After this patch, there is no arch-specific code touching
p->set_child_tid or p->clear_child_tid whatsoever.
- It may look like MIPS/OpenRISC wanted to always have these fields be
NULL, but that's not true, as copy_process() would unconditionally
set them again _after_ calling copy_thread_tls() before commit
4d6501dce079.
Fixes: 4d6501dce079c1eb6bf0b1d8f528a5e81770109e ("kthread: Fix use-after-free if kthread fork fails")
Reported-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Guenter Roeck <linux@roeck-us.net> # MIPS only
Acked-by: Stafford Horne <shorne@gmail.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: openrisc@lists.librecores.org
Cc: Jamie Iles <jamie.iles@oracle.com>
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
This the mips version of commit c1bd55f922a2d ("x86: opt into
HAVE_COPY_THREAD_TLS, for both 32-bit and 64-bit").
Simply use the tls system call argument instead of extracting the tls
argument by magic from the pt_regs structure.
See commit 3033f14ab78c3 ("clone: support passing tls argument via C
rather than pt_regs magic") for more background.
Signed-off-by: James Cowgill <James.Cowgill@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/15855/
When the separate IRQ stack was introduced, stack unwinding only
proceeded as far as the top of the IRQ stack, leading to kernel
backtraces being less useful, lacking the trace of what was interrupted.
Fix this by providing a means for the kernel to unwind the IRQ stack
onto the interrupted task stack. The processor state is saved to the
kernel task stack on interrupt. The IRQ_STACK_START macro reserves an
unsigned long at the top of the IRQ stack where the interrupted task
stack pointer can be saved. After the active stack is switched to the
IRQ stack, save the interrupted tasks stack pointer to the reserved
location.
Fix the stack unwinding code to look for the frame being the top of the
IRQ stack and if so get the next frame from the saved location. The
existing test does not work with the separate stack since the ra is no
longer pointed at ret_from_{irq,exception}.
The test to stop unwinding the stack 32 bytes from the top of a stack
must be modified to allow unwinding to continue up to the location of
the saved task stack pointer when on the IRQ stack. The low / high marks
of the stack are set depending on whether the sp is on an irq stack or
not.
Cc: Masanari Iida <standby24x7@gmail.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Jason A. Donenfeld <jason@zx2c4.com>
Patchwork: https://patchwork.linux-mips.org/patch/15788/
<linux/sched/task_stack.h>
We are going to split <linux/sched/task_stack.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/task_stack.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
<linux/sched/task.h>
We are going to split <linux/sched/task.h> out of <linux/sched.h>, which
Create a trivial placeholder <linux/sched/task.h> file that just
bisectable.
<linux/sched/debug.h>
We are going to split <linux/sched/debug.h> out of <linux/sched.h>, which
Create a trivial placeholder <linux/sched/debug.h> file that just
bisectable.
Current register dump methods for MIPS are implemented inside ptrace
methods, but there will be other uses in the kernel for them, so keep
them separately in process.c and use those definitions for ptrace
instead.
Signed-off-by: Marcin Nowakowski <marcin.nowakowski@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14587/
If a secondary CPU failed to start, for any reason, the CPU requesting
the secondary to start would get stuck in the loop waiting for the
secondary to be present in the cpu_callin_map.
Rather than that, use a completion event to signal that the secondary
CPU has started and is waiting to synchronise counters.
Since the CPU presence will no longer be marked in cpu_callin_map,
remove the redundant test from arch_cpu_idle_dead().
Cc: Maciej W. Rozycki <macro@imgtec.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Qais Yousef <qsyousef@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/14502/
is_jump_ins() checks for plain jump ("j") instructions since commit
e7438c4b893e ("MIPS: Fix sibling call handling in get_frame_info") but
that commit didn't make the same change to the microMIPS code, leaving
it inconsistent with the MIPS32/MIPS64 code. Handle the microMIPS
encoding of the jump instruction too such that it behaves consistently.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Fixes: e7438c4b893e ("MIPS: Fix sibling call handling in get_frame_info")
Cc: Tony Wu <tung7970@gmail.com>
Cc: <stable@vger.kernel.org> # v3.10+
Patchwork: https://patchwork.linux-mips.org/patch/14533/
get_frame_info() calculates the offset of the return address within a
stack frame simply by dividing a the bottom 16 bits of the instruction,
treated as a signed integer, by the size of a long. Whilst this works
for MIPS32 & MIPS64 ISAs where the sw or sd instructions are used, it's
incorrect for microMIPS where encodings differ. The result is that we
typically completely fail to unwind the stack on microMIPS.
