path: root/arch/mips/gt64120
2010-08-05MIPS: WRPPMC: Move code one directory level up.Ralf Baechle
It was the last platform under gt64120 and will fit better into the new platform makefile scheme, if moved. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03Update Yoichi Yuasa's e-mail addressYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] remove wrppmc_machine_power_off()Yoichi Yuasa
It can be replace wrppmc_machine_halt(). Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] replace inline assembler to cpu_wait()Yoichi Yuasa
2008-01-29[MIPS] remove unused mips_machtypeYoichi Yuasa
Removed unused mips_machtype. These are only set but not used. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] time: Remove wrppmc's definition of plat_timer_setup.Ralf Baechle
The only thing it used to do is now done by cevt-r4k.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] WRPPMC serial support move to platform deviceYoichi Yuasa
2007-10-11[MIPS] cleanup WRPPMC include filesYoichi Yuasa
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] Use -Werror on subdirectories which build cleanly.Ralf Baechle
2007-07-31[MIPS] Delete unused arch/mips/gt64120/common/Ralf Baechle
2007-07-31[MIPS] Remove Momentum Ocelot support.Ralf Baechle
2007-07-18serial: add early_serial_setup() back to header fileYinghai Lu
early_serial_setup was removed from serial.h, but forgot to put in serial_8250.h Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[MIPS] WRPPMC: Fix build.Ralf Baechle
Using another systems defines is a safe way to get your code broken by accident when that system is removed. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] Put an end to <asm/serial.h>'s long and annyoing existenceRalf Baechle
2007-07-10[MIPS] EV64120: Remove supportYoichi Yuasa
2007-04-27[MIPS] merge GT64111 PCI routines and GT64120 PCI_0 routinesYoichi Yuasa
This patch has merged GT64111 PCI routines and GT64120 PCI_0 routines. GT64111 PCI is almost the same as GT64120's PCI_0. This patch don't change GT64120 PCI routines. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-29[MIPS] Ocelot: Fix warning.Ralf Baechle
Remove unused variable. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-29[MIPS] Ocelot: Give PMON_v1_setup a proper prototype.Ralf Baechle
2007-03-19[MIPS] Misc fixes for plat_irq_dispatch functionsThiemo Seufer
o adds missing ST0_IM masks, which caused the logging of valid interrupts as spurious o stops pnx8550 to log every interrupt as spurious o adds cause register masks for ip22/ip32, which caused handling of masked interrupts o removes some superfluous parentheses in the SNI interrupt code Signed-Off-By: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] Fix and cleanup the mess that a dozen prom_printf variants are.Ralf Baechle
early_printk is a so much saner thing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-26[MIPS] Kill redundant EXTRA_AFLAGSAtsushi Nemoto
Many Makefiles in arch/mips have EXTRA_AFLAGS := $(CFLAGS) line. This is redundant while AFLAGS contains $(cflags-y) and any options only listed in CFLAGS (not in cflags-y) should be unnecessary for asm sources. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] Remove superfluous "ifdef CONFIG_KGDB".Robert P. J. Day
Given that the Makefiles involved already have conditional compilation of the form: obj-$(CONFIG_KGDB) += dbg_io.o there seems to be little value for the dbg_io.c source files to check that config variable yet again. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] use name instead of typename for each irq_chipAtsushi Nemoto
The "typename" field was obsoleted by the "name" field. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] prom_free_prom_memory cleanupAtsushi Nemoto
Current prom_free_prom_memory() implementations are almost same as free_init_pages(), or no-op. Make free_init_pages() extern (again) and make prom_free_prom_memory() use it. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] Define MIPS_CPU_IRQ_BASE in generic headerAtsushi Nemoto
The irq_base for {mips,rm7k,rm9k}_cpu_irq_init() are constant on all platforms and are same value on most platforms (0 or 16, depends on CONFIG_I8259). Define them in asm-mips/mach-generic/irq.h and make them customizable. This will save a few cycle on each CPU interrupt. A good side effect is removing some dependencies to MALTA in generic SMTC code. Although MIPS_CPU_IRQ_BASE is customizable, this patch changes irq mappings on DDB5477, EMMA2RH and MIPS_SIM, since really customizing them might cause some header dependency problem and there seems no good reason to customize it. So currently only VR41XX is using custom MIPS_CPU_IRQ_BASE value, which is 0 regardless of CONFIG_I8259. Testing this patch on those platforms is greatly appreciated. Thank you. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] IRQ cleanupsAtsushi Nemoto
