path: root/arch/mips/dec
2014-06-09Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: - three fixes for 3.15 that didn't make it in time - limited Octeon 3 support. - paravirtualization support - improvment to platform support for Netlogix SOCs. - add support for powering down the Malta eval board in software - add many instructions to the in-kernel microassembler. - add support for the BPF JIT. - minor cleanups of the BCM47xx code. - large cleanup of math emu code resulting in significant code size reduction, better readability of the code and more accurate emulation. - improvments to the MIPS CPS code. - support C3 power status for the R4k count/compare clock device. - improvments to the GIO support for older SGI workstations. - increase number of supported CPUs to 256; this can be reached on certain embedded multithreaded ccNUMA configurations. - various small cleanups, updates and fixes * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (173 commits) MIPS: IP22/IP28: Improve GIO support MIPS: Octeon: Add twsi interrupt initialization for OCTEON 3XXX, 5XXX, 63XX DEC: Document the R4k MB ASIC mini interrupt controller DEC: Add self as the maintainer MIPS: Add microMIPS MSA support. MIPS: Replace calls to obsolete strict_strto call with kstrto* equivalents. MIPS: Replace obsolete strict_strto call with kstrto MIPS: BFP: Simplify code slightly. MIPS: Call find_vma with the mmap_sem held MIPS: Fix 'write_msa_##' inline macro. MIPS: Fix MSA toolchain support detection. mips: Update the email address of Geert Uytterhoeven MIPS: Add minimal defconfig for mips_paravirt MIPS: Enable build for new system 'paravirt' MIPS: paravirt: Add pci controller for virtio MIPS: Add code for new system 'paravirt' MIPS: Add functions for hypervisor call MIPS: OCTEON: Add OCTEON3 to __get_cpu_type MIPS: Add function get_ebase_cpunum MIPS: Add minimal support for OCTEON3 to c-r4k.c ...
2014-06-06arch/mips/dec: switch DECstation systems to rtc-cmosMaciej W. Rozycki
This adds an RTC platform device for DECstation systems so that they can use the rtc-cmos driver for their RTC device. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-30MIPS: DEC: Remove the Halt button interrupt on R4k systemsMaciej W. Rozycki
On R4k DECstations the Halt button is wired to the NMI processor input rather than an ordinary interrupt input such as on R3k DECstations. This is possible with a different design of the CPU daughtercard that routes the Halt button line from the baseboard connector. Additionally the interrupt input has been reused for a different purpose on the KN04 and KN05 R4k CPU daughtercards so it is better kept masked. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6705/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-13MIPS: DEC/SNI: O32 wrapper stack switching fixesMaciej W. Rozycki
Commit 231a35d37293ab88d325a9cb94e5474c156282c0 [[MIPS] RM: Collected changes] broke DECstation support by introducing an incompatible copy of arch/mips/dec/prom/call_o32.S in arch/mips/fw/lib/, built unconditionally. The copy happens to land earlier of the two among the modules used in the link and is therefore chosen for the DECstation rather than the intended original. As a result random kernel data is corrupted because a pointer to the "%s" formatted output template is used as a temporary stack pointer rather than being passed down to prom_printf. This also explains why prom_printf still works, up to a point -- the next argument is the actual string to output so it works just fine as the output template until enough kernel data has been corrupted to cause a crash. This change adjusts the modified wrapper in arch/mips/fw/lib/call_o32.S to let callers request no stack switching by passing a null temporary stack pointer in $a1, reworks the DECstation callers to work with the updated interface and removes the old copy from arch/mips/dec/prom/call_o32.S. A few minor readability adjustments are included as well, most importantly O32_SZREG is now used throughout where applicable rather than hardcoded multiplies of 4 and $fp is used to access the argument save area as a more usual register to operate the stack with rather than $s0. Finally an update is made to the temporary stack space used by the SNI platform to guarantee 8-byte alignment as per o32 requirements. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6668/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-13MIPS: DEC: Bus error handler <asm/cpu-type.h> fixesMaciej W. Rozycki
Commit 69f24d1784b631b81a54eb57c49bf46536dd2382 [MIPS: Optimize current_cpu_type() for better code.] missed an update for two DECstation bus error support files that now do not build, this is a fix. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6667/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-10-29DEC: Whitespace cleanupMaciej W. Rozycki
