Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
* 'for-next' of git://git.infradead.org/users/dhowells/linux-headers:
UAPI: Split trivial #if defined(__KERNEL__) && X conditionals
UAPI: Don't have a #elif clause in a __KERNEL__ guard in linux/soundcard.h
UAPI: Fix AHZ multiple inclusion when __KERNEL__ is removed
UAPI: Make linux/patchkey.h easier to parse
UAPI: Fix nested __KERNEL__ guards in video/edid.h
UAPI: Alter the S390 asm include guards to be recognisable by the UAPI splitter
UAPI: Guard linux/cuda.h
UAPI: Guard linux/pmu.h
UAPI: Guard linux/isdn_divertif.h
UAPI: Guard linux/sound.h
UAPI: Rearrange definition of HZ in asm-generic/param.h
UAPI: Make FRV use asm-generic/param.h
UAPI: Make M32R use asm-generic/param.h
UAPI: Make MN10300 use asm-generic/param.h
UAPI: elf_read_implies_exec() is a kernel-only feature - so hide from userspace
UAPI: Don't include linux/compat.h in sparc's asm/siginfo.h
UAPI: Fix arch/mips/include/asm/Kbuild to have separate header-y lines
Split trivial #if defined(__KERNEL__) && X conditionals to make automated
disintegration easier.
There is no user now.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
All architectures can use the common dma_addr_t typedef now. We can
remove the arch specific dma_addr_t.
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
This provides a reliable way for asm-generic/types.h and other
files to find out if it is running on a 32 or 64 bit platform.
We cannot use CONFIG_64BIT for this in headers that are included
from user space because CONFIG symbols are not available there.
We also cannot do it inside of asm/types.h because some headers
need the word size but cannot include types.h.
The solution is to introduce a new header <asm/bitsperlong.h>
that defines both __BITS_PER_LONG for user space and
BITS_PER_LONG for usage in the kernel. The asm-generic
version falls back to 32 bit unless the architecture overrides
it, which I did for all 64 bit platforms.
Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com>
This fixes a few warnings - and triggers a few new ones which the rest of
this patch fixes.
