path: root/arch/mips/ddb5xxx
2006-02-07[MIPS] Rename _machine_power_off to pm_power_off so the kernel builds again.Ralf Baechle
2005-11-17[MIPS] DDB5477: Fix unused variable warning.Ralf Baechle
2005-11-07Use rtc_lock to protect RTC operationsAtsushi Nemoto
Many RTC routines were not protected against each other, so there are potential races, for example, ntp-update against /dev/rtc. This patch fixes them using rtc_lock. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Sliceup Kconfig; it's grown too large.Ralf Baechle
2005-10-29Convert struct hw_interrupt_type initializations to ISO C99 namedRalf Baechle
initializers. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Get rid of early_init. There's more need to make this form ofRalf Baechle
initialization actually useful and as is certainly unmergable with upstream. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