Commit 7034228792cc561e79ff8600f02884bd4c80e287 [MIPS: Whitespace cleanup.] did a lot of good and a little damage. Revert the damage. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5875/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-10-29MIPS: DECstation I/O ASIC DMA interrupt classesMaciej W. Rozycki
This change complements commits d0da7c002f7b2a93582187a9e3f73891a01d8ee4 [MIPS: DEC: Convert to new irq_chip functions] and 5359b938c088423a28c41499f183cd10824c1816 [MIPS: DECstation I/O ASIC DMA interrupt handling fix] and implements automatic handling of the two classes of DMA interrupts the I/O ASIC implements, informational and errors. Informational DMA interrupts do not stop the transfer and use the `handle_edge_irq' handler that clears the request right away so that another request may be recorded while the previous is being handled. DMA error interrupts stop the transfer and require a corrective action before DMA can be reenabled. Therefore they use the `handle_fasteoi_irq' handler that only clears the request on the way out. Because MIPS processor interrupt inputs, one of which the I/O ASIC's interrupt controller is cascaded to, are level-triggered it is recommended that error DMA interrupt action handlers are registered with the IRQF_ONESHOT flag set so that they are run with the interrupt line masked. This change removes the export of clear_ioasic_dma_irq that now does not have to be called by device drivers to clear interrupts explicitly anymore. Originally these interrupts were cleared in the .end handler of the `irq_chip' structure, before it was removed. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5874/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-09-17MIPS: Optimize current_cpu_type() for better code.Ralf Baechle
o Move current_cpu_type() to a separate header file o #ifdefing on supported CPU types lets modern GCC know that certain code in callers may be discarded ideally turning current_cpu_type() into a function returning a constant. o Use current_cpu_type() rather than direct access to struct cpuinfo_mips. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5833/
2013-09-13MIPS: DECstation I/O ASIC DMA interrupt handling fixMaciej W. Rozycki
This change complements commit d0da7c002f7b2a93582187a9e3f73891a01d8ee4 and brings clear_ioasic_irq back, renaming it to clear_ioasic_dma_irq at the same time, to make I/O ASIC DMA interrupts functional. Unlike ordinary I/O ASIC interrupts DMA interrupts need to be deasserted by software by writing 0 to the respective bit in I/O ASIC's System Interrupt Register (SIR), similarly to how CP0.Cause.IP0 and CP0.Cause.IP1 bits are handled in the CPU (the difference is SIR DMA interrupt bits are R/W0C so there's no need for an RMW cycle). Otherwise the handler is reentered over and over again. The only current user is the DEC LANCE Ethernet driver and its extremely uncommon DMA memory error handler that does not care when exactly the interrupt is cleared. Anticipating the use of DMA interrupts by the Zilog SCC driver this change however exports clear_ioasic_dma_irq for device drivers to choose the right application-specific sequence to clear the request explicitly rather than calling it implicitly in the .irq_eoi handler of `struct irq_chip'. Previously these interrupts were cleared in the .end handler of the said structure, before it was removed. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5826/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-09-13MIPS: DECstation HRT initialization rearrangementMaciej W. Rozycki
Not all I/O ASIC versions have the free-running counter implemented, an early revision used in the 5000/1xx models aka 3MIN and 4MIN did not have it. Therefore we cannot unconditionally use it as a clock source. Fortunately if not implemented its register slot has a fixed value so it is enough if we check for the value at the end of the calibration period being the same as at the beginning. This also means we need to look for another high-precision clock source on the systems affected. The 5000/1xx can have an R4000SC processor installed where the CP0 Count register can be used as a clock source. Unfortunately all the R4k DECstations suffer from the missed timer interrupt on CP0 Count reads erratum, so we cannot use the CP0 timer as a clock source and a clock event both at a time. However we never need an R4k clock event device because all DECstations have a DS1287A RTC chip whose periodic interrupt can be used as a clock source. This gives us the following four configuration possibilities for I/O ASIC DECstations: 1. No I/O ASIC counter and no CP0 timer, e.g. R3k 5000/1xx (3MIN). 