Fix this by adjusting is_ra_save_ins() to calculate the return address
offset, and take into account the various different encodings there in
the same place as we consider whether an instruction is storing the
ra/$31 register.
With this we are now able to unwind the stack for kernels targetting the
microMIPS ISA, for example we can produce:
Call Trace:
[<80109e1f>] show_stack+0x63/0x7c
[<8011ea17>] __warn+0x9b/0xac
[<8011ea45>] warn_slowpath_fmt+0x1d/0x20
[<8013fe53>] register_console+0x43/0x314
[<8067c58d>] of_setup_earlycon+0x1dd/0x1ec
[<8067f63f>] early_init_dt_scan_chosen_stdout+0xe7/0xf8
[<8066c115>] do_early_param+0x75/0xac
[<801302f9>] parse_args+0x1dd/0x308
[<8066c459>] parse_early_options+0x25/0x28
[<8066c48b>] parse_early_param+0x2f/0x38
[<8066e8cf>] setup_arch+0x113/0x488
[<8066c4f3>] start_kernel+0x57/0x328
---[ end trace 0000000000000000 ]---
Whereas previously we only produced:
Call Trace:
Cc: Leonid Yegoshin <leonid.yegoshin@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14532/
is_jump_ins() checks 16b instruction fields without verifying that the
instruction is indeed 16b, as is done by is_ra_save_ins() &
is_sp_move_ins(). Add the appropriate check.
Patchwork: https://patchwork.linux-mips.org/patch/14531/
get_frame_info() is meant to iterate over up to the first 128
instructions within a function, but for microMIPS kernels it will not
reach that many instructions unless the function is 512 bytes long since
we calculate the maximum number of instructions to check by dividing the
function length by the 4 byte size of a union mips_instruction. In
microMIPS kernels this won't do since instructions are variable length.
Fix this by instead checking whether the pointer to the current
instruction has reached the end of the function, and use max_insns as a
simple constant to check the number of iterations against.
Patchwork: https://patchwork.linux-mips.org/patch/14530/
During stack unwinding we call a number of functions to determine what
type of instruction we're looking at. The union mips_instruction pointer
provided to them may be pointing at a 2 byte, but not 4 byte, aligned
address & we thus cannot directly access the 4 byte wide members of the
union mips_instruction. To avoid this is_ra_save_ins() copies the
required half-words of the microMIPS instruction to a correctly aligned
union mips_instruction on the stack, which it can then access safely.
The is_jump_ins() & is_sp_move_ins() functions do not correctly perform
this temporary copy, and instead attempt to directly dereference 4 byte
fields which may be misaligned and lead to an address exception.
Fix this by copying the instruction halfwords to a temporary union
mips_instruction in get_frame_info() such that we can provide a 4 byte
aligned union mips_instruction to the is_*_ins() functions and they do
not need to deal with misalignment themselves.
Patchwork: https://patchwork.linux-mips.org/patch/14529/
get_frame_info() can be called in microMIPS kernels with the ISA bit
already clear. For example this happens when unwind_stack_by_address()
is called because we begin with a PC that has the ISA bit set & subtract
the (odd) offset from the preceding symbol (which does not have the ISA
bit set). Since get_frame_info() unconditionally subtracts 1 from the PC
in microMIPS kernels it incorrectly misaligns the address it then
attempts to access code at, leading to an address error exception.
Fix this by using msk_isa16_mode() to clear the ISA bit, which allows
get_frame_info() to function regardless of whether it is provided with a
PC that has the ISA bit set or not.
Patchwork: https://patchwork.linux-mips.org/patch/14528/
Within unwind stack, check if the stack pointer being unwound is within
the CPU's irq_stack and if so use that page rather than the task's stack
page.
Acked-by: Jason A. Donenfeld <jason@zx2c4.com>
Cc: Adam Buchbinder <adam.buchbinder@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/14741/
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Patch series "improvements to the nmi_backtrace code" v9.
This patch series modifies the trigger_xxx_backtrace() NMI-based remote
backtracing code to make it more flexible, and makes a few small
improvements along the way.
The motivation comes from the task isolation code, where there are
scenarios where we want to be able to diagnose a case where some cpu is
about to interrupt a task-isolated cpu. It can be helpful to see both
where the interrupting cpu is, and also an approximation of where the
cpu that is being interrupted is. The nmi_backtrace framework allows us
to discover the stack of the interrupted cpu.
I've tested that the change works as desired on tile, and build-tested
x86, arm, mips, and sparc64. For x86 I confirmed that the generic
cpuidle stuff as well as the architecture-specific routines are in the
new cpuidle section. For arm, mips, and sparc I just build-tested it
and made sure the generic cpuidle routines were in the new cpuidle
section, but I didn't attempt to figure out which the platform-specific
idle routines might be. That might be more usefully done by someone
with platform experience in follow-up patches.
