None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Signed-off-by: John Crispin <blogic@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/6320/
If this is not done then the new just read data which remains in dcache
will not make it into icache on time. Thus the CPU loads invalid data
and executes crap. The result is that the user is not able to execute
anything from its IDE based media while reading plain data is still
working well.
This problem has been reported as Debian #404951
http://bugs.debian.org/404951
http://comments.gmane.org/gmane.linux.ide/45092
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Patchwork: http://patchwork.linux-mips.org/patch/2820/
Only one MIPS development board actually supports enabling/disabling DMA
coherency at runtime, so it's not a good idea to push the overhead of
checking that configuration setting onto every other supported target as
well.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/5912/
The semantics stay the same - on Cavium Octeon the functions were dead
code (it overrides the MIPS DMA ops) - on other platforms they contained
no code at all.
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/5720/
Fix build error below:
arch/mips/include/asm/mach-generic/spaces.h:29:0: warning:
"UNCAC_BASE" redefined [enabled by default]
In file included from arch/mips/include/asm/addrspace.h:13:0,
from arch/mips/include/asm/barrier.h:11,
from arch/mips/include/asm/bitops.h:18,
from include/linux/bitops.h:22,
from include/linux/kernel.h:10,
from include/asm-generic/bug.h:13,
from arch/mips/include/asm/bug.h:41,
from include/linux/bug.h:4,
from include/linux/page-flags.h:9,
from kernel/bounds.c:9:
arch/mips/include/asm/mach-ar7/spaces.h:20:0: note: this is the
location of the previous definition
Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/5583/
Signed-off-by: Tony Wu <tung7970@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/5536/
Provide a default implementation of phys_to_dma and dma_to_phys in
mach-generic/dma_coherence.h.
If CONFIG_NEED_SG_DMA_LENGTH is defined, the dma_length field in
struct scatterlist is used. Set this up in mips_dma_map_sg so that
the default mips DMA ops can be used when SWIOTLB is enabled.
Signed-off-by: Jayachandran C <jchandra@broadcom.com>
Patchwork: https://patchwork.linux-mips.org/patch/5409/
git://git.linux-mips.org/pub/scm/sjhill/linux-sjhill into mips-for-linux-next
Both Guest kernel and Guest Userspace execute in UM. The memory map is as follows:
Guest User address space: 0x00000000 -> 0x40000000
Guest Kernel Unmapped: 0x40000000 -> 0x60000000
Guest Kernel Mapped: 0x60000000 -> 0x80000000
- Guest Usermode virtual memory is limited to 1GB.
Signed-off-by: Sanjay Lal <sanjayl@kymasys.com>
Cc: kvm@vger.kernel.org
Some MIPS controllers have hardware I/O coherency. This patch
detects those and turns off software coherency. A new kernel
command line option also allows the user to manually turn
software coherency on or off.
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
Nobody seems to be interested anymore and upstream also never had an
ethernet driver.
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled],
We run all interrupt handlers with interrupts disabled and we even check
and yell when an interrupt handler returns with interrupts enabled (see
commit [b738a50a: genirq: Warn when handler enables interrupts]).
So now this flag is a NOOP and can be removed.
[ralf@linux-mips.org: Fixed up conflicts in
arch/mips/alchemy/common/dbdma.c, arch/mips/cavium-octeon/smp.c and
arch/mips/kernel/perf_event.c.]
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
To: linux-kernel@vger.kernel.org
Cc: tglx@linutronix.de
Patchwork: https://patchwork.linux-mips.org/patch/2835/
To: Sergei Shtylyov <sshtylyov@mvista.com>
Patchwork: https://patchwork.linux-mips.org/patch/2391/
Memory maps and addressing quirks are normally defined in <spaces.h>.
There are already three targets that need to override FIXADDR_TOP, and
others exist. This will be a cleaner approach than adding lots of
ifdefs in fixmap.h .
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Patchwork: https://patchwork.linux-mips.org/patch/1573/
Acked-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Now each architecture has the own dma_get_cache_alignment implementation.
dma_get_cache_alignment returns the minimum DMA alignment. Architectures
define it as ARCH_KMALLOC_MINALIGN (it's used to make sure that malloc'ed
buffer is DMA-safe; the buffer doesn't share a cache with the others). So
we can unify dma_get_cache_alignment implementations.
This patch:
dma_get_cache_alignment() needs to know if an architecture defines
ARCH_KMALLOC_MINALIGN or not (needs to know if architecture has DMA
alignment restriction). However, slab.h define ARCH_KMALLOC_MINALIGN if
architectures doesn't define it.
Let's rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGN.
ARCH_KMALLOC_MINALIGN is used only in the internals of slab/slob/slub
(except for crypto).
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: <linux-arch@vger.kernel.org>
We add a dev parameter to plat_unmap_dma_mem(), and hooks for
plat_dma_supported() and plat_extra_sync_for_device() which should be
nop changes for all existing targets.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
There is now a generic solution [ide_generic_check_pci_legacy_iobases()]
so MIPS-specific ide_probe_legacy() is no longer necessary.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