2. No I/O ASIC counter but the CP0 timer, i.e. R4k 5000/150 (4MIN). 3. The I/O ASIC counter but no CP0 timer, e.g. R3k 5000/240 (3MAX+). 4. The I/O ASIC counter and the CP0 timer, e.g. R4k 5000/260 (4MAX+). For #1 and #2 this change stops the I/O ASIC free-running counter from being installed as a clock source of a 0Hz frequency. For #2 it also arranges for the CP0 timer to be used as a clock source rather than a clock event device, because having an accurate wall clock is more important than a high-precision interval timer. For #3 there is no change. For #4 the change makes the I/O ASIC free-running counter installed as a clock source so that the CP0 timer can be used as a clock event device. Unfortunately the use of the CP0 timer as a clock event device relies on a succesful completion of c0_compare_interrupt. That never happens, because while waiting for a CP0 Compare interrupt to happen the function spins in a loop reading the CP0 Count register. This makes the CP0 Count erratum trigger reliably causing the interrupt waited for to be lost in all cases. As a result #4 resorts to using the CP0 timer as a clock source as well, just as #2. However we want to keep this separate arrangement in case (hope) c0_compare_interrupt is eventually rewritten such that it avoids the erratum. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5825/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-09-05MIPS: DECstation HRT calibration bug fixesMaciej W. Rozycki
This change corrects DECstation HRT calibration, by removing the following bugs: 1. Calibration period selection -- HZ / 10 has been chosen, however on DECstation computers, HZ never divides by 10, as the choice for HZ is among 128, 256 and 1024. The choice therefore results in a systematic calibration error, e.g. 6.25% for the usual choice of 128 for HZ: 128 / 10 * 10 = 120 (128 - 120) / 128 -> 6.25% The change therefore makes calibration use HZ / 8 that is always accurate for the HZ values available, getting rid of the systematic error. 2. Calibration starting point synchronisation -- the duration of a number of intervals between DS1287A periodic interrupt assertions is measured, however code does not ensure at the beginning that the interrupt has not been previously asserted. This results in a variable error of e.g. up to another 6.25% for the period of HZ / 8 (8.(3)% with the original HZ / 10 period) and the usual choice of 128 for HZ: 1 / 16 -> 6.25% 1 / 12 -> 8.(3)% The change therefore adds an initial call to ds1287_timer_state that clears any previous periodic interrupt pending. The same issue applies to both I/O ASIC counter and R4k CP0 timer calibration on DECstation systems as similar code is used in both cases and both pieces of code are covered by this fix. On an R3400 test system used this fix results in a change of the I/O ASIC clock frequency reported from values like: I/O ASIC clock frequency 23185830Hz to: I/O ASIC clock frequency 24999288Hz removing the miscalculation by 6.25% from the systematic error and (for the individual sample provided) a further 1.00% from the variable error, accordingly. The nominal I/O ASIC clock frequency is 25MHz on this system. Here's another result, with the fix applied, from a system that has both HRTs available (using an R4400 at 60MHz nominal): MIPS counter frequency 59999328Hz I/O ASIC clock frequency 24999432Hz Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5807/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-06-18MIPS: DEC: remove unbuildable promcon.cPaul Bolle
promcon.o is built if CONFIG_PROM_CONSOLE is set. But there's no Kconfig symbol PROM_CONSOLE, so promcon.c is unbuildable. Remove it. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/5344/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-07-23MIPS: DEC: use IS_ENABLED()Florian Fainelli
Signed-off-by: Florian Fainelli <florian@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3333/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-03-28Disintegrate asm/system.h for MIPSDavid Howells
Disintegrate asm/system.h for MIPS. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org
2011-12-07MIPS: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. [ralf@linux-mips.org: Fixed up conflicts in arch/mips/alchemy/common/dbdma.c, arch/mips/cavium-octeon/smp.c and arch/mips/kernel/perf_event.c.] Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> To: linux-kernel@vger.kernel.org Cc: tglx@linutronix.de linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2835/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-09-21MIPS: Mark cascade and low level interrupts IRQF_NO_THREADWu Zhangjin