This patch (of 4):
Currently you can only request a backtrace of either all cpus, or all
cpus but yourself. It can also be helpful to request a remote backtrace
of a single cpu, and since we want that, the logical extension is to
support a cpumask as the underlying primitive.
This change modifies the existing lib/nmi_backtrace.c code to take a
cpumask as its basic primitive, and modifies the linux/nmi.h code to use
the new "cpumask" method instead.
The existing clients of nmi_backtrace (arm and x86) are converted to
using the new cpumask approach in this change.
The other users of the backtracing API (sparc64 and mips) are converted
to use the cpumask approach rather than the all/allbutself approach.
The mips code ignored the "include_self" boolean but with this change it
will now also dump a local backtrace if requested.
Link: http://lkml.kernel.org/r/1472487169-14923-2-git-send-email-cmetcalf@mellanox.com
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm]
Reviewed-by: Aaron Tomlin <atomlin@redhat.com>
Reviewed-by: Petr Mladek <pmladek@suse.com>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
cpu_has_fpu macro uses smp_processor_id() and is currently executed
with preemption enabled, that triggers the warning at runtime.
It is assumed throughout the kernel that if any CPU has an FPU, then all
CPUs would have an FPU as well, so it is safe to perform the check with
preemption enabled - change the code to use raw_ variant of the check to
avoid the warning.
Patchwork: https://patchwork.linux-mips.org/patch/14125/
In some cases the kernel needs to execute an instruction from the delay
slot of an emulated branch instruction. These cases include:
- Emulated floating point branch instructions (bc1[ft]l?) for systems
which don't include an FPU, or upon which the kernel is run with the
"nofpu" parameter.
- MIPSr6 systems running binaries targeting older revisions of the
architecture, which may include branch instructions whose encodings
are no longer valid in MIPSr6.
Executing instructions from such delay slots is done by writing the
instruction to memory followed by a trap, as part of an "emuframe", and
executing it. This avoids the requirement of an emulator for the entire
MIPS instruction set. Prior to this patch such emuframes are written to
the user stack and executed from there.
This patch moves FP branch delay emuframes off of the user stack and
into a per-mm page. Allocating a page per-mm leaves userland with access
to only what it had access to previously, and compared to other
solutions is relatively simple.
When a thread requires a delay slot emulation, it is allocated a frame.
A thread may only have one frame allocated at any one time, since it may
only ever be executing one instruction at any one time. In order to
ensure that we can free up allocated frame later, its index is recorded
in struct thread_struct. In the typical case, after executing the delay
slot instruction we'll execute a break instruction with the BRK_MEMU
code. This traps back to the kernel & leads to a call to do_dsemulret
which frees the allocated frame & moves the user PC back to the
instruction that would have executed following the emulated branch.
In some cases the delay slot instruction may be invalid, such as a
branch, or may trigger an exception. In these cases the BRK_MEMU break
instruction will not be hit. In order to ensure that frames are freed
this patch introduces dsemul_thread_cleanup() and calls it to free any
allocated frame upon thread exit. If the instruction generated an
exception & leads to a signal being delivered to the thread, or indeed
if a signal simply happens to be delivered to the thread whilst it is
executing from the struct emuframe, then we need to take care to exit
the frame appropriately. This is done by either rolling back the user PC
to the branch or advancing it to the continuation PC prior to signal
delivery, using dsemul_thread_rollback(). If this were not done then a
sigreturn would return to the struct emuframe, and if that frame had
meanwhile been used in response to an emulated branch instruction within
the signal handler then we would execute the wrong user code.
Whilst a user could theoretically place something like a compact branch
to self in a delay slot and cause their thread to become stuck in an
infinite loop with the frame never being deallocated, this would:
- Only affect the users single process.
- Be architecturally invalid since there would be a branch in the
delay slot, which is forbidden.
- Be extremely unlikely to happen by mistake, and provide a program
with no more ability to harm the system than a simple infinite loop
would.
If a thread requires a delay slot emulation & no frame is available to
it (ie. the process has enough other threads that all frames are
currently in use) then the thread joins a waitqueue. It will sleep until
a frame is freed by another thread in the process.
Since we now know whether a thread has an allocated frame due to our
tracking of its index, the cookie field of struct emuframe is removed as
we can be more certain whether we have a valid frame. Since a thread may
only ever have a single frame at any given time, the epc field of struct
emuframe is also removed & the PC to continue from is instead stored in
struct thread_struct. Together these changes simplify & shrink struct
emuframe somewhat, allowing twice as many frames to fit into the page
allocated for them.