This is a big irq cleanup patch. * Use set_irq_chip() to register irq_chip. * Initialize .mask, .unmask, .mask_ack field. Functions for these method are already exist in most case. * Do not initialize .startup, .shutdown, .enable, .disable fields if default routines provided by irq_chip_set_defaults() were suitable. * Remove redundant irq_desc initializations. * Remove unnecessary local_irq_save/local_irq_restore, spin_lock. With this cleanup, it would be easy to switch to slightly lightwait irq flow handlers (handle_level_irq(), etc.) instead of __do_IRQ(). Though whole this patch is quite large, changes in each irq_chip are not quite simple. Please review and test on your platform. Thanks. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-06[MIPS] Fix EV64120 and Ocelot builds by providing a plat_timer_setup().Ralf Baechle
2006-11-06[MIPS] EV64120: Fix timer initialization for HZ != 100.Ralf Baechle
2006-10-09[MIPS] Cleanup unnecessary <asm/ptrace.h> inclusions.Ralf Baechle
2006-10-09[MIPS] Fix return type of gt64120_irq.Ralf Baechle
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-09-29[PATCH] simplify update_times (avoid jiffies/jiffies_64 aliasing problem)Atsushi Nemoto
Pass ticks to do_timer() and update_times(), and adjust x86_64 and s390 timer interrupt handler with this change. Currently update_times() calculates ticks by "jiffies - wall_jiffies", but callers of do_timer() should know how many ticks to update. Passing ticks get rid of this redundant calculation. Also there are another redundancy pointed out by Martin Schwidefsky. This cleanup make a barrier added by 5aee405c662ca644980c184774277fc6d0769a84 needless. So this patch removes it. As a bonus, this cleanup make wall_jiffies can be removed easily, since now wall_jiffies is always synced with jiffies. (This patch does not really remove wall_jiffies. It would be another cleanup patch) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-07-13[MIPS] Eleminate interrupt migration helper use.Ralf Baechle
> #define hw_interrupt_type irq_chip > typedef struct irq_chip hw_irq_controller; > #define no_irq_type no_irq_chip > typedef struct irq_desc irq_desc_t; Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Don't include obsolete <linux/config.h>.Ralf Baechle
2006-07-02[PATCH] irq-flags: MIPS: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (33 commits) [MIPS] Add missing backslashes to macro definitions. [MIPS] Death list of board support to be removed after 2.6.18. [MIPS] Remove BSD and Sys V compat data types. [MIPS] ioc3.h: Uses u8, so include <linux/types.h>. [MIPS] 74K: Assume it will also have an AR bit in config7 [MIPS] Treat CPUs with AR bit as physically indexed. [MIPS] Oprofile: Support VSMP on 34K. [MIPS] MIPS32/MIPS64 S-cache fix and cleanup [MIPS] excite: PCI makefile needs to use += if it wants a chance to work. [MIPS] excite: plat_setup -> plat_mem_setup. [MIPS] au1xxx: export dbdma functions [MIPS] au1xxx: dbdma, no sleeping under spin_lock [MIPS] au1xxx: fix PSC_SMBTXRX_RSR. [MIPS] Early printk for IP27. [MIPS] Fix handling of 0 length I & D caches. [MIPS] Typo fixes. [MIPS] MIPS32/MIPS64 secondary cache management [MIPS] Fix FIXADDR_TOP for TX39/TX49. [MIPS] Remove first timer interrupt setup in wrppmc_timer_setup() [MIPS] Fix configuration of R2 CPU features and multithreading. ...
2006-06-29[MIPS] Remove BSD and Sys V compat data types.Ralf Baechle
2006-06-29[MIPS] Remove first timer interrupt setup in wrppmc_timer_setup()Yoichi Yuasa
The first timer interrupt setup already happens in time_init(). Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29[MIPS] Remove set_c0_status(ST0_IM) from wrppmc's irq.c.Yoichi Yuasa
mips_cpu_irq_init() does clear_c0_status(ST0_IM) first, so set_c0_status(ST0_IM) isn't necessary. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29[MIPS] Removes unused functions for GT64120Yoichi Yuasa
2006-06-29[MIPS] Fix the build error of Wind River PPMC board, rewrite irq code to CMark.Zhan
o Fix the build error Wind River PPMC board caused by the change of plat_setup hook interface. o Rewrite first level interrupt dispatch code to C. Signed-off-by: Rongkai.Zhan <rongkai.zhan@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19[MIPS] Cleanup memory managment initialization.Ralf Baechle
Historically plat_mem_setup did the entire platform initialization. This was rather impractical because it meant plat_mem_setup had to get away without any kind of memory allocator. To keep old code from breaking plat_setup was just renamed to plat_setup and a second platform initialization hook for anything else was introduced. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Wind River 4KC PPMC Eval Board SupportMark.Zhan
Support for the GT-64120-based Wind River 4KC PPMC Evaluation board. Signed-off-by: Rongkai.Zhan <Rongkai.zhan@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-05[SERIAL] typo: buad -> baudHorst Schirmeier
Replacing mistyped "buad" with "baud" where applicable. Signed-off-by: Horst Schirmeier <horst@schirmeier.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-19[MIPS] Rewrite all the assembler interrupt handlers to C.Ralf Baechle
Saves like 1,600 lines of code, is way easier to debug, compilers frequently do a better job than the cut and paste type of handlers many boards had. And finally having all the stuff done in a single place also means alot of bug potencial for the MT ASE is gone. The only surviving handler in assembler is the DECstation one; I hope Maciej will rewrite it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