Mark interrupts with no_action handler, cascade interrupts, low level interrupts (bus error, halt ..) with IRQF_NO_THREAD to exclude them from forced threading. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org Cc: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-29MIPS: Convert the irq functions to the new namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25MIPS: DEC: Convert to new irq_chip functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2178/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-13set_rtc_mmss: show warning message only onceStephen Hemminger
Occasionally the system gets into a state where the CMOS clock has gotten slightly ahead of current time and the periodic update of RTC fails. The message is a nuisance and repeats spamming the log. See: http://www.ntp.org/ntpfaq/NTP-s-trbl-spec.htm#Q-LINUX-SET-RTC-MMSS Rather than just removing the message, make it show only once and reduce severity since it indicates a normal and non urgent condition. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflagsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflags: Fix IRQ flag handling naming MIPS: Add missing #inclusions of <linux/irq.h> smc91x: Add missing #inclusion of <linux/irq.h> Drop a couple of unnecessary asm/system.h inclusions SH: Add missing consts to sys_execve() declaration Blackfin: Rename IRQ flags handling functions Blackfin: Add missing dep to asm/irqflags.h Blackfin: Rename DES PC2() symbol to avoid collision Blackfin: Split the BF532 BFIN_*_FIO_FLAG() functions to their own header Blackfin: Split PLL code from mach-specific cdef headers
2010-10-19MIPS: Repair Kbuild make clean breakage.David Daney
When running make clean, Kbuild doesn't process the .config file, so nothing generates a platform-y variable. We can get it to descend into the platform directories by setting $(obj-). The dec Platform file was unconditionally setting platform-, obliterating its previous contents and preventing some directories from being cleaned. This is change to an append operation '+=' to allow cavium-octeon to be cleaned. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: Sam Ravnborg <sam@ravnborg.org> Patchwork: https://patchwork.linux-mips.org/patch/1718/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-07MIPS: Add missing #inclusions of <linux/irq.h>David Howells
Add missing #inclusions of <linux/irq.h> to a whole bunch of files that should really include it. Note that this can replace #inclusions of <asm/irq.h>. This is required for the patch to sort out irqflags handling function naming to compile on MIPS. The problem is that these files require access to things like setup_irq() - which isn't available by #including <linux/interrupt.h> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: DECstation: Migrate to new platform makefile style.Ralf Baechle
2010-08-05MIPS: DECstation: Checkpatch cleanupAndrea Gelmini
arch/mips/dec/promcon.c:37: ERROR: that open brace { should be on the previous line Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1270/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: DEC: Convert KN01 lock to raw spinlock.Ralf Baechle
2010-02-27MIPS: Make various locks static.Ralf Baechle
2010-02-27MIPS: Nuke trailing blank linesRalf Baechle
Recent git versions now warn about those and they've always been a bit of an annoyance. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-18Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (34 commits) time: Prevent 32 bit overflow with set_normalized_timespec() clocksource: Delay clocksource down rating to late boot clocksource: clocksource_select must be called with mutex locked clocksource: Resolve cpu hotplug dead lock with TSC unstable, fix crash timers: Drop a function prototype clocksource: Resolve cpu hotplug dead lock with TSC unstable timer.c: Fix S/390 comments timekeeping: Fix invalid getboottime() value timekeeping: Fix up read_persistent_clock() breakage on sh timekeeping: Increase granularity of read_persistent_clock(), build fix time: Introduce CLOCK_REALTIME_COARSE x86: Do not unregister PIT clocksource on PIT oneshot setup/shutdown clocksource: Avoid clocksource watchdog circular locking dependency clocksource: Protect the watchdog rating changes with clocksource_mutex clocksource: Call clocksource_change_rating() outside of watchdog_lock timekeeping: Introduce read_boot_clock timekeeping: Increase granularity of read_persistent_clock() timekeeping: Update clocksource with stop_machine timekeeping: Add timekeeper read_clock helper functions timekeeping: Move NTP adjusted clock multiplier to struct timekeeper ... Fix trivial conflict due to MIPS lemote -> loongson renaming.