The primary benefit of this patch is that we are now free to mark the
user stack non-executable where that is possible.
Cc: Maciej Rozycki <maciej.rozycki@imgtec.com>
Cc: Faraz Shahbazker <faraz.shahbazker@imgtec.com>
Cc: Raghu Gandham <raghu.gandham@imgtec.com>
Cc: Matthew Fortune <matthew.fortune@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/13764/
Pull more MIPS updates from Ralf Baechle:
"This is the secondnd batch of MIPS patches for 4.7. Summary:
CPS:
- Copy EVA configuration when starting secondary VPs.
EIC:
- Clear Status IPL.
Lasat:
- Fix a few off by one bugs.
lib:
- Mark intrinsics notrace. Not only are the intrinsics
uninteresting, it would cause infinite recursion.
MAINTAINERS:
- Add file patterns for MIPS BRCM device tree bindings.
- Add file patterns for mips device tree bindings.
MT7628:
- Fix MT7628 pinmux typos.
- wled_an pinmux gpio.
- EPHY LEDs pinmux support.
Pistachio:
- Enable KASLR
VDSO:
- Build microMIPS VDSO for microMIPS kernels.
- Fix aliasing warning by building with `-fno-strict-aliasing' for
debugging but also tracing them might result in recursion.
Misc:
- Add missing FROZEN hotplug notifier transitions.
- Fix clk binding example for varioius PIC32 devices.
- Fix cpu interrupt controller node-names in the DT files.
- Fix XPA CPU feature separation.
- Fix write_gc0_* macros when writing zero.
- Add inline asm encoding helpers.
- Add missing VZ accessor microMIPS encodings.
- Fix little endian microMIPS MSA encodings.
- Add 64-bit HTW fields and fix its configuration.
- Fix sigreturn via VDSO on microMIPS kernel.
- Lots of typo fixes.
- Add definitions of SegCtl registers and use them"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (49 commits)
MIPS: Add missing FROZEN hotplug notifier transitions
MIPS: Build microMIPS VDSO for microMIPS kernels
MIPS: Fix sigreturn via VDSO on microMIPS kernel
MIPS: devicetree: fix cpu interrupt controller node-names
MIPS: VDSO: Build with `-fno-strict-aliasing'
MIPS: Pistachio: Enable KASLR
MIPS: lib: Mark intrinsics notrace
MIPS: Fix 64-bit HTW configuration
MIPS: Add 64-bit HTW fields
MAINTAINERS: Add file patterns for mips device tree bindings
MAINTAINERS: Add file patterns for mips brcm device tree bindings
MIPS: Simplify DSP instruction encoding macros
MIPS: Add missing tlbinvf/XPA microMIPS encodings
MIPS: Fix little endian microMIPS MSA encodings
MIPS: Add missing VZ accessor microMIPS encodings
MIPS: Add inline asm encoding helpers
MIPS: Spelling fix lets -> let's
MIPS: VR41xx: Fix typo
MIPS: oprofile: Fix typo
MIPS: math-emu: Fix typo
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Cc: paul.burton@imgtec.com
Cc: macro@imgtec.com
Cc: james.hogan@imgtec.com
Cc: jslaby@suse.cz
Cc: adam.buchbinder@gmail.com
Cc: trivial@kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/13330/
Define HAVE_EXIT_THREAD for archs which want to do something in
exit_thread. For others, let's define exit_thread as an empty inline.
This is a cleanup before we change the prototype of exit_thread to
accept a task parameter.
[akpm@linux-foundation.org: fix mips]
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Helge Deller <deller@gmx.de>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Rich Felker <dalias@libc.org>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Richard Weinberger <richard@nod.at>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Commit 9791554b45a2 ("MIPS,prctl: add PR_[GS]ET_FP_MODE prctl options
for MIPS") added support for the PR_SET_FP_MODE prctl, which allows a
userland program to modify its FP mode at runtime. This is most notably
required if dynamic linking leads to the FP mode requirement changing at
runtime from that indicated in the initial executable's ELF header. In
order to avoid overhead in the general FP context restore code, it aimed
to have threads in the process become unable to enable the FPU during a
mode switch & have the thread calling the prctl syscall wait for all
other threads in the process to be context switched at least once. Once
that happens we can know that no thread in the process whose mode will
be switched has live FP context, and it's safe to perform the mode
switch. However in the (rare) case of modeswitches occurring in
multithreaded programs this can lead to indeterminate delays for the
thread invoking the prctl syscall, and the code monitoring for those
context switches was woefully inadequate for all but the simplest cases.