2009-09-17MIPS: Remove useless zero initializations.Ralf Baechle
2009-08-15timekeeping: Increase granularity of read_persistent_clock()Martin Schwidefsky
The persistent clock of some architectures (e.g. s390) have a better granularity than seconds. To reduce the delta between the host clock and the guest clock in a virtualized system change the read_persistent_clock function to return a struct timespec. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134811.013873340@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-03MIPS: Eleminate filenames from commentsRalf Baechle
They tend to get not updated when files are moved around or copied and lack any obvious use. While at it zap some only too obvious comments and as per Shinya's suggestion, add a copyright header to extable.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Acked-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
2008-10-20mips: use bcd2bin/bin2bcdAdrian Bunk
Changes mips to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28[MIPS] DS1287: Add clockevent driverYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] add DECstation I/O ASIC clocksourceYoichi Yuasa
Add DECstation I/O ASIC clocksource Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] time: remove unused mips_timer_state()Yoichi Yuasa
2007-10-11[MIPS] Allow hardwiring of the CPU type to a single type for optimization.Ralf Baechle
This saves a few k on systems which only ever ship with a single CPU type. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] dec/time.c: Remove no longer needed inclusion of <asm/div64.h>.Maciej W. Rozycki
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-09-19[MIPS] DEC: Initialise ioasic_ssr_lockMaciej W. Rozycki
Fix the definition of the ioasic_ssr_lock spinlock to include a proper initialisation. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] Use -Werror on subdirectories which build cleanly.Ralf Baechle
2007-07-10[MIPS] DECstation: Optimised early printk()Maciej W. Rozycki
This is an optimised implementation of early printk() for the DECstation. After the recent conversion to a MIPS-specific generic routine using a character-by-character output the performance dropped significantly. This change reverts to the previous speed -- even at 9600 bps of the serial console the difference is visible with a naked eye; I presume for a framebuffer it is even worse (it may depend on exactly which one is used though). Additionally the change includes a fix for a problem that the old implementation had -- the format used would not actually limit the length of the string output. This new implementation uses a local buffer to deal with it -- even with this additional copying it is much faster than the generic function. Plus this driver is registered much earlier than the generic one, allowing one to see critical messages, such as one about an incorrect CPU setting used, that are produced beforehand. :-) Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] Transform old-style macros to newer "__noreturn"Robert P. J. Day
Convert old/obsolete NORET_TYPE and ATTRIB_NORET macros to use the newer standard of "__noreturn" as defined in compiler-gcc.h. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-09[MIPS] DEC: Remove call to register_prom_console.Ralf Baechle
Register_prom_console was removed when mips was converted to early printk. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] Fix and cleanup the mess that a dozen prom_printf variants are.Ralf Baechle
early_printk is a so much saner thing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] DEC: Remove redeclarations of mips_machgroup and mips_machtype.Ralf Baechle
2007-02-26[MIPS] Kill redundant EXTRA_AFLAGSAtsushi Nemoto
Many Makefiles in arch/mips have EXTRA_AFLAGS := $(CFLAGS) line. This is redundant while AFLAGS contains $(cflags-y) and any options only listed in CFLAGS (not in cflags-y) should be unnecessary for asm sources. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-13[MIPS] DECstation: Fix irq handlingAtsushi Nemoto
When I post a patch (commit f431baa55abf8adeed0c718b51deacbc151f58f1), I just tried to not change behavior of existing codes, but it seems dec/int-handler.S had been broken since its previous commit 937a801576f954bd030d7c4a5a94571710d87c0b. The caller of plat_irq_dispatch do setup/restore TI_REGS($28), so dec's plat_irq_dispatch should not do it, and there is no need to adjust RA. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-09[TC] TURBOchannel support for the DECstationMaciej W. Rozycki
This is the platform-specific part of TURBOchannel bus support for the DECstation. It implements determining whether the bus is actually there, getting bus parameters, IRQ assignments for devices and protected accesses to possibly unoccupied slots that may trigger bus error exceptions. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