Fix this by broadcasting an IPI if other CPUs may have live FP context
for an affected thread, with a handler causing those CPUs to relinquish
their FPU ownership. Threads will then be allowed to continue running
but will stall on the wait_on_atomic_t in enable_restore_fp_context if
they attempt to use FP again whilst the mode switch is still in
progress. The end result is less fragile poking at scheduler context
switch counts & a more expedient completion of the mode switch.
Reviewed-by: Maciej W. Rozycki <macro@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/13145/
Whilst a PR_SET_FP_MODE prctl is performed there are decisions made
based upon whether the task is executing on the current CPU. This may
change if we're preempted, so disable preemption to avoid such changes
for the lifetime of the mode switch.
Tested-by: Aurelien Jarno <aurelien@aurel32.net>
Patchwork: https://patchwork.linux-mips.org/patch/13144/
Avoids function calls to an empty function.
When unwinding through IRQs and exceptions, the unwinding only continues
if the PC is a kernel text address, however since EVA it is possible for
user and kernel address ranges to overlap, potentially allowing
unwinding to continue to user mode if the user PC happens to be in the
kernel text address range.
Adjust the check to also ensure that the register state from before the
exception is actually running in kernel mode, i.e. !user_mode(regs).
I don't believe any harm can come of this problem, since the PC is only
output, the stack pointer is checked to ensure it resides within the
task's stack page before it is dereferenced in search of the return
address, and the return address register is similarly only output (if
the PC is in a leaf function or the beginning of a non-leaf function).
However unwind_stack() is only meant for unwinding kernel code, so to be
correct the unwind should stop there.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Reviewed-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Cc: <stable@vger.kernel.org> # 3.15+
Patchwork: https://patchwork.linux-mips.org/patch/11700/
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/12617/
start_thread() (called for execve(2)) clears the TIF_USEDFPU flag
without atomically disabling the FPU. With a preemptive kernel, an
unfortunately timed preemption after this could result in another
task (or KVM guest) being scheduled in with the FPU still enabled, since
lose_fpu_inatomic() only turns it off if TIF_USEDFPU is set.
Use lose_fpu(0) instead of the separate FPU / MSA management, which
should do the right thing (drop FPU properly and atomically without
saving state) and will be more future proof.
Reviewed-by: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/12302/
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull final removal of deprecated cpus_* cpumask functions from Rusty Russell:
"This is the final removal (after several years!) of the obsolete
cpus_* functions, prompted by their mis-use in staging.
With these function removed, all cpu functions should only iterate to
nr_cpu_ids, so we finally only allocate that many bits when cpumasks
are allocated offstack"
* tag 'cpumask-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits)
cpumask: remove __first_cpu / __next_cpu
cpumask: resurrect CPU_MASK_CPU0
linux/cpumask.h: add typechecking to cpumask_test_cpu
cpumask: only allocate nr_cpumask_bits.
Fix weird uses of num_online_cpus().
cpumask: remove deprecated functions.
mips: fix obsolete cpumask_of_cpu usage.
x86: fix more deprecated cpu function usage.
ia64: remove deprecated cpus_ usage.
powerpc: fix deprecated CPU_MASK_CPU0 usage.
CPU_MASK_ALL/CPU_MASK_NONE: remove from deprecated region.
staging/lustre/o2iblnd: Don't use cpus_weight
staging/lustre/libcfs: replace deprecated cpus_ calls with cpumask_
staging/lustre/ptlrpc: Do not use deprecated cpus_* functions
blackfin: fix up obsolete cpu function usage.
parisc: fix up obsolete cpu function usage.
tile: fix up obsolete cpu function usage.
arm64: fix up obsolete cpu function usage.
mips: fix up obsolete cpu function usage.
x86: fix up obsolete cpu function usage.
The 'arg' argument to copy_thread() is only ever used when forking a new
kernel thread. Hence, rename it to 'kthread_arg' for clarity (and consistency
with do_fork() and other arch-specific implementations of copy_thread()).
Signed-off-by: Alex Dowad <alexinbeijing@gmail.com>
Cc: Alex Smith <alex@alex-smith.me.uk>
Cc: Markos Chandras <markos.chandras@imgtec.com>
Cc: Eunbong Song <eunb.song@samsung.com>
Cc: linux-mips@linux-mips.org (open list:MIPS)
Patchwork: https://patchwork.linux-mips.org/patch/9546/
Thanks to spatch, plus manual removal of "&*". Then a sweep for
for_each_cpu_mask => for_each_cpu.
Cc: Kevin Cernekee <cernekee@gmail.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
